PBSS4032PX
30 V, 4.2 A PNP low VCEsat (BISS) transistor
Rev. 01 — 1 April 2010
Product data sheet
1. Product profile
1.1 General description
PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a medium power and
flat lead SOT89 (SC-62) Surface-Mounted Device (SMD) plastic package.
NPN complement: PBSS4032NX.
1.2 Features and benefits
Very low collector-emitter saturation voltage VCEsat
Optimized switching time
High collector current capability IC and ICM
High collector current gain (hFE) at high IC
High energy efficiency due to less heat generation
AEC-Q101 qualified
Smaller required Printed-Circuit Board (PCB) area than for conventional transistors
1.3 Applications
Battery-driven devices
Power management
Charging circuits
Power switches (e.g. motors, fans)
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter voltage
open base
−30
V
IC
collector current
−4.2
A
ICM
peak collector current
single pulse;
tp ≤ 1 ms
−10
A
RCEsat
collector-emitter
saturation resistance
IC = −4 A;
IB = −400 mA
58
86
mΩ
[1]
Pulse test: tp ≤ 300 μs; δ ≤ 0.02.
[1]
PBSS4032PX
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Description
1
emitter
2
collector
3
base
Simplified outline
Graphic symbol
2
3
3
2
1
1
006aaa231
3. Ordering information
Table 3.
Type number
PBSS4032PX
Package
Name
Description
Version
SC-62
plastic surface-mounted package; 3 leads
SOT89
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PBSS4032PX
*6J
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
PBSS4032PX_1
Product data sheet
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
−30
V
VCEO
open base
−30
V
VEBO
emitter-base voltage
open collector
−5
V
IC
collector current
−4.2
A
ICM
single pulse;
tp ≤ 1 ms
−10
A
IB
base current
−1
A
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 15
PBSS4032PX
Nexperia
Table 5.
Limiting values …continued
Symbol
Ptot
Parameter
Conditions
total power dissipation
Tamb ≤ 25 °C
Min
Max
Unit
[1]
600
mW
[2]
1650
mW
[3]
2500
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm2.
[3]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
006aac174
3.0
Ptot
(W)
(1)
2.0
(2)
1.0
(3)
0.0
−75
−25
25
75
125
175
Tamb (°C)
(1) Ceramic PCB, Al2O3, standard footprint
(2) FR4 PCB, mounting pad for collector 6 cm2
(3) FR4 PCB, standard footprint
Fig 1.
PBSS4032PX_1
Product data sheet
Power derating curves
3 of 15
PBSS4032PX
Nexperia
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
thermal resistance from
junction to ambient
Rth(j-a)
in free air
Min
Typ
Max
Unit
[1]
210
K/W
[2]
75
K/W
[3]
50
K/W
K/W
junction to solder point
Rth(j-sp)
[1]
[2]
[3]
006aac175
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.5
0.33
0.2
0.1
0.05
10
0.02
0.01
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 2.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
PBSS4032PX_1
Product data sheet
4 of 15
PBSS4032PX
Nexperia
006aac176
102
duty cycle = 1
0.75
Zth(j-a)
(K/W)
0.5
0.33
0.2
10
0.1
0.05
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 3.
006aac177
102
duty cycle = 1
Zth(j-a)
(K/W)
0.75
0.5
0.33
10
0.2
0.1
0.05
1
0.01
10−1
10−5
0.02
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 4.
PBSS4032PX_1
Product data sheet
5 of 15
PBSS4032PX
Nexperia
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol Parameter
ICBO
Conditions
collector-base cut-off VCB = −30 V; IE = 0 A
current
VCB = −30 V; IE = 0 A;
Tj = 150 °C
Max
Unit
−100
nA
−50
μA
collector-emitter
cut-off current
VCE = −24 V; VBE = 0 V
−100
nA
IEBO
emitter-base cut-off
current
VEB = −5 V; IC = 0 A
−100
nA
hFE
DC current gain
VCE = −2 V
IC = −500 mA
200
350
IC = −1 A
200
320
IC = −2 A
150
240
60
100
IC = −1 A; IB = −50 mA
−110
−165
mV
IC = −1 A; IB = −10 mA
−160
−240
mV
IC = −2 A; IB = −40 mA
−200
−300
mV
IC = −4 A; IB = −400 mA
−230
−345
mV
VCEsat
[1]
collector-emitter
saturation voltage
[1]
IC = −4 A; IB = −200 mA
−270
−400
mV
[1]
58
86
mΩ
[1]
−0.78
−0.9
V
[1]
−1.02
−1.1
V
VCE = −2 V; IC = −2 A
[1]
−0.81
−0.9
V
30
ns
RCEsat
collector-emitter
VBEsat
base-emitter
saturation voltage
VBEon
base-emitter turn-on
voltage
td
delay time
VCC = −12.5 V;
IC = −1 A; IBon = −0.05 A;
IBoff = 0.05 A
tr
rise time
ton
turn-on time
ts
60
ns
90
ns
storage time
140
ns
tf
fall time
80
ns
220
ns
115
MHz
85
pF
toff
turn-off time
fT
transition frequency
Cc
collector capacitance VCB = −10 V;
IE = ie = 0 A; f = 1 MHz
[1]
Product data sheet
Typ
ICES
IC = −4 A
PBSS4032PX_1
Min
VCE = −10 V;
IC = −100 mA;
f = 100 MHz
6 of 15
PBSS4032PX
Nexperia
006aac202
600
IB (mA) = −600
IC
(A)
(1)
hFE
006aac203
−10.0
−540
−480
−420
−360
−8.0
−300
−240
−180
400
−6.0
(2)
−120
−60
−4.0
200
(3)
−2.0
−10−1
−1
−10
−102
0.0
0.0
−103
−104
IC (mA)
−1.0
−2.0
−3.0
−4.0
−5.0
VCE (V)
Tamb = 25 °C
VCE = 2 V
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 5.
