山东晶导微电子股份有限公司
P6SMB Series
Jingdao Microelectronics co.LTD
Surface mount transient voltage suppressor power 600 watts
PINNING
Stand-Off Voltage:6.8V~550V
PIN
FEATURES
• For surface mounted applications in order to
optimize board space.
• Low profile package
• Glass passivated junction
• Low inductance
• Plastic package has Underwriters Laboratory
Flammability
DESCRIPTION
1
Cathode
2
Anode
2
Unipolar
1
Bipolar
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.1g / 0.0034oz
Simplified outline SMB and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Parameter
Peak Pulse Power Dissipation on 10/1000 s waveform
( Note1,Note2, Fig.1).
Symbol
Value
Unit
P PPM
600
W
100
A
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load, (JEDEC Method) (Note 3,Fig4).
(UNI)
Peak Pulse Current on 10/1000 us waveform (Note 1, Fig 3)
I PPM
see Table 1
A
Typical Junction capacitance at VR=4V, f=1MHz
CJ
390
pF
I FSM
V ESD1
V ESD2
30
30
kV
Typical Thermal Resistance Junction to Ambient(Note 2)
RθJA
100
°C/W
Operating Junction Temperature and Storage Temperature Range
T j , T stg
-65 ~ +150
°C
Contact
Air
ESD Voltage per IEC6100-4-2
NOTES:
1. Non-repetitive current pulse, per Fig.3 and derated above T A = 25°C per Fig. 2.
2
2. Mounted on 5 mm (0.13mm thick) land areas.
3. Measured on 8.3ms,single half sine-wave or equivalent square wave,duty cycle=4 pulses per minute maximum.
4. Peak pulse power waveform is 10/1000μS.
2017.01
SMB-TVS-P6SMB Series-600W
Page 1 of 4
山东晶导微电子股份有限公司
P6SMB Series
Characteristics at Ta=25°C
Reverse
Stand-off
Voltage
Type
UNI
Table 1
BI
Package:SMB
Breakdown
Voltage
Test
Current
V BR @ I T
IT
Maximum
Reverse
Leakage
Max. Clamp Peak Pulse
Current
Voltage
I PP
V C @ I PP
V RMW
Min
Max
V
V
V
mA
μA
V
A
Device Marking Ccode
UNI
BI
600W Transient Voltage Suppresso
P6SMB6.8A
P6SMB6.8CA
5.8
6.45
7.14
10
1000
10.5
58.1
6V8A
6V8C
P6SMB7.5A
P6SMB7.5CA
6.4
7.13
7.88
10
500
11.3
54
7V5A
7V5C
P6SMB8.2A
P6SMB8.2CA
7.02
7.79
8.61
10
200
12.1
50.4
8V2A
8V2C
P6SMB9.1A
P6SMB9.1CA
7.78
8.65
9.55
1
50
13.4
45.5
9V1A
9V1C
P6SMB10A
P6SMB10CA
8.55
9.5
10.5
1
10
14.5
42.1
10A
10C
P6SMB11A
P6SMB11CA
9.4
10.5
11.6
1
5
15.6
39.1
11A
11C
P6SMB12A
P6SMB12CA
10.2
11.4
12.6
1
5
16.7
36.5
12A
12C
P6SMB13A
P6SMB13CA
11.1
12.4
13.7
1
1
18.2
33.5
13A
13C
P6SMB15A
P6SMB15CA
12.8
14.3
15.8
1
1
21.2
28.8
15A
15C
P6SMB16A
P6SMB16CA
13.6
15.2
16.8
1
1
22.5
27.1
16A
16C
P6SMB18A
P6SMB18CA
15.3
17.1
18.9
1
1
25.5
24.2
18A
18C
P6SMB20A
P6SMB20CA
17.1
19
21
1
1
27.7
22
20A
20C
P6SMB22A
P6SMB22CA
18.8
20.9
23.1
1
1
30.6
19.9
22A
22C
P6SMB24A
P6SMB24CA
20.5
22.8
25.2
1
1
33.2
18.4
24A
24C
P6SMB27A
P6SMB27CA
23.1
25.7
28.4
1
1
37.5
16.3
27A
27C
P6SMB30A
P6SMB30CA
25.6
28.5
31.5
1
1
41.4
14.7
30A
30C
P6SMB33A
P6SMB33CA
28.2
31.4
34.7
1
1
45.7
13.3
33A
33C
P6SMB36A
P6SMB36CA
30.8
34.2
37.8
1
1
49.9
12.2
36A
36C
39A
39C
P6SMB39A
P6SMB39CA
33.3
37.1
41
1
1
53.9
11.3
P6SMB43A
P6SMB43CA
36.8
