74AVCH4T245
4-bit dual supply translating transceiver with configurable
voltage translation; 3-state
Rev. 5 — 17 December 2015
Product data sheet
1. General description
The 74AVCH4T245 is a 4-bit, dual supply transceiver that enables bidirectional level
translation. The device can be used as two 2-bit transceivers or as a 4-bit transceiver. It
features two 2-bit input-output ports (nAn and nBn), a direction control input (nDIR), a
output enable input (nOE) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and
VCC(B) can be supplied at any voltage between 0.8 V and 3.6 V making the device suitable
for translating between any of the low voltage nodes (0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and
3.3 V). Pins nAn, nOE and nDIR are referenced to VCC(A) and pins nBn are referenced to
VCC(B). A HIGH on nDIR allows transmission from nAn to nBn and a LOW on nDIR allows
transmission from nBn to nAn. The output enable input (nOE) can be used to disable the
outputs so the buses are effectively isolated.
The device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing any damaging backflow current through the
device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at
GND level, both nAn and nBn outputs are in the high-impedance OFF-state. The bus hold
circuitry on the powered-up side always stays active.
The 74AVCH4T245 has active bus hold circuitry which is provided to hold unused or
floating data inputs at a valid logic level. This feature eliminates the need for external
pull-up or pull-down resistors.
2. Features and benefits
Wide supply voltage range:
VCC(A): 0.8 V to 3.6 V
VCC(B): 0.8 V to 3.6 V
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114E Class 3B exceeds 8000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101C exceeds 1000 V
Maximum data rates:
380 Mbit/s ( 1.8 V to 3.3 V translation)
74AVCH4T245
Nexperia
4-bit dual supply translating transceiver; 3-state
200 Mbit/s ( 1.1 V to 3.3 V translation)
200 Mbit/s ( 1.1 V to 2.5 V translation)
200 Mbit/s ( 1.1 V to 1.8 V translation)
150 Mbit/s ( 1.1 V to 1.5 V translation)
100 Mbit/s ( 1.1 V to 1.2 V translation)
Suspend mode
Bus hold on data inputs
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
3. Ordering information
Table 1.
Type number
Package
Temperature range Name
Description
Version
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74AVCH4T245PW 40 C to +125 C
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74AVCH4T245BQ 40 C to +125 C
DHVQFN16 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 16 terminals;
body 2.5 3.5 0.85 mm
SOT763-1
74AVCH4T245GU 40 C to +125 C
XQFN16
SOT1161-1
74AVCH4T245D
plastic, extremely thin quad flat package; no leads;
16 terminals; body 1.80 2.60 0.50 mm
4. Marking
Table 2.
Marking codes
Type number
Marking code
74AVCH4T245D
74AVCH4T245D
74AVCH4T245PW
CH4T245
74AVCH4T245BQ
H4T245
74AVCH4T245GU
K4
74AVCH4T245
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 29
74AVCH4T245
Nexperia
5. Functional diagram
13
12
1B1
VCC(A)
15
2
11
1B2
10
2B1
2B2
VCC(B)
1OE
2OE
1DIR
2DIR
1A1
1A2
2A1
14
3
2A2
001aak280
4
5
6
7
Pin numbers are shown for SO16, TSSOP16 and DHVQFN16 packages only.
Fig 1.
Logic symbol
DIR
OE
A1
B1
A2
B2
VCC(A)
VCC(B)
001aak281
Fig 2.
Logic diagram (one 2-bit transceiver)
74AVCH4T245
Product data sheet
3 of 29
74AVCH4T245
Nexperia
6. Pinning information
6.1 Pinning
74AVCH4T245
VCC(A)
1
16 VCC(B)
1DIR
2
15 1OE
2DIR
3
14 2OE
1A1
4
13 1B1
1A2
5
12 1B2
2A1
6
11 2B1
2A2
7
GND
8
74AVCH4T245
10 2B2
9
GND
VCC(A)
1
16 VCC(B)
1DIR
2
15 1OE
2DIR
3
14 2OE
1A1
4
13 1B1
1A2
5
12 1B2
2A1
6
11 2B1
2A2
7
10 2B2
GND
8
9
001aak287
001aak288
Fig 3.
GND
Pin configuration SOT109-1 (SO16)
Fig 4.
Pin configuration SOT403-1 (TSSOP16)
15 1OE
3
14 2OE
1A1
4
13 1B1
1A2
5
2A1
6
2A2
7
terminal 1
index area
12 1B2
GND(1)
1OE 1
8
9
GND
12 2B2
11 2B1
10 2B2
GND
13 2B1
2
2DIR
14 1B2
1DIR
15 1B1
74AVCH4T245
16 2OE
1
terminal 1
index area
16 VCC(B)
VCC(A)
74AVCH4T245
VCC(B) 2
11 GND
VCC(A) 3
10 GND
001aak289
9 2A2
1DIR 4
Fig 5.
