2 × 2.2 mm Pitch, Wire-to-Wire Connectors for Small Spaces
DF62 Series
Compact shape due to 2 x 2.2 grid layout of pins
*Both are 7 contacts with 3A current rating
16
16
Existing
products
DF62
Fig.1
■Features
1. The slim, sleek design and smooth contour
combine to complete connections in tight spaces.
Grid Arrangement
Smooth external
shape
No exposed metal
These connectors were designed to take full
advantage of small/narrow spaces. The contacts
are arranged in a grid pattern which shortens the
diagonal distances and the body was slimmed
down by creating smooth outer surfaces. This
design helps to save precious space and makes
these connectors virtually tangle free. There is
no visible or exposed metal which would
eliminate the possibility of electrical arcing
between the connector and the inside of a metal
conduit. (Please refer to Fig. 1 and 2)
Fig.2
2. Secure lock mechanism
The locking structure emits a clear tactile click
upon lock completion. After completion, a second
indicator can be utilized. The socket lock can be
visually checked through the plug window after
mating. These indicators function together to
prevent incomplete mating. (Please refer to Fig. 3)
Visual check area
3. Reliable contact structure
The structure utilizes two contact points to
provide a reliable contact that resists damage
from vibration and rough operation.
4. Robust contact structure
The unique structure provides protection to the
contacts and lance areas, it prevents any
bending or deformity that might occur during
mating, the assembly procedure or while in
transportation. (Please refer to Fig. 4)
Fig.3
Contact appearance image
5. Multiple variations available
There are several different wire counts available,
giving the designer the variety needed to
complete the application. *Waterproof type is
currently under development, for any inquiries
on this series please contact your local Hirose
Sales Representative.
6. Applicator sharing
The applicators for the DF11 and DF59 series
(existing products) can be adapted to
accommodate the DF62 series applicators.
*Some modifications are required. Please
contact Hirose for additional details.
Fig.4
2013.11 ②
1
DF62 Series●2 × 2.2 mm Pitch, Wire-to-Wire Connectors for Small Spaces
■Product Specifications
Ratings
Current
Rating
(Note 1)
22 AWG: 4A/pin (2 pos.)
3A/pin (3 - 13 pos.)
2.5A/pin (24 pos.)
24 AWG: 2A/pin
26-30 AWG: 1A/pin
Operating Temperature Range
Operating Humidity Range
-35 ∼ 105ç (Note 2)
20 ∼ 80% (Note 3)
Voltage
Rating
AC/DC 250V
Storage Temperature Range
Storage Humidity Range
-10 ∼ 60ç (Note 4)
40 ∼ 70% (Note 4)
Items
1. Insulation Resistance
Specifications
Minimum of 1,000 Mø
Conditions
Measured with DC 500 V
2. Withstanding Voltage
3. Contact
Resistance
4. Vibration
Resistance
5. Shock
Resistance
6. Humidity
Resistance
7. Temperature
Cycles
8. Durability
No flashover or breakdown
Apply AC 650 V for 1 minute
Measured at a maximum of 20 mV and 100 mA (DC or
1000 Hz)
10 cycles in each of three directions at frequency 10-55
Hz, half amplitude 0.75 mm
Acceleration: 490 m/s2, 11 ms, Semi-sinusoidal 3 axle
direction 3 times each.
Left at temperature 40 ±2ç, humidity 90 to 95%, 96
hours
-55ç: 30 minutes → 5 ∼ 35ç: 2 ∼ 3 minutes → 85ç:
30 minutes → 5 ∼ 35ç: 2 ∼ 3 minutes, 5 cycles
Mating/unmating: 30 mating cycles
Maximum of 30 mø
No electrical discontinuity of 1µs or
greater
greater
Contact Resistance Maximum of 30 mø
Insulation Resistance: Minimum of 1,000 Mø
Contact Resistance: Maximum of 30 mø
(Note 1) This is the maximum current rating while all pins are powered or used as all power lines. When isolating power lines into multiple
circuits, current ratings may go above the stated current ratings. Please consult Hirose for specific details before doing this.
