Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
M3D088
PBSS4130T
30 V, 1 A
NPN low VCEsat (BISS) transistor
Product specification
2003 Nov 27
30 V, 1 A
PBSS4130T
QUICK REFERENCE DATA
FEATURES
• Low collector-emitter saturation voltage VCEsat
SYMBOL
• High collector current capability IC and ICM
PARAMETER
MAX.
UNIT
VCEO
collector-emitter voltage
30
V
• High efficiency leading to less heat generation
IC
collector current (DC)
1
A
• Reduced printed-circuit board requirements
ICM
peak collector current
3
A
• Cost effective alternative to MOSFETs in specific
applications.
RCEsat
equivalent on-resistance
220
mΩ
PINNING
APPLICATIONS
PIN
• Power management
– DC/DC conversion
– Supply line switching
– Battery charger
DESCRIPTION
1
base
2
emitter
3
collector
– LCD backlighting.
• Peripheral driver
– Driver in low supply voltage applications (e.g. lamps
and LEDs)
handbook, halfpage
3
– Inductive load drivers (e.g. relays, buzzers and
motors).
3
1
DESCRIPTION
NPN BISS transistor in a SOT23 plastic package providing
ultra low VCEsat and RCEsat parameters.
PNP complement: PBSS5130T.
1
Top view
2
2
MAM255
MARKING
MARKING CODE(1)
TYPE NUMBER
PBSS4130T
Fig.1 Simplified outline (SOT23) and symbol.
*3C
Note
1. * = p: made in Hong Kong.
* = t: made in Malaysia.
* = W: made in China.
ORDERING INFORMATION
PACKAGE
TYPE NUMBER
NAME
PBSS4130T
2003 Nov 27
DESCRIPTION
plastic surface mounted package; 3 leads
2
VERSION
SOT23
30 V, 1 A
PBSS4130T
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
VCBO
collector-base voltage
open emitter
40
V
VCEO
open base
30
V
VEBO
emitter-base voltage
open collector
5
V
IC
1
A
ICM
3
A
IBM
peak base current
300
mA
Ptot
total power dissipation
Tamb ≤ 25 °C; note 1
300
mW
Tamb ≤ 25 °C; note 2
480
mW
Tstg
storage temperature
−65
+150
°C
Tj
junction temperature
150
°C
Tamb
operating ambient temperature
−65
+150
°C
Notes
1. Device mounted on a FR4 printed-circuit board, single-sided copper, tinplated, standard footprint.
2. Device mounted on a FR4 printed-circuit board, single-sided copper, tinplated, mounting pad for collector 1 cm2.
THERMAL CHARACTERISTICS
SYMBOL
Rth j-a
PARAMETER
thermal resistance from junction to ambient
CONDITIONS
VALUE
UNIT
in free air; note 1
417
K/W
in free air; note 2
260
K/W
Notes
2003 Nov 27
3
30 V, 1 A
PBSS4130T
CHARACTERISTICS
Tamb = 25 °C unless otherwise specified.
SYMBOL
ICBO
PARAMETER
collector-base cut-off current
CONDITIONS
MIN.
TYP.
MAX.
VCB = 30 V; IE = 0
100
nA
VCB = 30 V; IE = 0; Tj = 150 °C
50
µA
nA
IEBO
emitter-base cut-off current
VEB = 4 V; IC = 0
100
hFE
DC current gain
VCE = 2 V; IC = 100 mA
350
470
VCE = 2 V; IC = 500 mA
300
450
VCE = 2 V; IC = 1 A
300
420
VCEsat
UNIT
IC = 100 mA; IB = 1 mA
90
mV
IC = 500 mA; IB = 50 mA
120
mV
IC = 750 mA; IB = 15 mA
220
mV
IC = 1 A; IB = 50 mA; note 1
270
mV
RCEsat
IC = 500 mA; IB = 50 mA; note 1
240
mΩ
VBEsat
base-emitter saturation voltage
IC = 1 A; IB = 100 mA; note 1
1.1
V
VBEon
base-emitter turn-on voltage
0.75
V
fT
transition frequency
IC = 100 mA; VCE = 10 V;
f = 100 MHz
100
MHz
Cc
collector capacitance
VCB = 10 V; IE = Ie = 0; f = 1 MHz
pF
Note
1. Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
2003 Nov 27
4
30 V, 1 A
PBSS4130T
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
SOT23
D
E
B
A
X
HE
v M A
3
Q
A
A1
1
2
e1
bp
c
w M B
Lp
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max.
