PBSS4540X
40 V, 5 A NPN low VCEsat (BISS) transistor
15 April 2020
Product data sheet
1. General description
NPN low VCEsat transistor in a medium power SOT89 (SC-62) package.
PNP complement: PBSS5540X.
2. Features and benefits
High hFE and low VCEsat at high current operation
High collector current capability: IC maximum 4 A
High efficiency leading to less heat generation.
AEC-Q101 qualified
3. Applications
Medium power peripheral drivers (e.g. fan and motor)
Strobe flash units for DSC and mobile phones
Inverter applications (e.g. TFT displays)
Power switch for LAN and ADSL systems
Medium power DC-to-DC conversionc
Battery chargers.
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCEO
collector-emitter
voltage
open base
40
V
IC
collector current
4
A
ICM
peak collector current
single pulse; tp ≤ 10 ms
10
A
RCEsat
collector-emitter
saturation resistance
IC = 5 A; IB = 500 mA; tp ≤ 300 µs;
pulsed; δ ≤ 0.02; Tamb = 25 °C
40
71
mΩ
PBSS4540X
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
1
E
emitter
2
C
collector
3
B
base
Simplified outline
Graphic symbol
C
B
3
2
1
SOT89
E
sym123
6. Ordering information
Table 3. Ordering information
Type number
Package
PBSS4540X
Name
Description
Version
SOT89
plastic, surface-mounted package; 3 leads; 1.5 mm pitch; 4.5
mm x 2.5 mm x 1.5 mm body
SOT89
7. Marking
Table 4. Marking codes
Type number
Marking code[1]
PBSS4540X
%1B
[1]
% = placeholder for manufacturing site code
PBSS4540X
Product data sheet
All information provided in this document is subject to legal disclaimers.
15 April 2020
Nexperia B.V. 2020. All rights reserved
2 / 13
PBSS4540X
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
40
V
VCEO
collector-emitter voltage
open base
40
V
VEBO
emitter-base voltage
open collector
6
V
IC
collector current
4
A
ICRM
repetitive peak collector
current
δ ≤ 0.02; tp ≤ 10 ms
5
A
ICM
10
A
IB
base current
1
A
IBM
peak base current
single pulse; tp ≤ 1 ms
2
A
Ptot
total power dissipation
Tamb ≤ 25 °C
[1] [2]
2.5
W
[1]
0.55
W
[3]
1
W
[4]
1.4
W
[5]
1.6
W
[1]
Tj
junction temperature
150
°C
Tamb
ambient temperature
-65
150
°C
Tstg
storage temperature
-65
150
°C
[1]
[2]
[3]
[4]
[5]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
Operated under pulsed conditions; tp ≤ 10 ms; δ ≤ 0.2.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm .
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 6 cm .
2
2
Device mounted on a 7 cm ceramic PCB, 1 cm single-sided copper and tin-plated.
001aaa229
1600
Ptot
(mW)
(1)
1200
(2)
800
(3)
400
100
2
150
200
Tamb (°C)
(1) FR4 PCB; 6 cm mounting pad for collector
2
(2) FR4 PCB; 1 cm mounting pad for collector
(3) FR4; standard footprint
Fig. 1.
Power derating curves
PBSS4540X
Product data sheet
15 April 2020
3 / 13
PBSS4540X
Nexperia
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Rth(j-a)
thermal resistance from in free air
junction to ambient
Rth(j-sp)
[1]
[2]
[3]
[4]
[5]
Conditions
Min
Typ
Max
Unit
[1] [2]
50
K/W
[1]
225
K/W
[3]
125
K/W
[4]
90
K/W
[5]
80
K/W
16
K/W
junction to solder point
2
2
2
2
006aaa232
103
Zth
(K/W)
(1)
102
(2)
(3)
(4)
(5)
(6)
10
(7)
(8)
(9)
1
10- 1
10- 5
(10)
10- 4
10- 3
10- 2
10- 1
1
10
102
tp (s)
103
Mounted on FR4 PCB; standard footprint
(1) δ = 1
(2) δ = 0.75
(3) δ = 0.5
(4) δ = 0.33
(5) δ = 0.2
(6) δ = 0.1
(7) δ = 0.05
(8) δ = 0.02
(9) δ = 0.01
(10) δ = 0
Fig. 2.
