A
B
D
C
E
9.5[0.37]±0.15
2
3
NC
2-2.00[0.08]
2-Ø2.2[0.09]±0.05
2-2.60[0.100]±0.05
2
6.80[0.270]
7.50[0.300]±0.15
OP
0.60[0.020]
1
FP:9.4 MAX
13.65[0.5
PT
3.40[0.130]
40]±0.15
1
COM 6-0.80[0.030]
NO
1.70[0.070]
3-2.50[0.100]
4.10[0.160] 4.10[0.160]
3-0.50[0.020]
2-3.25[0.130]
Circuit diagram
3
14.70[0.580]±0.15
5.40[0.210]±0.15
C
4
Rubber shell
PA66
2
Seal ring
Silica gel
3
Base
Brass+PA66
4
According to sincerity
Pom
5
Contact moving plate
Phosphor bronze
6
Strut
SUS
UNIT
COMMON
MM
DRAWN BY FUYUAN
台普
A2
A1
ROCPU
DATE
REVISION DESCRIPTION
A
ISSUE
B
X.XX
± 0.10
X.X
± 0.15
X
± 0.25
ANGULAR
C
DATE
2019
G
Technical Parameters
技术参数
1.Electrical Rating:0.1A 125/250VAC
3A/12VDC;0.1A/48VDC
1.电气额定值:0.1A 125/250VAC
3A/12VDC;0.1A/48VDC
2.Electrical lifetime:100,000 cycles
2.电气寿命:100,000 cycles
3.Mechanical lifetime:100,000 cycles
3.机械寿命:100,00 cycles
4.Contact Resistance:≤50mΩ
4.接触电阻:≤50兆欧
5.Operating force:2.2N MAX
5.操作力:2.2N MAX
6.Operation Position:7.1±0.5mm
6.动作位置:7.1±0.5mm
7.Pretravel:3.0mm
7.动作行程:3.0mm
8.Withstand Voltage:Feet and Feet 500V/5S/5mA
Feet and Shell 1500/5S/5mA
8.耐压:脚与脚 500/5s/5mA
脚与壳 1500/5S/5mA
9.Insulation Resistance:≥100MΩ
9.绝缘电阻:≥100MΩ
10.Proof Tracking Index(PTI):175V
10.漏电起痕指数(PTI):175V
11.Ambient temperature:125°
11.环境温度:125°
12.Waterproof grade: IP67
12.防水等级:IP67
13.working temperature:-25℃~﹢105℃
13.工作温度:-25℃~﹢105℃
PROJCTED
CHECKED BY
COCO
APPROVAL B
ALEN
MODEL NO:TP3305141365
Https:
www.rocpu.tw
ROCPU TECHNOLONGY CO.,LTD
Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission
D
E
1
2
3
4
PRODUCT NAME:
TOLERANCE
A3
REV
NC
1
A4
5
NO
F
F
G
5
很抱歉,暂时无法提供与“TP3305141365”相匹配的价格&库存,您可以联系我们找货
