WNT2F04
WNT2F04
NPN, General Purpose Transistors
Http//:www.willsemi.com
Descriptions
The WNT2F04 is designed for general purpose
amplifier applications. Standard products are Pb-free
SOT-23
and Halogen-free
(Top View)
3
Features
1AM
Complementary to WPT2F06
Collector Current: IC=0.2A
1
2
Marking :1AM
1: BASE
2: EMITTER
3: COLLECTOR
Order information
Device
Package
Shipping
WNT2F04-3/TR
SOT-23
3000/Reel&Tape
Absolute maximum ratings
Parameter
Symbol
Collector-emitter Voltage
VCEO
Collector-base Voltage
VCBO
Emitter-base Voltage
VEBO
Continues Collector Current
IC
Collector Power Dissipation
PC
Thermal Resistance From Junction To Ambient RΘJA
Junction Temperature
TJ
Operating Temperature
TOPR
Storage Temperature Range
Tstg
Will Semiconductor Ltd.
1
Value
40
60
6
200
250
625
150
-40~+85
-55~+150
Unit
V
V
V
mA
mW
°C /W
°C
°C
°C
Jun, 2018 - Rev.1.4
WNT2F04
Electronics Characteristics (Ta=25oC, unless otherwise noted)
Parameter
Collector-emitter breakdown voltage
Collector-base breakdown voltage
Emitter-base breakdown voltage
Collector cutoff current
Emitter cutoff current
Collector-emitter saturation voltage
Base-emitter saturation voltage
DC current gain
Symbol
BVCEO
BVCBO
BVEBO
ICEX
ICBO
IEBO
VCE(sat)
VBE(sat)
hFE
Test Conditions
IC=1mA, IB=0mA
IC=10uA, IE=0mA
IE=10uA, IC=0mA
VCE=30V,
VEB(OFF)=3V
VCB=50V, IE=0A
VEB=5V, IC=0A
IC=50mA, IB=5mA
IC=50mA, IB=5mA
Min.
40
60
6
VCE=1V, IC=1mA
70
100
60
VCE=1V, IC=10mA
VCE=1V, IC=50mA
Collector capacitance
CC
Emitter capacitance
CE
IE=Ie=0;VCE=5V;
f=1MHz
IC=Ic=0;VBE=0.5V;
f=1MHz
Max.
Unit
V
V
V
50
nA
100
100
0.3
0.95
nA
nA
V
V
300
4
pF
8
pF
5
dB
IC=100mA;
Noise figure
VCE=5V; RS=1kΩ;
F
f=10Hz to15.7kHz
Transition frequency
fT
Delay time
td
Rise time
tr
Storage time
Fall time
ts
tf
VCE=20V,
IC=10mA, f=100MHz
VCC=3V, VBE(off)=-0.5V
IC=10mA,
IB1=1mA
VCC=3V, IC=10mA,
IB1= IB2=1mA
2
300
MHz
35
ns
35
ns
200
50
ns
ns
Jun, 2018 - Rev.1.4
WNT2F04
Typical characteristics (Ta=25oC, unless otherwise noted)
3
Jun, 2018 - Rev.1.4
WNT2F04
Package outline dimensions
SOT-23
Symbol
Dimensions in millimeter
Min.
Typ.
Max.
A
0.900
1.025
1.150
A1
0.000
0.500
0.100
A2
0.900
0.975
1.050
b
0.300
0.400
0.500
c
0.080
0.115
0.150
D
2.800
2.900
3.000
E
1.200
1.300
1.400
E1
2.250
2.400
2.550
e
e1
0.950TYP
1.800
1.900
L
2.000
0.500REF
L1
0.300
0.400
0.500
θ
0°
4°
8°
Recommend PCB Layout (Unit: mm)
2.40
1.00
0.80
1.90
4
Jun, 2018 - Rev.1.4
很抱歉,暂时无法提供与“WNT2F04-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08250
- 500+0.07425
- 5000+0.06875
- 10000+0.06600
- 30000+0.06325
- 50000+0.06160
