74HC299D,653
74HC299D,653
    NEXPERIA(安世)
    SOIC20_300MIL
    8位通用移位寄存器;三态 SOIC20_300MIL 2~6V
74HC299D,653 数据手册
74HC299 8-bit universal shift register; 3-state Rev. 5 — 17 January 2019 Product data sheet 1. General description The 74HC299 is an 8-bit universal shift register with 3-state outputs. It contains eight edgetriggered D-type flip-flops and the interstage logic necessary to perform synchronous shift-right, shift-left, parallel load and hold operations. The type of operation is determined by the mode select inputs S0 and S1. Pins I/O0 to I/O7 are flip-flop 3-state buffer outputs which allow them to operate as data inputs in parallel load mode. The serial outputs Q0 and Q7 are used for expansion in serial shifting of longer words. A LOW signal on the asynchronous master reset input MR overrides the Sn and clock CP inputs and resets the flip-flops. All other state changes are initiated by the rising edge of the clock pulse. Inputs can change when the clock is either state, provided that the recommended set-up and hold times are observed. A HIGH signal on the 3-state output enable inputs OE1 or OE2 disables the 3-state buffers and the I/On outputs assume a high-impedance OFF-state. In this condition, the shift, hold, load and reset operations can still occur. The 3-state buffers are also disabled by HIGH signals on both S0 and S1, when in preparation for a parallel load operation. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • CMOS input levels Multiplexed inputs/outputs provide improved bit density Four operating modes: • Shift left • Shift right • Hold (store) • Load data Operates with output enable or at high-impedance OFF-state 3-state outputs drive bus lines directly Cascadable for n-bit word lengths ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC299D -40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74HC299DB -40 °C to +125 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 74HC299 Nexperia 8-bit universal shift register; 3-state 4. Functional diagram 1 11 12 9 8 2 3 19 S0 DSR S1 DSL 18 CP 8-BIT SHIFT REGISTER MR Q7 Q0 OE1 17 INPUT/3-STATE OUTPUT CIRCUITRY OE2 I/O0 I/O1 I/O2 I/O3 I/O4 I/O5 I/O6 I/O7 7 Fig. 1. 13 6 14 5 15 4 16 001aai460 Functional diagram 9 2 3 1 19 12 1 S0 I/O0 7 19 S1 I/O1 13 11 DSR I/O2 6 18 DSL I/O3 14 I/O4 5 12 CP I/O5 15 9 MR I/O6 4 I/O7 16 Q0 8 Q7 17 2 3 OE 11 7 13 6 14 5 15 4 16 18 R & Logic symbol 74HC299 Product data sheet 3EN5 0 0 M 3 1 C4/1 /2 1, 4D 3, 4D 6, 5 8 Z6 3, 4D 5 3, 4D 7, 5 2, 4D 17 Z7 001aai459 001aai458 Fig. 2. SRG8 Fig. 3. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 2 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state DSR S0 D S1 Q CP FF0 RD I/O0 CP Q0 D OE1 Q CP FF1 RD OE2 D Q CP FF2 RD D Q CP FF3 RD D Q CP FF4 RD D Q CP FF5 RD D Q CP FF6 RD DSL D Q CP FF7 RD Q7 I/O2 I/O3 I/O4 I/O5 I/O6 I/O7 001aai461 MR Fig. 4. I/O1 Logic diagram 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 3 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state 5. Pinning information 5.1. Pinning 74HC299 S0 1 20 VCC OE1 2 19 S1 OE2 3 18 DSL I/O6 4 17 Q7 I/O4 5 16 I/O7 I/O2 6 15 I/O5 I/O0 7 14 I/O3 Q0 8 13 I/O1 MR 9 12 CP GND 10 11 DSR 001aai511 Fig. 5. Pin configuration SOT163-1 (SO20) and SOT339-1 (SSOP20) 5.2. Pin description Table 2. Pin description Symbol Pin Description S0, S1 1, 19 mode select input OE1, OE2 2, 3 3-state output enable input (active LOW) I/O0, I/O1, I/O2, I/O3, I/O4, I/O5, I/O6, I/O7 7, 13, 6, 14, 5, 15, 4, 16 parallel data input or 3-state parallel output (bus driver) Q0, Q7 8, 17 serial output (standard output) MR 9 asynchronous master reset input (active LOW) GND 10 ground (0 V) DSR 11 serial data shift-right input CP 12 clock input (LOW to HIGH, edge-triggered) DSL 18 serial data shift-left input VCC 20 positive supply voltage 6. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; ↑ = LOW to HIGH CP transition; X = don’t care. Input Response MR S1 S0 CP L X X X asynchronous reset; Q0 to Q7 = LOW H H H ↑ parallel load; I/On → Qn H L H ↑ shift right; DSR → Q0, Q0 → Q1, etc. H H L ↑ shift left; DSL → Q7, Q7 → Q6, etc. H L L X hold 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 4 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current -0.5 V < VO < VCC + 0.5 V ICC supply current IGND ground current Tstg storage temperature Ptot total power dissipation [1] [2] [3] Conditions Min Max Unit -0.5 +7 V [1] - ±20 mA [1] - ±20 mA standard outputs - ±25 mA bus driver outputs - ±35 mA standard outputs - 50 mA bus driver outputs - 70 mA standard outputs -50 - mA bus driver outputs -70 - mA -65 +150 °C Tamb = -40 °C to +125 °C SO20 package [2] - 500 mW SSOP20 package [3] - 500 mW The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Ptot derates linearly at 8 mW/K above 70 °C. Ptot derates linearly at 5.5 mW/K above 60 °C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage VO output voltage Tamb ambient temperature Δt/ΔV input transition rise and fall rate 74HC299 Product data sheet Conditions Min Typ Max Unit 2.0 5.0 6.0 V 0 - VCC V 0 - VCC V -40 - +125 °C VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 5 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH HIGH-level input voltage LOW-level input voltage Conditions 25 °C -40 °C to +85 °C Min Typ Max Min Max VCC = 2.0 V 1.5 1.2 VCC = 4.5 V 3.15 2.4 - 1.5 - 3.15 VCC = 6.0 V 4.2 3.2 - VCC = 2.0 V - 0.8 VCC = 4.5 V - VCC = 6.0 V -40 °C to +125 °C Unit Min Max - 1.5 - V - 3.15 - V 4.2 - 4.2 - V 0.5 - 0.5 - 0.5 V 2.1 1.35 - 1.35 - 1.35 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = -6.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -7.8 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V IO = 6.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 7.8 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V - - ±0.1 - ±1.0 - ±1.0 μA ±10.0 μA HIGH-level output VI = VIH or VIL voltage all outputs standard outputs bus driver outputs VOL LOW-level output VI = VIH or VIL voltage all outputs standard outputs bus driver outputs II input leakage current IOZ OFF-state output VI = VIH or VIL; VCC = 6.0 V; current VO = VCC or GND - - ±0.5 - ±5.0 - ICC supply current - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF CI/O input/output capacitance - 10 - - - - - pF 74HC299 Product data sheet VI = VCC or GND; VCC = 6.0 V VI = VCC or GND; IO = 0 A; VCC = 6.0 V All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 6 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state Symbol Parameter CPD [1] Conditions 25 °C power dissipation VI = GND to VCC capacitance [1] -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max - 120 - - - - - Unit pF CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi + ∑(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz; 2 ∑(CL x VCC x fo) = sum of outputs. CL = output load capacitance in pF; VCC = supply voltage in V. 10. Dynamic characteristics Table 7. Dynamic characteristics GND (ground = 0 V); for test circuit, see Fig. 10. Symbol Parameter Conditions tpd CP to Q0, Q7; see Fig. 6 propagation delay 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 66 200 - 250 - 300 ns VCC = 4.5 V - 24 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns VCC = 6.0 V - 19 34 - 43 - 51 ns VCC = 2.0 V - 66 200 - 250 - 300 ns VCC = 4.5 V - 24 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns - 19 34 - 43 - 51 ns VCC = 2.0 V - 66 200 - 250 - 300 ns VCC = 4.5 V - 24 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 20 - - - - - ns VCC = 6.0 V - 19 34 - 43 - 51 ns VCC = 2.0 V - 14 60 - 75 - 90 ns VCC = 4.5 V - 5 12 - 15 - 18 ns VCC = 6.0 V - 4 10 - 13 - 15 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns [1] CP to I/On; see Fig. 6 VCC = 6.0 V MR to Q0, Q7 or I/On; see Fig. 7 