NSi6801
Single-Channel Isolated Gate Driver
Datasheet (EN) 1.0
Product Overview
Applications
The NSi6801 is a single-channel isolated gate driver which
is pin-compatible for popular opto-coupled gate driver. It
can source and sink 5A peak current. System robustness is
supported by 150kV/us minimum common-mode
transient immunity (CMTI).
The driver operates with a maximum supply voltage of
32V. While the input circuit imitates the characters of LEDs,
it has performance advantages compared to standard
opto isolated gate drivers, including better reliability and
aging performance, higher working temperature, shorter
propagation delay and smaller pulse width distortion.
As a result, the NSi6801 is suitable to replace opto-isolated
driver in high reliability, power density and efficiency
switching power system.
DC-to-AC solar inverters
Motor drives
UPS and battery chargers
Isolated DC/DC and AC/DC power supplies
Pin compatible, drop in upgrade for opto isolated gate
drivers
Driver side supply voltage: up to 32V with UVLO
5A peak source and sink output current
High CMTI: ±150kV/us
75ns typical propagation delay
30ns maximum pulse width distortion
Operation ambient temperature: -40°C ~125°C
RoHS-compliant packages:
NSi6801x-DDBR
DUB8
9.32mm × 6.4mm
Functional Block Diagram
ANODE 1
NC 2
6 VCC
UVLO
e
5 VOUT
CATHODE 3
4 VEE
Figure 1. NSi6801 SOW6 Block Diagram
NC 1
8 VCC
UVLO
ANODE 2
7 VOUT
e
6 VOUT
CATHODE 3
BARRIER
Body Size
7.5mm × 4.68mm
ISOLATION
Isolated single-channel driver
Package
SOW6
BARRIER
Part Number
NSi6801x-DSWFR
ISOLATION
Key Features
Device Information
NC 4
5 VEE
SOIC-6 wide body (SOW6)
DUB-8
UL recognition: 5700VRMS SOW6 and 5000VRMS DUB8 for
1 minute per UL1577
DIN VDE V 0884-11:2017-01
CSA component notice 5A
CQC certification per GB4943.1-2011
Copyright © 2021, NOVOSENSE
ANODE 2
8 VCC
UVLO
7 NC
e
CATHODE 3
NC 4
6 VOUT
BARRIER
NC 1
ISOLATION
Safety Regulatory Approvals
Figure 2. NSi6801T DUB8 Block Diagram
5 VEE
Figure 3. NSi6801L DUB8 Block Diagram
Page 1
NSi6801
INDEX
1. PIN CONFIGURATION AND FUNCTIONS ............................................................................................................................... 3
2. ABSOLUTE MAXIMUM RATINGS .......................................................................................................................................... 4
3. RECOMMENDED OPERATING CONDITIONS ......................................................................................................................... 4
4. THERMAL INFORMATION .................................................................................................................................................... 4
5. SPECIFICATIONS .................................................................................................................................................................. 5
5.1.
5.2.
5.3.
5.4.
DC ELECTRICAL CHARACTERISTICS ..................................................................................................................................... 5
SWITCHING ELECTRICAL CHARACTERISTICS .......................................................................................................................... 6
TYPICAL PERFORMANCE CHARACTERISTICS .......................................................................................................................... 6
PARAMETER MEASUREMENT INFORMATION........................................................................................................................ 8
6. HIGH VOLTAGE FEATURE DESCRIPTION ............................................................................................................................... 9
6.1.
6.2.
6.3.
6.4.
6.5.
6.6.
6.7.
INSULATION AND SAFETY RELATED SPECIFICATIONS ............................................................................................................... 9
DIN VDE V 0884-11 (VDE V 0884-11): 2017-01 INSULATION CHARACTERISTICS FOR SOW6 PACKAGE .................................... 10
SAFETY-LIMITING VALUES FOR SOW6 PACKAGE ................................................................................................................ 11
REGULATORY INFORMATION FOR SOW6 PACKAGE ............................................................................................................. 12
DIN VDE V 0884-11 (VDE V 0884-11): 2017-01 INSULATION CHARACTERISTICS FOR DUB8 PACKAGE..................................... 13
SAFETY LIMITING VALUES FOR DUB8 PACKAGE ................................................................................................................. 14
REGULATORY INFORMATION FOR DUB8 PACKAGE .............................................................................................................. 15
7. FUNCTION DESCRIPTION ................................................................................................................................................... 16
7.1.
7.2.
7.3.
7.4.
7.5.
7.6.
FUNCTIONAL BLOCK DIAGRAM ....................................................................................................................................... 16
TRUTH TABLES ........................................................................................................................................................... 16
OUTPUT STAGE........................................................................................................................................................... 16
VCC AND UNDER VOLTAGE LOCK OUT (UVLO)................................................................................................................... 17
ACTIVE PULL-DOWN .................................................................................................................................................... 17
SHORT CIRCUIT CLAMPING ............................................................................................................................................ 17
8. APPLICATION NOTE ........................................................................................................................................................... 18
8.1.
8.2.
8.3.
8.4.
