74LVC1G175
Single D-type flip-flop with reset; positive-edge trigger
Rev. 7 — 2 December 2016
Product data sheet
1. General description
The 74LVC1G175 is a low-power, low-voltage single positive edge triggered D-type
flip-flop with individual data (D) input, clock (CP) input, master reset (MR) input, and Q
output.
The master reset (MR) is an asynchronous active LOW input and operates independently
of the clock input. Information on the data input is transferred to the Q output on the
LOW-to-HIGH transition of the clock pulse. The D input must be stable one set-up time
prior to the LOW-to-HIGH clock transition for predictable operation.
The inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of
this device in a mixed 3.3 V and 5 V environment.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
Schmitt trigger action at all inputs makes the circuit highly tolerant of slower input rise and
fall times.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
5 V tolerant inputs for interfacing with 5 V logic
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V).
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V.
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C.
74LVC1G175
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G175GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74LVC1G175GV
40 C to +125 C
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
74LVC1G175GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC1G175GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74LVC1G175GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads;
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC1G175GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G175GW
YT
74LVC1G175GV
V75
74LVC1G175GM
YT
74LVC1G175GF
YT
74LVC1G175GN
YT
74LVC1G175GS
YT
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
05
4
&3
&3
05
DDD
Fig 1.
Logic symbol.
74LVC1G175
Product data sheet
4
DDD
Fig 2.
IEC logic symbol.
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 20
74LVC1G175
Nexperia
&3
4
05
Fig 3.
DDD
Logic diagram.
6. Pinning information
6.1 Pinning
/9&*
/9&*
&3
05
*1'
9&&
4
05
*1'
9&&
4
/9&*
&3
05
*1'
9&&
4
DDJ
DDJ
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
DDJ
Fig 4.
&3
Pin configuration SOT363
and SOT457
Fig 5.
Pin configuration SOT886
Fig 6.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
CP
1
clock input (LOW-to-HIGH, edge-triggered)
GND
2
ground (0 V)
D
3
data input
Q
4
output Q
VCC
5
supply voltage
MR
6
master reset input (active LOW)
74LVC1G175
Product data sheet
3 of 20
74LVC1G175
Nexperia
7. Functional description
Table 4.
Function table[1]
Operating mode
Input
Output
MR
CP
D
Q
Reset (clear)
L
X
X
L
Load ‘1’
H
h
H
Load ‘0’
H
l
L
[1]
H = HIGH voltage level;
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition;
L = LOW voltage level;
l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition;
= LOW-to-HIGH CP transition;
X = don’t care.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
IO
output current
ICC
supply current
IGND
ground current
Ptot
total power dissipation
Tstg
storage temperature
[1]
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
mA
mA
50
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
100
mA
100
mA
250
mW
65
+150
C
VO > VCC or VO < 0 V
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For SC-88 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
74LVC1G175
Product data sheet
4 of 20
74LVC1G175
Nexperia
9. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
10. Static characteristics
Table 7.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
0.65 VCC
V
Unit
Tamb = 40 C to +85 C
VIH
VIL
VOH
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
VCC = 1.65 V to 1.95 V
VCC = 2.3 V to 2.7 V
1.7
V
VCC = 2.7 V to 3.6 V
2.0
V
VCC = 4.5 V to 5.5 V
0.7 VCC
V
0.7
V
0.8
V
0.3 VCC
V
VI = VIH or VIL
IO = 100 A; VCC = 1.65 V to 5.5 V
VOL
LOW-level output voltage
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
1.54
V
IO = 8 mA; VCC = 2.3 V
1.9
2.15
V
IO = 12 mA; VCC = 2.7 V
2.2
2.50
V
IO = 24 mA; VCC = 3.0 V
2.3
2.62
V
IO = 32 mA; VCC = 4.5 V
3.8
4.11
V
0.10
V
0.07
0.45
V
0.12
0.30
V
0.17
0.40
V
0.33
0.55
V
VI = VIH or VIL
II
input leakage current
VCC = 0 V to 5.5 V; VI = 5.5 V or GND
IOFF
power-off leakage current
VCC = 0 V; VI or VO = 5.5 V
74LVC1G175
Product data sheet
0.35 VCC V
[2]
0.39
0.55
V
0.1
1
A
0.1
2
A
5 of 20
74LVC1G175
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
ICC
supply current
VCC = 1.65 V to 5.5 V; IO = 0 A;
VI = 5.5 V or GND
ICC
additional supply current
VCC = 2.3 V to 5.5 V; VI = VCC 0.6 V;
IO = 0 A
CI
input capacitance
VCC = 3.3 V; VI = GND to VCC
[2]
Min
Typ[1]
Max
0.1
4
A
5
500
A
2.5
pF
Unit
VIH
VIL
VOH
0.65 VCC
V
1.7
V
2.0
V
0.7 VCC
V
0.7
V
0.8
V
0.3 VCC
V
VCC 0.1
V
0.95
V
1.7
V
1.9
V
2.0
V
3.4
V
VI = VIH or VIL
VOL
0.35 VCC V
VI = VIH or VIL
0.10
V
0.70
V
0.45
V
0.60
V
0.80
V
0.80
V
II
1
A
IOFF
2
A
ICC
supply current
VI = 5.5 V or GND
4
A
ICC
IO = 0 A
500
A
[1]
All typical values are measured at Tamb = 25 C.