(Note 2) Includes the temperature rise of power lines
(Note 3) The connector should be completely dry (no condensation present)
(Note 4) The term “storage” refers to the long-term storage condition of unused products before PCB mounting.
The operating temperature and humidity ranges are applied while in a non-energized state, while in transport or after PCB mounting.
■Materials
Item
Component
Material
Finish
UL Flammability rating
Socket crimping contact
Plug crimping contact
Crimping socket
Crimping plug
Contact
Contact
Insulator
Insulator
Phosphorous bronze
Phosphorous bronze
PBT resin
PBT resin
Gold plating or tin plating
White
Black
UL94V-0
UL94V-0
■Product Number Structure
Refer to the charts below for determining specific part number characteristics.
Please select connectors listed in this catalog when placing orders and be sure to check the latest delivery specifications at the time of ordering the product.
●Connector
DF 62B - * S - 2.2 C (00)
❶
❷
❸ ❹
❺
❻
❼
❶Series Name:DF
❺Contact pitch: 2.2 mm
❷Series No.: 62B (regular type)
62C (Protected lock type )
62P (Panel mount type )
❻Connection part shape
C: Crimping housing
❸No. of Contacts: 2, 3, 4, 5, 6, 7, 13, 24
❹Connector type
S: Socket, EP: Extension plug
❼Color
Socket 00: White
11: Black
Extension plug 00: Black
10: White
●Contact
DF 62 - EP 2428 PCF A
❶
❷
❸
❶Series Name:DF
❷Series No.: 62
❸Terminal type
EP: Extension plug
❹Applicable wire size
22 :AWG#22
2428:AWG#24∼28
30 :AWG#30
2
❹
❺
❻
❺Contact type /packaging type
SCF: Socket crimping contact, reel
SC Socket crimping contact, pieces
PCF: Plug crimping contact, reel
PC: Plug crimping contact, pieces
❻Plating type
A: Gold plating
None: Tin plating
■Socket (standard type)
9.55
A
*7 pos. shown
as an example.
P=2
B
CAV No.
P=2.2
Contact No. marking
Unit:mm
Part No.
HRS No.
DF62B- 2S-2.2C(**)
DF62B- 3S-2.2C(**)
DF62B- 4S-2.2C(**)
DF62B- 5S-2.2C(**)
DF62B- 6S-2.2C(**)
DF62B- 7S-2.2C(**)
DF62B-13S-2.2C(**)
DF62B-24S-2.2C(**)
CL544-0551-0-**
CL544-0552-2-**
CL544-0553-5-**
CL544-0554-8-**
CL544-0555-0-**
CL544-0556-3-**
CL544-0557-6-**
CL544-0539-4-**
No. of
Contacts
2
3
4
5
6
7
13
24
A
B
4.9
4.9
4.9
7.1
7.1
7.1
9.3
12.3
5.08
7.08
7.08
7.08
7.08
9.08
11.08
13.08
[Specification No.] **
(00) : White
(11) : Black
(Note 1) This product is sold per pack (100 pieces per pack), please place orders in full pack increments.
■Socket (Protected lock type)
A
*7 pos. shown
as an example.
P=2
B
CAV No.
P=2.2
Contact No. marking
Unit:mm
Part No.
HRS No.
DF62C- 2S-2.2C(**)
DF62C- 3S-2.2C(**)
DF62C- 4S-2.2C(**)
DF62C- 5S-2.2C(**)
DF62C- 6S-2.2C(**)
DF62C- 7S-2.2C(**)
DF62C-13S-2.2C(**)
DF62C-24S-2.2C(**)
CL544-0565-4-**
CL544-0566-7-**
CL544-0567-0-**
CL544-0568-2-**
CL544-0569-5-**
CL544-0570-4-**
CL544-0571-7-**
CL544-0541-6-**
No. of
Contacts
2
3
4
5
6
7
13
24
A
B
4.9
4.9
4.9
7.1
7.1
7.1
9.3
12.3
5.65
7.65
7.65
7.65
7.65
9.65
11.65
13.65
(00) : White
(11) : Black
3
■Plug (standard type)
A
*7 pos. shown
as an example.