Pin configuration SOT763-1 (DHVQFN16)
74AVCH4T245
Product data sheet
2A1 8
1A2 7
2DIR 5
(1) This is not a supply pin, the substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad
however if it is soldered the solder land should remain
floating or be connected to GND.
1A1 6
Transparent top view
001aan189
Fig 6.
Pin configuration SOT1161-1 (XQFN16)
4 of 29
74AVCH4T245
Nexperia
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
SOT109-1, SOT403-1
and SOT763-1
SOT1161-1
VCC(A)
1
3
supply voltage A (nAn, nOE and nDIR inputs are
referenced to VCC(A))
1DIR, 2DIR
2, 3
4, 5
direction control
1A1, 1A2
4, 5
6, 7
data input or output
2A1, 2A2
6, 7
8, 9
GND[1]
8, 9
10, 11
ground (0 V)
2B2, 2B1
10, 11
12, 13
1B2, 1B1
12, 13
14, 15
2OE, 1OE
14, 15
16, 1
output enable input (active LOW)
VCC(B)
16
2
supply voltage B (nBn inputs are referenced to VCC(B))
[1]
All GND pins must be connected to ground (0 V).
7. Functional description
Table 4.
Function table[1]
Input/output[3]
Supply voltage
Input
VCC(A), VCC(B)
nOE[2]
nDIR[2]
nAn[2]
nBn[2]
0.8 V to 3.6 V
L
L
nAn = nBn
input
0.8 V to 3.6 V
L
H
input
nBn = nAn
0.8 V to 3.6 V
H
X
Z
Z
GND[3]
X
X
Z
Z
[1]
H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state.
[2]
The nAn, nDIR and nOE input circuit is referenced to VCC(A); The nBn input circuit is referenced to VCC(B).
[3]
If at least one of VCC(A) or VCC(B) is at GND level, the device goes into suspend mode.
74AVCH4T245
Product data sheet
5 of 29
74AVCH4T245
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC(A)
supply voltage A
VCC(B)
supply voltage B
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
Max
Unit
0.5
+4.6
V
0.5
+4.6
V
50
mA
0.5
+4.6
V
mA
VI < 0 V
Min
[1]
50
[1][2][3]
0.5
VCCO + 0.5 V
Suspend or 3-state mode
[1]
0.5
+4.6
V
[2]
50
mA
100
mA
VO < 0 V
Active mode
IO
output current
VO = 0 V to VCCO
ICC
supply current
per VCC(A) or VCC(B) pin
IGND
ground current
per GND pin
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
Tamb = 40 C to +125 C
[4]
500
mW
XQFN16
[5]
250
mW
[1]
The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
VCCO is the supply voltage associated with the output port.
[3]
VCCO + 0.5 V should not exceed 4.6 V.
[4]
For SO16 package: above 70 C the value of Ptot derates linearly at 8 mW/K.
For TSSOP16 package: above 60 C the value of Ptot derates linearly at 5.5 mW/K.
For DHVQFN16 package: above 60 C the value of Ptot derates linearly at 4.5 mW/K.
[5]
For XQFN16 package: above 133 C the value of Ptot derates linearly with 14.5 mW/K.
9. Recommended operating conditions
Table 6.
Symbol
Parameter
Min
Max
Unit
VCC(A)
supply voltage A
Conditions
0.8
3.6
V
VCC(B)
supply voltage B
0.8
3.6
V
VI
input voltage
V
output voltage
VO
Active mode
[1]
Tamb
t/V
ambient temperature
input transition rise and fall rate
VCCI = 0.8 V to 3.6 V
[1]
[2]
VCCI is the supply voltage associated with the input port.
74AVCH4T245
Product data sheet
[2]
VCCO
V
V
40
+125
C
5
ns/V
6 of 29
74AVCH4T245
Nexperia
10. Static characteristics
Table 7.
