PXT8050
NPN Transistor
Features
SOT-89
For Switching and Amplifier Applications.
As Complementary Type of the PNP
Transistor PXT8550 is Recommended.
Equivalent Circuit
2.Collector
1.Base 2.Collector 3. Emitter
Marking Code :
PXT8050C : GC
PXT8050D : GD
1.Base
3.. Emitter
Absolute Maximum Ratings
Ratings at 25℃ ambient temperature unless otherwise specified.
Parameter
Symbol
Value
Unit
Collector Base Voltage
VCBO
40
V
Collector Emitter Voltage
VCEO
25
V
Emitter Base Voltage
VEBO
6
V
Collector Current
IC
1.5
A
Maximum Power Dissipation
PD
1
W
Junction Temperature
TJ
150
TSTG
-55 to +150
Storage Temperature Range
www.pingjingsemi.com
Revison:3.0 Feb-2022
1/7
PXT8050
NPN Transistor
Electrical Characteristics (TA=25℃)
Parameter
Symbol
Min.
Typ.
Max.
Unit
120
200
160
320
40
ICBO
100
nA
V(BR)CBO
40
V
V(BR)CEO
25
V
V(BR)EBO
6
V
VCE(sat)
0.5
V
VBE(sat)
1.2
V
FT
100
MHz
DC Current Gain
at VCE = 1 V, IC = 100 mA
Current Gain Group
C
D
HFE
at VCE = 1 V, IC = 800 mA
Collector Base Cutoff Current
at VCB = 40 V
Collector Base Breakdown Voltage
at IC = 100 μA
Collector Emitter Breakdown Voltage
at IC = 0.1 mA
Emitter Base Breakdown Voltage
at IE = 100 μA
Collector Emitter Saturation Voltage
at IC = 800 mA, IB = 80 mA
Base Emitter Saturation Voltage
Transition Frequency
at VCE = 10 V, IC = 50 mA, f=30MHz
2/7
PXT8050
NPN Transistor
Typical Characteristic Curves
Ta = 100℃
DC Current Gain hFE
Collector Current IC (mA)
Common
Emitter
Ta = 25℃
Ta = 25℃
Common Emitter
VCE = 1V
Ta = 100℃
Ta = 25℃
Base-Emitter Saturation
Voltage VBE(sat) (mV)
Collector-Emitter Saturation
Voltage VCE(sat) (mV)
Collector-Emitter Voltage VCE (V)
Common Emitter
VCE = 1V
Base-Emitter Voltage VBE (mV)
Ta = 100℃
Transition Frequency fT (MHz)
25℃
Ta =
100℃
Ta =
Ta = 25℃
Common Emitter
VCE = 10V
Ta = 25℃
3/7
PXT8050
NPN Transistor
Package Outline
SOT-89
Dimensions in mm
Ordering Information
Device
Package
PXT8050
SOT-89
Shipping
1,000PCS/Reel&7inches
3,000PCS/Reel&13inches
4/7
PXT8050
NPN Transistor
Conditions of Soldering and Storage
Recommended condition of reflow soldering
Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust
the following parameters:
Time length of peak temperature (longer)
Time length of soldering (longer)
Thickness of solder paste (thicker)
Conditions of hand soldering
Temperature: 370 OC
Time: 3s max.
Times: one time
Storage conditions
Temperature
5 to 40 OC
Humidity
30 to 80% RH
Recommended period
One year after manufacturing
5/7
PXT8050
NPN Transistor
Package Specifications
The method of packaging (1,000PCS/Reel&7inches)
Cover Tape
1,000 pcs per reel
SOT-89
Carrier Tape
8,000 pcs per box
8 reels per box
32,000 pcs per carton
4 boxes per carton
Embossed tape and reel data
D
A
T1
E
B
G
F
Reel (7'')
symbol
Value(unit:mm)
A
Φ179±1
B
60.5±0.2
C
15.3±0.3
D
12.5~13.7
E
Φ13.5±0.2
F
Φ10.0±0.2
G
2.7±0.2
T1
1.0±0.2
C
6/7
PXT8050
NPN Transistor
The method of packaging (3,000PCS/Reel&13inches)
3,000 pcs per reel
SOT-89
9,000 pcs per box
3 reels per box
36,000 pcs per carton
4 boxes per carton
B
A
T
E
D
F
Reel (13'')
symbol
Value(unit:mm)
A
Φ330±1
B
12.7±0.5
C
16.5±0.3
D
Φ99.5±0.5
E
Φ13.6±0.3
F
2.8±0.3
T1
1.9±0.2
C
7/7
很抱歉,暂时无法提供与“PXT8050D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.16700
- 20+0.15200
- 100+0.13700
- 500+0.12200
- 1000+0.11500
- 2000+0.11000
