1S2638
1S2638
    ST(先科)
    DO-204AH, DO-35, Axial
    调谐器AFC二极管
1S2638 数据手册
1S2638 TUNER AFC DIODE The 1S2638 is a variable capacitor diode intended for AFC applications, VHF TV applications, FM receivers. Air craft Max. 0.5 Max. 0.45 communications gear, and other receivers Min. 27.5 Min. 27.5 Max. 1.9 Max. 1.9 in the 1 MHz to 500 MHz. Black Cathode Band Black Part No. Black "ST" Brand Black Cathode Band XXX Black Part No. Max. 3.9 ST XXX Max. 2.9 Standard package is DO-35 case, DO-34 case is available upon request. Min. 27.5 Min. 27.5 Glass Case DO-34 Dimensions in mm Glass Case DO-35 Dimensions in mm Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit BV 10 V Forward Current IF 250 mA Power Dissipation PD 350 mW Operating Temperature Range Topr - 65 to + 175 O Storage Temperature Range Tstg - 65 to + 200 O Breakdown Voltage C C Characteristics at Ta = 25 OC Parameter Symbol Min. Max. Unit Reverse Current at VR = 10 V IR - 5 µA Nominal Capacitance at VR = 4 V, f = 1 MHz C 5 20 pF Q 50 - - at VR = 4 V, f = 100 MHz SEMTECH ELECTRONICS LTD. (Subsidiary of Sino-Tech International Holdings Limited, a company listed on the Hong Kong Stock Exchange, Stock Code: 724) ® Dated : 20/06/2007 1S2638 SEMTECH ELECTRONICS LTD. (Subsidiary of Sino-Tech International Holdings Limited, a company listed on the Hong Kong Stock Exchange, Stock Code: 724) ® Dated : 20/06/2007
1S2638 价格&库存
很抱歉,暂时无法提供与“1S2638”相匹配的价格&库存,您可以联系我们找货
1S2638
    • 20+0.14303
    • 200+0.12482
    • 500+0.10088
    • 2000+0.09481
    • 10000+0.08955
    • 20000+0.08672
    库存:37022
    1S2638
      • 1+0.07515
      • 10+0.06894
      • 30+0.06769
      • 100+0.06397
      库存:500