DC current gain as a function of collector
current; typical values
006aac204
−1.4
Fig 6.
Collector current as a function of
collector-emitter voltage; typical values
006aac205
−1.4
VBE
(V)
VBEsat
(V)
−1.0
−1.0
(1)
(1)
(2)
(2)
−0.6
−0.6
(3)
(3)
−0.2
−10−1
−1
−10
−102
−103
−104
IC (mA)
−0.2
−10−1
−1
VCE = 2 V
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Fig 7.
Base-emitter voltage as a function of collector
PBSS4032PX_1
Product data sheet
Fig 8.
−10
−102
−103
−104
IC (mA)
Base-emitter saturation voltage as a function
of collector current; typical values
7 of 15
PBSS4032PX
Nexperia
006aac206
−1
006aac207
−1
VCEsat
(V)
VCEsat
(V)
−10−1
−10−1
(1)
(2)
(1)
(3)
(2)
(3)
−10−2
−10−1
−1
−10
−102
−103
−104
IC (mA)
−10−2
−10−1
−1
−102
−103
−104
IC (mA)
Tamb = 25 °C
IC/IB = 20
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig 9.
−10
Collector-emitter saturation voltage as a
function of collector current; typical values
006aac208
103
Fig 10. Collector-emitter saturation voltage as a
RCEsat
(Ω)
RCEsat
(Ω)
102
102
10
10
(1)
1
006aac209
103
(1)
1
(2)
10−1
(2)
10−1
(3)
10−2
−10−1
−1
−10
−102
−103
−104
IC (mA)
(3)
10−2
−10−1
−1
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig 11. Collector-emitter saturation resistance as a
Product data sheet
−102
−103
−104
IC (mA)
Tamb = 25 °C
IC/IB = 20
PBSS4032PX_1
−10
Fig 12. Collector-emitter saturation resistance as a
8 of 15
PBSS4032PX
Nexperia
8. Test information
− IB
input pulse
(idealized waveform)
90 %
− I Bon (100 %)
10 %
− I Boff
output pulse
− IC
90 %
− I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig 13. BISS transistor switching time definition
VBB
RB
oscilloscope
VCC
RC
Vo
(probe)
450 Ω
(probe)
450 Ω
oscilloscope
R2
VI
DUT
R1
mgd624
Fig 14. Test circuit for switching times
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PBSS4032PX_1
Product data sheet
9 of 15
PBSS4032PX
Nexperia
9. Package outline
4.6
4.4
1.8
1.4
1.6
1.4
2.6
2.4
4.25
3.75
1
2
0.53
0.40
1.5
1.2
0.8
3
0.48
0.35
0.44
0.23
3
Dimensions in mm
06-08-29
Fig 15. Package outline SOT89 (SC-62)
10. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Package Description
PBSS4032PX SOT89
[1]
PBSS4032PX_1
Product data sheet
Packing quantity
3000
10000
8 mm pitch, 12 mm tape and reel; T1
[2]
-115
-135
8 mm pitch, 12 mm tape and reel; T3
[3]
-120
For further information and the availability of packing methods, see Section 14.
[2]
T1: normal taping
[3]
T3: 90° rotated taping
10 of 15
PBSS4032PX
Nexperia
11. Soldering
4.75
2.25
2
1.9
1.2
0.2
0.85
solder lands
1.7
1.2
4.6
solder resist
0.5
4.85
solder paste
occupied area
1.1
(2×)
1
(3×)
1.5
Dimensions in mm
1.5
0.6
(3×)
0.7
(3×)
3.95
sot089_fr
Fig 16. Reflow soldering footprint SOT89 (SC-62)
6.6
2.4
3.5
solder lands
7.6
0.5
solder resist
occupied area
1.8
(2×)
Dimensions in mm
preferred transport direction during soldering
1.9
1.5
(2×)
1.9
0.7
5.3
sot089_fw
Fig 17. Wave soldering footprint SOT89 (SC-62)
PBSS4032PX_1
Product data sheet
11 of 15
PBSS4032PX
Nexperia
12. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PBSS4032PX_1
20100401
Product data sheet
PBSS4032PX_1
Product data sheet
12 of 15
PBSS4032PX
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
PBSS4032PX_1
Product data sheet
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on a weakness or default in the
customer application/use or the application/use of customer’s third party
customer(s) (hereinafter both referred to as “Application”). It is customer’s
sole responsibility to check whether the Nexperia product is
suitable and fit for the Application planned. Customer has to do all necessary
testing for the Application in order to avoid a default of the Application and the
product. Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13 of 15
PBSS4032PX
Nexperia
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PBSS4032PX_1
Product data sheet
14 of 15
Nexperia
PBSS4032PX
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9
Quality information . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Packing information . . . . . . . . . . . . . . . . . . . . 10
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Date of release: 01 April 2010
