UMW
R
LMV321/LMV358/LMV324
Low-Power rail-to-rail Operational Amplifier
Description
LMV321 (single channel) is a rail-to-rail input, output voltage feedback, low power consumption operational amplifier.
It has wide input common mode voltage and output swing. The minimum working voltage can be up to 2.1V, and the
maximum working voltage is recommended to be 5.5V. Used as power amplifier in all kinds of pocket or portable stereo
radio recorders.
LMV321 has the following characteristics:Can provide 1MHz gain bandwidth product. It has an extremely low input bias
current (about 10pA TYP) and can be used for integration,photo diode amplifiers and piezoelectric sensors. The Rail to
Rail input and output buffers are also used for specific IC designs in single power systems. Applications of this series of
amplifiers include safety monitoring, portable devices, batteries and power supplies, supply control, signal processing
and interfaces in low power sensor systems.
The LMV321 single is available in Green SC70-5 and SOT23-5 packages. The LMV358 dual is available in Green SOP-8 and
TSSOP-8 packages.The LMV324 Quad is available in Green SOP- 14 and TSSOP-14 packages.
Features
Application
Rail to rail input and output, typical 0.8mv Vos
ASIC input and output amplifier
Gain bandwidth product 1MHz
Sensor interface
Low input bias current: 10pA (TYP)
Piezoelectric sensing amplifier
Low Power consumption
Low operating current: 45uA
Audio output
2.1V ~ 5.5V working voltage
Battery-powered equipment
The mobile communication
Pin Configuration
LMV321
SOT23-5/SC70-5
LMV358
LMV324
SOP-8/TSSOP-8
SOP-14/TSSOP-14
www.umw-ic.com
1
UTD Semiconductor Co.,Limited
UMW
R
Absolute Maximum Ratings (TA =25℃) Note1
Parameter
Supply Voltage
Symbol
VCC
Value
7.5
Units
V
VICR
(-VS)-0.5~(+VS)0.5
V
TJ
150
°C
Common-mode Input Voltage
Junction Temperature
Operating Temperature Range
TOPR
TL
250
°C
TSTG
-50 to 150
°C
Lead Temperature (Soldering, 10 sec)
Storage Temperature Range
°C
-25 to +85
Note1: Exceeding the above limits may damage to the chip. The reliability of the device will also be affected if the device
works under the limit conditions. Electrostatic discharge can also cause damage to chips, so it is suggested to take some
preventive measures for integrated circuits. Failure to follow proper handling and installation can also cause damage.
Precision LMV321 and other devices are more vulnerable to damage than ordinary devices in the case of tiny
electrostatic, and small parameter changes may make the whole circuit performance substandard.
Electrical Characteristics
At RL = 100kΩ connected to Vs/2,and VOUT = Vs/2,Ta=25℃) , unless otherwise noted.
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Units
Input Offset Voltage
VOS
0.8
5
mV
Input offset current
lOS
10
pA
Input bias current
lB
10
pA
VS=5.5V
-0.1~5.6
V
Vo=0.1V to 4.9 V, RL =5 kΩ
70
80
Vo=0.035V to 4.96 V, RL =100 kΩ
80
84
VCM = -0.1V~4 V, VS=5.5V
62
70
VCM = -0.1V~5.6 V, VS=5.5V
56
68
60
80
dB
2.7
μ
. V/℃
RL= 100 kΩ
8
mV
RL=10 kΩ
80
mV
Common-mode input voltage
range
VCM
Open-loop Gain
AOL
Common Mode Rejection
CMRR
Power Supply Rejection
PSRR VCM = (-VS)+0.5 V, VS=2.5V~5.5V
Input offset voltage drift
∆VOS/∆T
dB
dB
Input voltage swing
VI
Operating voltage range
VW
2.1
5.5
mV
Output Current
IO
mA
Quiescent Current
IQ
IOUT=0
45
60
μA
Slew Rate
SR
G = +1 , 2V Output Step
0.52
V/μs
Gain Bandwidth Product
GBP CL = 100pF
1
MHz
Equivalent Input Noise Voltage
eN
f=1KHz
27
f=10KHz
www.umw-ic.com
2
nV/ Hz
UMW
R
Typical Characteristic Curves
www.umw-ic.com
3
UMW
R
Typical applications
1.differential amplifier
As shown in the figure, if the resistance is equal, (R4 / R3 = R2 / R1), then the output VOUT =
(Vp - Vn) × R2 / R1 + VREF
www.umw-ic.com
4
UMW
R
2.instrumentation amplifier
The circuit in the figure above performs the same function, but the input is high impedance.
