74LV4053
Triple single-pole double-throw analog switch
Rev. 6 — 17 March 2016
Product data sheet
1. General description
The 74LV4053 is a triple single-pole double-throw (SPDT) analog switch, suitable for use
as an analog or digital multiplexer/demultiplexer. It is a low-voltage Si-gate CMOS device
and is pin and function compatible with the 74HC4053 and 74HCT4053. Each switch has
a digital select input (Sn), two independent inputs/outputs (nY0 and nY1) and a common
input/output (nZ). All three switches share an enable input (E). A HIGH on E causes all
switches into the high-impedance OFF-state, independent of Sn.
VCC and GND are the supply voltage connections for the digital control inputs (Sn and E).
The VCC to GND range is 1 V to 6 V. The analog inputs/outputs (nY0, nY1 and nZ) can
swing between VCC as a positive limit and VEE as a negative limit. VCC VEE may not
exceed 6 V. For operation as a digital multiplexer/demultiplexer, VEE is connected to GND
(typically ground). VEE and VSS are the supply voltage connections for the switches.
2. Features and benefits
Optimized for low-voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Low ON resistance:
180 (typical) at VCC VEE = 2.0 V
100 (typical) at VCC VEE = 3.0 V
75 (typical) at VCC VEE = 4.5 V
Logic level translation:
To enable 3 V logic to communicate with 3 V analog signals
Typical ‘break before make’ built in
ESD protection:
HBM JESD22-A114-C exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from 40 C to +85 C and from 40 C to +125 C
74LV4053
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV4053D
40 C to +125 C
SO16
plastic small outline package; 16 leads; body
width 3.9 mm
SOT109-1
74LV4053DB
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads; body
width 5.3 mm
SOT338-1
74LV4053PW
40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74LV4053BQ
40 C to +125 C
DHVQFN16
plastic dual-in line compatible thermal enhanced very
thin quad flat package; no leads; 16 terminals;
body 2.5 3.5 0.85 mm
SOT763-1
4. Functional diagram
9&&
很抱歉,暂时无法提供与“74LV4053PW,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+1.233992500+0.14969
- 5000+1.154395000+0.14003
- 12500+1.0747712500+0.13038
- 25000+1.0190425000+0.12362
- 62500+0.9951662500+0.12072