Typical static characteristics at Tamb = 25 C[1][2]
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
VOH
HIGH-level output voltage
VI = VIH or VIL
VOL
LOW-level output voltage
VI = VIH or VIL
IO = 1.5 mA; VCC(A) = VCC(B) = 0.8 V
Min
Typ
Max
Unit
0.69
V
0.07
V
0.025 0.25 A
II
input leakage current
nDIR, nOE input; VI = 0 V or 3.6 V;
VCC(A) = VCC(B) = 0.8 V to 3.6 V
IBHL
bus hold LOW current
A or B port; VI = 0.42 V; VCC(A) = VCC(B) = 1.2 V
[3]
26
A
A or B port; VI = 0.78 V; VCC(A) = VCC(B) = 1.2 V
[4]
24
A
27
A
IBHH
bus hold HIGH current
IBHLO
bus hold LOW overdrive
current
A or B port; VCC(A) = VCC(B) = 1.2 V
[5]
IBHHO
bus hold HIGH overdrive
current
[6]
26
A
IOZ
OFF-state output current
A or B port; VO = 0 V or VCCO;
VCC(A) = VCC(B) = 3.6 V
[7]
0.5
2.5
A
suspend mode A port; VO = 0 V or VCCO;
VCC(A) = 3.6 V; VCC(B) = 0 V
[7]
0.5
2.5
A
suspend mode B port; VO = 0 V or VCCO;
VCC(A) = 0 V; VCC(B) = 3.6 V
[7]
0.5
2.5
A
A port; VI or VO = 0 V to 3.6 V;
VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V
0.1
1
A
B port; VI or VO = 0 V to 3.6 V;
VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V
0.1
1
A
IOFF
power-off leakage current
CI
input capacitance
nDIR, nOE input; VI = 0 V or 3.3 V;
VCC(A) = VCC(B) = 3.3 V
1.0
pF
CI/O
input/output capacitance
A and B port; VO = 3.3 V or 0 V;
4.0
pF
[1]
[2]
VCCI is the supply voltage associated with the data input port.
[3]
The bus hold circuit can sink at least the minimum low sustaining current at VIL max. IBHL should be measured after lowering VI to GND
and then raising it to VIL max.
[4]
The bus hold circuit can source at least the minimum high sustaining current at VIH min. IBHH should be measured after raising VI to VCC
and then lowering it to VIH min.
[5]
An external driver must source at least IBHLO to switch this node from LOW to HIGH.
[6]
An external driver must sink at least IBHHO to switch this node from HIGH to LOW.
[7]
For I/O ports, the parameter IOZ includes the input leakage current.
74AVCH4T245
Product data sheet
7 of 29
74AVCH4T245
Nexperia
Table 8.
Static characteristics [1][2]
Symbol Parameter
VIH
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
0.70VCCI
0.70VCCI
V
VCCI = 1.1 V to 1.95 V
0.65VCCI
0.65VCCI
V
VCCI = 2.3 V to 2.7 V
1.6
1.6
V
VCCI = 3.0 V to 3.6 V
2
2
V
VCC(A) = 0.8 V
0.70VCC(A)
0.70VCC(A)
V
VCC(A) = 1.1 V to 1.95 V
0.65VCC(A)
0.65VCC(A)
V
VCC(A) = 2.3 V to 2.7 V
1.6
1.6
V
VCC(A) = 3.0 V to 3.6 V
2
2
V
HIGH-level
data input
input voltage
VCCI = 0.8 V
nDIR, nOE input
VIL
LOW-level
data input
input voltage
VCCI = 0.8 V
0.30VCCI
0.30VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
0.8
0.8
V
VCC(A) = 0.8 V
0.30VCC(A)
0.30VCC(A) V
0.35VCC(A)
0.35VCC(A) V
0.7
0.7
V
0.8
0.8
V
VCCO 0.1
VCCO 0.1
V
IO = 3 mA;
VCC(A) = VCC(B) = 1.1 V
0.85
0.85
V
IO = 6 mA;
VCC(A) = VCC(B) = 1.4 V
1.05
1.05
V
IO = 8 mA;
VCC(A) = VCC(B) = 1.65 V
1.2
1.2
V
IO = 9 mA;
VCC(A) = VCC(B) = 2.3 V
1.75
1.75
V
IO = 12 mA;
VCC(A) = VCC(B) = 3.0 V
2.3
2.3
V
nDIR, nOE input
VOH
HIGH-level
output
voltage
74AVCH4T245
Product data sheet
VI = VIH or VIL
IO = 100 A;
8 of 29
74AVCH4T245
Nexperia
Table 8.
Static characteristics …continued[1][2]
Symbol Parameter
VOL
LOW-level
output
voltage
40 C to +85 C
Conditions
Max
Min
Max
IO = 100 A;
0.1
0.1
V
IO = 3 mA;
0.25
0.25
V
IO = 6 mA;
0.35
0.35
V
IO = 8 mA;
0.45
0.45
V
IO = 9 mA;
0.55
0.55
V
IO = 12 mA;
0.7
0.7
V
1
5
A
15
15
A
VI = 0.58 V;
25
25
A
VI = 0.70 V;
45
45
A
VI = 0.80 V;
100
90
A
15
15
A
VI = 1.07 V;
25
25
A
VI = 1.60 V;
45
45
A
VI = 2.00 V;
100
100
A
VCC(A) = VCC(B) = 1.6 V
125
125
A
VCC(A) = VCC(B) = 1.95 V
200
200
A
VCC(A) = VCC(B) = 2.7 V
300
300
A
500
500
A
125
125
A
200
200
A
300
300
A
500
500
A
VI = VIH or VIL
input leakage nDIR, nOE input; VI = 0 V or 3.6 V;
current
IBHL
bus hold
A or B port
LOW current
VI = 0.49 V;
IBHLO
bus hold
A or B port
HIGH current
VI = 0.91 V;
bus hold
LOW
overdrive
current
[3]
[4]
[5]
A or B port
IBHHO
bus hold
HIGH
overdrive
current
74AVCH4T245
Product data sheet
Unit
Min
II
IBHH
40 C to +125 C
[6]
A or B port
9 of 29
74AVCH4T245
Nexperia
Table 8.