3.Low pass active filtering
The low-pass filter circuit shown here has a (-R2 / R1) DC gain and -3db at a frequency of 1/2 PI
R2C corner. Make sure the filter is within the amplifier's bandwidth. Large feedback resistors are
easily accompanied by parasitic capacitance at high speed, resulting in adverse effects such as
oscillation. Keep the resistance value as low as possible and consider the appropriate output load.
www.umw-ic.com
5
UMW
R
SC70-5
Dimensions
Dimensions
In Millimeters
In Inches
Min
Max
Min
Max
A
0.900
1.100
0.035
0.043
A1
0.000
0.100
0.000
0.004
A2
0.900
1.000
0.035
0.039
b
0.150
0.350
0.006
0.014
C
0.080
0.150
0.003
0.006
D
2.000
2.200
0.079
0.087
E
1.150
1.350
0.045
0.053
E1
2.150
2.450
0.085
0.096
e
0.650TYP
0.026TYP
e1
1.200
0.047
L
0.525REF
0.021REF
L1
0.260
0.460
0.010
0.018
θ
0°
8°
0°
8°
Symbol
1.400
0.055
SOT23-5
Dimensions
Dimensions
In Millimeters
In Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.400
0.012
0.016
C
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950TYP
0.037TYP
e1
1.800
0.071
L
0.700REF
0.028REF
L1
0.300
0.460
0.012
0.024
θ
0°
8°
0°
8°
Symbol
www.umw-ic.com
6
2.000
0.079
UMW
R
SOP-8
A2
C
θ
L1
A1
e
E
D
Symbol
E1
b
www.umw-ic.com
Dimensions In
In Millimeters
Inches
Min
Max
Min
Max
A1
0.100
0.250
0.004
0.010
A2
1.350
1.550
0.053
0.061
b
0.330
0.510
0.013
0.020
C
0.190
0.250
0.007
0.010
D
4.780
5.000
0.188
0.197
E
3.800
4.000
0.150
0.157
E1
5.800
6.300
0.228
0.248
e
7
Dimensions
1.270 TYP
0.050 TYP
L1
0.400
1.270
0.016
0.050
θ
0°
8°
0°
8°
UMW
R
TSSOP-8
Dimensions
Dimensions In
In Millimeters
Inches
Min
Max
Min
Max
A
0.800
1.200
0.031
0.047
A1
0.000
0.200
0.000
0.008
A2
0.760
0.970
0.030
0.038
b
0.30 TYP
0.012 TYP
C
0.15 TYP
0.006 TYP
D
2.900
e
0.65 TYP
E
2.900
3.100
0.114
0.122
E1
4.700
5.100
0.185
0.201
L1
0.410
0.650
0.016
0.026
θ
0°
6°
0°
6°
Symbol
E
E1
A
A2
e
b
D
3.100
0.114
0.122
0.026
A1
R1
R
θ
L1
www.umw-ic.com
L
L2
8
UMW
R
TSSOP-14
Dimensions
E1
E
A
A2
e
Symbol
c
D
In Millimeters
MIN
TYP
MAX
A
1.20
A1
0.05
0.15
A2
0.90
1.00
1.05
b
0.20
0.28
c
0.10
0.19
D
4.86
4.96
5.06
E
6.20
6.40
6.60
E1
4.30
4.40
4.50
e
L
A1
R1
R
0.65 BSC
0.45
0.60
L1
1.00 REF
L2
0.25 BSC
0.75
R
0.09
θ
0°
8°
θ
L1
www.umw-ic.com
L
L2
9
UMW
R
SOP-14
D
E1
Dimensions
E
In Millimeters
Symbol
e
b
A A2
A1
MIN
TYP
MAX
A
1.35
1.60
1.75
A1
0.10
0.15
0.25
A2
1.25
1.45
1.65
b
0.36
D
8.53
8.63
8.73
E
5.80
6.00
6.20
E1
3.80
3.90
4.00
e
1.27 BSC
L
0.45
0.60
L1
1.04 REF
L2
0.25 BSC
θ
L
L1
0.49
0°
0.80
8°
θ
L2
ORDERING INFORMATION
Order Code
Package
Baseqty
Deliverymode
UMW LMV321IDCKR
SC70-5
3000
Tape and reel
UMW LMV321IDBVR
SOT23-5
3000
Tape and reel
UMW LMV358IDR
SOP-8
2500
Tape and reel
UMW LMV358IPWR
TSSOP-8
2000
Tape and reel
UMW LMV324IDR
SOP-14
2500
Tape and reel
UMW LMV324IPWR
TSSOP-14
2000
Tape and reel
www.umw-ic.com
10
很抱歉,暂时无法提供与“LMV358IDR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.53145
- 50+0.42091
- 150+0.36565
- 500+0.32420
- 2500+0.25466
- 5000+0.23808
