74LVC1G384-Q100
Bilateral switch
Rev. 2 — 9 December 2016
Product data sheet
1. General description
The 74LVC1G384-Q100 provides one single pole, single throw analog switch function. It
has two input/output terminals (Y and Z) and an active LOW enable input pin (E). When
pin E is HIGH, the analog switch is turned off.
Schmitt trigger action at the enable input makes the circuit tolerant of slower input rise and
fall times across the entire VCC range from 1.65 V to 5.5 V.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Wide supply voltage range from 1.65 V to 5.5 V
Very low ON resistance:
7.5 (typical) at VCC = 2.7 V
6.5 (typical) at VCC = 3.3 V
6 (typical) at VCC = 5 V
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Switch current capability of 32 mA
High noise immunity
CMOS low power consumption
TTL interface compatibility at 3.3 V
Latch-up performance meets requirements of JESD 78 Class I
Enable input accepts voltages up to 5.5 V
Inputs accept voltages up to 5 V
74LVC1G384-Q100
Nexperia
Bilateral switch
3. Ordering information
Table 1.
Type number
Package
Temperature
range
Name
Description
Version
74LVC1G384GW-Q100
40 C to +125 C TSSOP5 plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LVC1G384GV-Q100
40 C to +125 C SC-74A
SOT753
plastic surface-mounted package; 5 leads
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G384GW-Q100
YL
74LVC1G384GV-Q100
YL
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
DDD
DDJ
Fig 1.
Logic symbol
Fig 2.
IEC logic symbol
9&&
DDD
Fig 3.
Logic diagram
74LVC1G384_100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
6. Pinning information
6.1 Pinning
/9&*4
*1'
9&&
DDD
Fig 4.
Pin configuration SOT353-1 and SOT753
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
Y
1
independent input or output
Z
2
independent output or input
GND
3
ground (0 V)
E
4
enable input (active LOW)
VCC
5
supply voltage
7. Functional description
Table 4.
Function table[1]
Input E
Switch
L
ON-state
H
OFF-state
[1]
H = HIGH voltage level; L = LOW voltage level.
74LVC1G384_100
Product data sheet
3 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
[1]
VI
input voltage
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
ISK
switch clamping current
[2]
Min
Max
Unit
0.5
+6.5
V
0.5
+6.5
V
50
mA
50
mA
0.5
VCC + 0.5
VSW
switch voltage
enable and disable mode
ISW
switch current
VSW > 0.5 V or VSW < VCC + 0.5 V
50
mA
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[3]
[1]
The minimum input voltage rating may be exceeded if the input current rating is observed.
[2]
The minimum and maximum switch voltage ratings may be exceeded if the switch clamping current rating is observed.
[3]
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
V
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VSW
[1]
switch voltage
Tamb
ambient temperature
t/V
input transition rise and
fall rate
[1]
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
VCC
V
C
40
+125
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
To avoid sinking GND current from terminal Z when switch current flows in terminal Y, the voltage drop across the bidirectional switch
must not exceed 0.4 V. If the switch current flows into terminal Z, no GND current flows from terminal Y. In this case, there is no limit for
the voltage drop across the switch.
74LVC1G384_100
Product data sheet
4 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
HIGH-level
input voltage
VIH
LOW-level
input voltage
VIL
40 C to +85 C
Conditions
VCC = 1.65 V to 1.95 V
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.35VCC
0.7
0.7
V
0.8
0.8
V
0.35VCC V
0.3VCC
0.3VCC
V
0.1
1
1
A
II
input leakage
current
pin E; VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
[2]
IS(OFF)
OFF-state
VCC = 5.5 V; see Figure 5
leakage current
[2]
0.1
0.2
0.5
A
IS(ON)
ON-state
VCC = 5.5 V; see Figure 6
leakage current
[2]
0.1
1
2
A
ICC
supply current
VI = 5.5 V or GND;
VSW = GND or VCC;
VCC = 1.65 V to 5.5 V
[2]
0.1
4
4
A
ICC
additional
supply current
pin E; VI = VCC 0.6 V;
VSW = GND or VCC; VCC = 5.5 V
[2]
5
500
500
A
CI
input
capacitance
2.0
pF
CS(OFF)
OFF-state
capacitance
5.0
pF
CS(ON)
ON-state
capacitance
9.5
pF
[1]
All typical values are measured at Tamb = 25 C.