Symbol Parameter
IOZ
IOFF
OFF-state
output
current
power-off
leakage
current
74AVCH4T245
Product data sheet
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
[7]
5
30
A
VO = 0 V or VCCO; VCC(A) = 3.6 V;
VCC(B) = 0 V
[7]
5
30
A
VO = 0 V or VCCO; VCC(A) = 0 V;
VCC(B) = 3.6 V
[7]
5
30
A
VCC(A) = 0 V;
5
30
A
VCC(B) = 0 V;
5
30
A
10 of 29
74AVCH4T245
Nexperia
Table 8.
Symbol Parameter
ICC
supply
current
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Max
Min
Max
VCC(A) = 0.8 V to 3.6 V;
10
55
A
VCC(A) = 1.1 V to 3.6 V;
VCC(B) = 1.1 V to 3.6 V
8
50
A
8
50
A
2
12
A
10
55
A
8
50
A
2
12
A
A port; VI = 0 V or VCCI; IO = 0 A
B port; VI = 0 V or VCCI; IO = 0 A
8
50
A
A plus B port (ICC(A) + ICC(B));
IO = 0 A; VI = 0 V or VCCI;
A
16
65
A
[1]
[2]
[3]
[4]
[5]
[6]
[7]
Table 9.
VCC(A)
Typical total supply current (ICC(A) + ICC(B))
VCC(B)
Unit
0V
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
0V
0.1
0.1
0.1
0.1
0.1
A
0.8 V
0.1
0.1
0.1
0.1
0.1
0.3
1.6
A
1.2 V
0.1
0.1
0.1
0.1
0.1
0.1
0.8
A
1.5 V
0.1
0.1
0.1
0.1
0.1
0.1
0.4
A
1.8 V
0.1
0.1
0.1
0.1
0.1
0.1
0.2
A
2.5 V
0.1
0.3
0.1
0.1
0.1
0.1
0.1
A
3.3 V
0.1
1.6
0.8
0.4
0.2
0.1
0.1
A
74AVCH4T245
Product data sheet
11 of 29
74AVCH4T245
Nexperia
11. Dynamic characteristics
Table 10. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 C [1][2]
Symbol Parameter
power dissipation
capacitance
CPD
[1]
Conditions
VCC(A) = VCC(B)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
A port: (direction nAn to
nBn); output enabled
0.2
0.2
0.2
0.2
0.3
0.4
pF
nBn); output disabled
0.2
0.2
0.2
0.2
0.3
0.4
pF
A port: (direction nBn to
nAn); output enabled
9.5
9.7
9.8
9.9
10.7
11.9
pF
nAn); output disabled
0.6
0.6
0.6
0.6
0.7
0.7
pF
B port: (direction nAn to
9.5
9.7
9.8
9.9
10.7
11.9
pF
0.6
0.6
0.6
0.6
0.7
0.7
pF
B port: (direction nBn to
0.2
0.2
0.2
0.2
0.3
0.4
pF
0.2
0.2
0.2
0.2
0.3
0.4
pF
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
[2]
fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = .
74AVCH4T245
Product data sheet
12 of 29
74AVCH4T245
Nexperia
Table 11. Typical dynamic characteristics at VCC(A) = 0.8 V and Tamb = 25 C [1]
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8
Symbol Parameter
tpd
VCC(B)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
propagation delay nAn to nBn
14.5
7.3
6.5
6.2
5.9
6.0
ns
nBn to nAn
14.5
12.7
12.4
12.3
12.1
12.0
ns
nOE to nAn
14.3
14.3
14.3
14.3
14.3
14.3
ns
tdis
disable time
ten
enable time
[1]
Conditions
nOE to nBn
17.0
9.9
9.0
9.4
9.0
9.7
ns
nOE to nAn
18.2
18.2
18.2
18.2
18.2
18.2
ns
nOE to nBn
19.2
10.7
9.8
9.6
9.7
10.2
ns
tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH.
