ME2108
8 Series
ME2108
PFM Step-up DC/DC Converter, ME210
General Description
Features
ME2108 Series is a PFM Step-up DC/DC converter
IC with low supply current by CMOS process. High
frequency noise that occurs during switching is
reduced by using advanced circuit designed, output
voltage is programmable in 0.1V steps between
2.0~7.0V and maximum frequency is 180KHz(TYP.).
A low ripple, high efficiency step-up DC/DC
converter can be constructed of ME2108Xxx with
only three external components. Also available is a
CE(chip enable) function that reduce
power
dissipation During shut-down mode. ME2108Xxx is
suitable for use with battery-powered instruments
with low noise and low supply current.
Selection Guide
Typical Application
Power source for battery-powered equipment
Power source for wireless mouse, wireless
keyboard, toys, cameras, camcorders, VCRs,
PDAs, and hand-held communication equipment
Power source for appliances which require higher
cell voltage than that of batteries used in the
appliances
V10.0
Low ripple and low noise
Operating voltage range:0.9V~6.5V
Output voltage range:2.0V~7.0V(step 0.1V)
Output voltage accuracy:±2.5%
Output Current:If VIN=3.0V and VOUT=5.0V,then
IOUT=400mA
Low start voltage:≤0.9V(at IOUT =1mA)
Maximum oscillator frequency:180KHz(TYP.)
High Efficiency:85%(TYP.)
Package:SOT23、SOT89、TO92
1
ME2108
Pin Configuration
Pin Assignment
TYPE
POSTFIX
PACKAGE
M3
SOT23-3
P
SOT89-3
T1
TO92
M3
SOT23-3
P
SOT89-3
M5
SOT23-5
P
SOT89-5
M5
SOT23-5
P
SOT89-5
M5
SOT23-5
ME2108Axx
ME2108Bxx
ME2108Cxx
ME2108Dxx
ME2108F
SWITCHING TRANSISTOR
CE FUNCTION
FEATURES
Build in Transistor
No
Lx
External Transistor
No
Ext
Build in Transistor
Yes
Lx CE
External Transistor
Yes
Ext CE
External Transistor
Yes
Ext
ME2108AXX
PIN Number
Pin Name
Function
1
Vss
Ground
2
3
Vout
3
2
Lx
Switch
Pin Name
Function
Ground
SOT23-3
SOT89-3
TO92
1
1
3
2
ME2108BXX
PIN Number
SOT23-3
SOT89-3
1
1
Vss
3
2
Vout
2
3
Ext
V10.0
Output voltage monitor, IC internal power supply
External switch transistor drive
2
ME2108
ME2108CXX
PIN Number
Pin Name
Function
5
Vss
Ground
2
2
Vout
5
4
Lx
Switch
1
3
CE
Chip enable
3
1
NC
NC
Pin Name
Function
SOT23-5
SOT89-5
4
XX
ME2108DXX
ME2108D
PIN Number
SOT23-5
SOT89-5
4
5
Vss
Ground
2
2
Vout
5
4
Ext
1
3
CE
Chip enable
3
1
NC
NC
ME2108F
PIN Number
Pin Name
Function
1
FB
Feed Back
2
Vdd
3
NC
NC
4
Vss
Ground
5
EXT
SOT23-5
V10.0
3
ME2108
Absolute Maximum Ratings
PARAMETER
SYMBAL
RATINGS
UNITS
VIN Input Voltage
VIN
6.5
V
Lx Pin voltage
VLX
6.5
V
EXT Pin voltage
VEXT
-0.3~Vout+0.3
V
CE Pin voltage
VCE
-0.3~Vout+0.3
V
Lx Pin current
ILX
600
mA
EXT Pin current
IEXT
±30
mA
Vdd input voltage
Vdd
6.5
V
SOT23
Pd
300
mW
SOT89
Pd
500
mW
TO92
Pd
500
mW
Operating Ambient Temperature
TOpr
-25~+85
Storage Temperature
Tstg
-40~+125
Soldering temperature and time
Tsolder
260℃, 10s
Continuous Total Power Dissipation
Block Diagram
V10.0
4
ME2108
Electrical Characteristics
Measuring conditions:Unless otherwise specified , VIN=Vout×0.6,VSS=0V,IOUT=10mA,Topt=25℃。
ME2108Axx/Cxx Fosc=180kHz
SYMBOL
PARAMETER
CONDITIONS
MIN
TYP
MAX
UNITS
Vout×
0.975
Vout
Vout×
1.025
V
0.9
V
VOUT
Output Voltage
Vstart
Oscillation Start-up
Voltage
IOUT=1mA,
VIN:0→2V
0.8
Vhold
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.45
V
IDD1
Supply Current 1
No external component
Vout=Vout×0.95,
50
µA
IDD2
Supply Current 2
Vout=Vout+0.5V
9
µA
ILX
Lx Switching Current
VLX=0.4V,
Vout=Vout×0.95
360
mA
ILXleak
Lx Leakage Current
Vout=VLX=6V
Fosc
Oscillation
Frequency
Vout=set Vout×0.95
180
kHz
Maxdty
Duty Ratio
on(VLX“L”)side
84
85
EFFI
ME2108Bxx/Dxx
0.5
Efficiency
µA
Fosc=180kHz
MIN
TYP
MAX
UNITS
Vout×
0.975
Vout
Vout×
1.025
V
IOUT=1mA,
VIN:0→2V
0.8
0.9
V
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.45
V
IDD1
Supply Current 1
Vout=Vout×0.95,
80
µA
IDD2
Supply Current 2
Vout=Vout+0.5V
12
µA
ILX
VLX=0.4V,
Vout=Vout×0.95
360
mA
ILXleak
Lx Leakage Current
Vout=VLX=6V
Fosc
Oscillation
Frequency
Vout=set Vout×0.95
180
kHz
Maxdty
Duty Ratio
on(VLX“L”)side
84
EFFI
Efficiency
85
SYMBOL
PARAMETER
VOUT
Output Voltage
Vstart
Voltage
Vhold
V10.0
CONDITIONS
0.5
µA
5
ME2108
ME2108F
VFB=3.3V , Fosc=180kHz
SYMBOL
PARAMETER
VFB
Output Feedback
Voltage
Vstart
Voltage
Vhold
CONDITIONS
MIN
TYP
MAX
UNITS
3.22
3.3
3.38
V
IOUT=1mA,
VIN:0→2V
0.8
0.9
V
Oscillation Hold
Voltage
IOUT=1mA,
VIN:2→0V
0.45
V
IDD1
Supply Current 1
Vout=Vout×0.95,
80
µA
IDD2
Supply Current 2
Vout=Vout+0.5V
10
µA
ILX
VLX=0.4V,
Vout=Vout×0.95
360
mA
ILXleak
Lx Leakage Current
Vout=VLX=6V
Fosc
Oscillation
Frequency
Vout=set Vout×0.95
180
kHz
Maxdty
Duty Ratio
on(VLX“L”)side
84
EFFI
Efficiency
85
0.5
µA
Note:1、Diode use Schottky diode such as IN5817 or IN5819 (forward voltage drop:0.2V)
2、Inductor:33μH(r
很抱歉,暂时无法提供与“ME2108A50M3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.44496
- 100+0.35856
- 300+0.31536
- 3000+0.26784
- 国内价格
- 5+0.27686
- 20+0.27178
- 100+0.26162
