|S阳
MKseries
• Endurance: +105.C
z 童医
532
2 ,000 用 3, 000 hours
• Designed for surface mounting on high density PC board
• RoHS Compllant
L
..iJ
SPECIFICATIONS
Characterl8Uc:a
E棚n.
CS协goryl画mperature Ran咽'
Rated VoI同e
-40-中 10S'C(8.3
Range
-4S0Vdc)
6.3-4S0Vdc
Capacitance Tolerance
{at20.C, 120Hz)
量20%(M)
6.3-100 Vdc
160-450 Vdc
|量。 .01CVor 31lA , whichever is greater.
Leakage Current
1 量。.04CV+100IlA(1
(2 minutes)
minuta)
(eI20.C)
Where, I:Max.leakage current (μA), C:Nominelωpaciten饵 (μF), V: Rated voltage (V)
Rated Voltage(Vdc)
Dissipation Factor (tanl5)
tanlí (max.)
6.3
080副E80
10
16
25
35
50
63: 80 : 10(: 160-250 : 400-450 :
: 0.30: 0.24:0.20:0.16:0.14:0.12 :0.12:0.12 : 0.12:
! EBO-MNO : 0.40: 0.30:0.26:0.16:0.14:0.12 :0.12:0.12 : 0.12:
Low Temperature
RatedVoltage(Vdc)
6.3 : 10
16
25
35: 50
0.20
0.15
0.20
(at 20. C ,120Hz)
Charac恼ristics
Z(-25'C)/Z(+20'C)
(Max. Impedance Ratio)
4
(øt 120Hz)
Z(-40' C)/Z(+20'C)
The specifications listed below shall be met when the capacitors are restored t口 20.C after rated vollage is applied for a
speclfled perlod 口ftlmeat105'C
Capacilance Change
量:1:20%
ofthe initial value
-----+……-------一一----……---------一
Oissipation Fac也:or (lanð)
量200%
Leakage Currenl
:Hhe Inlllal speclflad valua
oflha inilial spacifiad valua
The following spe创f陆alions shall be salisfiad whan tha capacitors are raslored 10 20'C øfter leøvin目 Iham undar no load at
105.C for 1 , 00口 hours (6.3-100VdC: 500 hours).
ShelfL百e
: :s量20%
Capacilance Change
of lhe initial value
Dissipøtion Faclor (tønð)
Leaka目e
DIMENSIONS[mm]
Currenl
PART NUMBERING SYSTEM
E
u
R
T
L
Sla阳elMø闹闹 α对恼
lenmnøloooe
S国∞de
Cøpøciten四∞de
capaci恼n田 tolarøn皿∞dø
Sizecode D
D80
5
E80
8.3
EBO
6.3
8
FBO
FDO
8
FEO
a
FGO
8
GBO
10
10
GDO
GEO
10
GHO
10
WEO
12.5
WG5
12.5
WM5
12.5
LHO
16
LNO
16
MHO
18
MNO
18
L
7.7
7.7
10.5
10.5
12.5
13.5
15.5
10.5
12.5
13.5
16.5
13.5
16.0
21.0
16.5
21.5
18.5
21.5
A
5.3
自,自
6.6
8.3
8.3
8.3
8.3
10.3
10.3
10.3
10.3
13.0
13.0
13.0
17目。
17目。
19.0
19.0
B
5.3
8.8
6.8
8.3
8.3
8.3
8.3
10.3
10.3
10.3
10.3
13.0
13.0
13.0
17.0
17.0
19.0
19.0
c
5.9
7.2
7.2
9.0
9.口
9.口
9.口
11.口
11.0
11.0
11.0
13.7
13.7
13.7
18.0
'自.0
20.0
20.0
w
1.0-1.3
1.0-1.3
P
1.4
1.9
1.9
3.1
3.1
3.1
3.1
4.5
4.5
4.5
4.5
4.5
4.5
4.5
6.5
6.5
8.S
1.0-门
自.5
O.岳-0.8
0.5-0.8
。.5-0.8
0.7-1 .1
0.7- 1.1
0.7- 1.1
0.7-1 .1
0.7- 1.1
0.7- 1.1
0.7-1.1
。.7,罔 1 . 1
1.萨.1 .3
1.萨
1.0-1.3
1.0-叶 3
vo阳ge ∞de
Serie8 ∞de
Cate90哼∞de
RATED RIPPLE CURRENT MULTl P Ll ERS
Fraquøncyωrrøction faclor for ripplø currenl
59/60
@a」
h
FH5028帽za
2,000 hours( 160嗣450Vdc: 3 ,000 hours)
Load Life
Endurance
|Ai5Hi
SURFACE
MOUNTTYPEAL川UM ELECTROLYTIC CAPACITORS
MKseries
STANDARD RATINGS
WV
C.p
(Vdc)
lμF)
6.3(1口J)
10(1A)
Slze code
D80
。 .30
105
220
330
E80
FBO
0.30
0.40
160
340
1000
GBO
0.40
860
330
FBO
0.30
340
470
FBO
0.30
360
820
GBO
0.30
860
33
160(2C)
47
68
190
0.26
0.28
500
545
0.26
800
0.16
105
180
205
550
47
100
E80
0.16
0.16
220
FBO
0.16
AU-民斗'-
。 .20
FBO
FBO
制-…
m
即
E80
33
22
1∞
220
330
2∞(20)
m4412
47
WEO
0.12
900
330
WG5
0.12
1180
aaT7'
2.2
EO
HU
''E-
3.9
0.12
575
0.12
0.12
自目。
4 00(2G)
140
47
100
GBO
GDO
~:......+......:二
D80
由 .8
8.2
575
600
I.....~:~.~....j
0.12
15
22 一…r..