Transient thermal impedance as a function of pulse duration; typical values
PBSS4540X
Product data sheet
15 April 2020
4 / 13
PBSS4540X
Nexperia
006aaa233
103
Zth
(K/W)
102
(1)
(3)
(5)
10
(2)
(4)
(6)
(7)
(8)
(9)
1
(10)
10- 1
10- 5
10- 4
10- 3
10- 2
10- 1
Mounted on FR4 PCB; mounting pad for collector 1 cm
(1) δ = 1
(2) δ = 0.75
(3) δ = 0.5
(4) δ = 0.33
(5) δ = 0.2
(6) δ = 0.1
(7) δ = 0.05
(8) δ = 0.02
(9) δ = 0.01
(10) δ = 0
Fig. 3.
1
10
102
2
tp (s)
103
006aaa234
103
Zth
(K/W)
102
(1)
(3)
10
(5)
(6)
(2)
(4)
(7)
(8)
1
(9)
(10)
10- 1
10- 5
10- 4
10- 3
10- 2
10- 1
1
10
102
2
tp (s)
103
Mounted on FR4 printed-circuit board; mounting pad for collector 6 cm
(1) δ = 1
(2) δ = 0.75
(3) δ = 0.5
(4) δ = 0.33
(5) δ = 0.2
(6) δ = 0.1
(7) δ = 0.05
(8) δ = 0.02
(9) δ = 0.01
(10) δ = 0
Fig. 4.
PBSS4540X
Product data sheet
15 April 2020
5 / 13
PBSS4540X
Nexperia
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
VCB = 30 V; IE = 0 A; Tamb = 25 °C
100
nA
VCB = 30 V; IE = 0 A; Tj = 150 °C
50
µA
collector-base cut-off
current
ICES
collector-emitter cut-off VCE = 30 V; VBE = 0 V; Tamb = 25 °C
current
100
nA
IEBO
emitter-base cut-off
current
VEB = 5 V; IC = 0 A; Tamb = 25 °C
100
nA
hFE
DC current gain
VCE = 2 V; IC = 0.5 A; Tamb = 25 °C
300
VCE = 2 V; IC = 1 A; tp ≤ 300 µs; pulsed;
300
VCE = 2 V; IC = 2 A; tp ≤ 300 µs; pulsed;
250
VCE = 2 V; IC = 5 A; tp ≤ 300 µs; pulsed;
100
IC = 0.5 A; IB = 5 mA; Tamb = 25 °C
90
mV
IC = 1 A; IB = 10 mA; Tamb = 25 °C
120
mV
IC = 2 A; IB = 200 mA; tp ≤ 300 µs;
150
mV
IC = 4 A; IB = 200 mA; tp ≤ 300 µs;
290
mV
VCEsat
collector-emitter
saturation voltage
355
mV
collector-emitter
RCEsat
40
71
mΩ
VBEsat
base-emitter saturation IC = 4 A; IB = 200 mA; tp ≤ 300 µs;
voltage
1.1
V
1.2
V
VBEon
base-emitter turn-on
voltage
1.1
V
fT
transition frequency
VCE = 10 V; IC = 0.1 A; f = 100 MHz;
Tamb = 25 °C
70
MHz
Cc
collector capacitance
VCB = 10 V; IE = 0 A; ie = 0 A; f = 1 MHz;
Tamb = 25 °C
75
pF
PBSS4540X
Product data sheet
15 April 2020
6 / 13
PBSS4540X
Nexperia
001aaa223
800
hFE
001aaa222
1.2
(1)
VBE
(V)
600
(2)
0.8
(1)
(2)
400
(3)
(3)
0.4
200
1
10
102
0.0
10- 1
103
104
IC (mA)
VCE = 2 V
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 5.
10
102
103
104
IC (mA)
VCE = 2 V
(1) Tamb = -55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
DC current gain as a function of collector
current; typical values
Fig. 6.
