INTEGRATED CIRCUITS
DATA SHEET
For a complete data sheet, please also download:
• The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Information
• The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines
74HC/HCT4520
Dual 4-bit synchronous binary
counter
Product specification
File under Integrated Circuits, IC06
December 1990
Philips Semiconductors
Dual 4-bit synchronous binary counter
74HC/HCT4520
from all four bit positions (nQ0 to nQ3) and an active HIGH
overriding asynchronous master reset input (nMR).
FEATURES
• Output capability: standard
The counter advances on either the LOW-to-HIGH
transition of nCP0 if nCP1 is HIGH or the HIGH-to-LOW
transition of nCP1 if nCP0 is LOW. Either nCP0 or nCP1
may be used as the clock input to the counter and the other
clock input may be used as a clock enable input. A HIGH
on nMR resets the counter (nQ0 to nQ3 = LOW)
independent of nCP0 and nCP1.
• ICC category: MSI
GENERAL DESCRIPTION
The 74HC/HCT4520 are high-speed Si-gate CMOS
devices and are pin compatible with the “4520” of the
“4000B” series. They are specified in compliance with
JEDEC standard no. 7A.
APPLICATIONS
The 74HC/HCT4520 are dual 4-bit internally synchronous
binary counters with an active HIGH clock input (nCP0)
and an active LOW clock input (nCP1), buffered outputs
• Multistage synchronous counting
• Multistage asynchronous counting
• Frequency dividers
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns
TYPICAL
SYMBOL
PARAMETER
CONDITIONS
UNIT
HC
HCT
tPHL/ tPLH
propagation delay nCP0, nCP1 to nQn
CL = 15 pF; VCC = 5 V 24
24
ns
tPHL
propagation delay nMR to nQn
13
13
ns
fmax
maximum clock frequency
68
64
MHz
CI
input capacitance
3.5
3.5
pF
CPD
power dissipation capacitance per counter
29
24
pF
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW):
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
∑ (CL × VCC2 × fo) = sum of outputs
CL = output load capacitance in pF
VCC = supply voltage in V
2. For HC the condition is VI = GND to VCC
For HCT the condition is VI = GND to VCC − 1.5 V
ORDERING INFORMATION
See “74HC/HCT/HCU/HCMOS Logic Package Information”.
December 1990
2
74HC/HCT4520
PIN DESCRIPTION
PIN NO.
SYMBOL
NAME AND FUNCTION
1, 9
1CP0, 2CP0
clock inputs (LOW-to-HIGH, edge-triggered)
2, 10
1CP1, 2CP1
clock inputs (HIGH-to-LOW, edge-triggered)
3, 4, 5, 6
1Q0 to 1Q3
data outputs
7, 15
1MR, 2MR
asynchronous master reset inputs (active HIGH)
8
GND
ground (0 V)
11, 12, 13, 14
2Q0 to 2Q3
data outputs
16
VCC
positive supply voltage
Fig.1 Pin configuration.
December 1990
Fig.2 Logic symbol.
3
Fig.3 IEC logic symbol.
74HC/HCT4520
FUNCTION TABLE
nCP0
nCP1
MR
MODE
H
L
counter advances
L
L
counter advances
X
L
no change
X
L
no change
L
L
no change
H
L
no change
X
X
H
Q0 to Q3 = LOW
Notes
1. H = HIGH voltage level
L = LOW voltage level
X = don’t care
↑ = LOW-to-HIGH clock transition
↓ = HIGH-to-LOW clock transition
Fig.4 Functional diagram.
Fig.5 Logic diagram (one counter).
Fig.6 Timing diagram.
December 1990
4
74HC/HCT4520
DC CHARACTERISTICS FOR 74HC
For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”.
ICC category: MSI
AC CHARACTERISTICS FOR 74HC
GND = 0 V; tr = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HC
SYMBOL
PARAMETER
min.
+25
−40 to +85
typ.
max. min. max.
−40 to +125
min.