[2]
These typical values are measured at VCC = 3.3 V.
74LVC1G384_100
Product data sheet
5 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
10.1 Test circuits
9&&
9&&
9,+
9,
9,/
,6
,6
*1'
*1'
9,
92
92
DDJ
DDJ
VI = VCC or GND and VO = GND or VCC.
Fig 5.
VI = VCC or GND and VO = open circuit.
Test circuit for measuring OFF-state leakage
current
Fig 6.
Test circuit for measuring ON-state leakage
current
10.2 ON resistance
Table 8.
ON resistance
At recommended operating conditions; voltages are referenced to GND (ground 0 V); for graphs see Figure 8 to Figure 13.
Symbol
RON(peak)
RON(rail)
Parameter
ON resistance (peak)
ON resistance (rail)
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
ISW = 4 mA;
34.0
130
195
ISW = 8 mA; VCC = 2.3 V to 2.7 V
12.0
30
45
ISW = 12 mA; VCC = 2.7 V
10.4
25
38
ISW = 24 mA; VCC = 3 V to 3.6 V
7.8
ISW = 32 mA; VCC = 4.5 V to 5.5 V
6.2
15
23
ISW = 4 mA;
8.2
18
27
7.1
16
24
6.9
14
21
VI = GND to VCC; see Figure 7
VI = GND; see Figure 7
6.5
12
18
5.8
10
15
VI = VCC; see Figure 7
74LVC1G384_100
Product data sheet
ISW = 4 mA;
10.4
30
45
7.6
7.0
18
27
6.1
15
23
4.9
10
15
6 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
Table 8.
ON resistance …continued
Symbol
RON(flat)
Parameter
40 C to +85 C
Conditions
ON resistance
(flatness)
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
ISW = 4 mA;
26.0
5.0
3.5
[2]
VI = GND to VCC
2.0
1.5
[1]
Typical values are measured at Tamb = 25 C and nominal VCC.
[2]
Flatness is defined as the difference between the maximum and minimum value of ON resistance measured at identical VCC and
temperature.
10.3 ON resistance test circuit and graphs
PQD
521
ȍ
96:
9&&
9,/
9,
*1'
,6:
RON = VSW / ISW.
9,9
DDJ
(1) VCC = 1.8 V.
(2) VCC = 2.5 V.
(3) VCC = 2.7 V.
(4) VCC = 3.3 V.
(5) VCC = 5.0 V.
Fig 7.
Test circuit for measuring ON resistance
74LVC1G384_100
Product data sheet
Fig 8.
Typical ON resistance as a function of input
voltage; Tamb = 25 C
7 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
DDD
521
ȍ
DDD
521
ȍ
9,9
(1) Tamb = 125 C.
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
(4) Tamb = 40 C.
Fig 9.
ON resistance as a function of input voltage;
VCC = 1.8 V
DDD
9,9
521
ȍ
Fig 10. ON resistance as a function of input voltage;
VCC = 2.5 V
DDD
521
ȍ
9,9
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
(4) Tamb = 40 C.
74LVC1G384_100
Product data sheet
9,9
(1) Tamb = 125 C.
Fig 11. ON resistance as a function of input voltage;
VCC = 2.7 V
Fig 12. ON resistance as a function of input voltage;
VCC = 3.3 V
8 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
DDD
521
ȍ
9,9
(1) Tamb = 125 C.
(2) Tamb = 85 C.
(3) Tamb = 25 C.
(4) Tamb = 40 C.
Fig 13. ON resistance as a function of input voltage; VCC = 5.0 V
11. Dynamic characteristics
Table 9.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V); for test circuit see Figure 16.
