Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PBRP123ET
PNP 800 mA, 40 V BISS RET; R1 = 2.2 kΩ, R2 = 2.2 kΩ
Rev. 01 — 16 January 2008
Product data sheet
1. Product profile
1.1 General description
800 mA PNP low VCEsat Breakthrough In Small Signal (BISS) Resistor-Equipped
Transistor (RET) in a small SOT23 (TO-236AB) Surface-Mounted Device (SMD) plastic
package.
NPN complement: PBRN123ET.
1.2 Features
n 800 mA repetitive peak output current
n High current gain hFE
n Built-in bias resistors
n Simplifies circuit design
n Low collector-emitter saturation voltage
VCEsat
n Reduces component count
n Reduces pick and place costs
n ±10 % resistor ratio tolerance
1.3 Applications
n Digital application in automotive and
industrial segments
n Medium current peripheral driver
n Switching loads
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
VCEO
collector-emitter voltage
open base
Min
Typ
Max
Unit
−40
V
[1][2]
−600
mA
[3]
−800
mA
kΩ
IO
output current
IORM
repetitive peak output current tp ≤ 1 ms;
δ ≤ 0.33
R1
bias resistor 1 (input)
1.54
2.2
2.86
R2/R1
bias resistor ratio
0.9
1
1.1
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for
collector 1 cm2.
[2]
Device mounted on a ceramic PCB, Al2O3, standard footprint.
[3]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
PBRP123ET
NXP Semiconductors
2. Pinning information
Table 2.
Pinning
Pin
Description
1
input (base)
2
GND (emitter)
3
Simplified outline
Symbol
3
3
R1
output (collector)
1
1
2
R2
2
sym003
3. Ordering information
Table 3.
Type number
PBRP123ET
Package
Name
Description
Version
plastic surface-mounted package; 3 leads
SOT23
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
PBRP123ET
*7H
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
−40
V
VCEO
open base
−40
V
VEBO
emitter-base voltage
open collector
−10
V
VI
input voltage
+10
V
positive
−22
V
[1][2]
−600
mA
[3]
−800
mA
negative
IO
IORM
output current
tp ≤ 1 ms;
δ ≤ 0.33
PBRP123ET_1
Product data sheet
© NXP B.V. 2008. All rights reserved.
2 of 12
PBRP123ET
NXP Semiconductors
Table 5.
Limiting values …continued
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb ≤ 25 °C
Min
Max
Unit
[3]
250
mW
[1]
370
mW
[2]
570
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2.
[2]
[3]
006aaa998
600
(1)
Ptot
(mW)
400
(2)
(3)
200
−75
−25
25
75
125
175
Tamb (°C)
(1) Ceramic PCB, Al2O3 standard footprint
(2) FR4 PCB, mounting pad for collector 1 cm2
(3) FR4 PCB, standard footprint
Fig 1. Power derating curves for SOT23 (TO-236AB)
PBRP123ET_1
Product data sheet
3 of 12
PBRP123ET
NXP Semiconductors
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from
junction to ambient
in free air
Rth(j-sp)
Min
Typ
Max
Unit
[1]
500
K/W
[2]
338
K/W
[3]
219
K/W
105
K/W
junction to solder point
[1]
[2]
[3]
006aab000
103
δ=1
Zth(j-a)
(K/W)
0.75
0.50
102
0.33
0.20
0.10
0.05
10
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration for
SOT23 (TO-236AB); typical values
PBRP123ET_1
Product data sheet
4 of 12
PBRP123ET
NXP Semiconductors
006aab001
103
Zth(j-a)
(K/W)
δ=1
102
0.75
0.50
0.33
0.20
0.10
0.05
10
0.02
0.01
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration for
006aab002
103
Zth(j-a)
(K/W)
δ=1
102
0.75
0.50
0.33
0.20
0.10
10
0.05
0.02
0.01
1
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration for
PBRP123ET_1
Product data sheet
5 of 12
PBRP123ET
NXP Semiconductors
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ICBO
collector-base cut-off
current
VCB = −30 V;
IE = 0 A
−100
nA
ICEO
collector-emitter cut-off VCE = −30 V;
current
IB = 0 A
−0.5
µA
IEBO
emitter-base cut-off
current
VEB = −5 V;
IC = 0 A
−2
mA
hFE
DC current gain
VCE = −5 V;
IC = −50 mA
70
120
VCEsat
collector-emitter
saturation voltage