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.9
0.1
0.48
0.38
0.15
0.09
3.0
2.8
1.4
1.2
1.9
0.95
2.5
2.1
0.45
0.15
0.55
0.45
0.2
0.1
OUTLINE
VERSION
SOT23
2003 Nov 27
REFERENCES
IEC
JEDEC
EIAJ
EUROPEAN
PROJECTION
ISSUE DATE
97-02-28
99-09-13
TO-236AB
5
30 V, 1 A
PBSS4130T
DATA SHEET STATUS
LEVEL
DATA SHEET
STATUS(1)
PRODUCT
STATUS(2)(3)
Development
DEFINITION
I
Objective data
II
Preliminary data Qualification
This data sheet contains data from the preliminary specification.
Supplementary data will be published at a later date. Philips
Semiconductors reserves the right to change the specification without
notice, in order to improve the design and supply the best possible
product.
III
Product data
This data sheet contains data from the product specification. Philips
Semiconductors reserves the right to make changes at any time in order
to improve the design, manufacturing and supply. Relevant changes will
be communicated via a Customer Product/Process Change Notification
(CPCN).
Production
This data sheet contains data from the objective specification for product
development. Philips Semiconductors reserves the right to change the
specification in any manner without notice.
Notes
1. Please consult the most recently issued data sheet before initiating or completing a design.
2. The product status of the device(s) described in this data sheet may have changed since this data sheet was
published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com.
3. For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status.
DEFINITIONS
DISCLAIMERS
Short-form specification The data in a short-form
specification is extracted from a full data sheet with the
same type number and title. For detailed information see
the relevant data sheet or data handbook.
Life support applications These products are not
designed for use in life support appliances, devices, or
systems where malfunction of these products can
reasonably be expected to result in personal injury. Philips
Semiconductors customers using or selling these products
for use in such applications do so at their own risk and
agree to fully indemnify Philips Semiconductors for any
damages resulting from such application.
Limiting values definition Limiting values given are in
(IEC 60134). Stress above one or more of the limiting
values may cause permanent damage to the device.
These are stress ratings only and operation of the device
at these or at any other conditions above those given in the
Characteristics sections of the specification is not implied.
Exposure to limiting values for extended periods may
affect device reliability.
Right to make changes Philips Semiconductors
reserves the right to make changes in the products including circuits, standard cells, and/or software described or contained herein in order to improve design
and/or performance. When the product is in full production
(status ‘Production’), relevant changes will be
Notification (CPCN). Philips Semiconductors assumes no
responsibility or liability for the use of any of these
products, conveys no licence or title under any patent,
copyright, or mask work right to these products, and
makes no representations or warranties that these
products are free from patent, copyright, or mask work
right infringement, unless otherwise specified.
Application information Applications that are
described herein for any of these products are for
illustrative purposes only. Philips Semiconductors make
no representation or warranty that such applications will be
suitable for the specified use without further testing or
modification.
2003 Nov 27
6
Philips Semiconductors – a worldwide company
Contact information
For additional information please visit http://www.semiconductors.philips.com.
Fax: +31 40 27 24825
For sales offices addresses send e-mail to: sales.addresses@www.semiconductors.philips.com.
SCA75
© Koninklijke Philips Electronics N.V. 2003
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R75/01/pp7
Date of release: 2003
Nov 27
Document order number:
9397 750 11897
