PHD20N06T
N-channel TrenchMOS standard level FET
Rev. 02 — 1 December 2009
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
Suitable for high frequency
applications due to fast switching
characteristics
1.3 Applications
DC-to-DC convertors
Switched-mode power supplies
General purpose switching
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage 25 °C ≤ Tj ≤ 175 °C
55
V
ID
drain current
Tmb = 25 °C; VGS = 10 V;
see Figure 1 and 3
18
A
Ptot
total power
dissipation
Tmb = 25 °C;
see Figure 2
51
W
VGS = 10 V; ID = 25 A;
VDS = 44 V; Tj = 25 °C;
see Figure 13
6
nC
VGS = 10 V; ID = 10 A;
Tj = 175 °C;
see Figure 11 and 12
154
mΩ
Tj = 25 °C;
65
77
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
drain-source
on-state resistance
PHD20N06T
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
D
G
mbb076
S
2
1
3
SOT428 (DPAK)
3. Ordering information
Table 3.
Type number
PHD20N06T
Package
Name
Description
Version
DPAK
plastic single-ended surface-mounted package (DPAK); 3 leads (one
lead cropped)
SOT428
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
55
V
VDGR
drain-gate voltage
RGS = 20 kΩ
55
V
VGS
gate-source voltage
-20
V
ID
drain current
VGS = 10 V; Tmb = 100 °C; see Figure 1
13
A
VGS = 10 V; Tmb = 25 °C; see Figure 1 and 3
18
A
73
A
51
W
IDM
peak drain current
tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3
Ptot
total power dissipation
Tmb = 25 °C; see Figure 2
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
[1]
Source-drain diode
IS
source current
Tmb = 25 °C
18
A
ISM
peak source current
73
A
36
mJ
Avalanche ruggedness
EDS(AL)S
[1]
non-repetitive
VGS = 10 V; Tj = 25 °C; ID = 6 A; RGS = 50 Ω;
drain-source avalanche Vsup ≤ 55 V; unclamped inductive load
energy
Peak drain current is limited by chip, not package.
PHD20N06T_2
Product data sheet
2 of 12
Nexperia B.V. 2017. All rights reserved
PHD20N06T
Nexperia
03aa24
120
03aa16
120
Ider
Pder
80
80
40
40
100
150
200
100
150
Tmb (°C)
Fig 1.
200
Tmb (°C)
Fig 2.
Normalized continuous drain current as a
function of mounting base temperature
Normalized total power dissipation as a
003aaa043
103
ID
(A)
102
RDSon = VDS/ ID
tp = 10 μs
10
100 μs
P
δ=
tp
D.C.
T
1 ms
10 ms
1
t
tp
T
10−1
1
Fig 3.
10
VDS (V)
102
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PHD20N06T_2
Product data sheet
3 of 12
PHD20N06T
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-mb)
Rth(j-a)
Conditions
Min
Typ
Max
Unit
thermal resistance from see Figure 4
junction to mounting
base
2.9
K/W
thermal resistance from minimum footprint; FR4 board
junction to ambient
71.4
K/W
003aaa053
10
Zth(j-mb)
(K/W)
δ = 0.5
1
0.2
0.1
0.05
10−1
P
0.02
δ=
tp
T
Single pulse
t
tp
10−2
10−6
T
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Fig 4.
Transient thermal impedance from junction to mounting base as a function of pulse duration
PHD20N06T_2
Product data sheet
4 of 12
PHD20N06T
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
50
V
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
55
V
gate-source threshold
voltage
ID = 1 mA; VDS= VGS; Tj = -55 °C;
see Figure 10
4.4
V
ID = 1 mA; VDS= VGS; Tj = 175 °C;
see Figure 10
1
V
ID = 1 mA; VDS= VGS; Tj = 25 °C;
see Figure 10
2
3
4
V
VDS = 55 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
VDS = 55 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 10 A; Tj = 175 °C;
154
mΩ
VGS = 10 V; ID = 10 A; Tj = 25 °C;
65
77
mΩ
ID = 25 A; VDS = 44 V; VGS = 10 V;
Tj = 25 °C; see Figure 13
11
nC
3
nC
6
nC
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
drain-source on-state
resistance
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 14
VDS = 30 V; RL = 1.2 Ω; VGS = 10 V;
RG(ext) = 10 Ω; Tj = 25 °C
316
422
pF
92
110
pF
64
87
pF
10
ns
50
ns
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
70
ns
tf
fall time
40
ns
LD
internal drain
inductance
measured from drain lead from package to
centre of die; Tj = 25 °C
2.5
nH
LS
internal source
inductance
measured from source lead from package
to source bond pad; Tj = 25 °C
7.5
nH
Source-drain diode
VSD
source-drain voltage
IS = 10 A; VGS = 0 V; Tj = 25 °C;
see Figure 15
0.85
1.2
V
trr
reverse recovery time
32
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs; VGS = -10 V;
VDS = 30 V; Tj = 25 °C
120
nC
PHD20N06T_2
Product data sheet
5 of 12
PHD20N06T
Nexperia
003aaa045
60
ID
(A)
VGS (V) =
50
16
12
40
10
003aaa051
160
RDSon
(mΩ)
140
120
9.0
100
30
8.0
7.5
7.0
6.5
6.0
80
60
5.0
Fig 5.
