RS3ACG THRU RS3MCG
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
PIN
Forward Current - 3 A
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: R3A~R3M
Simplified outline SMC symbol
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols RS3ACG RS3BCG RS3DCG RS3GCG RS3JCG RS3KCG RS3MCG Units
Parameter
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Forward Voltage at 3 A
VF
1.3
V
IR
5
100
μA
Cj
40
pF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
t rr
500
ns
RθJA
RθJC
45
15
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
250
150
1 of 3
RS3ACG THRU RS3MCG
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Maximum Average Forward Current Rating
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
2.0
2.5
Peak Forward Surage Current (A)
100
120
140
T J =25°C
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1.0
10
Reverse Voltage (V)
100
Number of Cycles
REV.08
80
100
0.1
Fig.5 Maximum Non-Repetitive Peak
1
60
1
0.5
Instaneous Forward Voltage (V)
00
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
2 of 3
100
RS3ACG THRU RS3MCG
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
REV.08
3 of 3
Type number
Marking code
RS3ACG
RS3A
RS3BCG
RS3B
RS3DCG
RS3D
RS3GCG
RS3G
RS3JCG
RS3J
RS3KCG
RS3K
RS3MCG
RS3M
很抱歉,暂时无法提供与“RS3MCG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.31360
- 30+0.30240
- 100+0.29120
- 500+0.26880
- 1000+0.25760
- 2000+0.25088
- 国内价格
- 5+0.48434
- 50+0.39648
- 150+0.35255
- 500+0.31960
- 3000+0.26463
- 6000+0.25145