tt transition time bus driver (I/On); see Fig. 6 [2] [3] standard (Q0, Q7); see Fig. 6 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 7 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state Symbol Parameter tW pulse width Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 80 17 - 100 - 120 - ns VCC = 4.5 V 16 6 - 20 - 24 - ns VCC = 6.0 V 14 5 - 17 - 20 - ns VCC = 2.0 V 80 19 - 100 - 120 - ns VCC = 4.5 V 16 7 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V - 50 155 - 195 - 235 ns VCC = 4.5 V - 18 31 - 39 - 47 ns VCC = 6.0 V - 14 26 - 33 - 40 ns VCC = 2.0 V - 41 130 - 165 - 195 ns VCC = 4.5 V - 15 26 - 33 - 39 ns - 12 22 - 28 - 33 ns VCC = 2.0 V - 66 185 - 230 - 280 ns VCC = 4.5 V - 24 37 - 46 - 56 ns VCC = 6.0 V - 19 31 - 39 - 48 ns VCC = 2.0 V - 55 155 - 195 - 235 ns VCC = 4.5 V - 20 31 - 39 - 47 ns VCC = 6.0 V - 16 26 - 33 - 40 ns VCC = 2.0 V 5 -14 - 5 - 5 - ns VCC = 4.5 V 5 -5 - 5 - 5 - ns VCC = 6.0 V 5 -4 - 5 - 5 - ns VCC = 2.0 V 100 33 - 125 - 150 - ns VCC = 4.5 V 20 12 - 25 - 30 - ns VCC = 6.0 V 17 10 - 21 - 26 - ns VCC = 2.0 V 100 33 - 125 - 150 - ns VCC = 4.5 V 20 12 - 25 - 30 - ns VCC = 6.0 V 17 10 - 21 - 26 - ns VCC = 2.0 V 125 39 - 155 - 190 - ns VCC = 4.5 V 25 14 - 31 - 38 - ns VCC = 6.0 V 21 11 - 26 - 32 - ns CP HIGH or LOW; see Fig. 6 MR LOW; see Fig. 7 tPZH tPZL OFF-state to HIGH propagation delay OFF-state to LOW propagation delay OEn to I/On; see Fig. 9 [4] OEn to I/On; see Fig. 9 VCC = 6.0 V tPHZ tPLZ trec tsu HIGH to OFF-state propagation delay LOW to OFF-state propagation delay recovery time set-up time OEn to I/On; see Fig. 9 [5] OEn to I/On; see Fig. 9 MR to CP; see Fig. 7 DSR, DSL to CP; see Fig. 6 S0, S1 to CP; see Fig. 8 I/On to CP; see Fig. 6 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 8 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state Symbol Parameter th hold time Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 0 -14 - 0 - 0 - ns VCC = 4.5 V 0 -5 - 0 - 0 - ns VCC = 6.0 V 0 -4 - 0 - 0 - ns VCC = 2.0 V 0 -28 - 0 - 0 - ns VCC = 4.5 V 0 -10 - 0 - 0 - ns VCC = 6.0 V 0 -8 - 0 - 0 - ns VCC = 2.0 V 5.0 15 - 4.0 - 3.4 - MHz VCC = 4.5 V 25 45 - 20 - 17 - MHz - 50 - - - - - MHz 29 54 - 24 - 20 - MHz I/On, DSR, DSL to CP; see Fig. 6 S0, S1 to CP; see Fig. 8 maximum frequency CP input; see Fig. 6 fmax VCC = 5.0 V; CL = 15 pF VCC = 6.0 V [1] [2] [3] [4] [5] tpd is the same as tPHL and tPLH. tpd is the same as tPHL. tt is the same as tTHL and tTLH. ten is the same as tPZH and tPZL. tdis is the same as tPHZ and tPLZ. 10.1. Waveforms and test circuit VI I/On, DSR, DSL inputs VM GND th th tsu tsu 1/fmax VI CP input VM GND tW tPHL tPLH VOH I/On, Q0, Q7 outputs VM VOL tTHL tTLH 001aai462 The shaded areas indicate when the input is permitted to change for predictable output performance. Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. Clock pulse to outputs I/On, Q0, Q7 propagation delays, the clock pulse width, the I/On, DSR and DSL to clock pulse set-up and hold times, the output transition times and the maximum clock frequency 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 9 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state VI MR input VM GND tW trec VI VM CP input GND tPHL VOH I/On, Q0, Q7 outputs VOL VM 001aai463 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 7. The master reset pulse width (LOW), the master reset to outputs I/On, Q0, Q7 propagation delays and the master reset to clock pulse removal time VI I/On, DSR, DSL, Sn inputs VM GND tsu th tsu th VI CP input VM GND 001aai464 Measurement points are given in Table 8. Fig. 8. Set-up and hold times from the mode control inputs S0, S1 to the clock pulse tr VI OEn input tf 90 % VM GND 10 % tPLZ VOH I/On output LOW to OFF OFF to LOW VOL tPZL VM 10 % tPZH tPHZ VOH I/On output HIGH to OFF OFF to HIGH VOL 90 % VM outputs enabled outputs disabled outputs enabled 001aai465 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. 