4
6
40
8
10
VDS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
5
Fig 6.
03aa35
10−1
ID
(A)
10
15
VGS (V)
Drain-source on-state resistance as a function
of gate-source voltage; typical values
003aaa047
8
gfs
min
10−2
typ
max
(S)
6
10−3
4
10−4
2
10−5
10−6
4
6
10
15
VGS (V)
Fig 7.
25
ID (A)
Sub-threshold drain current as a function of
gate-source voltage
Fig 8.
Forward transconductance as a function of
drain current; typical values
PHD20N06T_2
Product data sheet
6 of 12
PHD20N06T
Nexperia
003aaa049
25
03aa32
5
VGS(th)
(V)
ID
(A) 20
4
15
3
10
2
5
max
typ
min
1
Tj = 175 °C
Tj = 25 °C
−60
Fig 9.
2
4
6
8
VGS (V)
10
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
5.5
6
6.5 7
8
120
180
Tj (°C)
03aa28
2.4
VGS (V) =
(mΩ)
60
Fig 10. Gate-source threshold voltage as a function of
003aaa046
180
RDSon
a
10
160
1.8
140
120
1.2
100
80
0.6
60
40
40
ID (A)
50
Fig 11. Drain-source on-state resistance as a function
of drain current; typical values
−60
120
180
Tj (°C)
Fig 12. Normalized drain-source on-state resistance
factor as a function of junction temperature
PHD20N06T_2
Product data sheet
7 of 12
PHD20N06T
Nexperia
003aaa050
10
VGS
(V)
003aaa048
600
Ciss,
Coss,
Crss 500
VDD = 44 V
8
(pF)
VDD = 14 V
400
6
Ciss
300
4
200
Coss
2
100
Crss
10
QG (nC)
15
10−3
10−2
102
10
1
VDS (V)
Fig 13. Gate-source voltage as a function of gate
charge; typical values
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
003aaa052
120
IS
(A)
100
80
60
Tj = 175 °C
40
Tj = 25 °C
1.0
1.5
VSD (V)
2.0
Fig 15. Source current as a function of source-drain voltage; typical values
PHD20N06T_2
Product data sheet
8 of 12
PHD20N06T
Nexperia
7. Package outline
Plastic single-ended surface-mounted package (DPAK); 3 leads (one lead cropped)
SOT428
y
E
A
A
A1
b2
E1
mounting
base
D2
D1
HD
2
L
L2
1
L1
3
b1
b
w
M
c
A
e
e1
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
b2
c
D1
D2
min
E
E1
min
e
e1
HD
L
L1
min
L2
w
y
max
mm
2.38
2.22
0.93
0.46
0.89
0.71
1.1
0.9
5.46
5.00
0.56
0.20
6.22
5.98
4.0
6.73
6.47
4.45
2.285
4.57
10.4
9.6
2.95
2.55
0.5
0.9
0.5
0.2
0.2
OUTLINE
VERSION
SOT428
REFERENCES
IEC
JEDEC
JEITA
TO-252
SC-63
EUROPEAN
PROJECTION
ISSUE DATE
06-02-14
06-03-16
Fig 16. Package outline SOT428 (DPAK)
PHD20N06T_2
Product data sheet
9 of 12
PHD20N06T
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PHD20N06T_2
20091201
Product data sheet
PHD20N06T-01
Modifications:
PHD20N06T-01
(9397 750 07895)
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
20010222
Product specification
PHD20N06T_2
Product data sheet
10 of 12
PHD20N06T
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft— The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet— A short data sheet is an extract from a full data sheet with
the same product type number(s) and title. A short data sheet is intended for
quick reference only and should not be relied upon to contain detailed and full
information. For detailed and full information see the relevant full data sheet,
which is available on request via the local Nexperia sales office.
In case of any inconsistency or conflict with the short data sheet, the full data
sheet shall prevail.
9.3
Disclaimers
General— Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes— Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use— Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications— Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data— The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values— Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale— Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license— Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control— This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit:http://www.nexperia.com
For sales office addresses, please send an email to:salesaddresses@nexperia.com
PHD20N06T_2
Product data sheet
11 of 12
Nexperia
PHD20N06T
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 01 December 2009
很抱歉,暂时无法提供与“PHD20N06T,118”相匹配的价格&库存,您可以联系我们找货
