FM43X224K251EFG
FM43X224K251EFG
    PSA(信昌电陶)
    贴片电容(MLCC) 1812 220nF ±10% 250V X7R
FM43X224K251EFG 数据手册
信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Tel.:886-3-3224471 Fax:886-3-3212216 Messrs.: : 一般共用 Date: : APPROVAL SHEET Product Name : Medium Voltage Multilayer Ceramic Chip Capacitors Part No. : Description : Size 0402~2225, C0G/X7R/Y5V, 100Vdc to 630Vdc FM Series PREPARED BY APPROVED BY 信昌電子陶瓷股份有限公司 PROSPERITY DIELECTRICS CO., LTD. 桃園縣蘆竹鄉南山路二段 220-1 號 Tel: 03-322-4471 ext: Contactor: http://www.pdc.com.tw Fax: 03-322-5231 / 03-321-2215 Mobile: 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Tel.:886-3-3224471 Fax:886-3-3212216 SPECIFICATION FOR Product Name : Medium Voltage Multilayer Ceramic Chip Capacitors Part No. : Description : Size 0402~2225, C0G/X7R/Y5V, 100Vdc to 630Vdc FM Series SPEC. No. :FM-000-001-07 DATE : DRAWN BY CHECEKED BY APPROVED BY Yvens Chou Yvens Chou Ryan Chen 1. INTRODUCTION FM Series green type capacitors are manufactured by using green materials without lead and cadmium. These capacitors feature series connection of multi-layer capacitor units in a MLCC to realize high voltage performance. Reliable performances are built-in through exact formulation of dielectric powders, preparation of conductive paste, advanced automatic manufacturing, and strict quality control to assure excellent control in dielectric thickness, electrode integrity, and electrode-to-termination continuity. 2. FEATURES 3. APPLICATIONS a. High Voltage in a given case size. b. High reliability and stability. c. RoHS & HALOGEN Compliant. a. b. c. d. DC to DC converter. High voltage coupling/DC blocking. Back-lighting inverters. Snubbers in high frequency power convertors. 4. HOW TO ORDER FM PDC Family Table 1 31 X Size 471 K 251 Rated Voltage Table 6 Dielectric Capacitance Tolerance Table 2 Table 3 Table 4 Table 5 P X Packaging Thickness Table 7 Table 8 Table 6 G Control Code Table 9 Table 1 PDC Family Code Description Code Description Code Description Code Description FM 100V≤Rated Voltage≤630V series 101 100VDC 251 250VDC 501 500VDC 201 200VDC 401 400VDC 631 630VDC Table 2 Size Code Description Code Description Code Description 15 18 21 0402 (1005) 0603 (1608) 0805 (2012) 32 42 43 1210 (3225) 1808 (4520) 1812 (4532) 52 55 56 2211 (5728) 2220 (5750) 2225 (5763) 31 1206 (3216) 46 1825 (4563) Table 3 Table 7 Dielectric Material Characteristics Code Description Code Description N B C0G X5R X F X7R Y5V Table 4 Rated Voltage Capacitance Rule Code Packaging Type Code Description Code Description B E K L Bulk T P D G Tray package Tape and 7” Reel, Embossed Tape Tape and 10” Reel, Embossed Tape Tape and 13” Reel, Embossed Tape Table 8 Tape and 7” Reel, Paper Tape Tape and 10” Reel, Paper Tape Tape and 13” Reel, Paper Tape Thickness Description Code Description Code Description Code Description Code Description Code Description R47 0R5 100 0.47pF 0.5pF 100=10x100=10pF 102 104 106 102=10x102=1000pF 104=10x104=100nF 106=10x106=10µF A B C 0.60 ± 0.10 mm 1.25 ± 0.20 mm 1.25 ± 0.10 mm 0.50 ± 0.20 mm Q R S 0.50 +0.02/-0.05 mm 0.8 + 0.15/-0.10 mm I J K D 1.40 ± 0.15 mm L 0.30 ± 0.03 mm T 0.85 ± 0.10 mm E F G H 1.60 ± 0.20 mm M N O P 0.95 ± 0.10 mm U V X Z 0.50 ± 0.10 mm Table 5 Tolerance Code Description Code Description Code Description A B ±0.05 pF ±0.10 pF I J -10% ~ 0% ±5 % Q Z ±0.03 pF -20% ~ +80% C ±0.25 pF K ±10 % X +10%~+20% D F G H ±0.50 pF ±1 % ±2 % ±3 % L M N P 0% ~ +10% ±20 % -5% ~ +10% ±0.02 pF 2.00 ± 0.20 mm 2.50 ± 0.30 mm 2.80 ± 0.30 mm Table 9 1.15 ± 0.15 mm 0.50 ± 0.05 mm 3.50 ± 0.20 mm 1.60 +0.3/-0.10 mm Special Control Code Code Description G Q RoHS Compliant Surface Coating (Size 1206~2225) Prosperity Dielectrics Co., Ltd. http://www.pdc.com.tw No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. SPEC. No.: :FM-000-001-07 Page 1 of 18 3.10 ± 0.30 mm 0.80 ± 0.07 mm 0.20 ± 0.02 mm 0.80 ± 0.10 mm 0.25 ± 0.03 mm 5. EXTERNAL DIMENSIONS Size Inch (mm) L (mm) W (mm) Code / T (mm) MB (mm) 0402(1005) 1.00±0.10 0.50±0.10 0.25 +0.05/-0.10 0603(1608) 1.60±0.15 0.80±0.15 0.40±0.15 0805(2012) 2.00±0.20 1.25±0.20 0.50±0.20 1206(3216) 3.20±0.20 1.60±0.20 0.60±0.20 1210(3225) 3.20±0.30 2.50±0.30 1808(4520) 4.50±0.40 2.00±0.25 1812(4532) 4.50±0.40 3.20±0.30 0.75±0.35 1825(4563) 4.50±0.40 6.30±0.40 0.75±0.35 2220(5750) 5.70±0.40 5.00±0.40 0.85±0.35 2225(5763) 5.70±0.40 6.30±0.40 0.85±0.35 L T See No.4 Reference Table 8 0.75±0.35 W 0.75±0.35 MB MB Fig.5-1 The outline of MLCC 6. GENERAL ELECTRICAL DATA Dielectric C0G X7R Y5V Size 0402, 0603, 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225 0402, 0603, 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225 0805, 1206, 1210, 1812 Rated voltage (WVDC) 100V, 200V, 250V, 500V, 630V 100V, 200V, 250V, 500V, 630V 100V, 200V, 250V 0.5pF ~ 220nF 100pF ~ 820nF 10nF to 680nF Reference to Table5 Reference to Table5 Reference to Table5 ≤2.5% ≤5.0% Capacitance range Capacitance tolerance Tan δ Cap. Rang Q Spec. Cap.1000pF 1.0±0.2Vrms, 1.0KHz±10% Insulation resistance at Ur Operating temperature Capacitance characteristic ≥100GΩ or RxC≥500Ω-F, whichever is smaller ≥10GΩ or RxC≥100Ω-F, whichever is smaller -55 to +125°C ±30ppm/°C Termination -25 to +85°C ±15% Cu (or Ag)/Ni/Sn (lead-free termination) Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 1.0±0.2Vrms, 1.0KHz±10%, at 20°C ambient temperature 2 of 18 http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 +30/-80% 7. CAPACITANCE RANGE 7-1. C0G Dimension Cap(pF) code 0.5 0R5 1.0 1R0 1.2 1R2 1.5 1R5 1.8 1R8 2.2 2R2 2.7 2R7 3.3 3R3 3.9 3R9 4.7 4R7 5.6 5R6 6.8 6R8 8.2 8R2 10 100 12 120 15 150 18 180 22 220 27 270 33 330 39 390 47 470 56 560 68 680 82 820 100 101 120 121 150 151 180 181 220 221 270 271 330 331 390 391 470 471 560 561 680 681 820 821 1000 102 1200 122 1500 152 1800 182 2200 222 2700 272 3300 332 3900 392 4700 472 5600 562 6800 682 8200 822 10000 103 12000 123 15000 153 18000 183 22000 223 27000 273 33000 333 100V N N N N N N N N N N N N N N N N N N N N N N N N N N N N N N 0402 200V N N N N N N N N N N N N N N N N N N N N N N N N N N 250V N N N N N N N N N N N N N N N N N N N N N N N 100V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B 0603 200V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B 250V S S S S S S S S S S S S S S S S S S S S S S S S S S S S S S B B B B B B B 100V A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A X X X X X X X X X X C C C C C C 200V A A A A A A A A A A A A A A A A A A A A A A A A A A A X X C C C C C C C C C C C C C C C 0805 250V A A A A A A A A A A A A A A A A A A A A A A A A A X X X C C C C C C C C C C C C C C C C 500V A A A A A A A A A A A A A A A A A A A A A A A A X X C C C C C C C C C C C C C C C C 630V A A A A A A A A A A A A A A A A A A A A A A A A X X C C C C C C C C C C C C C C C C 100V X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X M C C P P P P 200V 1206 250V X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X