3-state enable and disable times for OEn inputs 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 10 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state Table 8. Measurement points Input Output VI VM VM VCC 0.5VCC 0.5VCC VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VCC VO RT RL S1 open CL 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig. 10. Test circuit for measuring switching times Table 9. Test data Input S1 position Load VI tr, tf CL RL tPHL, tPLH VCC 6 ns 15 pF, 50 pF 1 kΩ open 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 11 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state 11. Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e detail X w M bp 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 inches 0.1 0.012 0.096 0.004 0.089 0.043 0.039 0.01 0.01 Z (1) 0.9 0.4 0.035 0.004 0.016 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 11. Package outline SOT163-1 (SO20) 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 12 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 pin 1 index A (A 3) A1 θ Lp L 1 10 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Fig. 12. Package outline SOT339-1 (SSOP20) 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 13 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC299 v.5 20190117 Product data sheet - 74HC299 v.4 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74HC299PW (SOT360-1) removed. 74HC299 v.4 20160226 Modifications: • • • • 74HC_HCT299 v.3 20080728 Modifications: • • • • • • 74HC_HCT299_CNV v.2 74HC299 Product data sheet Product data sheet - 74HC_HCT299 v.3 Type numbers 74HC299N and 74HCT299N (SOT146-1) removed. Type number 74HCT299D (SOT163-1) removed. Type number 74HCT299DB (SOT339-1) removed. Type number 74HCT299PW (SOT360-1) removed. Product data sheet - 74HC_HCT299_CNV_2 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. Section 3: Ordering information added Section 12: Package outline drawings added Section 9 "Static characteristics": Family data added Section 11 "Waveforms": Test circuit added 19970828 Product specification - All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 - © Nexperia B.V. 2019. All rights reserved 14 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC299 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 15 / 16 74HC299 Nexperia 8-bit universal shift register; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................4 5.1. Pinning.........................................................................4 5.2. Pin description............................................................. 4 6. Functional description................................................. 4 7. Limiting values............................................................. 5 8. Recommended operating conditions..........................5 9. Static characteristics....................................................6 10. Dynamic characteristics............................................ 7 10.1. Waveforms and test circuit........................................ 9 11. Package outline........................................................ 12 12. Abbreviations............................................................ 14 13. Revision history........................................................14 14. Legal information......................................................15 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 January 2019 74HC299 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 5 — 17 January 2019 © Nexperia B.V. 2019. All rights reserved 16 / 16
74HC299D,653 价格&库存
很抱歉,暂时无法提供与“74HC299D,653”相匹配的价格&库存,您可以联系我们找货
74HC299D,653
  • 2000+3.157712000+0.38215
  • 4000+3.142954000+0.38036
  • 6000+3.142896000+0.38035
  • 8000+3.142828000+0.38034
  • 10000+3.1427410000+0.38034
库存:2000
