富满微电子集团股份有限公司
FINE MADE MICROELECTRONICS GROUP CO., LTD.
AMS1117(文件编号:S&CIC0539)
800mA Adjustable & Fixed Voltage LDO Linear Regulator
General description
The AMS1117 is a low-dropout linear regulator that operates in the input voltage range from +2.5V to +12.0V and delivers
800mA output current.
The AMS1117 is available in two types, fixed output voltage type or adjustable output voltage type. The fixed output voltage
type is preset at an internally trimmed voltage 1.8V, 2.5V, or 3.3V. Other options 1.5V, 2.85V, 3.0V and 3.6V are available by
special order only. The output voltage range of the adjustable type is from 1.25V to 5V.
The AMS1117 consists of a 1.25V bandgap reference, an error amplifier, and a P-channel pass transistor. Other features
include short-circuit protection and thermal shutdown protection. The AMS1117 devices are available in SOT-223 and
TO-252 packages.
Features
Low dropout voltage 1300mV at 800mA typ.
Adjustable output voltage (AMS1117-Cx) or fixed output voltage (AMS1117-xxCx) preset at 1.8V, 2.5V, or 3.3V
High output voltage accuracy
Fixed output voltage: Vout±2%mV
Adjustable output voltage: ±50mV
Small output capacitor
Output current limit
Thermal overload shutdown protection
SOT-2231 and TO-252 packages
2
3
Applications
D
Active SCSI terminators
AM S1 11 7- XX X X
High efficiency linear Package
regulators
G:SOT-223 1.IN
Monitor microprocessors
H:SOT-223 1.GND
J:SOT-223 1.GND
Low voltage micro-controllers
P:TO-252 1.IN
R:TO-252 power
1.GND
Post regulator for switching
Pin Out
2.GND 3.OUT
2.IN 3.OUT
2.OUT 3.IN
2.GND 3.OUT
2.OUT 3.IN
Note:For the adjustable voltage types,the
GND pin is replaced with the ADJ pin
Temperature Range
Ordering information
C:Commercial Standard
AMS1117-- XX
P:Commercial Standard,Lead(Pb)
Free and phosphorous(P) Free Package
Output Voltage
(For fixed voltage types lnly.for adjustable
voltage types,these two digits are eliminated.)
15:1.5V 18:1.8V 25:2.5V
29:2.85V 30:3.0V 33:3.3V
36:3.6V
Default: Adjustable Output
C
Note:The output voltages other than the preset
values are available by order only.
www.superchip.cn
第 1 页 共 11 页
Version 1.1
富满微电子集团股份有限公司
Pin configurations
PartNo.
Pin1C
Pin2
Pin3
AMS1117-XX
GND/ADJ
OUT
(TAP)
IN
TO-252
SOT-223
AMS1117
XXXXXXXX
AMS1117
XXXXXXXX
2
1
1
2
3
3
B
Pin description
Part No
Symbol
Description
GND/ADJ
Ground pin or adjust terminal pin
IN
Regulator input pin
OUT
Regulator output pin
AMS1117-xx
IN
is the regulator input pin. Supply voltage can range from 2.5V to 12.0V. Bypass with a 10uF capacitor to GND.
OUT is the output voltage pin. Sources up to 800mA. Bypass with a 10uF capacitor to GND.
GND provides the reference for all voltages.
ADJ provides VREF=1.25V (TYP.) for adjustable output voltage.
A
1
2
www.superchip.cn
2
3
第 2 页 共 11 页
Version 1.1
富满微电子集团股份有限公司
1
2
3
3
4
4
Typical application circuit
5
5
6
AMS1117-Cx
VIN
VIN
10uF
VOUT
VOUT
10uF
ADJ
D
VREF R1
IADJ
VOUT=VREF×(1+R2/R1)+Iadj×R2
R2
AMS1117-xxCx
VIN
VIN
10uF
VOUT
VOUT
10uF
ADJ
C
Functional block diagrams
IN
IN
Current Limit
Current Limit
Thermal
Protection
B
Thermal
Protection
Shutdown
Logic
Shutdown
Logic
OUT
1.25V
Bandgap
Reference
OUT
1.25V
Bandgap
Reference
R1
R2
GND
Fixed Voltage Type
ADJ
Title
Adjustable Voltage Type
Size
Nu mber
A
B
Date:
File:
Title
1
2
3
Size
Absolute maximum ratings
3
4
1 8-Mar-2 0 08
E:\规格书\规格图\规格图-0 \ZBO\SC1
5
Revision
Number
B
Date:
File:
4
5
11-May -2006
Sheet of
E:\规格书\规格图\规格图-0\ZBO\SC8860.ddb Drawn By :
6
Input voltage VIN to GND-----------------------------------------------------------------------------12.0V
Output current limit, I(LIMIT)-----------------------------------------------------------------------------------------------------------------800mA
Continuous power dissipation------------------------------------------------------------------------Internally limited
Junction temperature, TJ----------------------------------------------------------------------------------------------------------------------+155℃
Storage temperature range, TSTG---------------------------------------------------------------------------------------------------------55℃ to +150℃
Operating junction temperature range---------------------------------------------------------------40℃ to +125℃
Lead temperature (soldering, 10sec)----------------------------------------------------------------260℃
* Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are
stress ratings only, and function operation of the device at these or any other conditions beyond those indicated under
“recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods
may affect device reliability
www.superchip.cn
第 3 页 共 11 页
Version 1.1
富满微电子集团股份有限公司
Electrical characteristics(CIN=10uF, COUT=10uF, TA=25℃, unless otherwise noted.)
Symbol
Parameter
VIN
Input voltage
VOUT
△VOUT
Output voltage
Output voltage accuracy
Test Conditions
Maximum output current
ILIMIT
Current limit
Typ
2.5
Max
Unit
12.0
V
Fixed voltage type
VIN=VOUT+1.0V, IOUT=1mA
VOUT*
(1-2%)
VOUT
VOUT*(1
+2%)
V
Adjustable voltage type
VIN=VOUT+1.2V, IOUT=1mA
1.2
1.25
1.3
V
VIN>VOUT+2.0V,
voltage type)
VIN ≤ 12V(fixed
VIN>VOUT+1.5V, VIN≤12V(adjustable
voltage type)
IMAX
Min
-VOUT*2
+VOUT*2
-50
+50
0.8
mV
A
2.1
A
300
500
mA
ISC
Short-circuit current
IQ
Ground pin current
ILOAD=0mA, VIN=VOUT+1.0V
2
5
mA
IADJ
ADJ pin current
ILOAD=0mA to 800mA, VIN=5.0V
55
150
uA
IOUT=100mA
1200
1300
mV
VDROP
Dropout voltage
(fixed output voltage
Version )
IOUT=500mA
1200
1300
mV
IOUT=700mA
1300
1500
mV
VOUT+1.5V
很抱歉,暂时无法提供与“AMS1117-3.3V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.13520
- 100+0.12960
- 500+0.12400
