rtl8211f
rtl8211f
    REALTEK(瑞昱)
    QFN40_5X5MM_EP
    集成 10/100/1000M 以太网精密收发器
rtl8211f 数据手册
RTL8211F-CG RTL8211FI-CG RTL8211FD-CG RTL8211FDI-CG INTEGRATED 10/100/1000M ETHERNET TRANSCEIVER DATASHEET (CONFIDENTIAL: Development Partners Only) Rev. 1.1 21 February 2014 Track ID: JATR-8275-15 Realtek Semiconductor Corp. No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan Tel.: +886-3-578-0211 Fax: +886-3-577-6047 www.realtek.com RTL8211F(I)/RTL8211FD(I) Datasheet COPYRIGHT ©2014 Realtek Semiconductor Corp. All rights reserved. No part of this document may be reproduced, transmitted, transcribed, stored in a retrieval system, or translated into any language in any form or by any means without the written permission of Realtek Semiconductor Corp. DISCLAIMER Realtek provides this document ‘as is’, without warranty of any kind. Realtek may make improvements and/or changes in this document or in the product described in this document at any time. This document could include technical inaccuracies or typographical errors. TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. Other names mentioned in this document are trademarks/registered trademarks of their respective owners. LICENSE This product is covered by one or more of the following patents: US5,307,459, US5,434,872, US5,732,094, US6,570,884, US6,115,776, and US6,327,625. USING THIS DOCUMENT This document is intended for the software engineer’s reference and provides detailed programming information. Though every effort has been made to ensure that this document is current and accurate, more information may have become available subsequent to the production of this guide. REVISION HISTORY Revision 1.0 1.1 Release Date 2013/05/20 2014/02/21 Summary First release. Added RTL8211FD-CG, RTL8211FI-CG, and RTL8211FDI-CG data. Integrated 10/100/1000M Ethernet Transceiver ii Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Table of Contents 1. GENERAL DESCRIPTION..............................................................................................................................................1 2. FEATURES.........................................................................................................................................................................2 3. SYSTEM APPLICATIONS...............................................................................................................................................3 3.1. 3.2. APPLICATION DIAGRAM - RTL8211F(I) ......................................................................................................................3 APPLICATION DIAGRAM - RTL8211FD(I) ...................................................................................................................4 4. BLOCK DIAGRAM...........................................................................................................................................................5 5. PIN ASSIGNMENTS .........................................................................................................................................................6 5.1. 6. PIN DESCRIPTIONS ........................................................................................................................................................7 6.1. 6.2. 6.3. 6.4. 6.5. 6.6. 6.7. 6.8. 6.9. 7. PACKAGE IDENTIFICATION ...........................................................................................................................................6 TRANSCEIVER INTERFACE ............................................................................................................................................7 CLOCK .........................................................................................................................................................................7 RGMII.........................................................................................................................................................................8 MANAGEMENT INTERFACE...........................................................................................................................................8 RESET ..........................................................................................................................................................................9 MODE SELECTION ........................................................................................................................................................9 LED DEFAULT SETTINGS ...........................................................................................................................................10 REGULATOR AND REFERENCE ....................................................................................................................................10 POWER AND GROUND ................................................................................................................................................10 FUNCTION DESCRIPTION ..........................................................................................................................................11 7.1. TRANSMITTER ............................................................................................................................................................11 7.1.1. 1000Mbps Mode...................................................................................................................................................11 7.1.2. 100Mbps Mode.....................................................................................................................................................11 7.1.3. 10Mbps Mode.......................................................................................................................................................11 7.2. RECEIVER...................................................................................................................................................................11 7.2.1. 1000Mbps Mode...................................................................................................................................................11 7.2.2. 100Mbps Mode.....................................................................................................................................................11 7.2.3. 