High Power Current Sensing Resistors RLP Series
( Halogen-Free )
AEC-Q 200-Ver D qualified
Document No
TRLP-250S008F
Issued date
2016/10/11
page
1/6
1. Scope:
This specification applied to the products of current sensing resistor of metal foil for Lead-Free RLP series
manufactured by TA-I TECHNOLOGY CO.,LTD.
2. Type Designation:
RLP
Item
25
Series
No.
F
Resistance
tolerance
E
Packaging
25:2512
F:±1%
E: Embossed Tape
(6432)
C
Power
rating
R010
Resistance
C=1W
e.g :
G:±2%
D=1.5W
R010=10mΩ
J:±5%
E=2W
R100=100mΩ
G=3W
R500=500mΩ
3. Construction and Dimension :
3.1 Construction:
Over-Coat
Ni / Sn
Plating
Metal Alloy Plate
3.2 Dimension:
Unit : mm
Style
L
W
C
T
Material
2.0±0.2(≦4mΩ)
RLP25
6.4±0.2
3.2±0.2
Strip: Alloy
0.7 ±0.20 Over Coating:Polymer
0.9±0.2(R>4mΩ)
Compound UL-94V-0 grade
TA-I TECHNOLOGY CO., LTD
Document No
TRLP-250S008F
Issued date
2016/10/11
page
2/6
( Halogen-Free )
4. Features:
Type
RLP25
Power Rating
Resistance Value
Operation Temperature Range
Temperature Coefficient of Resistance
Tolerance
Insulation Resistance
Maximum Working Current (A)
1 mΩ<R≦100mΩ(1W、1.5 W、2 W、3W)
100 mΩ<R≦500mΩ(1W、1.5 W、2 W)
1mΩ<R≦500mΩ
-55℃~+170℃
±50ppm/℃
±1%,±2%,±5%
100 Meg Ohms Minimum
(P/R)1/2
Note:2&3watts total Solder pad and trace size of 300mm
5. Reliability Tests :
Test Items
of Resistance
High Temperature
Exposure(Storage)
Low temperature
operation
Temperature Cycling
Short time overload
Biased Humidity
Operation life
Resistance to Soldering Heat
Mechanical Shock
Resistance to vibration
Board Flex
Flammability
Reference
IEC60115-1 4.8
MIL-STD202 Method
108
IEC60115-1 4.23.4
JESD22
Method
JA-104
IEC60115-1 4.13
Condition of Test
Test
Limits
+25 ~ 125℃
Refer 4.0
T=125℃,1000hrs,Measurement
at 24hrs after test conclusion.
< ±1%
-55 °C for 45 min
< ±0.5%
1000Cycle (-55℃ to 125
℃),Measurement at 24hrs after test
conclusion.
< ±0.5%
5 X rated power for 5s
< ±0.5%
MIL-STD202 Method
103
MIL-STD202
Method 108
10% Rated voltage at 85
℃,RH:85% ,1000Hrs, Measurement < ±0.5%
IEC60115-1 4.18
T=260+/-5℃ solder,10+/-1 sec dwell < ±0.5%
MIL-STD202
Method 213
MIL-STD202
Method 204
AEC-Q200005
UL-94
1000 h at +70 °C, 1.5 h “ON”, 0.5 h
“OFF”
< ±1%
100g's , Normal duration is 6ms , half
< ±0.5%
sine shock pulse
5g's for 20min.12cycles, 10-2000Hz
0.004
4.0
2.1
4.1
R≦0.004
4.0
3.1
1.3
Unit: mm
( Halogen-Free )
Document No
TRLP-250S008F
Issued date
2016/10/11
page
4/6
7. Number of Package:
4000 Pieces / package
8. Label:
Date Code
Series
QTY: 4000 PCS
T019C0071H
LOT NO:
Resistance
R010 FEE
0308
RLP25FEE
Tolerance
Package
Power Rating
9. Taping
Packing
Emboss
Type
RLP25
A
3.6±0.2
B
6.9±0.2
W
12.±0.2
F
5.5±0.05
E
1.75±0.1
P1
4.0±0.1
P2
2.0±0.05
P0
D0
t
4.0±0.05
ψ1.5
(+0.1/-0)
1.2±0.15
( Halogen-Free )
Document No
TRLP-250S008F
Issued date
2016/10/11
page
5/6
10. Reel Specification
Series
ψA
ψB
ψC
W
T
13.0±1.0
15.4±2.0
+0
RLP 25
60 ±1.0
180
13.0±1.0
-3
11. Peeling Strength of Top Cover Tape
Test Condition: 0.1 to 0.7 N at a peel-off speed of 300 mm / min.
top cover tape
pull
300 mm/min
10 ~15 standard pulling force: 0.1 ~ 0.7 N
carrier tape
12. Storage Conditions:
Temperature: 5℃~35℃,Humidity:40%~75%
13. Shelf Life:
2 years from manufacturing date.
( Halogen-Free )
Document No
TRLP-250S008F
Issued date
2016/10/11
page
6/6
14. Recommend IR – Reflow profile: (solder: Sn96.5 / Ag3 / Cu0.5)
Peak : 260
5
℃ , 5 sec
Pre – heat zone : 150 to 180 ℃, 90±30 sec
Soldering zone : 230℃ or higher , 30±10 sec
Iron Solder:350±10℃ , 3+1/-0 sec
15. ECN
Engineering Change Notice: The customer will be informed with ECN if there is significant
modification on the characteristics and materials described in approval sheet.
16. Manufacturing Country & City :
TA-I TECHNOLOGY CO., LTD. ( Taiwan– Tao Yuan )
Tel: (+886) 3-3246169
Fax : (+886) 3-3246167
Associated companies :
(1)TA-I TECHNOLOGY ( SU ZHOU ) CO., LTD. ( China – Su Zhou)
Tel :(+86) 512-63457879
Fax : (+86) 512-63457869
(2) TA-I TECHNOLOGY ELECTRONIC (DONGGUAN ) CO., LTD. ( China –Dongguan )
Tel : (+86) 769-8339-4790〜3
Fax : (+86) 769-8339-4794
(3) FORTUNE TASK RESISTOR FACTORY
( China – Dongguan )
(4) TAI OHM ELECTRONICS ( M ) SDN. BHD. ( Malaysia – Penang )
Tel :(+60) 4- 3900480
Fax : (+60) 4-3901481
(5) P.T.TAI ELECTRONIC Indonesia ( Indonesia – Jakarta )
Tel :(+62) 21-44820254
Fax : (+62) 21-44820256
很抱歉,暂时无法提供与“RLP25FEER400”相匹配的价格&库存,您可以联系我们找货