VCE = −5 V;
IC = −300 mA
[1]
180
250
VCE = −5 V;
IC = −600 mA
[1]
170
240
IC = −50 mA;
IB = −2.5 mA
−35
−45
mV
IC = −200 mA;
IB = −10 mA
−70
−100
mV
IC = −500 mA;
IB = −10 mA
[1]
−200
−300
mV
IC = −600 mA;
IB = −6 mA
[1]
−450
−750
mV
VI(off)
off-state input voltage
VCE = −5 V;
IC = −100 µA
−0.6
−1
−1.8
V
VI(on)
on-state input voltage
VCE = −0.3 V;
IC = −20 mA
−1
−1.3
−2
V
R1
1.54
2.2
2.86
kΩ
R2/R1
bias resistor ratio
0.9
1
1.1
Cc
collector capacitance
11
[1]
VCB = −10 V;
IE = ie = 0 A;
f = 1 MHz
Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
PBRP123ET_1
Product data sheet
pF
6 of 12
PBRP123ET
NXP Semiconductors
006aab085
103
006aab086
−10−1
hFE
102
(1)
(2)
(3)
VCEsat
(V)
(1)
(2)
(3)
10
1
10−1
−10−1
−1
−10
−102
−103
−10−2
−1
−10
IC (mA)
VCE = −5 V
IC/IB = 20
(1) Tamb = 100 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −40 °C
(3) Tamb = −40 °C
Fig 5. DC current gain as a function of collector
current; typical values
006aab087
−1
VCEsat
(V)
Fig 6. Collector-emitter saturation voltage as a
function of collector current; typical values
−10−1
(1)
(2)
(3)
−103
−102
−10−2
−10
IC (mA)
(1)
(2)
(3)
−103
−102
IC (mA)
IC/IB = 50
IC/IB = 100
(1) Tamb = 100 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = −40 °C
(3) Tamb = −40 °C
Fig 7. Collector-emitter saturation voltage as a
Fig 8. Collector-emitter saturation voltage as a
PBRP123ET_1
Product data sheet
006aab088
−1
VCEsat
(V)
−10−1
−10−2
−10
−103
−102
IC (mA)
7 of 12
PBRP123ET
NXP Semiconductors
006aab089
−10
006aab090
−10
VI(on)
(V)
VI(off)
(V)
−1
−10−1
−10−1
−1
(1)
(2)
(3)
−1
−10
−102
(1)
(2)
(3)
−10−1
−10−1
−103
−1
−10
IC (mA)
−102
IC (mA)
VCE = −0.3 V
VCE = −5 V
(1) Tamb = −40 °C
(1) Tamb = −40 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Fig 9. On-state input voltage as a function of collector
Fig 10. Off-state input voltage as a function of collector
8. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
Dimensions in mm
0.48
0.38
0.15
0.09
04-11-04
Fig 11. Package outline SOT23 (TO-236AB)
PBRP123ET_1
Product data sheet
8 of 12
PBRP123ET
NXP Semiconductors
9. Packing information
Table 8.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PBRP123ET
[1]
Package
Description
SOT23
Packing quantity
4 mm pitch, 8 mm tape and reel
3000
10000
-215
-235
For further information and the availability of packing methods, see Section 13.
10. Soldering
2.90
2.50
0.85
2
1
solder lands
1.30
3.00
2.70
0.85
solder resist
solder paste
3
occupied area
0.60
(3x)
Dimensions in mm
0.50 (3x)
0.60 (3x)
1.00
3.30
sot023
Fig 12. Reflow soldering footprint SOT23 (TO-236AB)
3.40
1.20 (2x)
solder lands
solder resist
occupied area
2
1
4.60 4.00 1.20
3
Dimensions in mm
2.80
preferred transport direction during soldering
4.50
sot023
Fig 13. Wave soldering footprint SOT23 (TO-236AB)
PBRP123ET_1
Product data sheet
9 of 12
PBRP123ET
NXP Semiconductors
11. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PBRP123ET_1
20080116
Product data sheet
PBRP123ET_1
Product data sheet
10 of 12
PBRP123ET
NXP Semiconductors
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
12.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13. Contact information
For additional information, please visit: http://www.nxp.com
For sales office addresses, send an email to: salesaddresses@nxp.com
PBRP123ET_1
Product data sheet
11 of 12
PBRP123ET
NXP Semiconductors
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics. . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Packing information. . . . . . . . . . . . . . . . . . . . . . 9
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2008.
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
Date of release: 16 January 2008
Document identifier: PBRP123ET_1
