TSD103EZ
TSD103EZ
    ROCPU(台普)
    SW6_7.58X6.6MM_SM
    拨码开关 间距:2.54mm 3位 凸起式 安装方式:贴片 额定电流:25mA 额定电压:24V 电路结构:单刀单掷 样式:鸥翼型 工作温度:-30℃~+85℃ 使用寿命:3000 颜色:黑色
TSD103EZ 数据手册
A B D C E A 0.95 [0.037] 1.54 [0.060] 2.54 [0.100] Terminal Contact 0.60[0.024] Actuator 2 3 4 5 6 7 8 9 10 11 12 6.15 [0.242] 1 Movadle Base Terminal 3.40 [0.134] 0.25 [0.010] 0.80 [0.031] 0.795[0.031] 9.40 [0.370] 3 2.54x(N-1)±0.20 1.44 [0.057] 2.20 [0.087] 6.60 [0.260] 11.00 [0.433] 1.10 [0.043] 4 1 2 0.60 [0.024] 3.20 [0.126] 2 G Switching:25mA at 24VDC Non-Switching:100mA at 50VDC Initial:50m Ω Max After life:100mΩ Max Insulation Resistance:100mΩ Min,60 sec at 500VDC Dielectyic Strength:500VAC for 60seconds Swith Capacitance:5pF Max at 1MHZ Operation Temperature:-30℃to﹢85℃ Storage Temperature:-40℃to﹢85℃ Operation Force:500gf Max Mechanicai Life:3000 cycles opertions Resistance to Soldering:260±5℃ for 3-5 seconds Cover NO F Poles(N) A Dimension(mm) 01 2.54 02 5.08 03 7.62 04 10.16 05 12.70 06 15.24 07 17.78 08 20.32 09 22.86 10 25.40 12 30.48 3 Part Name Material Finished Base PPS UL94 VO Black Cover PPS UL94 VO Black 1 2 3 4 5 6 7 8 9 10 11 12 Actuator Nylon UL94 VO White SCHEMATIC Movadle Copper Alloy Gold Terminal Contact Brass Gold Terminal Brass Gold/Tin 4 2.54 [0.100] UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C PROJCTED PRODUCT NAME: TOLERANCE A3 5 MM DATE 2019 CHECKED BY APPROVAL B COCO ALEN MODEL NO: TSD103EZ Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E F G 5
TSD103EZ 价格&库存
很抱歉,暂时无法提供与“TSD103EZ”相匹配的价格&库存,您可以联系我们找货
