74LVC374A-Q100
Octal D-type flip-flop with 5 V tolerant inputs/outputs; positive
edge-trigger; 3-state
Rev. 1 — 22 November 2012
Product data sheet
1. General description
The 74LVC374A-Q100 is an octal D-type flip-flop featuring separate D-type inputs for
each flip-flop and 3-state outputs for bus-oriented applications. A clock input (CP) and an
outputs enable input (OE) are common to all flip-flops.
The eight flip-flops store the state of their individual D-inputs that meet the set-up and hold
times requirements on the LOW to HIGH CP transition.
When pin OE is LOW, the contents of the eight flip-flops is available at the outputs. When
pin OE is HIGH, the outputs go to the high-impedance OFF-state. Operation of the OE
input does not affect the state of the flip-flops.
Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be
applied to the outputs. These features allow the use of these devices as translators in
mixed 3.3 V and 5 V applications.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
5 V tolerant inputs/outputs; for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
High-impedance when VCC = 0 V
8-bit positive edge-triggered register
Independent register and 3-state buffer operation
Complies with JEDEC standard:
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A (2.3 V to 2.7 V)
JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
74LVC374A-Q100
Nexperia
Octal D-type flip-flop; 5 V tolerance; positive edge-trigger; 3-state
3. Ordering information
Table 1.
Type number
Package
74LVC374AD-Q100
Temperature range
Name
Description
Version
40 C to +125 C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
TSSOP20
plastic thin shrink small outline package;
20 leads; body width 4.4 mm
SOT360-1
74LVC374APW-Q100 40 C to +125 C
40 C to +125 C
74LVC374ABQ-Q100
DHVQFN20 plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads;
20 terminals; body 2.5 4.5 0.85 mm
SOT764-1
4. Functional diagram
1
11
EN
C1
11
3
4
7
8
13
14
17
18
3
CP
D0
Q0
D1
Q1
D2
Q2
D3
Q3
D4
Q4
D5
Q5
D6
Q6
D7
Q7
2
4
5
6
7
6
9
8
9
12
13
12
14
15
17
16
18
19
5
15
16
19
OE
1
Fig 1.
Logic symbol
74LVC374A_Q100
Product data sheet
2
1D
mna196
mna891
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 18
74LVC374A-Q100
Nexperia
3
D0
Q0
2
4
D1
Q1
5
7
D2
Q2
6
8
D3
Q3
9
13
D4
14
D5
Q5 15
17
D6
Q6 16
18
D7
Q7 19
FF1
to
FF8
3-STATE
OUTPUTS
Q4 12
11 CP
1 OE
mna892
Fig 3.
Functional diagram
D0
D1
D
Q
D2
D
CP
Q
D
CP
FF1
D3
Q
D
CP
FF2
D4
Q
D
CP
FF3
D5
Q
D
CP
FF4
D6
Q
D
CP
FF5
D7
Q
D
CP
FF6
Q
CP
FF7
FF8
CP
OE
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
mna893
Fig 4.
Logic diagram
74LVC374A_Q100
Product data sheet
3 of 18
74LVC374A-Q100
Nexperia
5. Pinning information
5.1 Pinning
2(
WHUPLQDO
LQGH[DUHD
/9&$4
2(
4
9&&
4
9&&
/9&$4
4
4
4
4
4
4
4
4
4
4
4
4
*1'
&3
*1'
4
&3
*1'
4
DDD
7UDQVSDUHQWWRSYLHZ
DDD
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 5.
Pin configuration SO20 and TSSOP20
Fig 6.
Pin configuration DHVQFN20
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1
OE
output enable input (active LOW)
11
CP
clock input (LOW to HIGH, edge-triggered)
D[0:7]
3, 4, 7, 8, 13, 14, 17, 18
data input
Q[0:7]
2, 5, 6, 9, 12, 15, 16, 19
3-state flip-flop output
10
GND
ground (0 V)
VCC
supply voltage
74LVC374A_Q100
Product data sheet
4 of 18
74LVC374A-Q100
Nexperia
6. Functional description
Table 3.
