DF9A-9P-1V(22)
DF9A-9P-1V(22)
    HRS(广濑)
    SMD,P=1MM
    DF9A-9P-1V(22)
DF9A-9P-1V(22) 数据手册
1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1) May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF9 Series ■Features 1. Compliant with the VESA FPDI-1 Standard Interface Connector The 31 and 41 contact connectors comply with the standard connector specification for the flat panel display interface, which U.S VESA. has selected as FPDI-1. VESA: Video Electronics Standards Association FPDI-1: Flat Panel Display Interface 2. Perfect Mis-insertion Prevention The mating area is designed in a trapezoidal structure, and perfectly prevents the mis-insertion despite the miniature size. 3. Equipped with Easy Lock Mechanism The easy lock mechanism assures the firm insertion and extraction properties as well as the insertion/extraction feeling touch. 4. Smooth Insertion and Extraction Feeling The contact is constructed without the material fragible surface in the contact portion, and provides a smooth insertion and use feeling. 5. Setting Two Type Platings as Standard Two type platings, tin plated and gold plated, are prepared, and either appropriate plating can be selected under cost and use conditions. Structure to Prevent Mis-insertion Lock Mechanism A135 DF9 Series●1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1) ■Product Specifications Rating Current rating 0.5A Operating Temperature Range -45 to +125ç (Note 1) Storage Temperature Range -10 to +60ç (Note 2) Voltage rating150V AC Operating Humidity Range 40 to 80% Item 1. Insulation Resistance Storage Humidity Range 40 to 70% specification Condition 500MΩ min. 100V DC 2. Withstanding voltage No flashover or insulation breakdown. 250V AC/1 minute 3. Contact Resistance 50mΩ max. 100mA 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Contact resistance: 50mΩ max. Insulation resistance: 500MΩ min. 96 hours at temperature of 40ç and humidity of 90% to 95% May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. Temperature Cycle Contact resistance: 50mΩ max. Insulation resistance: 500MΩ min. (-55ç: 30 minutes 5 to 35ç: 10 minutes 85ç: 30 minutes 5 to 35ç: 10 minutes) 5 cycles 7. Durability (Mating/un-mating) Contact resistance: 50mΩ max: Tin plating: 30 cycles 8. Resistance to Soldering heat No deformation of components affecting performance. Gold plating: 100 cycles Reflow: At the recommended temperature profile Manual soldering: 380ç for 3 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. ■Material / Finish Product Part Material Finish Remarks Insulator Polyamide Beige UL94V-0 Contact Phosphor copper Tin plated or gold plated ––––––– Metal fitting Brass Tin plating ––––––– Receptacle/Header Note : The gold plated product contact area is plated with gold, and lead plated with tin. ■ Product Number Structure ●Receptacle/Header DF9 q q Series Name # - * S - 1 V (**) w e t y u r Connector Type : DF9 w Type S : Receptacle Fitting Boss Blank K K A ∞ K B K ∞ C ∞ ∞ e Number of Contacts 9 to 25,31,41,51 r P : Header t Contact Pitch : 1mm y Contact Type V : Straight SMT u Contact Surface Finish/Packaging Type (22)(32) : Tin plated, embossed tape packaging (1000pcs/reel) (69) : Gold plated, embossed tape packaging (1000pcs/reel) A136 DF9 Series●1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1) ■Receptacle With metal fitting With boss [Specific No.] _ **, (**) (32) : Tin plated, embossed tape packaging (69) : Gold plated, embossed tape packaging May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit: mm Part No. HRS No. No. of Contacts A B 3 8.3 9 DF9- 9S-1V (**) 540-0054-0 ** 4 9.3 11 DF9-11S-1V (**) 540-0055-2 ** 5 10.3 13 DF9-13S-1V (**) 540-0056-5 ** 6 11.3 15 DF9-15S-1V (**) 540-0057-8 ** 7 12.3 17 DF9-17S-1V (**) 540-0058-0 ** 8 13.3 19 DF9-19S-1V (**) 540-0059-3 ** 9 14.3 21 DF9-21S-1V (**) 540-0060-2 ** 15.3 10 23 DF9-23S-1V (**) 540-0061-5 ** 16.3 11 25 DF9-25S-1V (**) 540-0062-8 ** 19.3 14 31 DF9-31S-1V (**) 540-0063-0 ** 24.3 19 41 DF9-41S-1V (**) 540-0213-1 ** 29.3 24 51 DF9-51S-1V (**) 540-0064-3 ** Note 1 : Please order the embossed tape packaging product per reel. (1000 pcs/reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. ■Receptacle Without metal fitting C D E 4 5 6 7 8 9 10 11 12 15 20 25 7.1 8.1 9.