10Mbps Mode.......................................................................................................................................................12 7.3. ENERGY EFFICIENT ETHERNET (EEE)........................................................................................................................12 7.4. WAKE-ON-LAN (WOL)............................................................................................................................................12 7.5. INTERRUPT .................................................................................................................................................................13 7.6. INTB/PMEB PIN USAGE ...........................................................................................................................................13 7.7. MDI INTERFACE ........................................................................................................................................................14 7.8. HARDWARE CONFIGURATION ....................................................................................................................................15 7.9. LED AND PHY ADDRESS CONFIGURATION ...............................................................................................................16 7.10. GREEN ETHERNET (1000/100MBPS MODE ONLY) .....................................................................................................17 7.10.1. Cable Length Power Saving ............................................................................................................................17 7.10.2. Register Setting................................................................................................................................................17 7.11. MAC/PHY INTERFACE ..............................................................................................................................................18 7.11.1. RGMII..............................................................................................................................................................18 7.11.2. Management Interface.....................................................................................................................................18 7.11.3. Change Page ...................................................................................................................................................19 7.11.4. Access to MDIO Manageable Device (MMD).................................................................................................20 7.12. AUTO-NEGOTIATION ..................................................................................................................................................20 7.12.1. Auto-Negotiation Priority Resolution..............................................................................................................23 Integrated 10/100/1000M Ethernet Transceiver iii Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.12.2. Auto-Negotiation Master/Slave Resolution .....................................................................................................23 7.12.3. Auto-Negotiation PAUSE/ASYMMETRIC PAUSE Resolution........................................................................24 7.13. CROSSOVER DETECTION AND AUTO-CORRECTION ....................................................................................................24 7.14. LED CONFIGURATION................................................................................................................................................26 7.14.1. Customized LED Function...............................................................................................................................26 7.14.2. EEE LED Function..........................................................................................................................................27 7.15. POLARITY CORRECTION .............................................................................................................................................28 7.16. POWER .......................................................................................................................................................................28 7.17. PHY RESET (HARDWARE RESET) ..............................................................................................................................28 8. REGISTER DESCRIPTIONS.........................................................................................................................................29 8.1. REGISTER MAPPING AND DEFINITIONS.......................................................................................................................29 8.2. MMD REGISTER MAPPING AND DEFINITIONS ............................................................................................................30 8.3. OTHER PAGE REGISTER MAPPING AND DEFINITIONS .................................................................................................30 8.4. REGISTER TABLES ......................................................................................................................................................30 8.4.1. BMCR (Basic Mode Control Register, Address 0x00) .........................................................................................30 8.4.2. BMSR (Basic Mode Status Register, Address 0x01).............................................................................................32 8.4.3. PHYID1 (PHY Identifier Register 1, Address 0x02) ............................................................................................33 8.4.4. PHYID2 (PHY Identifier Register 2, Address 0x03) ............................................................................................33 8.4.5. ANAR (Auto-Negotiation Advertising Register, Address 0x04) ...........................................................................33 8.4.6. ANLPAR (Auto-Negotiation Link Partner Ability Register, Address 0x05) .........................................................34 8.4.7. ANER (Auto-Negotiation Expansion Register, Address 0x06) .............................................................................35 8.4.8. ANNPTR (Auto-Negotiation Next Page Transmit Register, Address 0x07) .........................................................36 8.4.9. ANNPRR (Auto-Negotiation Next Page Receive Register, Address 0x08) ...........................................................36 8.4.10. GBCR (1000Base-T Control Register, Address 0x09).....................................................................................37 8.4.11. GBSR (1000Base-T Status Register, Address 0x0A) .......................................................................................37 8.4.12. MACR (MMD Access Control Register, Address 0x0D) .................................................................................38 8.4.13. MAADR (MMD Access Address Data Register, Address 0x0E)......................................................................38 8.4.14. GBESR (1000Base-T Extended Status Register, Address 0x0F) .....................................................................39 8.4.15. INER (Interrupt Enable Register, Address 0x12) ............................................................................................39 8.4.16. PHYCR1 (PHY Specific Control Register 1, Address 0x18)............................................................................40 8.4.17. PHYCR2 (PHY Specific