M M M M M M C C C C C E E E E E E X X X X X X X X X X X X X X X X X X X X X X X X X X X M M M M C C E E E E E E E E E E E E E E T Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 3 of 18 http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 500V 630V X X X X X X X X X X X X X X X X X X X X X X X X X X X X M M M M C C E E E E E E E E E E E E X X X X X X X X X X X X X X X X X X X X X X X X X X X M M M M C C E E E E E E E E E E E 7. CAPACITANCE RANGE(Con.) 7-1. C0G Dimension Cap(pF) code 2.2 2R2 2.7 2R7 3.3 3R3 3.9 3R9 4.7 4R7 5.6 5R6 6.8 6R8 8.2 8R2 10 100 12 120 15 150 18 180 22 220 27 270 33 330 39 390 47 470 56 560 68 680 82 820 100 101 120 121 150 151 180 181 220 221 270 271 330 331 390 391 470 471 560 561 680 681 820 821 1000 102 1200 122 1500 152 1800 182 2200 222 2700 272 3300 332 3900 392 4700 472 5600 562 6800 682 8200 822 10000 103 12000 123 15000 153 18000 183 22000 223 27000 273 33000 333 39000 393 47000 473 56000 563 68000 683 82000 823 100000 104 100V 200V 1210 250V M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M M C C E E E E F G G G G G G M M M M M M M M M M M M M M M M M M M M M M M M C C C C C C C C C C E E F F G G G G G M M M M M M M M M M M M M M M M M M M M M M M M C C C C C C C C C C E E F F G G G G G 500V 630V M M M M M M M M M M M M M M M M M M M M M M M M C C C C C C C C C C E E F F G G M M M M M M M M M M M M M M M M M M M M M M M M C C C C C C C C C C E E F F G 100V C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F F F F 200V C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F F F F Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 4 of 18 1808 250V C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F F F F 500V C C C C C C C C C C C C C C C C C C C C C C C C C F F F F F F F F F F F F F F F F F F F F F 630V C C C C C C C C C C C C C C C C C C C C C C C C C F F F F F F F F F F F F F F F F F F F F 100V 200V 1812 250V C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F G G G G G G C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F G G G G G C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F G G G G G http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 500V 630V C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F G G G C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E F F G G 7. CAPACITANCE RANGE(Con.) 7-1. C0G Dimension Cap(pF) code 10 100 12 120 15 150 18 180 22 220 27 270 33 330 39 390 47 470 56 560 68 680 82 820 100 101 120 121 150 151 180 181 220 221 270 271 330 331 390 391 470 471 560 561 680 681 820 821 1000 102 1200 122 1500 152 1800 182 2200 222 2700 272 3300 332 3900 392 4700 472 5600 562 6800 682 8200 822 10000 103 12000 123 15000 153 18000 183 22000 223 27000 273 33000 333 39000 393 47000 473 56000 563 68000 683 82000 823 100000 104 120000 124 150000 154 180000 184 220000 224 100V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G 200V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G 1825 250V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G 500V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G 630V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G 100V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G 200V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 5 of 18 2220 250V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G 500V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G 630V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G 