ESD5Z3V3
ESD5Z3V3
1-Line Uni-directional Transient Voltage Suppres-
Http//:www.willsemi.com
sors
Descriptions
The ESD5Z3V3 is a transient voltage suppressors
(TVS) which provide a very high level protection for
sensitive electronic components that may be subjected
SOD-523
to electrostatic discharge (ESD). It is designed to replace multilayer varistors (MLV) in consumer equipments applications such as mobile phone, notebook,
PAD, STB, LCD TV etc.
The ESD5Z3V3 was past ESD transient voltage
up to ±30kV (contact) according to IEC61000-4-2 and
Pin configuration (Top view)
withstand peak current up to 9A for 8/20us pulse according to IEC61000-4-5.
The ESD5Z3V3 is available in SOD-523 package.
Standard products are Pb-free and Halogen-free.
5*
Features
SOD-523
Working voltage
: 3.3V
5
= Device code
Peak power (tp=8/20us)
: 108W
= Month code (A~Z)
ESD protection
Marking
IEC61000-4-2 (Contact)
: ±30kV
IEC61000-4-2 (Air)
: ±30kV
Low leakage current
Small package
Order information
Applications
Mobile phone
PAD
Notebook
STB
LCD TV
Digital camera
Other electronics equipments
Will Semiconductor Ltd.
1
Device
Package
Shipping
ESD5Z3V3-2/TR
SOD-523
3000/Tape&Reel
Dec, 2012 - Rev. 2.0
ESD5Z3V3
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp=8/20us)
Ppk
108
W
Peak pulse current (tp=8/20us)
Ipp
9
A
ESD voltage IEC61000-4-2 air
±30
VESD
ESD voltage IEC61000-4-2 contact
Junction temperature
125
o
-40~85
o
260
o
-55~150
o
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
kV
±30
TSTG
C
C
C
C
Electronics characteristics (Ta=25 oC, unless otherwise noted)
Parameter
Symbol
Reverse maximum working voltage
VRWM
IR
Max.
Unit
3.3
V
VRWM=1V
0.1
uA
VRWM=4.2V
10
uA
Min.
Typ.
Reverse breakdown voltage
VBR
IT=1mA
4.8
5.2
5.4
V
Forward voltage
VF
IF=-10mA
0.55
0.8
1.25
V
Clamping voltage
VC
Ipp=1A tp=8/20us
6.5
V
Ipp=9A tp=8/20us
12
V
Junction capacitance
C
90
pF
110
100
90
80
70
60
50
40
30
F=1MHz, VR=0V
Duration=20us
10
15
30
Peak Pulse time (us)
35
10
30ns
tr=0.7~1ns
40
8/20us waveform
70
100
90
Front times=1.25*( t90-t10) =8us
Peak Pulse Current (%)
Reverse leakage current
Condition
60ns
IEC61000-4-2 waveform
2
t
ESD5Z3V3
o
Typical characteristics (Ta=25 C, unless otherwise noted)
15
80
10
5
6
Fsignal =1MHz
C - Junction capacitance (pF)
VC - Clamping voltage (V)
Pulse waveform: tp=8/20us
70
Vsignal =50mVrms
60
50
40
30
9
Ipp - Peak pulse current (A)
2
3
4
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reveres voltage
1000
100
% of Rated power
Peak Pulse Power (W)
100
10
80
60
40
10
100
Pulse Duration(us)
1000
50
75
100
125
TA - Ambient temperature ( C)
Non-Repetitive Peak Pulse Power vs. Pulse time
Power derating vs. Temperature
ESD Clamping
ESD Clamping
(IEC61000-4-2 +8kV contact)
(IEC61000-4-2 -8kV contact)
150
o
3
ESD5Z3V3
Package outline dimensions
SOD-523
Symbol
Dimensions in millimeter
Min.
Typ.
Max.
A
0.510
0.770
A1
0.500
0.700
b
0.250
c
0.080
D
0.750
0.800
0.850
E
1.100
1.200
1.300
E1
1.500
1.600
1.700
0.300
0.150
E2
L
θ
0.350
0.200 Ref.
0.010
0.070
o
8o
Recommend PCB Layout (Unit: mm)
4
很抱歉,暂时无法提供与“ESD5Z3V3-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09900
- 500+0.08910
- 5000+0.08250
- 10000+0.07920
- 30000+0.07590
- 50000+0.07392
