SS32BF THRU SS320BF
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200V Forward Current - 3.0A
PINNING
FEATURES
• Metal silicon junction, majority carrier conduction
PIN
1
Cathode
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
2
Anode
DESCRIPTION
1
MECHANICAL DATA
• Case: SMBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 57 mg / 0.002oz
2
Simplified outline SMBF and symbol
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS32BF
SS34BF
SS36BF
SS38BF SS310BF SS312BF SS315BF SS320BF
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 2 A
Maximum DC Reverse Current
at Rated DC Reverse Voltage
VF
T a = 25°C
T a =100°C
IR
T a =125°C
Typical Thermal Resistance
1)
Operating Junction Temperature Range
Storage Temperature Range
80
0.55
70
0.70
0.85
V
mA
RθJA
50
°C/W
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
1) Measured
at 1MHz and applied reverse voltage of 4 V D.C.
P.C.B. mounted with 0.5 X 0.5" (12.7 X 12.7 mm) copper pad areas.
REV.08
A
0.95
0.3
5
0.5
5
1) P.C.B. mounted with 0.5 X 0.5" (12.7 X 12.7 mm) copper pad areas.
2)
A
3.0
1 of 3
SS32BF THRU SS320BF
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
3.5
100LFM
3.0
2.4
1.8
1.2
Single phase half wave resistive
or inductive P.C.B mounted on
0.5×0.5"(12.7×12.7mm ) pad areas
0.6
0.0
25
50
75
100
125
150
Lead Temperature (°C)
10 4
T J =100°C
10 3
T J =75°C
10 2
SS32BF/SS34BF
SS36BF-SS320BF
10
1
T J =25°C
10 0
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
SS32BF/SS34BF
SS36BF/SS38BF
SS310BF/SS312BF
SS315BF/SS320BF
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
Transient Thermal Impedance( °C /W)
100
10
1
10
100
t, Pulse Duration(sec)
REV.08
60
80
100
8.3 ms Single Half Sine Wave
(JEDEC Method)
70
60
50
40
SS32BF-SS38BF
30
SS310BF-SS320BF
Number of Cycles at 60Hz
Fig.5- Typical Transient Thermal Impedance
0.1
80
1
1.8
Instaneous Forward Voltage (V)
1
0.01
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristic
1.0
Percent of Rated Peak Reverse Voltage(%)
2 of 3
100
SS32BF THRU SS320BF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMBF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
Top View
mil
Bottom View
g
A
C
D
E
HE
e
max
1.3
0.26
4.4
3.7
5.5
2.2
min
1.1
0.18
4.2
3.5
5.1
1.9
max
51
10
173
146
216
86
min
43
7
165
138
200
75
UNIT
mm
g
pad
e
E
A
pad
HE
1.0
9°
40
Marking
The recommended mounting pad size
Type number
3.0(118)
1.8(71)
2.54(100)
1.8(71)
Unit:mm(mil)
REV.08
3 of 3
Marking code
SS32BF
S32B
SS34BF
S34B
SS36BF
S36B
SS38BF
S38B
SS310BF
S310B
SS312BF
S312B
SS315BF
S315B
SS320BF
S320B
很抱歉,暂时无法提供与“SS36BF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.28000
- 30+0.27000
- 100+0.26000
- 500+0.24000
- 1000+0.23000
- 2000+0.22400
- 国内价格
- 10+0.31674
- 100+0.27885
- 300+0.25991
- 1000+0.24570
- 5000+0.20459
- 10000+0.19891
