Low Capacitance Series
ESD Protection
PTP88L2M2BA60
Features
600 watts peak pulse power (tp = 8/20μs)
Protects two line pairs (Four Lines)
Ultra low leakage: nA level
Low operating voltage: 2.8V
Very low capacitance: 1pF
Ultra low clamping voltage
RoHS compliant
Pb
lead- free
Ro H S
2002/95/EC
SOP-8
IEC Compatibility (EN61000-4)
IEC 61000-4-2 ±30kV contact ±30kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 25A (8/20μs)
Mechanical Characteristics
Applications
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Base Station
Analog Inputs
Switch Systems
10/100/1000 Ethernet
WAN/LAN Equipment
Desktops, Servers, and Notebooks
Low Voltage Interfaces
Schematic & PIN Configuration
Circuit and Pin Schematic
Specifications are subject to change without notice.
Document No:P0E5910130239001M
C PROSEMI
1 of 4
SOP-8 Outline
www.prosemitech .com
ESD Protection
PTP88L2M2BA60
Absolute Maximum Ratings
Parameter
Symbol
Value
Unit
Peak Pulse Power ( tP =8/20μs waveform)
PPP
600
W
Peak Pulse Current (8/20µs)
IPP
30
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
TSTG
−55 to +150
°C
Electrical Characteristics
Parameter
Symbol
Test Condition
Min
Typ
VRWM
Reverse Working Voltage
Breakdown Voltage
VBR
IT = 2uA
Reverse Leakage Current
IR
VRWM = 2.8V
Clamping Voltage
VC
Clamping Voltage
Max
Unit
2.8
V
V
3
0.1
1
µA
IPP = 1A (8 x 20µs pulse)
6
V
VC
IPP = 5A (8 x 20µs pulse)
8
V
Clamping Voltage
VC
IPP = 10A (8 x 20µs pulse)
10
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
pF
2
Electrical Parameters (TA = 25°C unless otherwise noted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
VC VBR
VRWM
IT
IR
IR
IT
VRWM
VBR VC
V
Test Current
IPP
Note:. 8/20μs pulse waveform.
C PROSEMI
2 of 4
ESD Protection
PTP88L2M2BA60
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Peak Pulse Power vs. Pulse Time
Junction Capacitance vs. Reverse Voltage
Clamping Voltage
_Vc(V
15
10
5
10
15
25
Peak Pulse Current_Ipp (A)
Power Derating Curve
Clamping Voltage vs. Peak Pulse Current
100
% of Peak Pulse
Current
80
60
40
60
80
Note:Data is taken with a 10x attenuator
Time_t(μs)
ESD Clamping Voltage
8 kV Contact per IEC61000−4−2
8 X 20μs Pulse Waveform
C PROSEMI
3 of 4
ESD Protection
PTP88L2M2BA60
Package Mechanical Data
SYM
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM MAX
A
1.35
1.75
0.053
0.069
A1
0.10
0.25
0.004
0.010
A2
1.25
1.65
0.049
0.065
b
0.31
0.51
0.012
0.020
c
0.17
0.25
0.007
0.010
D
4.80
4.90
5.00
0.189
0.193
0.197
E1
3.80
3.90
4.00
0.150
0.154
0.157
E
6.00BSC
0.236BSC
e
1.27BSC
0.050BSC
h
0.25
0.50
0.010
0.020
L
0.40
0.72
1.04
0.016
0.028
0.041
L1
(1.04)
(0.041)
N
8.000
8.000
∅1
0°
HE
8°
0°
0.10
0.004
0.25
0.010
0.20
0.008
8°
Suggested Land Pattern
DIMENSIONS
0,//,0(7(56
,1&+(6
SYM
3
Ordering Information
Order code
PTP88L2M2BA60
C PROSEMI
Package
Base qty
Delivery mode
SOP-8
2.5K
Tape and reel
4 of 4
很抱歉,暂时无法提供与“PTP88L2M2BA60”相匹配的价格&库存,您可以联系我们找货
