Ø3.30[0.130]
3.50[0.138]
2
18.50[0.728]±0.10
3
1
1.80[0.070]
PT
7.50[0.295]
2
E
OP
5.60[0.22]
6.80[0.268]
1
5.40[0.213]±0.10
D
C
3.80[0.150]
B
3.15[0.124]±0.10
A
3-Ø1.30[0.050]
3-2.50[0.100]
3.25[0.130]
4.10[0.161]
4.10[0.161]
2-Ø2.95[0.12]±0.05
13.00[0.511]±0.15
3
Circuit diagram
Ø1.40[0.055]
1.40[0.055]±0.10
1.40[0.05]±0.10
4
3-0.50[0.020]
1
Rubber shell
PA66
2
Seal ring
Silica gel
3
Base
Brass+PA66
4
According to sincerity
Pom
5
Contact moving plate
Phosphor bronze
6
Strut
SUS
UNIT
A4
COMMON
DRAWN BY FUYUAN
台普
A2
A1
REV
MM
ROCPU
DATE
REVISION DESCRIPTION
A
ISSUE
B
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
C
DATE
2019
G
Technical Parameters
技术参数
1.Electrical Rating: 0.1A 125/250VAC
3A/12VDC;0.1A/48VDC
1.电气额定值:0.1A 125/250VAC
3A/12VDC;0.1A/48VDC
2.Electrical lifetime:100,000 cycles
2.电气寿命:100,000 cycles
3.Mechanical lifetime:100,000 cycles
3.机械寿命:100,00 cycles
4.Contact Resistance:≤100mΩ
4.接触电阻:≤100兆欧
5.Operating force:1.3N MAX
5.操作力:1.3N MAX
6.Pretravel:0.3~1.0mm
6.动作行程:0.3~1.0mm
7.OP:6.75±0.2mm
7.动作位置:6.75±0.2mm
8.Withstand Voltage:Feet and Feet 500V/5S/5mA
Feet and Shell 1500/5S/5mA
8.耐压:脚与脚 500/5s/5mA
脚与壳 1500/5S/5mA
9.Insulation Resistance:≥100MΩ
9.绝缘电阻:≥100MΩ
10.Proof Tracking Index(PTI):175V
10.漏电起痕指数(PTI):175V
11.Ambient temperature:125°
11.环境温度:125°
12.Waterproof grade: IP67
12.防水等级:IP67
13.working temperature:-25℃~﹢105℃
13.工作温度:-25℃~﹢105℃
PROJCTED
CHECKED BY
APPROVAL B
COCO
ALEN
MODEL NO: TP330414000
Https:
www.rocpu.tw
ROCPU TECHNOLONGY CO.,LTD
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
D
E
1
2
3
4
PRODUCT NAME:
TOLERANCE
A3
5
NC
NO
c
F
F
G
5
很抱歉,暂时无法提供与“TP330414000”相匹配的价格&库存,您可以联系我们找货
