山东晶导微电子有限公司
US3ABF THRU US3MBF
Jingdao Microelectronics
Surface Mount Ultrafast Recovery Rectifier
Reverse Voltage – 50V~1000 V
PINNING
Forward Current – 3.0 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• High efficiency
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: U3AB~U3MB
Simplified outline SMBF symbol
MECHANICAL DATA
• Case: SMBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 5 7mg / 0.002oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
US3ABF
US3BBF
US3DBF
US3GBF
US3JBF
US3KBF
US3MBF
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Parameter
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
80
A
Maximum Instantaneous Forward Voltage at 3 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Maximum Reverse Recovery Time (1)
Typical Thermal Resistance
Operating and Storage Temperature Range
1.3
1.68
5
100
IR
t rr
(2)
1.0
μA
75
50
V
ns
RθJA
RθJC
45
15
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SMBF-U-US3ABF~US3BMF-3A1KV
Page 1 of 3
山东晶导微电子有限公司
US3ABF THRU US3MBF
Fig.2 Typical Reverse Characteristics
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Maximum Average Forward Current Rating
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
T J =25°C
1.0
US3ABF~US3DBF
US3GBF
0.1
US3JBF~US3MBF
0.01
0.001
1.0
1.5
60
80
100
120
140
2.0
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
2.5
1
10
100
Number of Cycles
Instaneous Forward Voltage (V)
2016.01
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristics
10
percent of Rated Peak Reverse Voltage (%)
www.sdjingdao.com
Page 2of 3
山东晶导微电子有限公司
US3ABF THRU US3MBF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMBF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
Top View
mil
Bottom View
g
A
C
D
E
HE
e
max
1.3
0.26
4.4
3.7
5.5
2.2
min
1.1
0.18
4.2
3.5
5.1
1.9
max
51
10
173
146
216
86
min
43
7
165
138
200
75
UNIT
mm
g
pad
e
E
A
pad
HE
1.0
9°
40
Marking
The recommended mounting pad size
Type number
3.0(118)
Unit:mm(mil)
2016.01
Marking code
1.8(71)
2.54(100)
1.8(71)
JD512268B0
US3ABF
U3AB
US3BBF
U3BB
US3DBF
U3DB
US3GBF
U3GB
US3JBF
U3JB
US3KBF
U3KB
US3MBF
U3MB
Page 3 of 3
很抱歉,暂时无法提供与“US3JBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.16801
- 100+0.15681
- 300+0.14561
- 500+0.13441
- 2000+0.12881
- 5000+0.12545