Control Register 2, Address 0x19)............................................................................41 8.4.18. PHYSR (PHY Specific Status Register, Address 0x1A) ...................................................................................41 8.4.19. INSR (Interrupt Status Register, Address 0x13) ..............................................................................................42 8.4.20. EPAGSR (Extension Page Select Register, Address 0x1F) .............................................................................43 8.4.21. PC1R (PCS Control 1 Register, MMD Device 3, Address 0x00) ....................................................................43 8.4.22. PS1R (PCS Status1 Register, MMD Device 3, Address 0x01) ........................................................................43 8.4.23. EEECR (EEE Capability Register, MMD Device 3, Address 0x14)................................................................44 8.4.24. EEEWER (EEE Wake Error Register, MMD Device 3, Address 0x16) ..........................................................44 8.4.25. EEEAR (EEE Advertisement Register, MMD Device 7, Address 0x3c) ..........................................................44 8.4.26. EEELPAR (EEE Link Partner Ability Register, MMD Device 7, Address 0x3d) ............................................45 8.4.27. LCR (LED Control Register, ExtPage 0xd04, Address 0x10) .........................................................................45 8.4.28. EEELCR (EEE LED Control Register, ExtPage 0xd04, Address 0x11)..........................................................45 9. REGULATORS AND POWER SEQUENCE................................................................................................................46 9.1. SWITCHING REGULATOR (RTL8211F(I))...................................................................................................................46 9.1.1. PCB Layout ..........................................................................................................................................................46 9.1.2. Inductor and Capacitor Parts List .......................................................................................................................47 9.1.3. Measurement Criteria ..........................................................................................................................................48 9.1.4. Efficiency Measurement .......................................................................................................................................54 9.2. LOW-DROPOUT REGULATOR (RTL8211FD(I)) ..........................................................................................................55 9.3. POWER SEQUENCE .....................................................................................................................................................56 10. CHARACTERISTICS.................................................................................................................................................57 Integrated 10/100/1000M Ethernet Transceiver iv Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 10.1. ABSOLUTE MAXIMUM RATINGS.................................................................................................................................57 10.2. RECOMMENDED OPERATING CONDITIONS .................................................................................................................57 10.3. CRYSTAL REQUIREMENTS ..........................................................................................................................................58 10.4. OSCILLATOR/EXTERNAL CLOCK REQUIREMENTS ......................................................................................................58 10.5. DC CHARACTERISTICS ...............................................................................................................................................59 10.6. AC CHARACTERISTICS ...............................................................................................................................................60 10.6.1. MDC/MDIO Timing ........................................................................................................................................60 10.6.2. RGMII Timing Modes......................................................................................................................................61 11. 11.1. 12. MECHANICAL DIMENSIONS.................................................................................................................................64 MECHANICAL DIMENSIONS NOTES ............................................................................................................................64 ORDERING INFORMATION...................................................................................................................................65 List of Tables TABLE 1. TRANSCEIVER INTERFACE ..............................................................................................................................................7 TABLE 2. CLOCK............................................................................................................................................................................7 TABLE 3. RGMII ...........................................................................................................................................................................8 TABLE 4. MANAGEMENT INTERFACE .............................................................................................................................................8 TABLE 5. RESET.............................................................................................................................................................................9 TABLE 6. MODE SELECTION ..........................................................................................................................................................9 TABLE 7. LED DEFAULT SETTINGS .............................................................................................................................................10 TABLE 8. REGULATOR AND REFERENCE ......................................................................................................................................10 TABLE 9. POWER AND GROUND ...................................................................................................................................................10 TABLE 10. CONFIG PINS VS. CONFIGURATION REGISTER ............................................................................................................15 TABLE 11. CONFIGURATION REGISTER DEFINITIONS ....................................................................................................................15 TABLE 12. MANAGEMENT FRAME FORMAT ..................................................................................................................................18 TABLE 13. MANAGEMENT FRAME DESCRIPTION ...........................................................................................................................18 TABLE 14. 