16.05
P=2
B
CAV No.
P=2.2
Contact No. marking
Unit : mm
Part No.
HRS No.
DF62B- 2EP-2.2C(**)
DF62B- 3EP-2.2C(**)
DF62B- 4EP-2.2C(**)
DF62B- 5EP-2.2C(**)
DF62B- 6EP-2.2C(**)
DF62B- 7EP-2.2C(**)
DF62B-13EP-2.2C(**)
DF62B-24EP-2.2C(**)
CL544-0558-9-**
CL544-0559-1-**
CL544-0560-0-**
CL544-0561-3-**
CL544-0562-6-**
CL544-0563-9-**
CL544-0564-1-**
CL544-0540-3-**
No. of
Contacts
2
3
4
5
6
7
13
24
A
B
6.0
6.0
6.0
8.2
8.2
8.2
10.4
13.4
5.3
7.3
7.3
7.3
7.3
9.3
11.3
13.3
(00) : Black
(10) : White
A
■Plug (Panel mount type )
16.05
P=2
B
CAV No.
P=2.2
Contact No. marking
Unit : mm
Part No.
HRS No.
DF62P- 2EP-2.2C(**)
DF62P- 3EP-2.2C(**)
DF62P- 4EP-2.2C(**)
DF62P- 5EP-2.2C(**)
DF62P- 6EP-2.2C(**)
DF62P- 7EP-2.2C(**)
DF62P-13EP-2.2C(**)
DF62P-24EP-2.2C(**)
CL544-0543-1-**
CL544-0544-4-**
CL544-0545-7-**
CL544-0546-0-**
CL544-0547-2-**
CL544-0548-5-**
CL544-0549-8-**
CL544-0550-7-**
No. of
Contacts
2
3
4
5
6
7
13
24
A
B
11.3
11.3
11.3
13.5
13.5
13.5
15.7
18.7
5.3
7.3
7.3
7.3
7.3
9.3
11.3
13.3
(00) : Black
(10) : White
4
BSocket contact No. Summary diagram (from the mating section side)
2 pos.
1
2
3 pos.
2
1
3
4 pos.
1
3
2
4
5 pos.
2
1
4
6 pos.
3
5
1
4
2
5
7 pos.
3
6
2
1
4
3
6
13 pos.
1
5
7
4
8
2 3
5 6 7
9 10 11
12 13
24 pos.
1 2 3 4 5
6 7 8 9 10
11 12 13 14 15
16 17 18 19 20
21 22 23 24
BPlug contact No. Summary diagram (from the mating section side)
2 pos.
3 pos.
4 pos.
2 1
2 1
3
2 1
4 3
5 pos.
3
5
2 1
4
6 pos.
3
6
2 1
5 4
5
7 pos.
13 pos.
24 pos.
2 1
4 3
7 6
3 2 1
7 6 5 4
11 10 9 8
13 12
5 4 3 2 1
10 9 8 7 6
15 14 13 12 11
20 19 18 17 16
24 23 22 21
BContact No. diagram
No.1
No.2
No.3
No.4
No.5
No.6
No.8
No.10
No.11
No.12
No.13
No.15
No.16
No.20
No.21
No.22
No.23
No.24
No.7
5
■Socket crimping contact
Part No.
HRS No.
DF62-22SCFA
DF62-2428SCFA
DF62-30SCFA
DF62-22SCA
DF62-2428SCA
DF62-30SCA
DF62-22SCF
DF62-2428SCF
DF62-30SCF
DF62-22SC
DF62-2428SC
DF62-30SC
CL544-0506-5-00
CL544-0500-9-00
CL544-0508-0-00
CL544-0526-2-00
CL544-0527-5-00
CL544-0528-8-00
CL544-0520-6-00
CL544-0521-9-00
CL544-0522-1-00
CL544-0572-0-00
CL544-0573-2-00
CL544-0574-5-00
Packaging type
Quantity
Reel contact (Note 1)
1 reel = 15,000 pieces
Finish
Selective gold
plating
Loose piece (Note 2)
1 pack = 100 pieces
Tin plating
1 pack = 100 pieces
(Note 1) This product is sold in full reel quantities (15,000 pieces per reel), please place orders in full reel increments.