Symbol Parameter
tpd
ten
propagation delay
enable time
74LVC1G384_100
Product data sheet
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
0.8
2.0
3.0
ns
0.4
1.2
2.0
ns
VCC = 2.7 V
0.4
1.0
1.5
ns
VCC = 3.0 V to 3.6 V
0.3
0.8
1.5
ns
0.2
0.6
1.0
ns
1.0
10.0
12.0
1.0
15.5
ns
Y to Z or Z to Y; see Figure 14
E to Y or Z; see Figure 15
[2][3]
[4]
1.0
5.7
6.5
1.0
8.5
ns
VCC = 2.7 V
1.0
5.4
6.0
1.0
8.0
ns
1.0
4.8
5.0
1.0
6.5
ns
1.0
3.3
4.2
1.0
5.5
ns
9 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
Table 9.
Dynamic characteristics …continued
Symbol Parameter
tdis
disable time
40 C to +85 C
Conditions
Min
Max
Min
Max
1.0
7.4
10.0
1.0
13.0
ns
1.0
4.1
6.9
1.0
9.0
ns
VCC = 2.7 V
1.0
4.9
7.5
1.0
9.5
ns
1.0
5.4
6.5
1.0
8.5
ns
1.0
3.6
5.0
1.0
6.5
ns
VCC = 2.5 V
13.7
pF
VCC = 3.3 V
15.2
pF
VCC = 5.0 V
18.3
pF
[5]
power dissipation
capacitance
CPD
40 C to +125 C Unit
Typ[1]
[6]
CL = 50 pF; fi = 10 MHz;
VI = GND to VCC
[1]
[2]
tpd is the same as tPLH and tPHL.
[3]
propagation delay is the calculated RC time constant of the typical ON resistance of the switch and the specified capacitance when
driven by an ideal voltage source (zero output impedance).
[4]
ten is the same as tPZH and tPZL.
[5]
tdis is the same as tPLZ and tPHZ.
[6]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + {(CL + CS(ON)) VCC2 fo} where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
CS(ON) = maximum ON-state switch capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
{(CL + CS(ON)) VCC2 fo} = sum of the outputs.
11.1 Waveforms and test circuit
9,
90
500
MHz
VCC = 4.5 V
> 500
MHz
VCC = 1.65 V
200
MHz
VCC = 2.3 V
350
MHz
VCC = 3.0 V
410
MHz
VCC = 4.5 V
440
MHz
VCC = 1.65 V
46
dB
VCC = 2.3 V
46
dB
VCC = 3.0 V
46
dB
VCC = 4.5 V
46
dB
VCC = 1.65 V
37
dB
RL = 50 ; CL = 10 pF; see Figure 18
iso
isolation
(OFF-state)
RL = 600 ; CL = 50 pF; fi = 1 MHz; see Figure 19
RL = 50 ; CL = 5 pF; fi = 1 MHz; see Figure 19
Vct
crosstalk
voltage
74LVC1G384_100
Product data sheet
VCC = 2.3 V
37
dB
VCC = 3.0 V
37
dB
VCC = 4.5 V
37
dB
VCC = 1.65 V
69
mV
VCC = 2.3 V
87
mV
VCC = 3.0 V
156
mV
VCC = 4.5 V
302
mV
between digital input and switch;
RL = 600 ; CL = 50 pF; fi = 1 MHz; tr = tf = 2 ns;
see Figure 20
13 of 21
74LVC1G384-Q100
Nexperia
Bilateral switch
Table 12. Additional dynamic characteristics …continued
At recommended operating conditions; typical values measured at Tamb = 25 C.
Symbol Parameter
Qinj
Conditions
Min
Typ
Max
Unit
charge injection CL = 0.1 nF; Vgen = 0 V; Rgen = 0 ; fi = 1 MHz; RL = 1
M; see Section 11
VCC = 1.8 V
3.3
pC
VCC = 2.5 V
4.1
pC
VCC = 3.3 V
5.0
pC
VCC = 4.5 V
6.4
pC
VCC = 5.5 V
7.5
pC
11.3 Test circuits
9&&
9,/
5/
很抱歉,暂时无法提供与“74LVC1G384GV-Q100H”相匹配的价格&库存,您可以联系我们找货