Table 12. Typical dynamic characteristics at VCC(B) = 0.8 V and Tamb = 25 C [1]
Symbol Parameter
tpd
VCC(A)
Unit
0.8 V
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
14.5
12.7
12.4
12.3
12.1
12.0
ns
nBn to nAn
14.5
7.3
6.5
6.2
5.9
6.0
ns
nOE to nAn
14.3
5.5
4.1
4.0
3.0
3.5
ns
nOE to nBn
17.0
13.8
13.4
13.1
12.9
12.7
ns
nOE to nAn
18.2
5.6
4.0
3.2
2.4
2.2
ns
nOE to nBn
19.2
14.6
14.1
13.9
13.7
13.6
ns
tdis
disable time
ten
enable time
[1]
Conditions
74AVCH4T245
Product data sheet
13 of 29
74AVCH4T245
Nexperia
Table 13. Dynamic characteristics for temperature range 40 C to +85 C [1]
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9; for wave forms see Figure 7 and Figure 8.
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V 0.1 V
1.5 V 0.1 V 1.8 V 0.15 V 2.5 V 0.2 V
3.3 V 0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
0.5
9.4
0.5
7.1
0.5
6.2
0.5
5.2
0.5
5.1
ns
VCC(A) = 1.1 V to 1.3 V
tpd
propagation
delay
nAn to nBn
nBn to nAn
0.5
9.4
0.5
8.9
0.5
8.7
0.5
8.4
0.5
8.2
ns
tdis
disable time
nOE to nAn
1.8
10.9
1.8
10.9
1.8
10.9
1.8
10.9
1.8
10.9
ns
nOE to nBn
1.9
12.4
1.9
9.6
1.9
9.5
1.4
8.1
1.2
9.1
ns
nOE to nAn
1.4
12.8
1.4
12.8
1.4
12.8
1.4
12.8
1.4
12.8
ns
nOE to nBn
1.1
13.3
1.1
10.0
1.1
8.9
1.0
7.9
1.0
7.7
ns
propagation
delay
nAn to nBn
0.3
8.9
0.3
6.3
0.3
5.2
0.3
4.2
0.3
4.2
ns
nBn to nAn
0.7
7.1
0.7
6.3
0.5
6.0
0.4
5.7
0.3
5.6
ns
disable time
nOE to nAn
1.8
10.2
1.8
10.2
1.5
10.2
1.3
10.2
1.6
10.2
ns
nOE to nBn
1.9
11.3
1.9
10.3
1.9
9.1
1.4
7.4
1.2
7.6
ns
nOE to nAn
1.1
9.4
1.4
9.4
1.1
9.4
0.7
9.4
0.4
9.4
ns
nOE to nBn
1.4
12.1
1.4
9.6
1.1
7.7
0.9
5.8
0.9
5.6
ns
enable time
ten
VCC(A) = 1.4 V to 1.6 V
tpd
tdis
enable time
ten
VCC(A) = 1.65 V to 1.95 V
propagation
delay
nAn to nBn
0.1
8.7
0.1
6.0
0.1
4.9
0.1
3.9
0.3
3.9
ns
nBn to nAn
0.6
6.2
0.6
5.3
0.5
4.9
0.3
4.6
0.3
4.5
ns
tdis
disable time
nOE to nAn
1.8
8.6
1.6
8.6
1.8
8.6
1.3
8.6
1.6
8.6
ns
nOE to nBn
1.7
10.9
1.7
9.9
1.6
8.7
1.2
6.9
1.0
6.9
ns
ten
enable time
nOE to nAn
1.0
7.2
1.0
7.2
1.0
7.2
0.6
7.2
0.4
7.2
ns
nOE to nBn
1.2
11.7
1.2
9.2
1.0
7.4
0.8
5.3
0.8
4.6
ns
propagation
delay
nAn to nBn
0.1
8.4
0.1
5.7
0.1
4.6
0.2
3.5
0.1
3.6
ns
nBn to nAn
0.6
5.2
0.6
4.2
0.4
3.9
0.2
3.4
0.2
3.3
ns
disable time
nOE to nAn
1.0
6.2
1.0
6.2
1.0
6.2
1.0
6.2
1.0
6.2
ns
nOE to nBn
1.5
10.4
1.5
8.8
1.3
8.2
1.1
6.2
0.9
5.2
ns
tpd
tpd
tdis
enable time
ten
nOE to nAn
0.7
4.8
0.7
4.8
0.7
4.8
0.6
4.8
0.4
4.8
ns
nOE to nBn
0.9
11.3
0.9
8.8
0.8
7.0
0.6
4.8
0.6
4.0
ns
0.1
8.2
0.1
5.6
0.1
4.5
0.1
3.3
0.1
2.9
ns
tpd
propagation
delay
nAn to nBn
nBn to nAn
0.6
5.1
0.6
4.2
0.4
3.4
0.2
3.0
0.1
2.8
ns
tdis
disable time
nOE to nAn
0.7
5.6
0.7
5.6
0.7
