BZX84C Series
Silicon Planar Zener Diodes
Features
SOT-23
Total power dissipation: 350mW max
Package designed for optimal automated board assembly
Small package size for high density applications
Wide zener reverse voltage range:2.0V to 75V
Equivalent Circuit
1.Anode 2.NC 3.Cathode
3.Cathode
1.Anode
2.NC
Absolute Maximum Ratings at TA = 25 ℃
Parameter
Maximum Power Dissipation
Thermal Resistance,Junction-to-Ambient Note1
Junction Temperature
Storage Temperature Range
Symbols
Value
Unit
PD
350
mW
RθJA
357
°C/W
TJ
150
°C
TSTG
-65 to +150
°C
Note: 1. Alumina = 0.4 X 0.3 X 0.024 in,99.5% Alumina
www.pingjingsemi.com
Revision:3.0 Jun-2021
1/4
BZX84C Series
Electrical Characteristics at TA = 25 ℃
(Ta=25℃, unless otherwise noted, VF < 0.9 V at IF = 10 mA)
Type
Marking
Zener Voltage Range Note1
Code
Dynamic
IZT
VZT at IZT
Min.(V)
Nom.(V)
Max.(V)
(mA)
Impedance
Reverse Current
ZZT at IZT
IR
at VR
Max.(Ω)
Max.(μA)
(V)
BZX84C2V0
A8
1.8
2
2.15
5
100
120
0.5
BZX84C2V2
B8
2.08
2.2
2.33
5
100
120
0.7
BZX84C2V4
C8
2.2
2.4
2.6
5
100
50
1
BZX84C2V7
D8
2.5
2.7
2.9
5
100
BZX84C3V0
E8
2.8
3
3.2
5
95
10
1
BZX84C3V3
F8
3.1
3.3
3.5
5
95
5
1
BZX84C3V6
H8
3.4
3.6
3.8
5
90
5
1
BZX84C3V9
Z16
3.7
3.9
4.1
5
90
3
1
BZX84C4V3
K8
4
4.3
4.6
5
90
3
1
BZX84C4V7
M8
4.4
4.7
5
5
80
3
2
BZX84C5V1
N8
4.8
5.1
5.4
5
60
2
2
BZX84C5V6
P8
5.2
5.6
6
5
40
1
2
BZX84C6V2
R8
5.8
6.2
6.6
5
10
3
4
BZX84C6V8
X8
6.4
6.8
7.2
5
15
2
4
BZX84C7V5
Y8
7
7.5
7.9
5
15
1
5
BZX84C8V2
Z8
7.7
8.2
8.7
5
15
0.7
5
BZX84C9V1
A9
8.5
9.1
9.6
5
15
0.5
6
BZX84C10
B9
9.4
10
10.6
5
7
BZX84C11
C9
10.4
11
11.6
5
8
BZX84C12
D9
11.4
12
12.7
5
25
0.1
8
BZX84C13
E9
12.4
13
14.1
5
30
0.1
8
BZX84C15
F9
13.8
15
15.6
5
30
0.05
10.5
BZX84C16
H9
15.3
16
17.1
5
40
0.05
11.2
BZX84C18
J9
16.8
18
19.1
5
45
0.05
12.6
BZX84C20
K9
18.8
5
55
0.05
14
BZX84C22
M9
20.8
22
23.3
5
55
0.05
15.4
BZX84C24
N9
22.8
24
25.6
5
70
0.05
16.8
BZX84C27
P9
25.1
27
28.9
2
80
0.05
18.9
BZX84C30
R9
28
30
32
2
80
0.05
21
BZX84C33
X9
31
33
35
2
80
0.05
23.1
BZX84C36
Y9
34
36
38
2
90
0.05
25.2
BZX84C39
Z9
37
39
41
2
130
0.05
27.3
BZX84C43
A0
40
43
46
2
150
0.05
30.1
BZX84C47
B0
44
47
50
2
170
0.05
32.9
BZX84C51
C0
48
51
54
2
180
0.05
35.7
BZX84C56
D0
52
56
60
2
200
0.05
39.2
BZX84C62
E0
58
62
66
2
215
0.05
43.4
BZX84C68
F0
64
68
72
2
240
0.05
47.6
BZX84C75
H0
70
75
79
2
255
0.05
52.5
Note: 1. VZT is tested with 20ms pulse.
2/4
BZX84C Series
Typical Characteristic Curves
Temperature Coefficient (mV/℃)
8
7
6
5
4
3
2
1
-2
-3
3
4
5
6
7
8
9
10
11
100
10
1
12
10
100
Nominal Value VZ (V)
Zener voltage VZ (v)
220
Forward Current IF (mA)
Power Dissipation PD (mW)
200
180
160
140
120
5V1
100
80
27V
60
40
Ambient Temperature TA (℃)
500
700
900
1100
Forward Voltage VF (mV)
3/4
BZX84C Series
Package Outline
SOT-23
Dimensions in mm
Ordering Information
Device
Package
Shipping
BZX84C Series
SOT-23
3,000PCS/Reel&7inches
4/4
很抱歉,暂时无法提供与“BZX84C18”相匹配的价格&库存,您可以联系我们找货