1000BASE-T BASE AND NEXT PAGE BIT ASSIGNMENTS ..............................................................................................21 TABLE 15. LED DEFAULT DEFINITIONS ........................................................................................................................................26 TABLE 16. LED REGISTER TABLE .................................................................................................................................................26 TABLE 17. LED CONFIGURATION TABLE ......................................................................................................................................27 TABLE 18. REGISTER ACCESS TYPES ............................................................................................................................................29 TABLE 19. REGISTER MAPPING AND DEFINITIONS ........................................................................................................................29 TABLE 20. MMD REGISTER MAPPING AND DEFINITIONS..............................................................................................................30 TABLE 21. OTHER PAGE REGISTER MAPPING AND DEFINITIONS ...................................................................................................30 TABLE 22. BMCR (BASIC MODE CONTROL REGISTER, ADDRESS 0X00) ......................................................................................30 TABLE 23. BMSR (BASIC MODE STATUS REGISTER, ADDRESS 0X01)..........................................................................................32 TABLE 24. PHYID1 (PHY IDENTIFIER REGISTER 1, ADDRESS 0X02) ...........................................................................................33 TABLE 25. PHYID2 (PHY IDENTIFIER REGISTER 2, ADDRESS 0X03) ...........................................................................................33 TABLE 26. ANAR (AUTO-NEGOTIATION ADVERTISING REGISTER, ADDRESS 0X04)....................................................................33 TABLE 27. ANLPAR (AUTO-NEGOTIATION LINK PARTNER ABILITY REGISTER, ADDRESS 0X05) ...............................................34 TABLE 28. ANER (AUTO-NEGOTIATION EXPANSION REGISTER, ADDRESS 0X06)........................................................................35 TABLE 29. ANNPTR (AUTO-NEGOTIATION NEXT PAGE TRANSMIT REGISTER, ADDRESS 0X07).................................................36 TABLE 30. ANNPRR (AUTO-NEGOTIATION NEXT PAGE RECEIVE REGISTER, ADDRESS 0X08) ...................................................36 TABLE 31. GBCR (1000BASE-T CONTROL REGISTER, ADDRESS 0X09) .......................................................................................37 TABLE 32. GBSR (1000BASE-T STATUS REGISTER, ADDRESS 0X0A)..........................................................................................37 TABLE 33. MACR (MMD ACCESS CONTROL REGISTER, ADDRESS 0X0D) ..................................................................................38 TABLE 34. MAADR (MMD ACCESS ADDRESS DATA REGISTER, ADDRESS 0X0E) ......................................................................38 Integrated 10/100/1000M Ethernet Transceiver v Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet TABLE 35. GBESR (1000BASE-T EXTENDED STATUS REGISTER, ADDRESS 0X0F)......................................................................39 TABLE 36. INER (INTERRUPT ENABLE REGISTER, ADDRESS 0X12)..............................................................................................39 TABLE 37. PHYCR1 (PHY SPECIFIC CONTROL REGISTER 1, ADDRESS 0X18)..............................................................................40 TABLE 38. PHYCR2 (PHY SPECIFIC CONTROL REGISTER 2, ADDRESS 0X19)..............................................................................41 TABLE 39. PHYSR (PHY SPECIFIC STATUS REGISTER, ADDRESS 0X1A) .....................................................................................41 TABLE 40. INSR (INTERRUPT STATUS REGISTER, ADDRESS 0X13)...............................................................................................42 TABLE 41. EPAGSR (EXTENSION PAGE SELECT REGISTER, ADDRESS 0X1F)...............................................................................43 TABLE 42. PC1R (PCS CONTROL 1 REGISTER, MMD DEVICE 3, ADDRESS 0X00)........................................................................43 TABLE 43. PS1R (PCS STATUS 1 REGISTER, MMD DEVICE 3, ADDRESS 0X01) ...........................................................................43 TABLE 44. EEECR (EEE CAPABILITY REGISTER, MMD DEVICE 3, ADDRESS 0X14) ...................................................................44 TABLE 45. EEEWER (EEE WAKE ERROR REGISTER, MMD DEVICE 3, ADDRESS 0X16).............................................................44 TABLE 46. EEEAR (EEE ADVERTISEMENT REGISTER, MMD DEVICE 7, ADDRESS 0X3C) ...........................................................44 TABLE 47. EEELPAR (EEE LINK PARTNER ABILITY REGISTER, MMD DEVICE 7, ADDRESS 0X3D)............................................45 TABLE 48. LCR (LED CONTROL REGISTER, EXTPAGE 0XD04, ADDRESS 0X10) ..........................................................................45 TABLE 49. EEELCR (EEE LED CONTROL REGISTER, EXTPAGE 0XD04, ADDRESS 0X11)...........................................................45 TABLE 50. INDUCTOR AND CAPACITOR PARTS LIST ......................................................................................................................47 TABLE 51. POWER SEQUENCE PARAMETERS .................................................................................................................................56 TABLE 52. ABSOLUTE MAXIMUM RATINGS ..................................................................................................................................57 TABLE 53. RECOMMENDED OPERATING CONDITIONS ...................................................................................................................57 TABLE 54. CRYSTAL REQUIREMENTS ............................................................................................................................................58 TABLE 55. OSCILLATOR/EXTERNAL CLOCK REQUIREMENTS ........................................................................................................58 TABLE 56. DC CHARACTERISTICS .................................................................................................................................................59 TABLE 57. MDC/MDIO MANAGEMENT TIMING PARAMETERS ....................................................................................................60 TABLE 58. RGMII