TYPICAL APPLICATION .................................................................................................................................................. 18
INTERLOCK PROTECTION ............................................................................................................................................... 19
SELECTING INPUT RESISTOR ........................................................................................................................................... 19
PCB LAYOUT .............................................................................................................................................................. 19
9. PACKAGE INFORMATION ................................................................................................................................................... 20
10. ORDERING INFORMATION .............................................................................................................................................. 22
11. DOCUMENTATION SUPPORT ........................................................................................................................................... 22
12. TAPE AND REEL INFORMATION ....................................................................................................................................... 23
13. REVERSION HISTORY ....................................................................................................................................................... 25
Page 2
NSi6801
Datasheet (EN) 1.0
1. Pin Configuration and Functions
NSi6801 SOW6 Top View
ANODE
NC
CATHODE
1
6
2
5
3
4
VCC
VOUT
VEE
NSi6801T DUB8 Top View
NC
ANODE
CATHODE
NC
NSi6801L DUB8 Top View
1
8
2
7
3
6
4
5
NC
VCC
ANODE
VOUT
CATHODE
VOUT
NC
VEE
1
8
2
7
3
6
4
5
VCC
NC
VOUT
VEE
Table 1.1 NSi6801 Pin Configuration and Description
PIN NO.
SYMBOL
FUNCTION
NSi6801 SOW6
NSi6801T DUB8
NSi6801L DUB8
ANODE
1
2
2
Anode of LED emulator
CATHODE
3
3
3
Cathode of LED emulator
VEE
4
5
5
Negative output supply rail
VOUT
5
6, 7
6
Gate-drive output
VCC
6
8
8
Positive output supply rail
NC
2
1, 4
1, 4, 7
No Connection
Page 3
NSi6801
Datasheet (EN) 1.0
2. Absolute Maximum Ratings
Parameters
Symbol
Min
Max
Unit
Average Input Current
IF_AVG
25
mA
Peak Transient Input Current
IF_PEAK
0.2
A
Reverse Input Voltage
VR_MAX
6.5
V
Driver Side Supply Voltage
VCC-VEE
-0.3
35
V
VOUT
VEE-0.3
VCC+0.3
V
Operating Junction Temperature
TJ
-40
150
°C
Storage Temperature
Tstg
-65
150
°C
VESD_HBM
±2000
V
VESD_CDM
±1000
V
Output Signal Voltage
Electrostatic discharge
3. Recommended Operating Conditions
Parameters
Symbol
Min
Max
Unit
Input Current (ON)
IF(ON)
7
16
mA
Input Voltage (OFF)
VF(off)
-5.5
0.9
V
Driver Side Supply Voltage (NSi6801C)
VCC-VEE
14
32
V
Driver Side Supply Voltage (NSi6801B)
VCC-VEE
10
32
V
TA
-40
125
°C
Ambient Temperature
4. Thermal Information
NSi6801
Parameters
Symbol
Unit
SOW6
DUB8
Junction–to-ambient thermal resistance
RθJA
125
110
°C/W
Junction–to-top characterization parameter
ΨJT
30
30
°C/W
Page 4
NSi6801
Datasheet (EN) 1.0
5. Specifications
5.1. DC Electrical Characteristics
(Unless otherwise noted, Typical values are at VCC =15V, VEE=GND, TA=25°C. All min and max specifications are at TJ=-40°C to 150°C,
VCC=15V to 30V, VEE=GND, IF(ON)=7 mA to 16 mA, VF(off)= –5.5V to 0.8V)
Parameter
Symbol
Min
Typ
Max
Unit
Condition
Driver Side Supply
High Level Supply Current
ICCH
1.7
3
mA
IF=10mA, IOUT=0mA
Low Level Supply Current
ICCL
1.6
3
mA
VF=0V, IOUT=0mA
Driver Side Supply UVLO Threshold (NSi6801C, 13V UVLO Level)
VCC UVLO Rising Threshold
VCC_ON
12.6
13.2
13.7
V
VCC UVLO Falling Threshold
VCC_OFF
11.7
12.3
12.7
V
VCC UVLO Hysteresis
VCC_HYS
0.9
IF=10mA
V
Driver Side Supply UVLO Threshold (NSi6801B, 9V UVLO Level)
VCC2 UVLO Rising Threshold
VCC2_ON
8.7
9.2
9.7
V
VCC2 UVLO Falling Threshold
VCC2_OFF
8
8.5
9
V
VCC2 UVLO Hysteresis
VCC2_HYS
0.7
IF=10mA
V
Input Pin Characteristic
Input Forward Threshold Current Low to
High
IFLH
1.5
Threshold Input Voltage High to Low
VFHL
0.9
VF
1.8
Input Forward Voltage
Temp Coefficient of Input Forward
Voltage
ΔVF/ΔT
Input Reverse Breakdown Voltage
VR
Input Capacitance
CIN
2.7
mA
VOUT>5V, Cg=1nF
V
VOUT
很抱歉,暂时无法提供与“NSI6801C-DSWFR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.90000
- 30+2.80000
- 100+2.60000
- 500+2.40000
- 1000+2.30000
