SMW9070S
/DIMENSION( UNIT :mm)
A
9.0±0.5
A1
9.5±0.5
B
7.0±0.5
C
4.8Max
D
5.7Typ
E
1.5±0.2
F
2.0±0.2
G
1.7±0.2
Mark
/CIRCUIT DIAGRAM
ELECTRICAL CHARACTERISTIC
Ω
P/N
Z( )
@100MHz
Min
Typ
RDC
(mΩ)
Max
Rated Current
(A)
Max
IR
(MΩ)
Min
Rated Voltage
(V)
Max
SMW9070S301RTT
225
300
6
6.0
10
50
301
SMW9070S501PTT
450
600
8
5.0
10
50
501
SMW9070S701PTT
500
700
10
5.0
10
50
701
SMW9070S102NTT
750
1000
13
4.0
10
50
102
SMW9070S222KTT
1700
2200
60
2.5
10
50
222
測試儀器
Z(Ω):HP4395A
RDC(Ω):CH502BC
Rated Current(A):CH1062A+CH1320
IR(MΩ):CH19073
Rated Voltage(V):CH9052
Rev.01
注意事項
1.平贴度为 0.10mmMax.
2.特性测试方法
Page 1 of 4
www. sunltech.com
SMW9070S
MATERIAL LIST
NO.
ITEM
DESCRIPTION
SUPPLIER
1
CORE
FERRITE
SINCORES OR EQ
2
WIRE
2UEW P180
ELEKTRISOLA OR EQ
3
膠帶
DM 胶带
HENGRENXIN OR EQ
4
SOLDER
Sn Cu
SHENMAO OR EQ
5
EPOXY
ME-5890
PENGNO OR EQ
6
INK
黑色
BON MARK
TAPING SPECFICATIONS
起始字需对准定位孔,印字仅供參考
Transparent carrier and cover tape/透明载带和覆盖带
Adhesive strength of cover tape is 20 to 120 gf
The conduction band direction
80
165~1
Rev.01
Page 2 of 4
www. sunltech.com
SMW9070S
RELIABILITY TESTING
℃ ( Contain Heating coil )
Operating Temperature
- 30 to + 100
Appearance Inspection
No external defects by visual inspection
Terminal Strength
After soldering , between copper plaet and terminals
of coils , push in two directions of X , Y with
standing 10N(1.02kg) for10+/-2 sec.
Terminal should not peel off. ( Refer to figure at right )
Heat endurance of reflow
Refer to figure
soldering
Insulating resistance
Over 100 MΩ at 100V D.C . between wire and core .
Dielectric Strength
Apply at 0.5KV 3mA for 1 minute between wire and core .
Temperature characteristics
Inductance coefficient ( 0~2,000 ) × 10 /
Humidity characteristics
Inductance deviation within ± 10% , after 96 hours in 90~95%
relative humidity at 40 ± 2
℃( - 30 ~ + 100 ℃ )
℃ and 1 hours drying under normal condition .
A test is made under the above mentioned condition , and it is kept for 2 hours in the normal
IR Reflow profile
Temperature
300
250
Soldering
255
200
150
preheating
Natural cooling
100
50
Time
1 to 4 min
10 sec more than 2 min
Temperature and humidity . After that , no mechanical and electrical defect should be found .
Rev.01
Page 3 of 4
www. sunltech.com
SMW9070S
七.包装方式/PACKING LIST
1、轮盘规格:13'(直径 330mm)
数量:700PCS/盘
Label
作业说明:A.摆料方向为字首朝导带孔.
B.载带尾部用美纹胶纸固定.
2、数量:700PCS/袋.
作业说明:编带检查好的产品装进 PE 中.
3、数量:1400PCS/盒
作业说明:标签朝上装入内盒里面,将内盒盖扣好.
ITEM NO.
Q'TY:
PCS
N.W:
PCS
G.W:
PCS
Rev.01
4、数量:7000PCS/箱.
作业说明:A.先将内、外箱底部封好,内箱装进外箱里面.
B.将内盒装进内、外箱里面,并用透明胶带封好外箱顶部.
C.在外箱位置贴一张外箱标签.
D.当尾数箱不足一整箱时需用内盒或填充物装满.
Page 4 of 4
www. sunltech.com
很抱歉,暂时无法提供与“SMW9070S501PTT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.38310
- 30+3.25780
- 100+3.00720
- 500+2.75660
- 1000+2.63130
