ME2188
High Efficiency ,synchronous PFM step-up DC-DC converter
General Description
Features
ME2188 Series is a PFM Step-up DC/DC
converter IC with low supply current by CMOS
High efficiency:95%
Maximum frequency:350KHz
process. High frequency noise that occurs during
Low Quiescent Current:13μA
switching is reduced by using advanced circuit
Input Voltage: 0.9V~5.0V
designed, output voltage is programmable in 0.1V
Output Voltage Range:1.8V to 5.0V
steps between 1.8V~5.0V and maximum frequency
High Accuracy:± 2%
is 350KHz(TYP.). A low ripple, high efficiency step-up
Low ripple and Low noise
DC/DC converter can be constructed of ME2188Xxx
Package:
with only two external components. ME2188Xxx is
SOT23-3, SOT23-5,SOT23,SOT89-3,
suitable for use with battery-powered instruments
TO-92
with low noise and low supply current.
Selection Guide
Typical Application
Power source for battery-powered equipment
Power source for Wireless mouse,toys,
Cameras, VCRs, PDAs, MP3, and Led lighting etc
Typical Application Circuit
V03
www.microne.com.cn
Page 1 of 12
ME2188
Pin Configuration
Pin Assignment
SWITCHING
TYPE
POSTFIX
PACKAGE
CE FUNCTION
FEATURES
Build in Transistor
No
Lx
Build in Transistor
Yes
LX+CE
TRANSISTOR
ME2188Axx
ME2188Cxx
X
SOT23
M3
SOT23-3
P
SOT89-3
T
TO92
M5
SOT23-5
ME2188AXX
Pin Number
Pin Name
Description
SOT89-3
SOT23-3
SOT23
TO-92
1
1
1
1
GND
Ground
2
3
3
2
VOUT
Voltage output
3
2
2
3
LX
Switch pin
ME2188CXX
PIN Number
Pin Name
Description
SOT23-5
1
CE
2
VOUT
3
NC
NC
4
GND
Ground
5
LX
Switch
V03
Chip enable
Output voltage monitor, IC internal power supply
www.microne.com.cn
Page 2 of 12
ME2188
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
Supply Voltage
VMAX
8
V
LX pin current
ILXmax
1000
mA
SOT23
PD
300
mW
SOT89
PD
500
mW
TO92
PD
500
mW
Operating Temperature Range
TOPR
-20~+85
Storage Temperature Range
TSTG
-40~125
ESD
VESD
2000
V
Continuous Total Power Dissipation
Block Diagram
V03
www.microne.com.cn
Page 3 of 12
ME2188
Electrical Characteristics
TA=250C, Vin=VOUT×0.6V, L=22μH,CIN=10μF,COUT=100μF, unless otherwise noted.
ME2188Axx/Cxx
Symbol
Parameter
VOUT
Test Conditions
MIN
TYP
MAX
UNIT
Output Voltage
VOUT×0.98
VOUT
VOUT×1.02
V
VIN
Supply Voltage
0.9
5
V
VSTART
Start voltage
Iload=1mA,Vin:0→2V
0.85
1.1
V
Vhold
Hold voltage
Iload=1mA,Vin:2→0V
0.5
V
FOSC
oscillation frequency
350
KHz
η
Efficiency
90
95
Ilimit
Current limit
800
1000
1200
mA
IIN
Quiescent Current
13
15
μA
Note:1、Inductor:22μH(r
很抱歉,暂时无法提供与“ME2188A33M3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.29883
- 200+0.27653
- 600+0.25423
- 3000+0.23193