TIMING PARAMETERS ......................................................................................................................................63 TABLE 59. ORDERING INFORMATION ............................................................................................................................................65 Integrated 10/100/1000M Ethernet Transceiver vi Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet List of Figures FIGURE 1. APPLICATION DIAGRAM – RTL8211F(I) ......................................................................................................................3 FIGURE 2. APPLICATION DIAGRAM - RTL8211FD(I) ....................................................................................................................4 FIGURE 3. BLOCK DIAGRAM ..........................................................................................................................................................5 FIGURE 4. PIN ASSIGNMENTS (40-PIN QFN) .................................................................................................................................6 FIGURE 5. LED AND PHY ADDRESS CONFIGURATION ................................................................................................................16 FIGURE 6. MDC/MDIO READ TIMING ........................................................................................................................................19 FIGURE 7. MDC/MDIO WRITE TIMING.......................................................................................................................................19 FIGURE 8. EEE LED BEHAVIOR ..................................................................................................................................................27 FIGURE 9. PHY RESET TIMING ....................................................................................................................................................28 FIGURE 10. SWITCHING REGULATOR.............................................................................................................................................46 FIGURE 11. INPUT VOLTAGE OVERSHOOT 4V (BAD) ..................................................................................................................48 FIGURE 13. CERAMIC 10µF 0603 (X5R) (GOOD) ..........................................................................................................................49 FIGURE 14. L=GLK2510P-2R2M, C=CERAMIC 4.7µF 0805 X5R TDK (RIPPLE 12.4MV) ...........................................................49 FIGURE 15. L=GLK2510P-2R2M, C=CERAMIC 10µF 0603 X5R YAGEO (RIPPLE 13.2MV) ......................................................50 FIGURE 16. L=GLK2510P-4R7M, C=CERAMIC 4.7µF 0805 X5R TDK (RIPPLE 12MV) ..............................................................50 FIGURE 17. L=GLK2510P-4R7M, C=CERAMIC 10µF 0603 X5R YAGEO (RIPPLE 11.2MV) ......................................................51 FIGURE 18. L=GTSD32P-2R2M, C=CERAMIC 4.7µF 0805 X5R TDK (RIPPLE 9.2MV)...............................................................51 FIGURE 19. CERAMIC 10µF (Y5V) (BAD)......................................................................................................................................52 FIGURE 20. ELECTROLYTIC 100µF (RIPPLE TOO HIGH).................................................................................................................52 FIGURE 21. GTSD32P-2R2M (GOOD)..........................................................................................................................................53 FIGURE 22. 1µH BEAD (BAD)........................................................................................................................................................53 FIGURE 23. SWITCHING REGULATOR EFFICIENCY MEASUREMENT CHECKPOINT ..........................................................................54 FIGURE 24. POWER SEQUENCE ......................................................................................................................................................56 FIGURE 25. MDC/MDIO SETUP, HOLD TIME, AND VALID FROM MDC RISING EDGE TIME DEFINITIONS ....................................60 FIGURE 26. MDC/MDIO MANAGEMENT TIMING PARAMETERS ...................................................................................................60 FIGURE 27. RGMII TIMING MODES (FOR TXC) ...........................................................................................................................61 FIGURE 28. RGMII TIMING MODES (FOR RXC) ...........................................................................................................................62 Integrated 10/100/1000M Ethernet Transceiver vii Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 1. General Description The Realtek RTL8211F-CG/RTL8211FD-CG/RTL8211FI-CG/RTL8211FDI-CG is a highly integrated Ethernet transceiver that complies with 10Base-T, 100Base-TX, and 1000Base-T IEEE 802.3 standards. It provides all the necessary physical layer functions to transmit and receive Ethernet packets over CAT.5 UTP cable. The RTL8211FI and RTL8211FDI are manufactured to industrial grade standards. The RTL8211F(I)/RTL8211FD(I) uses state-of-the-art DSP technology and an Analog Front End (AFE) to enable high-speed data transmission and reception over UTP cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented in the RTL8211F(I)/RTL8211FD(I) to provide robust transmission and reception capabilities at 10Mbps, 100Mbps, or 1000Mbps. Data transfer between MAC and PHY is via the Reduced Gigabit Media Independent Interface (RGMII) for 1000Base-T, 10Base-T, and 100Base-TX. The RTL8211F(I)/RTL8211FD(I) supports various RGMII signaling voltages, including 3.3, 2.5, 1.8, and 1.5V. Integrated 10/100/1000M Ethernet Transceiver 1 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 2. Features „ Selectable 3.3/2.5/1.8/1.5V signaling for RGMII „ Supports 25MHz external crystal or OSC „ Provides 125MHz clock source for MAC „ Provides 3 network status LEDs „ Supports Link Down power saving Built-in Wake-on-LAN (WOL) „ Green Ethernet (1000/100Mbps mode only) „ Supports Interrupt function „ Built-in Switching Regulator and LDO „ Supports Parallel Detection „ 40-pin QFN Green Package „ Crossover Detection & Auto-Correction „ „ 55 nm process with ultra-low power consumption Automatic polarity correction „ „ Supports PHYRSTB core power Turn-Off Industrial grade manufacturing process (RTL8211FI/RTL8211FDI) „ Baseline Wander Correction „ Supports 120m for CAT.5 cable in 1000Base-T „ 1000Base-T IEEE 802.3ab Compliant „ 100Base-TX IEEE 802.3u Compliant „ 10Base-T IEEE 802.3 Compliant „ Supports RGMII „ Supports IEEE 802.3az-2010 (Energy Efficient Ethernet) „ Integrated 10/100/1000M Ethernet Transceiver 2 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 3. System Applications „ DTV (Digital TV) „ MAU (Media Access Unit) „ CNR (Communication and Network Riser) „ Game Console „ Printer and Office Machine „ DVD Player and Recorder „ Ethernet Hub „ Ethernet Switch In addition, the RTL8211F(I)/RTL8211FD(I) can be used in any embedded system with an Ethernet MAC that needs a UTP physical connection. 