Function table[1]
Operating mode
Load and read register
Load register and disable
outputs
[1]
Input
Internal flip-flop Output
OE
CP
Dn
Qn
L
l
L
L
L
h
H
H
H
l
L
Z
H
h
H
Z
H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW to HIGH CP transition
L = LOW voltage level
l = LOW voltage level one set-up time prior to the LOW to HIGH CP transition
Z = high-impedance OFF-state
= LOW to HIGH clock transition
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
Min
VI < 0
[1]
Max
Unit
0.5
+6.5
V
50
mA
0.5
+6.5
V
mA
50
output HIGH or LOW state
[2]
0.5
VCC + 0.5
V
output 3-state
[2]
0.5
+6.5
V
50
mA
100
mA
VO > VCC or VO < 0
IO
output current
ICC
supply current
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
500
mW
total power dissipation
Ptot
[1]
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
[2]
The output voltage ratings may be exceeded if the output current ratings are observed.
[3]
For SO20 packages: above 70 C derate linearly with 8 mW/K.
For TSSOP20 packages: above 60 C derate linearly with 5.5 mW/K.
For DHVQFN20 packages: above 60 C derate linearly with 4.5 mW/K.
74LVC374A_Q100
Product data sheet
5 of 18
74LVC374A-Q100
Nexperia
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
Conditions
VI
input voltage
VO
output voltage
Min
Typ
Max
Unit
1.65
3.6
V
functional
1.2
V
V
VCC
V
output 3-state
V
40
+125
C
Tamb
ambient temperature
in free air
t/V
input transition rise and fall rate
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
VIH
VIL
VOH
VOL
II
HIGH-level
input voltage
LOW-level
input voltage
HIGH-level
output
voltage
LOW-level
output
voltage
VCC = 1.2 V
Product data sheet
40 C to +125 C
Max
Min
Max
Unit
1.08
1.08
V
0.65 VCC
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
0.12
V
VCC = 1.65 V to 1.95 V
VCC = 1.2 V
0.12
0.35 VCC
0.7
0.7
V
0.8
0.8
V
VCC 0.2
VCC 0.3
V
IO = 4 mA; VCC = 1.65 V
1.2
1.05
V
IO = 8 mA; VCC = 2.3 V
1.8
1.65
V
IO = 12 mA; VCC = 2.7 V
2.2
2.05
V
IO = 18 mA; VCC = 3.0 V
2.4
2.25
V
IO = 24 mA; VCC = 3.0 V
2.2
2.0
V
IO = 100 A;
VCC = 1.65 V to 3.6 V
0.2
0.3
V
0.45
0.65
V
0.6
0.8
V
0.4
0.6
V
0.55
0.8
V
0.1
5
A
0.35 VCC V
VI = VIH or VIL
IO = 100 A;
VI = VIH or VIL
input leakage VCC = 3.6 V; VI = 5.5 V or GND
current
74LVC374A_Q100
Typ[1]
6 of 18
74LVC374A-Q100
Nexperia
Table 6.
Static characteristics …continued
Symbol Parameter
40 C to +85 C
Conditions
40 C to +125 C
Min
Typ[1]
Max
Min
Max
Unit
IOZ
OFF-state
output
current
VI = VIH or VIL; VCC = 3.6 V;
VO = 5.5 V or GND;
0.1
5
A
IOFF
power-off
leakage
supply
VCC = 0 V; VI or VO = 5.5 V
0.1
10
A
ICC
supply
current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
A
ICC
additional
supply
current
per input pin; VCC = 2.7 V to 3.6
V; VI = VCC 0.6 V; IO = 0 A
5
500
5000
A
CI
input
capacitance
VCC = 0 V to 3.6 V;
VI = GND to VCC
4.0
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10.
Symbol Parameter
tpd
propagation
delay
40 C to +85 C
Conditions
enable time
CP to Qn; see Figure 7
VCC = 1.2 V
disable time
Product data sheet
Min
Max
16
ns
2.2
7.4
16.3
2.2
18.8
ns
1.5
3.9
8.4
1.5
9.7
ns
VCC = 2.7 V
1.5
3.5
8.0
1.5
10.0
ns
1.5
3.3
7.0
1.5
9.0
ns
19
ns
1.5
6.6
16.7
1.5
19.3
ns
1.5
3.7
9.3
1.5
10.8
ns
VCC = 2.7 V
1.5
3.8
8.5
1.5
11.0
ns
VCC = 3.0 V to 3.6 V
1.5
3.0
7.5
1.5
9.5
ns
8.0
ns
[2]
OE to Qn; see Figure 8
[2]
VCC = 1.2 V
74LVC374A_Q100
Max
VCC = 1.2 V
tdis
Typ[1]
[2]
ten
40 C to +125 C Unit
Min
2.3
4.0
10.1
2.3
11.7
ns
1.0
2.2
5.7
1.0
6.7
ns
VCC = 2.7 V
1.5
3.1
6.5
1.5
9.0
ns
1.5
2.9
6.0
1.5
7.5
ns
7 of 18
74LVC374A-Q100
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
40 C to +85 C
Conditions
Min
tW
pulse width
set-up time
tsu
hold time
th
maximum
frequency
fmax
Typ[1]
Max
40 C to +125 C Unit
Min
Max
clock HIGH or LOW; see Figure 7
5.0
5.0
ns
4.0
4.0
ns
VCC = 2.7 V
3.0
4.5
ns
3.0
1.5
4.5
ns
4.0
4.0
ns
3.0
3.0
ns
VCC = 2.7 V
2.0
2.0
ns
2.0
ns
3.0
3.0
ns
2.0
2.0
ns
VCC = 2.7 V
1.5
1.5
ns
1.5
0.6
1.5
ns
100
64
MHz
125
100
MHz
VCC = 2.7 V
150
120
MHz
150
120
MHz
1.0
1.5
ns
11.6
pF
13.6
pF
15.4
pF
Dn to CP; see Figure 9
see Figure 7
tsk(o)
output skew
time
[3]
CPD
power
dissipation
capacitance
per flip-flop; VI = GND to VCC
[4]
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively.