100V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G 200V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G G 2225 250V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G G G http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 500V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G G 630V E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E F F G G G 7. CAPACITANCE RANGE(Con.) 7-2. X7R Dimension 0402 0603 0805 1206 Cap(pF) code 100V 100V 200V 250V 100V 200V 250V 500V 630V 100V 200V 250V 500V 630V 100 101 N S B B X X X X X X C C C C 120 150 121 151 N N S S B B B B X X X X X X X X X X X X C C C C C C C C 180 181 N S B B X X X X X X C C C C 220 221 N S B B X X X X X X C C C C 270 271 N S B B X X X X X X C C C C 330 331 N S B B X X X X X X C C C C 390 470 391 471 N N S S B B B B X X X X X X X X X X X X C C C C C C C C 560 561 N S B B X X X X X X C C C C 680 681 N S B B X X X X X X C C C C 820 821 N S B B X X X X X X C C C C 1000 102 N S B B X X X X X X C C C C 1200 1500 122 152 N N S S B B B B X X X X X X X X X X X X C C C C C C C C 1800 182 N S B B X X X X X X C C C C 2200 222 N S B B X X X X X X C C C C 2700 272 N S B B X X X X X X C C C C 3300 332 N S B B X X X X X X C C C C 3900 4700 392 472 N N S S B B B B X X X X X X X C X C X X C C C C C C C C 5600 562 S B B X X X C C X C C C C 6800 682 S B B X X X C C X C C C C 8200 822 S B B X C C C C X C C C C 10000 103 S B B X C C C C X C C C C 12000 15000 123 153 B B B B B B X X C C C C C C C C X X C C C C C C C C 18000 183 B X C C C C X C C C C 22000 223 B X C C C C X C C E E 27000 273 B C C C X C C E E 33000 333 B C C C X E E E E 39000 47000 393 473 B B C C C C C C X X E E E E E E E E 56000 563 B C C C X E E E E 68000 683 B C C C X E E 82000 823 B C C C E E 100000 104 B C C C E E 120000 150000 124 154 C C C E 180000 184 C E 220000 224 C E 270000 274 C E 330000 334 C E 390000 470000 394 474 C I E E 560000 564 P 680000 684 P 820000 824 P Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 6 of 18 http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 7. CAPACITANCE RANGE(Con.) 7-2. X7R Dimension 1210 100V 200V 250V 1808 Cap(pF) code 500V 100 101 120 121 150 180 151 181 220 221 M M M C 270 271 M M M C 330 331 M M M 390 391 M M 470 560 471 561 M M 680 681 820 821 1000 630V 1812 500V 630V 100V 200V 250V 500V 630V C C C C C C C C C C C C C C C C C C C C C C C M C C C C C C C C C M M M M C C C C C C C C C C C C C C C C C C C M M M M M M C C C C C C C C C C C C C C C C C 102 M M C M C C C C C C C C 1200 122 M C M M C C C C C C C C 1500 1800 152 182 C M M M M M M C C C C C C C C C C C C C C C C C C 2200 2700 222 M M M C C C C C C C C C 272 M M M C C C C C C C C C 3300 332 M M M C C C C C C C C C 3900 392 M M M C C C C C C C C C 4700 5600 472 562 M M M M M M C C C C C F C F C C C C C C C C C C 6800 682 M M M C C F F C C C C C 8200 822 M M M C C F F C C C C C 10000 103 M M M C C F F C C C C C 12000 123 M M M C C F F C C C C C 15000 18000 153 183 M M M M M M C C C C F F F F C C C C C C C C C C 22000 223 M M M C C F F C C C C C 27000 273 M M M E E F F C C C C C 33000 333 M M M E E F F C C C C C 39000 393 M M M E E F F C C C C C 47000 56000 473 563 M M C C C C E E E E F F F F C C C C C C C F C F 68000 683 M E E F F F F C C C F F 82000 823 M E E G G F F C C C F F 100000 104 M E E G G E C C F F 120000 124 M E E G G E C C G G 150000 180000 154 184 C C G G G G G G E E F F F F G G G G 220000 224 C G G E F F G G 270000 274 E G G E F F G 330000 334 E G G E F F G 