PTN203H410S24CA650
PTN203H410S24CA650
    PROSEMI(普罗森美)
    DFN3_2.1X2.1MM
    ESD Bidirectional 24.8V 140V 6500A 410W
PTN203H410S24CA650 数据手册
High Capacitance Series ESD Protection PTN203H410S24CA650 Features 6500W peak pulse power (8/20uS) Low leakage: nA level Operating voltage: 24V Ultra low clamping voltage One power line protects RoHS compliant Pb lead- free Ro H S 2002/95/EC DFN2020-3 IEC Compatibility (EN61000-4) IEC 61000-4-2 (ESD) ±30kV contact ±30kV air IEC 61000-4-5 (Lightning) 140A (8/20μs) Applications Mechanical Characteristics Power Management Lead Finish: NiPdAu Industrial Application Case Material: “Green” Molding Compound. Power Supply Protection UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Schematic & PIN Configuration DFN2020-3 Specifications are subject to change without notice. C PROSEMI Document No:P17010084S 1 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN203H6&$ Absolute Maximum Ratings Parameter Symbol Value Unit Peak Pulse Power ( TP =8/20μs waveform) PPP 6500 W Peak Pulse Current (8/20µs) IPP 140 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C TSTG −55 to +150 °C Electrical Characteristics Parameter Test Condition Symbol Min Typ Max Unit 24 V VRWM Reverse Working Voltage VBR IT = 1mA Reverse Leakage Current IR VRWM = 2 4 V 1 µA Clamping Voltage VC IPP = 50A (8 x 20µs pulse) 32 V Clamping Voltage VC IPP = 140A (8 x 20µs pulse) 50 V Junction Capacitance CJ VR = 0V, f = 1MHz Breakdown Voltage V 24.8 pF 410 Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP MaximumReversePeak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR I IF WorkingPeak Reverse Voltage Maximum Reverse Leakage Current @ VRWM VC VBRVRWM Breakdown Voltage @ IT IT Test Current IF Forward Current VF Forward Voltage @ IF IR VF IT V IPP Note:.8/20μs pulse waveform. Specifications are subject to change without notice. C PROSEMI Document No:P17010084S 2 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN203H410S24CA650 Typical Performance Characteristics Specifications are subject to change without notice. C PROSEMI Document No:P17010084S 3 of 4 www.prosemitech.com High Capacitance Series ESD Protection PTN203H410S24CA650 Package Mechanical Data SYM DIMENSIONS MILLIMETERS MIN NOM MAX A 0.55 0.60 0.65 A1 0.00 0.02 0.05 A3 0.10REF b 0.25 -- 0.35 D 1.90 -- 2.10 E 1.90 -- 2.10 D2 0.95 -- 1.15 E2 1.40 -- 1.60 e 1.20 H 0.20 K 0.20 L 0.35 -- 0.45 R 0.13 -- -- 1.40 -- 0.30 0.40 Suggested Land Pattern Ordering Information Order code PTN203H410S24CA650 Specifications are subject to change without notice. C PROSEMI Document No:P17010084S Package Base qty Delivery mode DFN2020 3k Tape and reel 4 of 4 www.prosemitech.com
PTN203H410S24CA650 价格&库存
很抱歉,暂时无法提供与“PTN203H410S24CA650”相匹配的价格&库存,您可以联系我们找货