3.1. Application Diagram - RTL8211F(I) *Note: 3.3/2.5/1.8/1.5V power here means I/O pad power sourced from external power, not from the internal LDO. Figure 1. Application Diagram – RTL8211F(I) Integrated 10/100/1000M Ethernet Transceiver 3 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 3.2. Application Diagram - RTL8211FD(I) *Note: 3.3/2.5/1.8/1.5V power here means I/O pad power sourced from external power, not from the internal LDO. Figure 2. Application Diagram - RTL8211FD(I) Integrated 10/100/1000M Ethernet Transceiver 4 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 4. Block Diagram Figure 3. Block Diagram Integrated 10/100/1000M Ethernet Transceiver 5 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 5. Pin Assignments Figure 4. Pin Assignments (40-Pin QFN) 5.1. Package Identification Green package is indicated by the ‘G’ in GXXXV (Figure 4). Integrated 10/100/1000M Ethernet Transceiver 6 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 6. Pin Descriptions Some pins have multiple functions. Refer to the Pin Assignments figure on page 6 for a graphical representation. I: Input LI: Latched Input During Power up or Reset O: Output IO: Bi-Directional Input and Output P: Power PD: Internal Pull Down During Power On Reset PU: Internal Pull Up During Power On Reset OD: Open Drain G: Ground 6.1. Transceiver Interface Table 1. Transceiver Interface Type Description IO In MDI mode, this is the first pair in 1000Base-T, i.e., the BI_DA+/- pair, and is the transmit pair in 10Base-T and 100Base-TX. In MDI crossover mode, this pair acts as the BI_DB+/- pair, and is the receive pair in IO 10Base-T and 100Base-TX. Pin No. 1 Pin Name MDIP0 2 MDIN0 4 MDIP1 IO 5 MDIN1 IO 6 7 9 10 MDIP2 MDIN2 MDIP3 MDIN3 IO IO IO IO In MDI mode, this is the second pair in 1000Base-T, i.e., the BI_DB+/- pair, and is the receive pair in 10Base-T and 100Base-TX. In MDI crossover mode, this pair acts as the BI_DA+/- pair, and is the transmit pair in 10Base-T and 100Base-TX. In MDI mode, this is the third pair in 1000Base-T, i.e., the BI_DC+/- pair. In MDI crossover mode, this pair acts as the BI_DD+/- pair. In MDI mode, this is the fourth pair in 1000Base-T, i.e., the BI_DD+/- pair. In MDI crossover mode, this pair acts as the BI_DC+/- pair. 6.2. Clock Pin No. 36 Pin Name XTAL_IN 37 XTAL_OUT/E XT_CLK 35 CLKOUT Table 2. Clock Type Description I 25MHz Crystal Input. Connect to GND if an external 25MHz oscillator drives XTAL_OUT/EXT_CLK. O 25MHz Crystal Output. If a 25MHz oscillator is used, connect XTAL_OUT/EXT_CLK to the oscillator’s output (see section 10.3, page 58 for clock source specifications). O 125/25MHz Reference Clock Generated from Internal PLL. This pin should be kept floating if this clock is not used by MAC. Integrated 10/100/1000M Ethernet Transceiver 7 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 6.3. RGMII Pin No. 20 Pin Name TXC Type I 18 17 16 15 19 27 TXD0 TXD1 TXD2 TXD3 TXCTL RXC I I I I I O/LI/PD 25 24 23 22 26 RXD0 RXD1 RXD2 RXD3 RXCTL O/LI/PU O/LI/PD O/LI/PD O/LI/PU O/LI/PD Table 3. RGMII Description The transmit reference clock will be 125MHz, 25MHz, or 2.5MHz depending on speed. Transmit Data. Data is transmitted from MAC to PHY via TXD[3:0]. Receive Control Signal from the MAC. The continuous receive reference clock will be 125MHz, 25MHz, or 2.5MHz, and is derived from the received data stream. Receive Data. Data is transmitted from PHY to MAC via RXD[3:0]. Transmit Control Signal to the MAC. 6.4. Management Interface Pin No. 13 14 Pin Name MDC MDIO Type I IO/PU 31 INTB/PMEB O/OD Table 4. Management Interface Description Management Data Clock. Input/Output of Management Data. Pull up 3.3/2.5/1.8/1.5V for 3.3/2.5/1.8/1.5V RGMII, respectively. 1. Interrupt (supports 3.3V pull up). Set low if status changed; active low. 2. Power Management Event (supports 3.3V pull up). Set low if received a magic packet or wake up frame; active low. Keep this pin floating if either of the functions is not used. Note 1: The behavior of this pin is level-triggered. Note 2: The function of this pin (INTB/PMEB) can be assigned by Page 0xd40, Reg.22, bit[5]: 1: Pin 31 functions as PMEB. 0: Pin 31 functions as INTB (default) Integrated 10/100/1000M Ethernet Transceiver 8 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 6.5. Reset Pin No. 12 Pin Name PHYRSTB Type I Table 5. Reset Description Hardware Reset. Active low. For a complete PHY reset, this pin must be asserted low for at least 10ms. All registers will be cleared after a hardware reset. 6.6. Mode Selection Pin No. 22 27 26 23 Pin Name PHYAD0 PHYAD1 PHYAD2 PLLOFF 24 TXDLY 25 RXDLY 32 CFG_EXT 33 34 CFG_LDO0 CFG_LDO1 Type O/LI/PU O/LI/PD O/LI/PD O/LI/PD Table 6. Mode Selection Description PHYAD[2:0]. PHY Address Configuration. ALDPS Mode PLL Off Configuration. Pull up to stop PLL when entering ALDPS mode. Note: Whole system power consumption in typical ALDPS mode is 39.6mW for the RTL8211F(I), and 69.3mW for the RTL8211FD(I). Whole system power consumption in ALDPS low power mode (with PLL turned off) is 10.3mW for the RTL8211F(I), and 23.1 mW for the RTL8211FD(I). All with 1.8V RGMII. O/LI/PD RGMII Transmit Clock Timing Control. Pull up to add 2ns delay to TXC for TXD latching O/LI/PU RGMII Receiver Clock Timing Control. Pull up to add 2ns delay to RXC for RXD latching O/LI/PD IO Pad External Power Source Mode Configuration. Pull up to use the external power source for the IO pad. Pull down to use the integrated LDO to transform the desired voltage for the IO pad. O/LI/PU LDO Output Voltage Selection for I/O Pad/ O/LI/PD External Power Source Voltage Selection for I/O Pad. When pulling down CFG_EXT pin, CFG_LDO[1:0] represent LDO output voltage setting for IO pad: 2’b00: Reserved. 2’b01: 2.5V. 2’b10: 1.8V. 2’b11: 1.5V. When pulling up CFG_EXT pin, CFG_LDO[1:0] stand for input voltage selection of the external power for IO pad: 2’b00: 3.3V. 2’b01: 2.5V. 2’b10: 1.8V. 2’b11: 1.5V. Integrated 10/100/1000M Ethernet Transceiver 9 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 6.7. LED Default Settings Table 7. LED Default Settings Description High=Link Up at 10Mbps Blinking=Transmitting or Receiving. 33 LED1 O/LI/PU Low=Link Up at 100Mbps Blinking=Transmitting or Receiving. 34 LED2 O/LI/PD High=Link Up at 1000Mbps Blinking=Transmitting or Receiving. Note: High/Low active depends on hardware configuration setting. See section 7.14 LED Configuration, page 26 for details. Pin No. 32 Pin Name LED0 Type O/LI/PD 6.8. Regulator and Reference Pin No. 39 Pin Name RSET 30 REG_OUT Table 8. Regulator and Reference Type Description O Reference. External Resistor Reference. O For RTL8211F(I): Switching Regulator 1.0V Output. Connect to a 2.2µH or 4.7µH inductor. For RTL8211FD(I): Low-dropout Regulator 1.0V Output. 