5.6
0.7
5.6
0.7
5.6
ns
nOE to nBn
1.4
10.2
1.4
9.3
1.2
8.1
1.0
6.4
0.8
6.2
ns
nOE to nAn
0.6
3.8
0.6
3.8
0.6
3.8
0.6
3.8
0.4
3.8
ns
nOE to nBn
0.8
11.3
0.8
8.7
0.6
6.8
0.5
4.7
0.5
3.8
ns
enable time
ten
[1]
74AVCH4T245
Product data sheet
14 of 29
74AVCH4T245
Nexperia
Table 14. Dynamic characteristics for temperature range 40 C to +125 C [1]
Symbol Parameter
Conditions
VCC(B)
Unit
1.2 V 0.1 V
3.3 V 0.3 V
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
7.9
0.5
6.9
0.5
5.8
0.5
5.7
ns
tpd
propagation
delay
nAn to nBn
0.5
10.4
0.5
nBn to nAn
0.5
10.4
0.5
9.8
0.5
9.6
0.5
9.3
0.5
9.1
ns
tdis
disable time
nOE to nAn
1.8
12.0
1.8
12.0
1.8
12.0
1.8
12.0
1.8
12.0
ns
nOE to nBn
1.9
13.7
1.9
10.6
1.9
10.5
1.4
9.0
1.2
10.1
ns
nOE to nAn
1.4
14.1
1.4
14.1
1.4
14.1
1.4
14.1
1.4
14.1
ns
nOE to nBn
1.1
14.7
1.1
11.0
1.1
9.8
1.0
8.7
1.0
8.5
ns
propagation
delay
nAn to nBn
0.3
9.8
0.3
7.0
0.3
5.8
0.3
4.7
0.3
4.7
ns
nBn to nAn
0.7
7.9
0.7
7.0
0.5
6.6
0.4
6.3
0.3
6.2
ns
disable time
nOE to nAn
1.8
11.3
1.8
11.3
1.5
11.3
1.3
11.3
1.6
11.3
ns
nOE to nBn
1.9
12.5
1.9
11.4
1.9
10.1
1.4
8.2
1.2
8.4
ns
nOE to nAn
1.1
10.4
1.4
10.4
1.1
10.4
0.7
10.4
0.4
10.4
ns
nOE to nBn
1.4
13.3
1.4
10.6
1.1
8.5
0.9
6.4
0.9
6.2
ns
enable time
ten
tpd
tdis
enable time
ten
propagation
delay
nAn to nBn
0.1
9.6
0.1
6.6
0.1
5.4
0.1
4.3
0.3
4.3
ns
nBn to nAn
0.6
6.9
0.6
5.9
0.5
5.4
0.3
5.1
0.3
5.0
ns
tdis
disable time
nOE to nAn
1.8
9.5
1.6
9.5
1.8
9.5
1.3
9.5
1.6
9.5
ns
nOE to nBn
1.7
12.0
1.7
10.9
1.6
9.6
1.2
7.6
1.0
7.6
ns
ten
enable time
nOE to nAn
1.0
8.0
1.0
8.0
1.0
8.0
0.6
8.0
0.4
8.0
ns
nOE to nBn
1.2
12.9
1.2
10.2
1.0
8.2
0.8
5.9
0.8
5.1
ns
propagation
delay
nAn to nBn
0.1
9.3
0.1
6.3
0.1
5.1
0.2
4.0
0.1
4.0
ns
nBn to nAn
0.6
5.8
0.6
4.7
0.4
4.3
0.2
3.9
0.2
3.8
ns
disable time
nOE to nAn
1.0
6.9
1.0
6.9
1.0
6.9
1.0
6.9
1.0
6.9
ns
nOE to nBn
1.5
11.5
1.5
10.4
1.3
9.1
1.1
6.9
0.9
5.8
ns
nOE to nAn
0.7
5.3
0.7
5.3
0.7
5.3
0.6
5.3
0.4
5.3
ns
nOE to nBn
0.9
12.4
0.9
9.7
0.8
7.7
0.6
5.3
0.6
4.4
ns
tpd
tpd
tdis
enable time
ten
tpd
propagation
delay
nAn to nBn
0.1
9.1
0.1
6.2
0.1
5.0
0.1
3.8
0.1
3.3
ns
nBn to nAn
0.6
5.7
0.6
4.7
0.4
3.9
0.2
3.4
0.1
3.3
ns
tdis
disable time
nOE to nAn
0.7
6.2
0.7
6.2
0.7
6.2
0.7
6.2
0.7
6.2
ns
nOE to nBn
1.4
11.3
1.4
10.3
1.2
9.0
1.0
7.1
0.8
6.9
ns
nOE to nAn
0.6
4.2
0.6
4.2
0.6
4.2
0.6
4.2
0.4
4.2
ns
nOE to nBn
0.8
12.4
0.8
9.6
0.6
7.5
0.5
5.2
0.5
4.2
ns
enable time
ten
[1]
74AVCH4T245
Product data sheet
15 of 29
74AVCH4T245
Nexperia
12. Waveforms
VI
nAn, nBn input
VM
GND
tPHL
tPLH
VOH
VM
nBn, nAn output
VOL
001aak285
Measurement points are given in Table 15.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 7.