[2]
These typical values are measured at VCC = 3.3 V.
74LVC1G175
Product data sheet
6 of 20
74LVC1G175
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9.
Symbol Parameter
tpd
40 C to +85 C
Conditions
40 C to +125 C Unit
Min
Typ[1]
Max
Min
Max
1.5
4.9
13.4
1.5
17
ns
1.0
3.1
7.1
1.0
9.0
ns
VCC = 2.7 V
1.0
3.2
7.1
1.0
9.0
ns
VCC = 3.0 V to 3.6 V
1.0
3.1
5.7
0.5
7.5
ns
1.0
2.2
4.0
0.5
5.5
ns
1.5
4.3
12.9
1.5
17
ns
propagation delay CP to Q; see Figure 7
[2]
MR to Q; see Figure 8
tW
pulse width
1.0
2.8
7.0
1.0
9.0
ns
VCC = 2.7 V
1.0
3.0
7.0
1.0
9.0
ns
1.0
2.5
5.8
0.5
7.5
ns
1.0
2.0
4.1
0.5
5.5
ns
6.2
6.2
ns
2.7
2.7
ns
VCC = 2.7 V
2.7
2.7
ns
2.7
1.3
2.7
ns
2.0
2.0
ns
CP HIGH or LOW;
see Figure 7
MR LOW; see Figure 8
trec
tsu
recovery time
set-up time
74LVC1G175
Product data sheet
6.2
6.2
ns
2.7
2.7
ns
VCC = 2.7 V
2.7
2.7
ns
2.7
1.6
2.7
ns
2.0
2.0
ns
1.9
1.9
ns
1.4
1.4
ns
VCC = 2.7 V
1.3
1.3
ns
1.2
0.4
1.2
ns
1.0
1.0
ns
MR; see Figure 8
D to CP; see Figure 7
2.9
2.9
ns
1.7
1.7
ns
VCC = 2.7 V
1.7
1.7
ns
1.3
0.5
1.3
ns
1.1
1.1
ns
7 of 20
74LVC1G175
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol Parameter
th
hold time
maximum
frequency
fmax
40 C to +85 C
Conditions
power dissipation
capacitance
Min
Max
Min
Max
0.0
0.0
ns
0.3
0.3
ns
VCC = 2.7 V
0.5
0.5
ns
1.2
0.2
1.2
ns
0.5
0.5
ns
80
125
80
MHz
175
175
MHz
VCC = 2.7 V
175
175
MHz
175
300
175
MHz
200
200
MHz
14
pF
CP; see Figure 7
CPD
40 C to +125 C Unit
Typ[1]
VI = GND to VCC; VCC = 3.3 V
[3]
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
74LVC1G175
Product data sheet
8 of 20
74LVC1G175
Nexperia
12. Waveforms
9,
90
'LQSXW
*1'
WK
WK
WVX
WVX
IPD[
9,
&3LQSXW
90
*1'
W:
W3+/
W3/+
92+
90
4RXWSXW
92/
DDD
Measurement points are given in Table 9.
The shaded areas indicate when the input is permitted to change for predictable output performance.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 7.
The clock input (CP) to output (Q) propagation delays, the clock pulse width, the D to CP set-up, the CP to
D hold times, and the maximum clock pulse frequency
9,
90
05LQSXW
*1'
W:
W UHF
9,
&3LQSXW
90
*1'
W 3+/
92+
90
4RXWSXW
92/
DDD
Fig 8.
The master reset (MR) input to output (Q) propagation delays, the master reset pulse width, and the MR to
CP recovery time
74LVC1G175
Product data sheet
9 of 20
74LVC1G175
Nexperia
Table 9.
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
1.65 V to 1.95 V
0.5 VCC
0.5 VCC
2.3 V to 2.7 V
0.5 VCC
0.5 VCC
2.7 V
1.5 V
1.5 V
3.0 V to 3.6 V
1.5 V
1.5 V
4.5 V to 5.5 V
0.5 VCC
0.5 VCC
9(;7
9&&
9,
5/
92
'87
57
5/
PQD
Test data is given in Table 10.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to the output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 9.
Table 10.
