Document: W03010022, Rev: G
WE05DF-BN
Transient Voltage Suppressor
Features
Protects one I/O or Power Line
Low Clamping Voltage
Working Voltage: 5V
Low Leakage Current
DFN1006-2L
IEC COMPATIBILITY (EN61000-4)
IEC 61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 4A (8/20μs)
Mechanical Characteristics
Applications
DFN1006-2L package
Cellular Handsets & Accessories
Marking : Marking Code
Personal Digital Assistants (PDAs)
Packaging : Tape and Reel per EIA 481
Notebooks & Handhelds
RoHS Compliant
Portable Instrumentation
Digital Cameras
MP3 Players
Schematic & PIN Configuration
Pin2
Pin1
©2019 WAYON Corporation
www.way-on.com
1/5
WE05DF-BN
Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp = 8/20μs )
PPP
60
Watts
Peak Pulse Current ( tp = 8/20μs )
IPP
4
A
Operating Temperature
TJ
-55 to + 125
TSTG
-55 to +150
Storage Temperature
Electrical Parameters (T=25℃)
Symbol
I
Parameter
I PP
IPP
Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
IT
IR
VC VBR VRWM
Reverse Stand-Off Voltage
IR
IT
Reverse Leakage Current @ VRWM
VBR
VRWM VBR VC
Breakdown Voltage @ IT
IT
I PP
Test Current
Electrical Characteristics
WE05DF-BN
Parameter
Reverse Breakdown Voltage
Symbol
Conditions
Minimum
Typical
VRWM
Maximum
Units
5
V
VBR
IT=1mA
6
V
IR
VRWM=5V, T=25℃
200
nA
Clamping Voltage
VC
IPP=1A, tp=8/20μs
9.5
V
Clamping Voltage
VC
IPP=4A, tp=8/20μs
15
V
ESD Clamping Voltage1
VC
IPP = 4A
tp = 0.2/100ns
9.5
V
VC
IPP = 16A
tp = 0.2/100ns
14.5
V
Dynamic Resistance1,2
RDYN
TLP=0.2/100ns
0.4
Ω
Junction Capacitance
Cj
VR =0V, f =1MHz
7
15
pF
Note:1、TLP Setting:tp=100ns, tr=0.2ns, ITLP and VTLP sample window:t1=70ns to t2=90ns.
2、Dynamic resistance calculated from IPP=4A to IPP=16A using “Best Fit”
www.way-on.com
2/5
V
WE05DF-BN
Typical Characteristics
Figure 2: Power Derating Curve
10
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW)
Figure 1: Peak Pulse Power Vs Pulse Time
1
60W 8/20µs
Waveform
0.1
110
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Ambient Temperature - TA (℃)
Figure 4: Normalized Junction Capacitance
vs. Reverse Voltage
14
13
12
11
10
9
8
7
6
5
4
3
2
1
Cj(VR)/Cj(VR=0)
Clamping Voltage -Vc(V)
Figure 3: Clamping Voltage vs. Peak Pulse
Current
1
1.5
2
2.5
3
3.5
4
4.5
1.2
1.1
1
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
Peak Pulse Current -Ipp(A)
5
30
TLP Current (A)
TLP Current (A)
35
25
RDYN=0.4 Ohms
10
TLP
Parameters:
tp=100ns
tr=0.2ns
5
4
6
8
10
12
14
16
6
18
-5
-10
RDYN=0.4 Ohms
-15
-20
TLP
Parameters:
tp=100ns
tr=0.2ns
-25
-30
-35
TLP Voltage (V)
5
Figure 6: TLP Negative I-V Curve
Figure 5: TLP Positive I-V Curve
15
2
3
4
Reverse Voltage -VR(V)
-18
-16
-14
-12
-10
-8
-6
-4
-2
TLP Voltage (V)
www.way-on.com
3/5
WE05DF-BN
Soldering Parameters
Pb – Free assembly
Reflow Condition
Pre Heat
Temperature Min (Ts(min))
Temperature Max (Ts(max))
Time (min to max) (ts )
Average ramp up rate (Liquidus Temp) (TL) to peak
TS(max) to TL——Ramp-up Rate
Temperature (TL) (Liquidus)
Reflow
Temperature (tL)
Peak Temperature (TP)
150°C
200°C
60 – 190 secs
5°C/second max
5°C/second max
217°C
60 – 150 seconds
260+0/-5 °C
Time within actual peak Temperature (tp )
20 – 40 seconds
Ramp-down Rate
Time 25°C to peak Temperature (TP)
Do not exceed
5°C/second max
8 minutes Max.
280°C
www.way-on.com
4/5
WE05DF-BN
Outline Drawing –DFN1006-2L
PACKAGE OUTLINE
D
e
h
DFN1006-2L
h
L1
MILIMETER
E
b
SYMBOL
MIN
2
2
1
L
A
A1
b
C
D
e
E
L
L1
h
L1
1
A1
C
A
BOTTOM VIEW
NOM
0.45
0.12
0.95
0.50
0.02
0.50
0.15
1.00
0.65BSC
0.55
0.60
0.20
0.25
0.05REF
0.07
0.12
MAX
0.55
0.05
0.55
0.18
1.05
0.65
0.30
0.17
Land Pattern
1.00
0.60
0.60
0.30
0.35
0.35
Marking Codes
Part Number
WE05DF-BN
Marking Code
PB
Package Information
Qty:10k/Reel
CONTACT INFORMATION
No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207
Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com
WAYON website: http://www.way-on.com
For additional information, please contact your local Sales Representative.
® is registered trademark of Wayon Corporation.
Specifications are subject to change without notice.
The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time.
Users should verify actual device performance in their specific applications.
www.way-on.com
5/5
很抱歉,暂时无法提供与“WE05DF-BN”相匹配的价格&库存,您可以联系我们找货