[2]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[3]
[4]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs
74LVC374A_Q100
Product data sheet
8 of 18
74LVC374A-Q100
Nexperia
11. Waveforms
1/f max
VI
CP input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
VOL
mna894
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 7.
Clock input to output propagation delays, pulse width, output transition times, and the maximum
frequency
VI
OE input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
VOH
tPZH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
mna644
Fig 8.
3-state enable and disable times
74LVC374A_Q100
Product data sheet
9 of 18
74LVC374A-Q100
Nexperia
VI
VM
CP input
GND
tsu
tsu
th
th
VI
VM
Dn input
GND
VOH
VM
Qn output
VOL
mna202
The shaded areas indicate when the input is permitted to change for predicable output performance.
Fig 9.
Table 8.
Data set-up and hold times for the Dn input to the CP input
Measurement points
Supply voltage
Input
VCC
VI
VM
VM
VX
VY
1.2 V
VCC
0.5 VCC
0.5 VCC
VOL + 0.15 V
VOH 0.15 V
1.65 V to 1.95 V
VCC
0.5 VCC
0.5 VCC
VOL + 0.15 V
VOH 0.15 V
2.3 V to 2.7 V
VCC
0.5 VCC
0.5 VCC
VOL + 0.15 V
VOH 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH 0.3 V
74LVC374A_Q100
Product data sheet
Output
10 of 18
74LVC374A-Q100
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
VI
RL
VO
G
DUT
RT
RL
CL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 10. Load circuitry for switching times
Table 9.
Test data
Supply voltage
Input
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
open
2 VCC
GND
2.7 V
2.7 V
2.5 ns
50 pF
500
open
2 VCC
GND
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
open
2 VCC
GND
74LVC374A_Q100
Product data sheet
Load
VEXT
11 of 18
74LVC374A-Q100
Nexperia
12. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
HE
y
v M A
Z
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
10
1
e
bp
detail X
w M
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
inches
0.1
0.012 0.096
0.004 0.089
0.043
0.039
0.01
0.01
Z
(1)
0.9
0.4
0.035
0.004
0.016
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 11. Package outline SOT163-1 (SO20)
74LVC374A_Q100
Product data sheet
12 of 18
74LVC374A-Q100
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
SOT360-1
E
D
A
X
c
HE
y
v M A
Z
11
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
10
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 12. Package outline SOT360-1 (TSSOP20)
74LVC374A_Q100
Product data sheet
13 of 18
74LVC374A-Q100
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT764-1
20 terminals; body 2.5 x 4.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
9
y
y1 C
v M C A B
w M C
b
L
1
10
Eh
e
19
12
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
4.6
4.4
3.15
2.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
3.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT764-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 13. Package outline SOT764-1 (DHVQFN20)
74LVC374A_Q100
Product data sheet
14 of 18
74LVC374A-Q100
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
MIL
Military
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC374A_Q100 v.1
20121122
Product data sheet
74LVC374A_Q100
Product data sheet
15 of 18
74LVC374A-Q100
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74LVC374A_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
16 of 18
74LVC374A-Q100
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC374A_Q100
Product data sheet
17 of 18
74LVC374A-Q100
Nexperia
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 5
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 6
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15
Legal information. . . . . . . . . . . . . . . . . . . . . . . 16
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Contact information. . . . . . . . . . . . . . . . . . . . . 17
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Date of release: 22 November 2012
