B0540WS
Schottky Barrier Diode
2
Features
Low Forward Voltage Drop
Guard Ring Construction for Transient Protection
High Conductance
Also Available in Lead Free Version
1.Cathode
2.Anode
1
■ Simplified outline(SOD-323)
Absolute Maximum Ratings Ta = 25
Parameter
Symbo
Value
Unit
40
V
VR(RMS)
28
V
Peak repetitive peak reverse voltage
VRRM
Working peak reverse voltage
VRWM
DC blocking voltage
VR
RMS reverse voltage reverse voltage (DC)
Average rectified output current
Io
0.5
A
Non-repetitive Peak Forward Surge Current
@t=8.3ms
IFSM
5.5
A
Power dissipation
PD
200
mW
Thermal resistance junction to ambient
℃/W
RθJA
500
Junction temperature
Tj
125
Storage temperature
TSTG
-55~+150
Voltage rate of change
dv/dt
1000
V/μs
Electrical Characteristics Ta = 25
Symbol
Reverse breakdown voltage
V(BR)
Reverse current
IR
Forward voltage
VF
Capacitance between terminals
CT
www.slkormicro.com
Test conditions
IR=20uA
Min
Max
40
V
VR =20V
10
VR =40V
IF=0.5A
0.51
IF =1.0A
0.62
VR=0,f=1MHz
170
1
Unit
uA
V
pF
B0540WS
Forward
Reverse
Characteristics
Characteristics
3000
1000
Ta=100 ℃
FORWARD CURRENT
(uA)
00
=1
Ta
5℃
=2
Ta
REVERSE CURRENT IR
100
IF
(mA)
1000
10
1
0.1
100
10
Ta=25 ℃
1
400
FORWARD VOLTAGE
600
VF
0.1
800
(mV)
REVERSE VOLTAGE
VR
40
(V)
Power Derating Curve
Capacitance Characteristics
120
300
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
f=1MHz
(mW)
100
POWER DISSIPATION
PD
80
60
40
200
100
10
15
REVERSE VOLTAGE
www.slkormicro.com
VR
25
50
AMBIENT TEMPERATURE
(V)
2
75
100
Ta
125
B0540WS
■ SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
mil
■ The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.slkormicro.com
3
8
很抱歉,暂时无法提供与“B0540WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08163
- 100+0.07619
- 300+0.07074
- 500+0.06530
- 2000+0.06258
- 5000+0.06095