6.9. Power and Ground Pin No. 29 28 Pin Name DVDD33 DVDD_RG Type P P 21 11, 40 3, 8, 38 41 DVDD10 AVDD33 AVDD10 GND P P P G Table 9. Power and Ground Description Digital Power. 3.3V. Digital I/O Pad Power. When pulling high CFG_EXT pin during Hardware Configuration (External Power mode), connect this pin to the external power source for 3.3/2.5/1.8/1.5V RGMII I/O. Digital Core Power. 1.0V. Analog Power. 3.3V. Analog Power. 1.0V. Ground. Exposed Pad (E-Pad) is Analog and Digital Ground (see section 11 Mechanical Dimensions, page 64). Integrated 10/100/1000M Ethernet Transceiver 10 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7. Function Description 7.1. Transmitter 7.1.1. 1000Mbps Mode The RTL8211F(I)/RTL8211FD(I)’s PCS layer receives data bytes from the MAC through the RGMII interface and performs generation of continuous code-groups through 4D-PAM5 coding technology. These code groups are passed through a waveform-shaping filter to minimize EMI effect, and are transmitted onto the 4-pair CAT.5 cable at 125MBaud/s through a D/A converter. 7.1.2. 100Mbps Mode The transmitted 4-bit nibbles (TXD[3:0]) from the MAC, clocked at 25MHz (TXCLK), are converted into 5B symbol code through 4B/5B coding technology, then through scrambling and serializing, are converted to 125MHz NRZ and NRZI signals. The NRZI signals are passed to the MLT3 encoder, then to the D/A converter and transmitted onto the media. 7.1.3. 10Mbps Mode The transmit 4-bit nibbles (TXD[3:0]) from the MAC, clocked at 2.5MHz (TXCLK), are serialized into 10Mbps serial data. The 10Mbps serial data is converted into a Manchester-encoded data stream and is transmitted onto the media by the D/A converter. 7.2. Receiver 7.2.1. 1000Mbps Mode Input signals from the media first pass through the on-chip sophisticated hybrid circuit to subtract the transmitted signal from the input signal for effective reduction of near-end echo. The received signal is processed with state-of-the-art technology, such as adaptive equalization, BLW (Baseline Wander) correction, cross-talk cancellation, echo cancellation, timing recovery, error correction, and 4D-PAM5 decoding. The 8-bit-wide data is recovered and is sent to the RGMII interface at a clock speed of 125MHz. The Rx MAC retrieves the packet data from the receive RGMII interface and sends it to the Rx Buffer Manager. 7.2.2. 100Mbps Mode The MLT3 signal is processed with an ADC, equalizer, BLW (Baseline Wander) correction, timing recovery, MLT3 and NRZI decoder, descrambler, 4B/5B decoder, and is then presented to the RGMII interface in 4-bit-wide nibbles at a clock speed of 25MHz. Integrated 10/100/1000M Ethernet Transceiver 11 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.2.3. 10Mbps Mode The received differential signal is converted into a Manchester-encoded stream first. Next, the stream is processed with a Manchester decoder, and is de-serialized into 4-bit-wide nibbles. The 4-bit nibbles are presented to the RGMII interface at a clock speed of 2.5MHz. 7.3. Energy Efficient Ethernet (EEE) The RTL8211F(I)/RTL8211FD(I) supports IEEE 802.3az-2010, also known as Energy Efficient Ethernet (EEE), at 10Mbps, 100Mbps, and 1000Mbps. It provides a protocol to coordinate transitions to/from a lower power consumption level (Low Power Idle mode) based on link utilization. When no packets are being transmitted, the system goes to Low Power Idle mode to save power. Once packets need to be transmitted, the system returns to normal mode, and does this without changing the link status and without dropping/corrupting frames. To save power, when the system is in Low Power Idle mode, most of the circuits are disabled, however, the transition time to/from Low Power Idle mode is kept small enough to be transparent to upper layer protocols and applications. EEE also specifies a negotiation method to enable link partners to determine whether EEE is supported. Refer to http://www.ieee802.org/3/az/index.html for more details. 7.4. Wake-On-LAN (WOL) The RTL8211F(I)/RTL8211FD(I) can monitor the network for a Wakeup Frame or a Magic Packet, and notify the system via the PMEB (Power Management Event; ‘B’ means low active) pin when such a packet or event occurs1. The system can then be restored to a normal state to process incoming jobs. The PMEB pin needs to be connected with a 4.7k-ohm resistor and pulled up to 3.3V. When the Wakeup Frame or a Magic Packet is sent to the PHY, the PMEB pin will be set low to notify the system to wake up. Refer to the WOL application note for details. Magic Packet Wakeup occurs only when the following conditions are met: • The destination address of the received Magic Packet is acceptable to the RTL8211F(I)/RTL8211FD(I), e.g., a broadcast, multicast, or unicast packet addressed to the current RTL8211F(I)/RTL8211FD(I). • The received Magic Packet does not contain a CRC error. • The Magic Packet pattern matches; i.e., 6 * FFh + MISC (can be none) + 16 * DID (Destination ID) in any part of a valid Ethernet packet. Integrated 10/100/1000M Ethernet Transceiver 12 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet A Wakeup Frame event occurs only when the following conditions are met: • The destination address of the received Wakeup Frame is acceptable to the RTL8211F(I)/RTL8211FD(I), e.g., a broadcast, multicast, or unicast address to the current RTL8211F(I)/RTL8211FD(I). • The received Wakeup Frame does not contain a CRC error. • The 16-bit CRC2 of the received Wakeup Frame matches the 16-bit CRC of the sample Wakeup Frame pattern given by the local machine’s OS. Or, the RTL8211F(I)/RTL8211FD(I) is configured to allow direct packet wakeup, e.g., a broadcast, multicast, or unicast network packet. Note 1: The INTB and PMEB functions share the same pin (pin 31), and can be determined by Page 0xd40, Reg.22, bit[5]. Note 2: 16-bit CRC: The RTL8211F(I)/RTL8211FD(I) supports eight long wakeup frames (covering 128 mask bytes from offset 0 to 127 of any incoming network packet). CRC16 polynomial=x16+x12+x5+1. 7.5. Interrupt Whenever there is a status change on the media detected by the RTL8211F(I)/RTL8211FD(I), they will drive the interrupt pin (INTB) low to issue an interrupt event. The MAC senses the status change and accesses the registers (Page 0, Register 19) through the MDC/MDIO interface in response. Once these status registers (Page 0, Register 19) have been read by the MAC through the MDC/MDIO, the INTB is de-asserted. The RTL8211F(I) /RTL8211FD(I) interrupt function removes the need for continuous polling through the MDC/MDIO management interface. Note 1: The interrupt of the RTL8211F(I)/RTL8211FD(I) is a level-triggered mechanism. Note 2: The INTB and PMEB functions share the same pin (pin 31), and can be determined by Page 0xd40, Reg.22, bit[5]. 