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 Spec. Spec. (32) (69) K K K K K K K K K K K _ K K K K K K K K K K K K Remarks With metal fitting With boss RoHS YES With pick and place tape With boss [Specific No.] _ **, (**) (22): Tin plated, tube packaging (69): Gold plated, embossed tape packaging Unit: mm Part No. HRS No. No. of Contacts A B 9 3 8.3 DF9A-09S-1V (**) 540-0004-1 ** 9.3 11 4 DF9A-11S-1V (**) 540-0005-4 ** 13 5 10.3 DF9A-13S-1V (**) 540-0006-7 ** 15 6 11.3 DF9A-15S-1V (**) 540-0007-0 ** 17 7 12.3 DF9A-17S-1V (**) 540-0008-2 ** 19 13.3 8 DF9A-19S-1V (**) 540-0009-5 ** 21 14.3 9 DF9A-21S-1V (**) 540-0010-4 ** 23 15.3 10 DF9A-23S-1V (**) 540-0011-7 ** 16.3 11 25 DF9A-25S-1V (**) 540-0012-0 ** 19.3 14 31 DF9A-31S-1V (**) 540-0013-2 ** 24.3 19 41 DF9A-41S-1V (**) 540-0222-2 ** 29.3 24 51 DF9A-51S-1V (**) 540-0014-5 ** Note 1 : Please order the emboss packaging product per reel. (1000 pcs/reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. C D E 4 5 6 7 8 9 10 11 12 15 20 25 7.1 8.1 9.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 _ _ _ _ _ _ _ _ _ _ _ _ Spec. Spec. (22) (69) K K K K K K K K K K K _ _ _ K K _ _ K _ K K K K Remarks Without metal fitting With boss RoHS YES With pick and place tape A137 DF9 Series●1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1) ■Receptacle With metal fitting Without boss [Specific No.] _ **, (**) (32): Tin plated, tube packaging (69): Gold plated, embossed tape packaging May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit: mm Part No. HRS No. No. of Contacts A B 08.3 03 09 DF9B-09S-1V (**) 540-0125-6 ** 09.3 04 11 DF9B-11S-1V (**) 540-0126-9 ** 10.3 05 13 DF9B-13S-1V (**) 540-0127-1 ** 11.3 06 15 DF9B-15S-1V (**) 540-0128-4 ** 12.3 07 17 DF9B-17S-1V (**) 540-0129-7 ** 13.3 08 19 DF9B-19S-1V (**) 540-0247-3 ** 14.3 09 21 DF9B-21S-1V (**) 540-0131-9 ** 15.3 10 23 DF9B-23S-1V (**) 540-0132-1 ** 16.3 11 25 DF9B-25S-1V (**) 540-0133-4 ** 19.3 14 31 DF9B-31S-1V (**) 540-0143-8 ** 24.3 19 41 DF9B-41S-1V (**) 540-0216-0 ** 29.3 24 51 DF9B-51S-1V (**) 540-0145-3 ** Note 1 : Please order the embossed tape packaging product per reel. (1000 pcs/reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. ■Header With metal fitting D E 04 05 06 07 08 09 10 11 12 15 20 25 _ _ _ _ _ _ _ _ _ _ _ _ 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 Spec. Spec. (32) (69) K K K K _ _ K K K K K _ K _ K K K K K _ _ K K K Remarks With metal fitting Without boss RoHS YES With pick and place tape With boss [Specific No.] _ **, (**) (32): Tin plated, tube packaging (69): Gold plated, embossed tape packaging Unit: mm Part No. HRS No. No. of Contacts A B 08.3 03 09 DF9-09P-1V (**) 540-0066-9 ** 09.3 04 11 DF9-11P-1V (**) 540-0067-1 ** 10.3 05 13 DF9-13P-1V (**) 540-0068-4 ** 11.3 06 15 DF9-15P-1V (**) 540-0069-7 ** 12.3 07 17 DF9-17P-1V (**) 540-0070-6 ** 13.3 08 19 DF9-19P-1V (**) 540-0071-9 ** 14.3 09 21 DF9-21P-1V (**) 540-0072-1 ** 15.3 10 23 DF9-23P-1V (**) 540-0073-4 ** 16.3 11 25 DF9-25P-1V (**) 540-0074-7 ** 19.3 14 31 DF9-31P-1V (**) 540-0075-0 ** 24.3 19 41 DF9-41P-1V (**) 540-0214-4 ** 29.3 24 51 DF9-51P-1V (**) 540-0088-1 ** Note 1 : Please order the emboss packaging product per reel. (1000 pcs/reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. A138 C C D E 04 05 06 07 08 09 10 11 12 15 20 25 07.1 08.1 09.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 Spec. Spec. (32) (69) K K K K K K K K K K K _ K K K K K K K K K K K K Remarks With metal fitting With boss With pick and place tape RoHS YES DF9 Series●1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1) ■Header Without metal fitting With boss [Specific No.] _ **, (**) (22) : Tin plated, embossed tape packaging (69) : Gold plated, embossed tape packaging May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit: mm Part No. HRS No. No. of Contacts A B 08.3 03 09 DF9A-09P-1V (**) 540-0016-0 ** 09.3 04 11 DF9A-11P-1V (**) 540-0017-3 ** 10.3 05 13 DF9A-13P-1V (**) 540-0018-6 ** 11.3 06 15 DF9A-15P-1V (**) 540-0019-9 ** 12.3 07 17 DF9A-17P-1V (**) 540-0020-8 ** 13.3 08 19 DF9A-19P-1V (**) 540-0021-0 ** 14.3 09 21 DF9A-21P-1V (**) 540-0022-3 ** 15.3 10 23 DF9A-23P-1V (**) 540-0023-6 ** 16.3 11 25 DF9A-25P-1V (**) 540-0024-9 ** 19.3 14 31 DF9A-31P-1V (**) 540-0025-1 ** 24.3 19 41 DF9A-41P-1V (**) 540-0223-5 ** 29.3 24 51 DF9A-51P-1V (**) 540-0026-4 ** Note 1 : Please order the emboss packaging product per reel. (1000 pcs/reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. ■Header With metal fitting C D E 04 05 06 07 08 09 10 11 12 15 20 25 07.1 08.1 09.1 10.1 11.1 12.1 13.1 14.1 15.1 18.1 23.1 28.1 _ _ _ _ _ _ _ _ _ _ _ _ Spec. Spec. (22) (69) K K K K K K K _ K K K _ _ _ K K K _ K _ K K _ K Remarks Without metal fitting With boss RoHS YES With pick and place tape Without boss [Specific No.] _ **, (**) (32) : Tin plated, embossed tape packaging (69) : Gold plated, embossed tape packaging Unit: mm Part No. HRS No. No. of Contacts A B 08.3 03 09 DF9B-09P-1V (**) 540-0134-7 ** 09.3 04 11 DF9B-11P-1V (**) 540-0135-0 ** 10.3 05 13 DF9B-13P-1V (**) 540-0136-2 ** 11.3 06 15 DF9B-15P-1V (**) 540-0137-5 ** 12.3 07 17 DF9B-17P-1V (**) 540-0138-8 ** 13.3 08 19 DF9B-19P-1V (**) 540-0248-6 ** 14.3 09 21 DF9B-21P-1V (**) 540-0140-0 ** 15.3 10 23 DF9B-23P-1V (**) 540-0141-2 ** 16.3 11 25 DF9B-25P-1V (**) 540-0142-5 ** 19.3 14 31 DF9B-31P-1V (**) 540-0144-0 ** 24.3 19 41 DF9B-41P-1V (**) 540-0221-0 ** 29.3 24 51 DF9B-51P-1V (**) 540-0146-6 ** Note 1 : Please order the emboss packaging product per reel. (1000 pcs/reel) Note 2 : _ are not available. Regarding blank, please contact Hirose sales representative. C D E 04 05 06 07 08 09 10 11 12 15 20 25 _ _ _ _ _ _ _ _ _ _ _ _ 10.1 11.1 12.1 13.1 14.1 15.1 16.1 17.1 18.1 21.1 26.1 31.1 Spec. Spec. (32) (69) K K K K K K K K K K K _ K K _ K K K K _ _ K K K Remarks With metal fitting Without boss RoHS YES With pick and place tape A139 DF9 Series●1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1) BRecommended PCB mounting pattern Note 1 : ●Without metal fitting, with boss ●Metal fitting, without boss If the pattern is included in the shaded area and not treated with resist, it could touch the connector contact . Note 2 : Please refer to each product size pattern for the universal size on the above patterns (A, B, C, D...). BApplication Pattern Board Board Note 1 : The board to board size 4.3mm in the pattern does not include the soldering paste thickness. 3± 0.2 BEmbossed Carrier Tape Dimensions Ø80±1 Ø330±1 Ø1 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●With metal fitting, with boss D±0.5 Unreeling direction (D+4)±1 Unit:mm Product Type DF9#-*S/P-1V Size No. of Contacts 9 to 21 23 to 31 41, 51 A 24 32 44 Note 1 : The pocket design may vary. Note 2 : The hole of the carrier tape will be only one side if A is less than 32mm. A140 B ―――――― 28.4 40.4 C 11.5 14.2 20.2 D 25.5 33.5 45.5 E 12 12 12 DF9 Series●1mm Pitch SMT Board-to-Board Connectors(Standard Interface Connector Compliant with VESA FPDI-1) BPrecautions for Use 1. Recommended Temperature Profile (SMT) Temperature (ç) 250ç 250 220ç 200 60sec max Soldering 180ç 150 150ç 90~120sec Preheating 100 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Note1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note2 : The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2. Recommended Manual Soldering Condition (SMT) Soldering iron temperature: 370±10ç, Soldering time: Within 3 seconds 3. Recommended Screen Thickness (SMT) 0.15mm 4. Board Warp(SMT) Maximum 0.03mm in the connector center area, based on both connector edges. 5. Cleaning Condition Refer to the "Nylon Connector Use Hand book". 6. Cautions ■ Avoid retaining the board with the connector only, and fix the board by any other means than the connector. ■ Where the board is not mounted, the insertion or extraction will cause damage or deformation in contacts. ■ Excessive scoop insertion or extraction may result in damage. ■ In the manual soldering process, don't carry out flux coating which will cause a flux blister on the connector. ■ The color phase of this product may be slightly different from that of the forming product according to the manufacturing lot. However, the difference doesn't affect the performance. A141
DF9A-9P-1V(22) 价格&库存
很抱歉,暂时无法提供与“DF9A-9P-1V(22)”相匹配的价格&库存,您可以联系我们找货
