PSBD1DF40V2L
PSBD1DF40V2L
    PRISEMI(上海芯导电子)
    SOD123FL
    肖特基二极管 独立式 VR=40V IF=2A IR=500μA SOD123FL
PSBD1DF40V2L 数据手册
PSBD1DF40V2L Schottky Barrier diode Feature  Ultra Small mold type. (SOD-123FL)  Low VF  High reliability. Construction  SOD-123FL (Top View) Silicon epitaxial planar Pin 2 Pin 1 Mechanical Characteristics  Lead finish:100% matte Sn(Tin)  Mounting position: Any  Qualified max reflow temperature:260℃  Device meets MSL 1 requirements  Pure tin plating: 7 ~ 17 um Circuit Diagram 220L Marking (Top View) Electrical characteristics per line@25℃ Parameter Symbol Min. Typ. Max. Unit Conditions Forward voltage VF - 0.31 0.35 V IF=1A Forward voltage VF - 0.35 0.38 V IF=2A Reverse current IR - 90 500 µA VR=40V Absolute maximum rating@25℃ Parameter Reverse voltage (DC) Symbol limits Unit VRM 40 V Io 2 A IFSM 50 A Tj -55 to 125 ℃ Tstg -40 to +125 ℃ Average rectified forward current Peak Forward Surge Current 8.3ms Single Half Sine Wave Superimposed on Rated Load Operating Junction temperature Range Storage temperature Rev.06.1 1 www.prisemi.com Schottky Barrier diode PSBD1DF40V2L Typical Characteristics 10000 IR –Reverse Current (µA) IF –Forward Current (mA) 10000 1000 25℃ 100 10 1 0.1 0.0 0.1 0.2 0.3 0.4 0.5 1000 25℃ 100 10 1 0.1 0.01 0 0.6 VF – Forward Voltage (V) 10 20 30 40 50 60 VR – Reverse Voltage (V) Fig 1.Forward Voltage Fig 2.Leakage Current CT –Total Capacitance (pF) 1000 800 600 400 200 0 0 5 10 15 20 25 30 35 40 VR – Reverse Voltage (V) Fig 3.Total Capacitance Rev.06.1 2 www.prisemi.com Schottky Barrier diode PSBD1DF40V2L Solder Reflow Recommendation Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec 280 240 200 160 120 80 40 0 0 30 60 90 120 150 180 210 240 270 300 330 360 390 420 450 480 Time (sec) Rev.06.1 3 www.prisemi.com Schottky Barrier diode PSBD1DF40V2L Product dimension (SOD-123FL) Unit:mm Ordering information Device Package Reel Shipping PSBD1DF40V2L SOD-123FL (Pb-Free) 7" 3000 / Tape & Reel Rev.06.1 4 www.prisemi.com Schottky Barrier diode PSBD1DF40V2L IMPORTANT NOTICE and are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi reserves the right to make changes without further notice to any products herein. Prisemi makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does Prisemi assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in Prisemi data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s technical experts. Prisemi does not convey any license under its patent rights nor the rights of others. The products listed in this document are designed to be used with ordinary electronic equipment or devices, Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. Website: http://www.prisemi.com For additional information, please contact your local Sales Representative. ©Copyright 2009, Prisemi Electronics is a registered trademark of Prisemi Electronics. All rights are reserved. Rev.06.1 5 www.prisemi.com
PSBD1DF40V2L 价格&库存
很抱歉,暂时无法提供与“PSBD1DF40V2L”相匹配的价格&库存,您可以联系我们找货
PSBD1DF40V2L
  • 20+0.36189
  • 200+0.33839
  • 500+0.31489
  • 1000+0.29139
  • 3000+0.27964
  • 6000+0.26319
库存:640