(Note 2) This product is sold per pack (100 pieces per pack), please place orders in full pack increments.
●Applicable wire (tin plating soft copper wire)
Conductor size (pos. line structure)
Insulation diameter
22 AWG (17/Ø 0.16 mm)
24 AWG (11/Ø 0.16 mm)
26 AWG (7/Ø 0.16 mm)
28 AWG (7/Ø 0.127 mm)
30 AWG (7/Ø 0.1 mm)
Ø1.2 ∼ Ø1.45mm
Recommended UL wire
spec.
UL1061
Ø0.9 ∼ Ø1.45mm
UL1007
Ø0.75 ∼ Ø1.2mm
UL1061
Strip length
1.7 ∼ 2.3mm
Note: When using wires that are not recommended by Hirose, please contact one of our sales representatives for
clarification.
6
■Plug crimping contact
Product No.
HRS No.
DF62-EP22PCFA
DF62-EP2428PCFA
DF62-EP30PCFA
DF62-EP22PCA
DF62-EP2428PCA
DF62-EP30PCA
DF62-EP22PCF
DF62-EP2428PCF
DF62-EP30PCF
DF62-EP22PC
DF62-EP2428PC
DF62-EP30PC
CL544-0507-8-00
CL544-0501-1-00
CL544-0509-3-00
CL544-0529-0-00
CL544-0530-0-00
CL544-0531-2-00
CL544-0523-4-00
CL544-0524-7-00
CL544-0525-0-00
CL544-0575-8-00
CL544-0576-0-00
CL544-0577-3-00
Packaging type
Quantity
Finish
Selective gold
plating
Single contact (Note 2)
1 pack = 100 pieces
Tin plating
Single piece (Note 2)
1 pack = 100 pieces
30 AWG (7/Ø 0.1 mm)
Cover outer diameter
Recommended wires
Ø1.2 ∼ Ø1.45mm
UL1061
Ø0.9 ∼ Ø1.45mm
UL1007
Strip length
1.7 ∼ 2.3mm
Ø0.75 ∼ Ø1.2mm
UL1061
clarification.
7
BApplicable Crimping Tool
Type
Applicator
Press body
Hand tool
Part No.
HRS No.
AP105-DF62-22
CL901-4626-3-00
AP105-DF62-2428
CL901-4625-0-00
AP105-DF62-30
CL901-4627-6-00
CM-105
CL901-0005-4-00
HT801/DF62-22(10)
CL550-0401-9-10
HT801/DF62-2428(10)
CL550-0400-6-10
CL550-0402-1-10
Extraction tool
DF62/RE-MD
CL902-4645-4-00
Applicable Contact
DF62-22SCFA/SCF
DF62-EP22PCFA/PCF
DF62-2428SCFA/SCF
DF62-EP2428PCFA/PCF
DF62-30SCFA/SCF
DF62-EP30PCFA/PCF
DF62-22SCA/SC
DF62-EP22PCA/PC
*UL1061 22 AWG only
DF62-2428SCA/SC
DF62-EP2428PCA/PC
*UL1007 24, 26, 28 AWG only
DF62-30SCA/SC
DF62-EP30PCA/PC
*UL1061 30 AWG only
DF62-**SCFA/SCF/SCA/SC
DF62-EP**PCFA/PCF/PCA/PC
Note: Hirose does not warranty problems that arise from the use of unapproved tools on Hirose products.
BOperating Precautions
□ Do not tilt the plug while it is being inserted into the plug, this can lead to damage of the contacts and will downgrade its
performance.
For precautions when handling the harness, please refer to the "DF62 Series Inserting/Extracting Procedures".
□ The color of the resin on these connectors may vary depending on the manufacturing lot. This variance will not affect the
connector’s performance.
□ For precautions relating to insertion and extraction of this connector, please refer to the “DF62 Series Inserting/
Extracting Procedures”.
8
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
