RS0102
2-Bit Bidirectional Voltage-Level Translator for
Open-Drain and Push-Pull Application
Features
Description
This two-bit non-inverting translator is a bidirectional
voltage-level translator and can be used to establish
digital switching compatibility between mixed-voltage
systems. It uses two separate configurable power-supply
rails, with the A ports supporting operating voltages from
1.65V to 5.5V while it tracks the VCCA supply, and the B
ports supporting operating voltages from 2.3V to 5.5V
while it tracks the VCCB supply. This allows the support of
both lower and higher logic signal levels while providing
bidirectional translation capabilities between any of the
1.8V, 2.5V, 3.3V and 5V voltage nodes.
No Direction-Control
Data Rates
24Mbps (Push-Pull)
2Mbps (Open-Drain)
1.65V to 5.5V on A ports and 2.3V to 5.5V
on B Ports (VCCA≤VCCB)
VCC Isolation: If Either VCC is at GND, Both
Ports are in the High-Impedance State
No Power-Supply Sequencing Required:
Either VCCA or VCCB can be Ramped First
IOFF: Supports Partial-Power-Down Mode
Operation
Extended Temperature: -40°C to +85°C
When the output-enable (OE) input is low, all I/Os are
placed in the high-impedance state, which significantly
reduces the power-supply quiescent current consumption.
OE has an internal pull-down current source, as long as
VCCA is powered.
Applications
I2C/ SMBus
UART
GPIO
To ensure the high-impedance state during power up or
power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is
determined by the current-sourcing capability of the driver.
The RS0102 is available in Green SOT-23-8 packages. It
operates over an ambient temperature range of -40°C to
+85°C.
Functional Block Diagram
VCCB
VCCA
OE
One Shot
Accelerator
One Shot
Accelerator
Gate Bias
10KΩ
10KΩ
A1
B1
One Shot
Accelerator
One Shot
Accelerator
Gate Bias
10KΩ
10KΩ
A2
REV A.1
B2
1
www.run-ic.com
010-67713792 sale@starttodo.com.cn
RS0102
PIN CONFIGURATIONS
VCCB
1
8
VCCA
B1
2
7
A1
B2
3
6
A2
OE
4
5
GND
VCCA
1
8
VCCB
A1
2
7
B1
A2
3
6
B2
GND
4
5
OE
DFN-1.4X1-8L
SOT-23-8
PIN DESCRIPTION
PIN
NAME
TYPE (1)
8
VCCB
P
2
7
B1
I/O
Input/output B1. Reference to VCCB.
3
6
B2
I/O
Input/output B2. Reference to VCCB.
4
5
OE
I
Output Enable (Active High). Pull OE low to place
all outputs in 3-state mode. Referenced to VCCA.
5
4
GND
Ground.
6
3
A2
I/O
Input/output A2. Reference to VCCA.
7
2
A1
I/O
Input/output A1. Reference to VCCA.
8
1
VCCA
P
SOT-23-8
DFN-1.4X1-8L
1
FUNCTION
B Ports Supply Voltage.2.3V ≤ VCCB ≤ 5.5V.
A Port Supply Voltage.1.65V ≤ VCCA ≤ 5.5V and
VCCA ≤ VCCB.
(1) I=input, O=output, I/O=input and output, P=power
2
www.run-ic.com
RS0102
PIN CONFIGURATIONS
B2
1
8
B1
GND
2
7
VCCB
VCCA
3
6
OE
A2
4
5
A1
VSSOP-8
PIN DESCRIPTION
PIN
NAME
TYPE (1)
1
B2
I/O
2
GND
Ground.
3
VCCA
P
A Port Supply Voltage.1.65V ≤ VCCA ≤ 5.5V and VCCA ≤ VCCB
4
A2
I/O
5
A1
I/O
6
OE
I
Output Enable (Active High). Pull OE low to place all outputs
7
VCCB
P
8
B1
I/O
VSSOP-8
FUNCTION
3
www.run-ic.com
RS0102
ABSOLUTE MAXIMUM RATINGS (1)
VCCA, Supply Voltage Range................................−0.3V to 6V
VCCB, Supply Voltage Range................................−0.3V to 6V
VI, A Ports, B Ports, OE Input Voltage Range (2)…−0.3V to 6V
VO, Voltage Range Applied to Any Output in the HighImpedance or Power-Off State (2)
A Ports ……………………………………..........−0.3V to 0.6V
B Ports ………………………………………......−0.3V to 0.6V
VO, Voltage Range Applied to Any Output in the High or Low
Impedance or Power-Off State (2)(3)
A Ports ……………………………..…...−0.3V to VCCA + 0.3V
B Ports …………………………………..−0.3V to VCCB +0.3V
IIK, Input Clamp Current (VI
很抱歉,暂时无法提供与“RS0102YH8”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.88944
- 30+0.85790
- 100+0.82636
- 500+0.76328
- 1000+0.73174
- 2000+0.71282
- 国内价格
- 1+1.07970
- 200+0.74590
- 1500+0.67760
- 国内价格
- 5+2.03630
- 50+1.67420
- 150+1.49740
- 500+1.33980
- 3000+1.29650
- 6000+1.27050
