UF2A-UF2M
Surface Mount Rectifiers
VOLTAGE RANGE: 50 --- 1000 V
CURRENT: 2.0 A
DO-214AA(SMB)
Features
4.7± 0.25
3.6± 0.3
2.0± 0.15
Low cost
Low leakage
Low forward voltage drop
High current capability
Easily cleaned with Alcohol,Isopropanol
and similar solvents
The plastic material carries U/L recognition 94V-0
2.3± 0.15
5.4± 0.2
Mechanical Data
Case:JEDEC DO-214AA,molded plastic
0.2± 0.05
0.203MAX
1.3± 0.2
Polarity: Color band denotes cathode
Weight: 0.003 ounces,0.093 grams
Mounting position: Any
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
UF2A
UF2B
UF2D
UF2G
UF2J
UF2K
UF2M UNITS
Maximum recurrent peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
V
Maximum average forw ard rectified current
@TL=90
IF(AV)
2.0
A
IFSM
50
A
Peak forw ard surge current
8.3ms single half-sine-w ave
superimposed on rated load
@TJ=125
Maximum instantaneous forw ard voltage at2.0 A
Maximum reverse current
at rated DC blocking voltage
@TA=25
@TA=100
VF
1.0
1.4
1.7
5.0
IR
V
A
100
Maximum thermal resistance (NOTE1)
trr
50
75
ns
Typical junction capacitance
(Note2)
CJ
15
12
pF
Typical thermal resistance
(Note3)
RθJA
Operating junction temperature range
Storage temperature range
15
TJ
- 55 ---- + 150
TSTG
- 55 ---- + 150
NOTE: 1. Measured with I F =0.5A, I R=1A, I rr=0.25A.
2. Measured at 1.0MHZ and applied rev erse v oltage of 4.0V DC.
/W
UF2A-UF2M
Ratings AND Charactieristic Curves
FIG.1 -- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC
trr
50
N 1.
+0.5A
10
N 1.
D.U.T.
25VDC
(approx)
-0.25A
OSCILLOSCOPE
(NOTE 1)
1
NONINDUCTIVE
PULSE
GENERATOR
(NOTE2)
-1.0A
1cm
SET TIME BASE FOR 20/30 ns/cm
NOTES:1.RISE TIME = 7ns MAX.INPUT IMPEDANCE = 1M .22pF.
JJJJJ2.RISE TIME =10ns MAX.SOURCE IMPEDANCE=50 .
100
TJ=25
Pulse Width=300µS
1.0
0.1
0.01
600\800\1000V
50\100\200V
0.2 0.4 0.6 0.8 1
FIG.3 -- FORWARD DERATING CURVE
AVERAGE FORWARD CURRENT
AMPERES
400V
10
AMPERES
INSTANTANEOUS FORWARD CURRENT
FIG.2 -- TYPICAL FORWARD CHARACTERISTIC
1.2 1.4 1.6 1.8 2
2
1.5
Single Phase
Half Wave 60HZ
Resistive or
Inductive Load
1
.5
UF2A-UF2G
6
4
0.1 0.2
0.4
1
UF2J-UF2M
2
4
10
REVERSE VOLTAGE,VOLTS
40
75
100
125
150
175
100
50
8.3ms Single Half
Sine-Wave
40
30
AMPERES
40
PEAK FORWARD SURGE CURRENT
60
1
50
FIG.5 -- PEAK FORWARD SURGE CURRENT
200
100
2
25
AMBIENT TEMPERATURE,
FIG.4 -- TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,pF
2.5
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
TJ=25
z
5
10
50
100
NUMBER OF CYCLES AT 60Hz
很抱歉,暂时无法提供与“UF2M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.19649
- 30+0.18899
- 100+0.18150
- 500+0.16650
- 1000+0.15900
- 2000+0.15450