40.9
45.2
1
1
59.3
10.3
43A
43C
P6SMB47A
P6SMB47CA
40.2
44.7
49.4
1
1
64.8
9.4
47A
47C
P6SMB51A
P6SMB51CA
43.6
48.5
53.6
1
1
70.1
8.7
51A
51C
P6SMB56A
P6SMB56CA
47.8
53.2
58.8
1
1
77
7.9
56A
56C
P6SMB58A
P6SMB58CA
52.78
55.1
60.9
1
1
79.8
7.7
58A
58C
P6SMB62A
P6SMB62CA
53
58.9
65.1
1
1
85
7.2
62A
62C
P6SMB68A
P6SMB68CA
58.1
64.6
71.4
1
1
92
6.6
68A
68C
P6SMB75A
P6SMB75CA
64.1
71.3
78.8
1
1
103
5.9
75A
75C
82C
P6SMB82A
P6SMB82CA
70.1
77.9
86.1
1
1
113
5.4
82A
P6SMB91A
P6SMB91CA
77.8
86.5
95.5
1
1
125
4.9
91A
91C
P6SMB100A
P6SMB100CA
85.5
95
105
1
1
137
4.5
100A
100C
P6SMB110A
P6SMB110CA
94
105
116
1
1
152
4
110A
110C
P6SMB120A
P6SMB120CA
102
114
126
1
1
165
3.7
120A
120C
P6SMB130A
P6SMB130CA
111
124
137
1
1
179
3.4
130A
130C
P6SMB150A
P6SMB150CA
128
143
158
1
1
207
2.9
150A
150C
P6SMB160A
P6SMB160CA
136
152
168
1
1
219
2.8
160A
160C
P6SMB170A
P6SMB170CA
145
162
179
1
1
234
2.6
170A
170C
P6SMB180A
P6SMB180CA
154
171
189
1
1
246
2.5
180A
180C
P6SMB200A
P6SMB200CA
171
190
210
1
1
274
2.2
200A
200C
P6SMB220A
P6SMB220CA
185
209
231
1
1
328
1.9
220A
220C
P6SMB250A
P6SMB250CA
214
237
263
1
1
344
1.8
250A
250C
P6SMB300A
P6SMB300CA
256
285
315
1
1
414
1.5
300A
300C
P6SMB350A
P6SMB350CA
300
332
368
1
1
482
1.3
350A
350C
P6SMB400A
P6SMB400CA
342
380
420
1
1
548
1.1
400A
400C
P6SMB440A
P6SMB440CA
376
418
462
1
1
602
1
440A
440C
P6SMB480A
P6SMB480CA
408
456
504
1
1
658
0.9
480A
480C
P6SMB510A
P6SMB510CA
434
485
535
1
1
698
0.9
510A
510C
P6SMB530A
P6SMB530CA
451
503.5
556.5
1
1
725
0.8
530A
530C
P6SMB540A
P6SMB540CA
460
513
567
1
1
740
0.8
540A
540C
P6SMB550A
P6SMB550CA
468
522.5
577.5
1
1
760
0.8
550A
550C
山东晶导微电子股份有限公司
P6SMB Series
Fig.2 Forward Current Derating Curve
100
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
10
1.0
0.1
0.1
1
10
100
1000
10000
PEAK PULSE POWER(PPP)OR CURRENT(Ipp)
DERATINGIN PERCENTAGE%
P PPM ,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
100
80
60
40
I ppm ,Peak Pulse Current (%)
Peak Value
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
I ppm
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
2.0
3.0
4.0
I FSM ,PEAK FORWARD SURGE CURRENT,
AMPERES
T A =25°C
100
125
150
175
120
100
80
60
40
T,TIME,ms
2017.01
100
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Pulse Waveform
t f =10usec
75
T A ,AMBIENT TEMPERATURE,°C
td,PULSE WIDTH ,us
120
50
T J =T J max
8.3ms Single Half Sinepwave
JEDEC Method
10
100
Number of Cycles at 60Hz
www.sdjingdao.com
Page 3 of 4
山东晶导微电子股份有限公司
P6SMB Series
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.11
3.3
5.08
0.05
0.8
0.152
1.91
155
220
7.9
59
12
83
200
2.0
32
6
75
E1
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
160
130
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2017.01
JD 80404 7B2/8B4/9B5
Page 4 of 4
很抱歉,暂时无法提供与“P6SMB47CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.17699
- 100+0.16519
- 300+0.15339
- 500+0.14159
- 2000+0.13569
- 5000+0.13215