390000 394 G G G E F F G 470000 560000 474 564 G G G G G G E F F G F G G 680000 684 F G G 820000 824 F Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 7 of 18 F G G F G G http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 7. CAPACITANCE RANGE(Con.) 7-2. X7R Dimension 1825 2220 2225 Cap(pF) code 100V 200V 250V 500V 630V 100V 200V 250V 500V 630V 100V 200V 250V 500V 630V 1000 102 F F F F F F F F F F F F F F F 1200 122 F F F F F F F F F F F F F F F 1500 152 F F F F F F F F F F F F F F F 1800 2200 182 222 F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F 2700 272 F F F F F F F F F F F F F F F 3300 332 F F F F F F F F F F F F F F F 3900 392 F F F F F F F F F F F F F F F 4700 472 F F F F F F F F F F F F F F F 5600 6800 562 682 F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F 8200 822 F F F F F F F F F F F F F F F 10000 103 F F F F F F F F F F F F F F F 12000 123 F F F F F F F F F F F F F F F 15000 153 F F F F F F F F F F F F F F F 18000 22000 183 223 F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F 27000 273 F F F F F F F F F F F F F F F 33000 333 F F F F F F F F F F F F F F F 39000 393 F F F F F F F F F F F F F F F 47000 473 F F F F F F F F F F F F F F F 56000 68000 563 683 F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F 82000 823 F F F F F F F F F F F F F F F 100000 104 F F F F F F F F F F F F F F F 120000 124 F F F F F F F F F F F F F F F 150000 154 F F F F F F F F F F F F F F F 180000 220000 184 224 F F F F F F F F F F F F F F F F F F F F F F F F F F F F F F 270000 274 F F F F F F F F F F F F F F F 330000 334 F F F F F F F F F F F F F F F 390000 394 F F F F F F F F F F F F F F F 470000 474 F F F F F F F F F F F F F F F 560000 680000 564 684 F F F F F F G G G G F F F F F F G G G G F F F F F F F F F F 820000 824 F F F H H F F F H H F F F G G Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 8 of 18 http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 7. CAPACITANCE RANGE 7-3. Y5V Dimension 0805 1206 1210 1812 Cap(µF) code 100V 200V 250V 100V 200V 250V 100V 200V 250V 100V 200V 250V 0.010 103 B B B B B B C C C D D D 0.015 153 B B B B B B C C C D D D 0.022 223 B B B B B B C C C D D D 0.033 0.047 333 473 B B B B B B B B B B B B C C C C C C D D D D D D 0.068 683 B B B 0.10 104 B 0.15 0.22 0.33 0.47 334 474 0.68 684 B B B C C C D D D B B B C C C D D D 154 C C C C C C 224 C D D D C D D D C D D D D D D D D D Prosperity Dielectrics Co., Ltd. No.220-1, Sec. 2, Nanshan Rd., Lujhu, Taoyuan 33860, Taiwan, R.O.C. Page 9 of 18 http://www.pdc.com.tw SPEC. No.: :FM-000-001-07 8. RELIABILITY TEST CONDITIONS AND REQUIREMENTS No. Item Visual and 1. Dimensions Test Condition Requirements * No remarkable defect. * Dimensions to confirm to individual specification sheet. --- 2. Capacitance * Shall not exceed the limits given in the detailed spec. Dielectric Q/ D.F. 3. (Dissipation Factor) * Class I : C0G Cap.≤1000pF, 1.0±0.2Vrms, 1MHz±10%. Cap.>1000pF, 1.0±0.2Vrms, 1KHz±10%. * Class II : (X7R, Y5V) 1.0±0.2Vrms, 1KHz±10%. Rated V. Class I (C0G) All 4. 5. 6. 7. Temperature Coefficient Insulation Resistance C0G -55~125°C at 25°C X7R -55~125°C at 25°C Y5V -25~85°C at 20°C Cap.≥30pF Q≥400+20C Cap.
FM43X224K251EFG 价格&库存
很抱歉,暂时无法提供与“FM43X224K251EFG”相匹配的价格&库存,您可以联系我们找货
FM43X224K251EFG
    • 10+0.41509
    • 100+0.33382
    • 300+0.29319
    库存:363
    FM43X224K251EFG
    • 5+0.35700
    • 20+0.32550
    • 100+0.29400
    • 500+0.26250
    • 1000+0.24780
    • 2000+0.23730
    库存:70
