深圳市首韩科技有限公司
SHENZHEN SHOUHAN TECHNOLOGY CO.,LTD
Tel: 0755-27597601 Fax: 0755-27597491
承
认
FOR APPROVAL
SPECIFICATION
客
书
户 Customer:
产品名称 Project:
规格型号 Part No:
USB插座
10.0QCHTZ6.8(10.0前插后贴直边6.8)
贵公司承认印 Approal slgnatures
料 号/Part No.
签
章/Signatures
日期 Date:
拟制/Drawn
李春风
审核/Check
刘学
批准/Approved
罗孝金
1
1/1
10.0QCHTZ6.8
(10.0前插后贴直边6.8)
產品名稱
Part Name
10.0短体系列
產品型號
Part Name
91-US01-424
測試日期
Date of Testing
2012.04.03~
2012.04.04
報告編號
Report NO.
MD20120403-02
樣品數量
Quantity
5PCS
測試環境
Measuring Environment
濕 度Temp:18~21℃
相對濕度R.H.:49%~57%
一.電性測試 ELECTRICAL TEST
判定Judge
測試記錄Testing Result
序
號
NO.
測試項目
Testing Item
1
Contact
i t
resistance
2
Insulation
resistance
3
測試條件
Testing Conditions
Test current:150mA
max
Test voltage:500VDC
Operation stated:1min
Test voltage:500VAC
Dielectric
Cut-off current:0.5mA
withstand voltage
Operation stated:1 min
測試設備
Testing Equipment
規格
SPEC
DIGITAL MICROOHMMETER
ULTRA HIGH
RESISTANCE
METER
BREAKDOWN
TESTER
1
2
3
4
5
Pass Fail
30 mΩ
M
Max
14.58
Ω
mΩ
18.31
Ω
mΩ
15.51
Ω
mΩ
16.29
Ω
mΩ
18.19
Ω
mΩ
P
1000 MΩ
Min
1820
MΩ
1231
MΩ
1479
MΩ
1625
MΩ
1591
MΩ
P
No discharge or
Pass
flashover occur
Pass
Pass
Pass
Pass
P
二.機械特性測試 MECHANICAL TEST
測試項目
Testing Item
1
Durability test
2
Mating Force
3
判定Judge
測試記錄Testing Result
序
號
NO.
測試條件
Testing Conditions
測試設備
Testing Equipment
規格
SPEC
Rate:200cycles/hour
Total: 1500 cycles
LIFE TESTER FOR
CONNECTOR
35 Newtons maximum
at a maximum rare of
7.5mm per minute
10 Newtons minimum
Un-Mating Force at a maximum rare of
7.5mm per minute
Pass Fail
1
2
3
4
5
No physical
damage
Pass
Pass
Pass
Pass
Pass
P
Insertion force
testing machine
No physical
damage
Pass
Pass
Pass
Pass
Pass
P
Insertion force
testing machine
No physical
damage
Pass
Pass
Pass
Pass
Pass
P
測試設備
Testing Equipment
規格
SPEC
三.環境特性測試 ENVIRONMENTAL TEST
序
號
NO.
測試項目
Testing Item
1
HumidityTemperature
cycle
2
Heat test
測試條件
Testing Conditions
Temperature: 40±2℃
Humidity: 90~95%
Duration:168H
Temperature: 70±2℃
Duration:168H
判定Judge
測試記錄Testing Result
1
2
3
4
5
Pass Fail
PROGRAM
CONTROLLED
TEMP. & HUMIDTY
CHAMBER
No physical
damage
Pass
Pass
Pass
Pass
Pass
P
OVEN
No physical
damage
Pass
Pass
Pass
Pass
Pass
P
第 1 頁,共 2 頁
李春风
深圳市首韩科技有限公司
刘学
罗孝金
很抱歉,暂时无法提供与“10.0QCHTZ6.8”相匹配的价格&库存,您可以联系我们找货