70
100(1 K)
~~........j........;=........I.....~~~.i....j
47
GBO
0.12
575
100
WEO
0.12
680
。.15
S臼
LNO
0.15
680
EBO
0.15
58
箱。(2W)
440
LHO
0.15
364
LNO
0.15
nu 5
j AHWAU
50
470
EBO
0.20
36
EBO
0.20
44
FBO
FBO
0.20
52
0却
84
M
-HM
E
num
nuh
o
108
0.20
130
GHO
0.20
158
LHO
WG5
。.20
0.20
176
184
LHO
0.20
210
FGO
MNO
GBO
WEO
u
m
m
m
LNO
"-n
u
0.15
200
WEO
2ω
'3
内u …nu… ,。
~~........J. ........~8.0.........I.....~:1.~....J. ...................1~~
0.15
ω
ω
ω-…
m
4.7
0.12
0.12
0.15
~~.......l.....~:2j)......l.....................!~
.......~El~.......J. .....O:~.....L.
一..一..… 78 …
nu
5.自
~~........j.........~=........I.....~:~.~....j
80(1 目}
4.7
Ru
0.15
0.15
Er…FU…E『 …F
GBO
WEO
E80
Rd
ω …以 …
mm
450
Edw
J
: .......f.....~:~......f
…-D
俩口
Ru
WM5
3.3
220
'自
33
MM
100
0.15
却…m …m …
刽
0.12
66口
MHO
∞ …m ∞
目
FBO
e+
hu-1-
520
0.15
j.......~.......f.....~:~.~......f.....................~:
22
az--E
今'a-
E
EFr
hu-nuv
1-T
饨ι
,-"'筒,
47
nu
0.15
LNO
可
220
LHO
nu 一内υ''
7口。
ω …ω …
田…
0.12
310
420
j........~.=.......f.....~:~.~......f.....................:
1.5
GBO
240
0.15
0.15
2
0.15
钉4
捕一刻…
2
h
2
100
au …句,-haa …
4·- 句,. +aa-
63(1J)
4
42
而
GHO
WEO
WG5
、J
5O(1H)
575
4.7
200
RU 一《υ
3
0.14
4
则E) I
180
0.15
MH …M川剧朋
…2 …3 …7
210
情…
四一
则
阳一
则创一
FBO
0.14
nu …nuvau…内uw
…nu …内υ
100
2
跚跚
m
删…
酬…
阳…
E80
m …泪。
47
0.15
WGEO
GHn?ro
…H
wG
33
白
GEO
WEO
GEO
22
68
2.2
35(1V)
rlpple current
(mArm./10S'C.100kHz)
~~........j
雪白
l.....~:1些 l.....................!lCl
~~........j.......~~.......l.....~:1.5......l.....................1~号
I.....~~~~....j
150
RI.阳 d
t.n l5
回…
惘…
m…
刚一
0.24
175
180
。 .24
Slze code I
nt)nu'-n协 …nT
E80
E80
C.p
(IIF)
u …M -G -G 一
甲O.........I.....~:坦J. ...................1~~
wv
(Vdc)
…川m 一
囚一
m…
~~........j
100
220
470
25(1E)
Rl.ted rlpple current
100
品|击
16(1C)
t.nð
ao
e
nua
~~........j.......t:6........f.....~::......f
22
LNO
。 20
240
很抱歉,暂时无法提供与“EMK1VM221FB0D00R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.56000
- 20+0.51200
- 100+0.46400
- 500+0.41600
- 1000+0.39360
- 2000+0.37760
- 国内价格
- 5+0.80378
- 50+0.66554
- 150+0.59642
- 550+0.49421
- 2750+0.45274
- 4950+0.43200
