BYS10 SERIES
Surface Mount Schottky Barrier Rectifiers
REVERSE VOLTAGE: 20 - 200 V
FORWARD CURRENT: 2.0 A
Features
SMA/DO-214AC
Schottky barrier rectifier
0. 181( 4. 60)
0. 161( 4. 10)
Guardring protection
Low forward voltage
Reverse energy tested
High current capability
Extremely low thermal resistance
0. 108( 2. 75)
0. 096( 2. 45)
0. 063(1.60)
0. 051(1.30)
0. 209( 5. 30)
0. 193( 4. 90)
Mechanical Data
0. 012(0.30)
0. 006(0.15)
0.096(2.45)
0.078(2.00)
Case: SMA molded plastic body
1111
Polarity: Color band denotes cathode end
Mounting position: ANY
Weight: 0.002 ounces, 0.064 gram
0. 059( 1. 50)
0. 035( 0. 90)
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
o
Ratings at 25 C ambient
temperature unless otherwise specified
BYS10-25
BYS10-35
25
35
BYS10-45
UNITS
Maximum repetitive peak reverse voltage
VRRM
Maximum average forward rectified current at
TL=90
IF(AV)
1.5
A
Peak forward surge current 8.3ms single
half-sine-wave
IFSM
30
A
Maximum instantaneous forward voltage
at I FM=2.0A (NOTE1)
VF
0.50
V
Maximum DC reverse current
TJ=25
at rated DC blocking voltage TJ=125
Maximum thermal resistance
Operating temperature range
Storage temperature range
0.5
IR
R
10
JL
25
V
45
mA
o
C/W
TJ
-55 ---- +150
o
C
TSTG
-55 ---- +150
o
C
NOTE: 1.Pulse test: Pulse width 300us,duty cycle 1 %
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
BYS10 SERIES
100
2.0
I F – Forward Current ( A )
I FAV – Average Forward Current ( A )
Ratings AND Charactieristic Curves
1.6
1.2
0.8
0.4
80
120
160
1
Tamb – Ambient Temperature ( °C )
I R – Reverse Current ( mA )
1000
100
10
VR= V R R M
1
0.1
40
80
120
160
Tj – Junction Temperature ( °C )
Figure 3. Reverse Current vs.
ht t p : //
0.8
1.2
2.0
1.6
VF – Forward Voltage ( V )
Figure 2. Forward Current vs. Forward Voltage
PR – Maximum Reverse Power Dissipation ( W )
Figure 1. Average Forward Current
Tj = 2 5 °C
0.1
0.01
200
Tj = 150°C
10
95 9710
7
BYS10-45
6
5
BYS10-35
4
3
BYS10-25
2
1
80
120
200
160
Figure 4. Reverse Power Dissipation vs.
www.lgesemi .c o m
很抱歉,暂时无法提供与“BYS10-45”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.50999
- 100+0.47599
- 300+0.44199
- 500+0.40799
- 2000+0.39099
- 5000+0.38079