Test circuit for measuring switching times
Test data
Supply voltage
Input
Load
VEXT
VCC
VI
tr = tf
CL
RL
tPLH, tPHL
1.65 V to 1.95 V
VCC
2.0 ns
30 pF
1 k
open
2.3 V to 2.7 V
VCC
2.0 ns
30 pF
500
open
2.7 V
2.7 V
2.5 ns
50 pF
500
open
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
open
4.5 V to 5.5 V
VCC
2.5 ns
50 pF
500
open
74LVC1G175
Product data sheet
10 of 20
74LVC1G175
Nexperia
13. Package outline
3ODVWLFVXUIDFHPRXQWHGSDFNDJHOHDGV
627
Y 0 $
4
SLQ
LQGH[
H
ES
F
/S
Z 0 %
H
GHWDLO;
PP
VFDOH
',0(16,216PPDUHWKHRULJLQDOGLPHQVLRQV
81,7
PD[
ES
F
H
H
/S
4
Y
Z
PP
287/,1(
9(56,21
5()(5(1&(6
-(,7$
6&
627
(8523($1
352-(&7,21
,668('$7(
Fig 10. Package outline SOT363 (SC-88)
74LVC1G175
Product data sheet
11 of 20
74LVC1G175
Nexperia
3ODVWLFVXUIDFHPRXQWHGSDFNDJH7623OHDGV
627
Y 0 $
4
SLQ
LQGH[
F
/S
H
ES
Z 0 %
GHWDLO;
PP
VFDOH
81,7
ES
F
H
/S
4
Y
Z
PP
287/,1(
9(56,21
5()(5(1&(6
-(,7$
6&
627
(8523($1
352-(&7,21
,668('$7(
Fig 11. Package outline SOT457 (SC-74)
74LVC1G175
Product data sheet
12 of 20
74LVC1G175
Nexperia
627
;621SODVWLFH[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGVWHUPLQDOVERG\[[PP
E
H
H
H
WHUPLQDO
LQGH[DUHD
PP
VFDOH
'LPHQVLRQVPPDUHWKHRULJLQDOGLPHQVLRQV
8QLW
PP
PD[
QRP
PLQ
E
H
H
1RWHV
,QFOXGLQJSODWLQJWKLFNQHVV
&DQEHYLVLEOHLQVRPHPDQXIDFWXULQJSURFHVVHV
2XWOLQH
YHUVLRQ
627
VRWBSR
5HIHUHQFHV
-(,7$
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
02
Fig 12. Package outline SOT886 (XSON6)
74LVC1G175
Product data sheet
13 of 20
74LVC1G175
Nexperia
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
PP
VFDOH
81,7
PD[
PD[
E
H
H
PP
1RWH
5()(5(1&(6
287/,1(
9(56,21
627
-(,7$
(8523($1
352-(&7,21
,668('$7(
Fig 13. Package outline SOT891 (XSON6)
74LVC1G175
Product data sheet
14 of 20
74LVC1G175
Nexperia
;621H[WUHPHO\WKLQVPDOORXWOLQHSDFNDJHQROHDGV
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
PP
PP
E
H
H
PD[
QRP
PLQ
1RWH
9LVLEOHGHSHQGLQJXSRQXVHGPDQXIDFWXULQJWHFKQRORJ\
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 14. Package outline SOT1115 (XSON6)
74LVC1G175
Product data sheet
15 of 20
74LVC1G175
Nexperia
WHUPLQDOVERG\[[PP
627
E
î
H
H
H
î
WHUPLQDO
LQGH[DUHD
VFDOH
'LPHQVLRQV
8QLW
PP
PP
E
H
H
PD[
QRP
PLQ
1RWH
VRWBSR
5HIHUHQFHV
2XWOLQH
YHUVLRQ
-(,7$
627
(XURSHDQ
SURMHFWLRQ
,VVXHGDWH
Fig 15. Package outline SOT1202 (XSON6)
74LVC1G175
Product data sheet
16 of 20
74LVC1G175
Nexperia
14. Abbreviations
Table 11.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
15. Revision history
Table 12.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC1G175 v.7
20161202
Product data sheet
74LVC1G175 v.6
Modifications:
74LVC1G175 v.6
Modifications:
74LVC1G175 v.5
Modifications:
Table 7: The maximum limits for leakage current and supply current have changed.
20131011
74LVC1G175 v.5
Package outline drawing of SOT886 (Figure 12) modified.
20111206
Product data sheet
Product data sheet
74LVC1G175 v.4
Legal pages updated.
74LVC1G175 v.4
20101004
Product data sheet
74LVC1G175 v.3
74LVC1G175 v.3
20070521
Product data sheet
74LVC1G175 v.2
74LVC1G175 v.2
20041018
Product specification
74LVC1G175 v.1
74LVC1G175 v.1
20040318
74LVC1G175
Product data sheet
17 of 20
74LVC1G175
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LVC1G175
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
18 of 20
74LVC1G175
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC1G175
Product data sheet
19 of 20
74LVC1G175
Nexperia
18. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17
Legal information. . . . . . . . . . . . . . . . . . . . . . . 18
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19
Contact information. . . . . . . . . . . . . . . . . . . . . 19
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20
Date of release: 02 December 2016