UNIT
VCC
(V)
WAVEFORMS
max.
tPHL/ tPLH
propagation delay
nCP0 to nQn
77
28
22
240
48
41
300
60
51
360
72
61
ns
2.0
4.5
6.0
Fig.8
tPHL/ tPLH
propagation delay
nCP1 to nQn
77
28
22
240
48
41
300
60
51
360
72
61
ns
2.0
4.5
6.0
Fig.8
tPHL
propagation delay
nMR to nQn
44
16
13
150
30
26
190
38
33
225
45
38
ns
2.0
4.5
6.0
Fig.9
tTHL/ tTLH
output transition time
19
7
6
75
15
13
95
19
16
110
22
19
ns
2.0
4.5
6.0
Fig.8
tW
clock pulse width
HIGH or LOW
tW
22
8
6
100
120
24
ns
2.0
4.5
6.0
Fig.7
master reset pulse width 120
HIGH
24
14
11
150
30
26
180
36
31
ns
2.0
4.5
6.0
Fig.7
trem
removal time
nMR to nCP0; nCP1
−28
−10
−8
ns
2.0
4.5
6.0
Fig.7
tsu
set-up time
nCP1 to nCP0;
nCP0 to nCP1
80
16
14
14
5
4
100
120
24
ns
2.0
4.5
6.0
Fig.8
fmax
maximum clock pulse
frequency
6.0
30
35
19
58
69
4.8
24
28
4.0
MHz
2.0
4.5
6.0
Fig.7
December 1990
80
16
14
5
74HC/HCT4520
DC CHARACTERISTICS FOR 74HCT
ICC category: MSI
Note to HCT types
The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications.
To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below.
INPUT
UNIT LOAD COEFFICIENT
nCP0, nCP1
nMR
0.80
1.50
AC CHARACTERISTICS FOR 74HCT
Tamb (°C)
TEST CONDITIONS
74HCT
SYMBOL
PARAMETER
+25
−40 to +85
min. typ.
max. min. max.
−40 to +125
min.
UNIT V
CC
(V)
WAVEFORMS
max.
tPHL/ tPLH
propagation delay
nCP0 to nQn
28
53
66
80
ns
4.5
Fig.8
tPHL/ tPLH
propagation delay
nCP1 to nQn
25
53
66
80
ns
4.5
Fig.8
tPHL
propagation delay
nMR to nQn
16
35
44
53
ns
4.5
Fig.9
tTHL/ tTLH
7
15
19
22
ns
4.5
Fig.8
tW
clock pulse width
HIGH or LOW
25
30
ns
4.5
Fig.7
tW
HIGH
25
30
ns
4.5
Fig.7
trem
removal time
nMR to nCP0; nCP1
−8
ns
4.5
Fig.7
tsu
set-up time
nCP1 to nCP0;
nCP0 to nCP1
16
6
ns
4.5
Fig.8
fmax
maximum clock pulse
frequency
30
58
24
MHz
4.5
Fig.7
December 1990
6
74HC/HCT4520
AC WAVEFORMS
Conditions:
nCP1 = HIGH while nCP0 is triggered on a LOW-to-HIGH transition; tW
and trem also apply when nCP0 = LOW and nCP1 is triggered on a
HIGH-to-LOW transition.
(1) HC : VM = 50%; VI = GND to VCC.
HCT: VM = 1.3 V; VI = GND to 3 V.
Fig.7
Waveforms showing removal time for nMR; minimum nCP0, nCP1, nMR pulse widths and maximum clock
pulse frequency.
Fig.8
Waveforms showing set-up times for nCP0 to nCP1 and nCP1 to nCP0, propagation delays and output
transition times.
Fig.9 Waveforms showing propagation delay from nMR to nQn output.
PACKAGE OUTLINES
See “74HC/HCT/HCU/HCMOS Logic Package Outlines”.
December 1990
7
很抱歉,暂时无法提供与“74HC4520D,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2500+1.984712500+0.24021
- 5000+1.975445000+0.23909
- 7500+1.975397500+0.23908
- 10000+1.9753510000+0.23907
- 12500+1.9753012500+0.23907