001aaa225
1
Base-emitter voltage as a function of collector
001aaa997
1
VCEsat
(V)
VCEsat
(V)
10- 1
10- 1
(1)
(1)
(2)
10- 2
1
10- 2
(3)
(2)
(3)
10- 3
10- 1
1
10
102
10- 3
10- 1
103
104
IC (mA)
IC/IB = 20
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 7.
Product data sheet
10
102
103
104
IC (mA)
Tamb = 25 °C
(1) IC/IB = 100
(2) IC/IB = 50
(3) IC/IB = 10
Collector-emitter saturation voltage as a
function of collector current; typical values
PBSS4540X
1
Fig. 8.
15 April 2020
7 / 13
PBSS4540X
Nexperia
001aaa227
10
001aaa224
102
RCEsat
(Ω)
VBEsat
(V)
10
1
1
(1)
(2)
(3)
10- 1
(1)
(2)
(3)
10- 1
10- 1
1
10
102
10- 2
10- 1
103
104
IC (mA)
IC/IB = 20
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
Fig. 9.
1
102
10
103
104
IC (mA)
IC/IB = 20
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
Base-emitter saturation voltage as a function of Fig. 10. Equivalent on-resistance as a function of
001aaa973
103
RCEsat
(Ω)
001aaa221
10
IC
(A)
102
8
(1)
(1)
10
6
(2)
(2)
(3)
1
(3)
4
(5)
10- 1
10- 2
10- 1
2
1
10
102
104
IC (mA)
Tamb = 25 °C
(1) IC/IB = 100
(2) IC/IB = 50
(3) IC/IB = 10
Fig. 11. Equivalent on-resistance as a function of
PBSS4540X
Product data sheet
(4)
1
1.5
VCE (V)
2
(1) IB = 25 mA
(2) IB = 20 mA
(3) IB = 15 mA
(4) IB = 10 mA
(5) IB = 5 mA
Fig. 12. Collector current as a function of collectoremitter voltage; typical values
15 April 2020
8 / 13
PBSS4540X
Nexperia
11. Package outline
4.6
4.4
1.8
1.4
1.6
1.4
2.6
2.4
4.25
3.75
1
0.53
0.40
1.5
2
1.2
0.8
3
0.48
0.35
0.44
0.23
3
Dimensions in mm
06-08-29
Fig. 13. Package outline SOT89
12. Soldering
4.75
2.25
2
1.9
1.2
0.2
0.85
solder lands
1.7
1.2
4.6
solder resist
0.5
1
(3×)
4.85
1.1
(2×)
1.5
solder paste
occupied area
Dimensions in mm
1.5
0.6
(3×)
0.7
(3×)
3.95
sot089_fr
Fig. 14. Reflow soldering footprint for SOT89
PBSS4540X
Product data sheet
15 April 2020
9 / 13
PBSS4540X
Nexperia
6.6
2.4
3.5
solder lands
7.6
0.5
solder resist
occupied area
1.8
(2×)
Dimensions in mm
preferred transport direction during soldering
1.9
1.5
(2×)
1.9
0.7
5.3
sot089_fw
Fig. 15. Wave soldering footprint for SOT89
PBSS4540X
Product data sheet
15 April 2020
10 / 13
PBSS4540X
Nexperia
13. Revision history
Table 8. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PBSS4540X v.3
20200415
Product data sheet
PBSS4540X v.2
Modifications:
The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Limiting values at ICM: conditions corrected
Characteristics at figure 6: legend corrected
PBSS4540X v.2
20041104
Product data sheet
PBSS4540X v.1
PBSS4540X v.1
20040611
Product data sheet
PBSS4540X
Product data sheet
15 April 2020
11 / 13
PBSS4540X
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
PBSS4540X
Product data sheet
15 April 2020
12 / 13
PBSS4540X
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 6
11. Package outline.......................................................... 9
12. Soldering..................................................................... 9
13. Revision history........................................................11
14. Legal information......................................................12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 15 April 2020
PBSS4540X
Product data sheet
15 April 2020
13 / 13