The data input (nAn, nBn) to output (nBn, nAn) propagation delay times
VI
VM
nOE input
GND
tPLZ
tPZL
VCCO
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
VOH
tPZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
enabled
outputs
disabled
001aak286
Fig 8.
Table 15.
Enable and disable times
Measurement points
Supply voltage
Input[1]
Output[2]
VCC(A), VCC(B)
VM
VM
VX
VY
0.8 V to 1.6 V
0.5VCCI
0.5VCCO
VOL + 0.1 V
VOH 0.1 V
1.65 V to 2.7 V
0.5VCCI
0.5VCCO
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5VCCI
0.5VCCO
VOL + 0.3 V
VOH 0.3 V
[1]
[2]
74AVCH4T245
Product data sheet
16 of 29
74AVCH4T245
Nexperia
tW
VI
90 %
negative
pulse
VM
VM
10 %
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
VM
VM
10 %
0V
tW
VEXT
VCC
VI
RL
VO
G
DUT
RT
RL
CL
001aae331
Test data is given in Table 16.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance.
VEXT = External voltage for measuring switching times.
Fig 9.
Table 16.
Test circuit for measuring switching times
Test data
Supply voltage
Input
VCC(A), VCC(B)
VI[1]
t/V[2]
Load
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ[3]
0.8 V to 1.6 V
VCCI
1.0 ns/V
15 pF
2 k
open
GND
2VCCO
1.65 V to 2.7 V
VCCI
1.0 ns/V
15 pF
2 k
open
GND
2VCCO
3.0 V to 3.6 V
VCCI
1.0 ns/V
15 pF
2 k
open
GND
2VCCO
[1]
[2]
dV/dt 1.0 V/ns
[3]
74AVCH4T245
Product data sheet
VEXT
17 of 29
74AVCH4T245
Nexperia
13. Typical propagation delay characteristics
001aai476
24
tpd
(ns)
(1)
(2)
(3)
(4)
(5)
(6)
tpd
(ns)
(1)
001aai477
21
17
16
12
13
(2)
(3)
(4)
(5)
(6)
8
4
9
60
60
CL (pF)
CL (pF)
a. Propagation delay (nAn to nBn); VCC(A) = 0.8 V
b. Propagation delay (nAn to nBn); VCC(B) = 0.8 V
(1) VCC(B) = 0.8 V.
(1) VCC(A) = 0.8 V.
(2) VCC(B) = 1.2 V.
(2) VCC(A) = 1.2 V.
(3) VCC(B) = 1.5 V.
(3) VCC(A) = 1.5 V.
(4) VCC(B) = 1.8 V.
(4) VCC(A) = 1.8 V.
(5) VCC(B) = 2.5 V.
(5) VCC(A) = 2.5 V.
(6) VCC(B) = 3.3 V.
(6) VCC(A) = 3.3 V.
Fig 10. Typical propagation delay versus load capacitance; Tamb = 25 C
74AVCH4T245
Product data sheet
18 of 29
74AVCH4T245
Nexperia
001aai478
7
001aai491
7
(1)
tPLH
(ns)
tPHL
(ns)
(2)
5
(1)
5
(3)
(2)
(3)
(4)
(4)
(5)
(5)
3
3
1
1
60
60
CL (pF)
CL (pF)
a. LOW to HIGH propagation delay (nAn to nBn);
VCC(A) = 1.2 V
b. HIGH to LOW propagation delay (nAn to nBn);
VCC(A) = 1.2 V
001aai479
7
001aai480
7
(1)
tPLH
(ns)
tPHL
(ns)
(1)
5
5
(2)
(3)
(2)
(3)
(4)
(5)
3
(4)
(5)
3
1
1
60
60
CL (pF)
CL (pF)
c. LOW to HIGH propagation delay (nAn to nBn);
VCC(A) = 1.5 V
d. HIGH to LOW propagation delay (nAn to nBn);
VCC(A) = 1.5 V
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
Fig 11. Typical propagation delay versus load capacitance; Tamb = 25 C
74AVCH4T245
Product data sheet
19 of 29
74AVCH4T245
Nexperia
001aai481
7
(1)
tPLH
(ns)
001aai482
7
tPHL
(ns)
5
(1)
5
(2)
(3)
(2)
(3)
(4)
3
(4)
(5)
3
(5)
1
1
60
60
CL (pF)
CL (pF)
VCC(A) = 1.8 V
VCC(A) = 1.8 V
001aai483
7
tPLH
(ns)
001aai486
7
tPHL
(ns)
(1)
5
(1)
5
(2)
(2)
(3)
(3)
(4)
3
3
(4)
(5)
(5)
1
1
60
60
CL (pF)
CL (pF)
VCC(A) = 2.5 V
VCC(A) = 2.5 V
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
Fig 12. Typical propagation delay versus load capacitance; Tamb = 25 C
74AVCH4T245
Product data sheet
20 of 29
74AVCH4T245
Nexperia
001aai485
7
tPLH
(ns)
001aai484
7
tPHL
(ns)
(1)
5
(1)
5
(2)
(2)
(3)
(3)
3
3
(4)
(4)
(5)
(5)
1
1
60
60
CL (pF)
CL (pF)
VCC(A) = 3.3 V
VCC(A) = 3.3 V
(1) VCC(B) = 1.2 V.
(2) VCC(B) = 1.5 V.
(3) VCC(B) = 1.8 V.
(4) VCC(B) = 2.5 V.
(5) VCC(B) = 3.3 V.
Fig 13. Typical propagation delay versus load capacitance; Tamb = 25 C
74AVCH4T245
Product data sheet
21 of 29
74AVCH4T245
Nexperia
14. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 14. Package outline SOT109-1 (SO16)
74AVCH4T245
Product data sheet
22 of 29
74AVCH4T245
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 15. Package outline SOT403-1 (TSSOP16)
74AVCH4T245
Product data sheet
23 of 29
74AVCH4T245
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
7
y
y1 C
v M C A B
w M C
b
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 16. Package outline SOT763-1 (DHVQFN16)
74AVCH4T245
Product data sheet
24 of 29
74AVCH4T245
Nexperia
XQFN16: plastic, extremely thin quad flat package; no leads;
16 terminals; body 1.80 x 2.60 x 0.50 mm
SOT1161-1
X
A
B
D
terminal 1
index area
A
E
A1
A3
detail X
e1
e
5
8
C
C A B
C
v
w
b
y1 C
y
L
4
9
e
e2
1
12
terminal 1
index area
16
L1
13
scale
Dimensions
Unit(1)
mm
max
nom
min
2 mm
A
A1
0.5
0.05
A3
b
0.25
0.127 0.20
0.15
0.00
D
E
1.9
1.8
1.7
2.7
2.6
2.5
e
e1
0.4
1.2
L
e2
1.2
L1
0.45 0.55
0.40 0.50
0.35 0.45
v
0.1
w
y
y1
0.05 0.05 0.05
Note
References
Outline
version
IEC
JEDEC
JEITA
SOT1161-1
sot1161-1_po
European
projection
Issue date
09-12-28
09-12-29
Fig 17. Package outline SOT1161-1 (XQFN16)
74AVCH4T245
Product data sheet
25 of 29
74AVCH4T245
Nexperia
15. Abbreviations
Table 17.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
16. Revision history
Table 18.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74AVCH4T245 v.5
20151217
Product data sheet
74AVCH4T245 v.4
Modifications:
74AVCH4T245 v.4
Modifications:
Table 5: conditions ICC and IGND changed (errata).
20111214
Product data sheet
74AVCH4T245 v.3
Legal pages updated.
74AVCH4T245 v.3
20110927
Product data sheet
74AVCH4T245 v.2
74AVCH4T245 v.2
20101203
Product data sheet
74AVCH4T245 v.1
74AVCH4T245 v.1
20090806
Product data sheet
74AVCH4T245
Product data sheet
26 of 29
74AVCH4T245
Nexperia
17. Legal information
17.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
17.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
17.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AVCH4T245
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
27 of 29
74AVCH4T245
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
17.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
18. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AVCH4T245
Product data sheet
28 of 29
Nexperia
74AVCH4T245
19. Contents
1
2
3
4
5
6
6.1
6.2
7
8
9
10
11
12
13
14
15
16
17
17.1
17.2
17.3
17.4
18
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . 12
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Typical propagation delay characteristics . . 18
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 22
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 26
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 26
Legal information. . . . . . . . . . . . . . . . . . . . . . . 27
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 27
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 28
Contact information. . . . . . . . . . . . . . . . . . . . . 28
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
Date of release: 17 December 2015