7.6. INTB/PMEB Pin Usage The INTB/PMEB pin (pin 31) of the RTL8211F(I)/RTL8211FD(I) is designed to notify in cases of both interrupt and WOL events. The default mode of this pin is INTB (Page 0xd40, Reg.22, bit[5] = 0). For general use, indication of a WOL event is also integrated into one of the interrupt events (Page 0, Reg 18, bit[7] which is triggered when any specified WOL event occurs. However, the ‘Low Pulse’ waveform format is not supported during this mode; only the active low, level-triggered waveform is provided. If PMEB mode is selected (Page 0xd40, Reg.22, bit[5] = 1), pin 31 becomes a fully functional PMEB pin. Note that the interrupt function is disabled in this mode. Integrated 10/100/1000M Ethernet Transceiver 13 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.7. MDI Interface This interface consists of four signal pairs; MDI0, MDI1, MDI2, and MDI3. Each signal pair consists of two bi-directional pins that can transmit and receive at the same time. The MDI interface has internal termination resistors to reduce BOM cost and PCB complexity. For 1000Base-T, all four pairs are used in both directions at the same time. For 10/100 links and during auto-negotiation, only pairs A and B are used. Integrated 10/100/1000M Ethernet Transceiver 14 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.8. Hardware Configuration The I/O pad voltage, interface mode, and PHY address can be set by the CONFIG pins. The respective value mapping of CONFIG with the configurable vector is listed in Table 10. To set the CONFIG pins, an external pull-high or pull-low via resistor is required. Table 10. CONFIG Pins vs. Configuration Register CONFIG Pin Configuration RXD3 PHYAD[0] RXC PHYAD[1] RXCTL PHYAD[2] RXD2 PLLOFF RXD1 TXDLY RXD0 RXDLY LED0 CFG_EXT LED1 CFG_LDO[0] LED2 CFG_LDO[1] Configuration PHYAD[2:0] PLLOFF TXDLY RXDLY CFG_EXT Table 11. Configuration Register Definitions Description PHY Address. PHYAD sets the PHY address for the device. The RTL8211F(I)/ RTL8211FD(I) supports PHY addresses from 00001 to 00111. Note 1: An MDIO command with PHY address=0 is a broadcast from the MAC; each PHY device should respond. This function can be disabled by setting Reg24.13=0 (See Table 37). Note 2: The RTL8211F(I)/ RTL8211FD(I) with PHYAD[2:0]=000 can automatically remember the first non-zero PHY address. This function can be enabled by setting Reg24.6 = 1 (See Table 37). ALDPS Mode PLL Off Configuration. 1: Stop PLL when entering ALDPS mode (via 4.7k-ohm to DVDD_RG) 0: PLL continue toggling when entering ALDPS mode (via 4.7k-ohm to GND) RGMII Transmit Clock Timing Control. 1: Add 2ns delay to RXC for RXD latching (via 4.7k-ohm to DVDD_RG) 0: No delay (via 4.7k-ohm to GND) RGMII Receive Clock Timing Control. 1: Add 2ns delay to RXC for RXD latching (via 4.7k-ohm to DVDD_RG) 0: No delay (via 4.7k-ohm to GND) I/O Pad External Power Source Mode Configuration. 1: Use the external power source for the IO pad (via 4.7k-ohm to 3.3V) 0: Use the integrated LDO to transform the desired voltage for the IO pad (via 4.7k-ohm to GND) Integrated 10/100/1000M Ethernet Transceiver 15 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Configuration CFG_LDO[1:0] Description LDO Output Voltage Selection for I/O pad/ External Power Source Voltage Selection for I/O pad. When pulling down CFG_EXT pin, CFG_LDO[1:0] represent LDO output voltage setting for IO pad: (via 4.7k-ohm to GND) 00: Reserved. 01: 2.5V 10: 1.8V 11: 1.5V When pulling up CFG_EXT pin, CFG_LDO[1:0] stand for external power voltage selection for IO pad: (via 4.7k-ohm to 3.3V) 00: 3.3V 01: 2.5V 10: 1.8V 11: 1.5V 7.9. LED and PHY Address Configuration In order to reduce the pin count on the RTL8211F(I)/RTL8211FD(I), the LED pins are duplexed with the CFG_EXT and CFG_LDO pins. As the Hardware Configuration shares the LED output pins, the external combinations required for strapping and LED usage must be considered in order to avoid contention. Specifically, when the LED outputs are used to drive LEDs directly, the active state of each output driver is dependent on the logic level sampled by the corresponding CFG_EXT/CFG_LDO inputs upon power-on/reset. For example, as Figure 5 (left-side) shows, if a given CFG_EXT/CFG_LDO inputs are resistively pulled high then the corresponding LED outputs will be configured as an active low driver. On the right side, we can see that if a given CFG_EXT/CFG_LDO inputs are resistively pulled low then the corresponding output will be configured as an active high driver. The Hardware Configuration pins should not be connected to GND or VCC directly, but must be pulled high or low through a resistor (e.g., 4.7KΩ). If no LED indications are needed, the components of the LED path (LED+510Ω) can be removed. CFG_LDO[1:0] = Logical 1 CFG_EXT = Logical 1 LED Indication=Active low CFG_LDO[1:0] = Logical 0 CFG_EXT = Logical 0 LED Indication=Active High Figure 5. LED and PHY Address Configuration Integrated 10/100/1000M Ethernet Transceiver 16 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.10. Green Ethernet (1000/100Mbps Mode Only) 7.10.1. Cable Length Power Saving In 1000/100Mbps mode the RTL8211F(I)/RTL8211FD(I) provides dynamic detection of cable length and dynamic adjustment of power required for the detected cable length. This feature provides intermediate performance with minimum power consumption. 7.10.2. Register Setting Follow the register settings below to DISABLE Green Ethernet (Default is ‘Enabled’) Write Reg27, Data=0x8011 Write Reg28, Data=0x573f Follow the register settings below to ENABLE Green Ethernet (Default is ‘Enabled’) Write Reg27, Data=0x8011 Write Reg16, Data=0xd73f Integrated 10/100/1000M Ethernet Transceiver 17 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.11. MAC/PHY Interface The RTL8211F(I)/RTL8211FD(I) supports industry standards and is suitable for most off-the-shelf MACs with an RGMII interface. 7.11.1. RGMII Among the RGMII interface in 100Base-TX and 10Base-T modes, TXC and RXC sources are 25MHz and 2.5MHz respectively; while in 1000Base-T mode, TXC and RXC sources are 125MHz. TXC will always be generated by the MAC and RXC will always be generated by the PHY. TXD[3:0] and RXD[3:0] signals are used for data transitions on the rising and falling edge of the clock. 7.11.2. Management Interface The management interface provides access to the internal registers through the MDC and MDIO pins as described in IEEE 802.3u section 22. The MDC signal, provided by the MAC, is the management data clock reference to the MDIO signal. The MDIO is the management data input/output and is a bi-directional signal that runs synchronously to MDC. The MDIO pin needs a 1.5k Ohm pull-up resistor to maintain the MDIO high during idle and turnaround. The RTL8211F(I)/RTL8211FD(I) can share the same MDIO line. In switch/router applications, each port should be assigned a unique address during the hardware reset sequence, and it can only be addressed via that unique PHY address. For detailed information on the management registers, see section 8 Register Descriptions, page 29. Read Write Name Preamble ST OP PHYAD REGAD Preamble 1…1 1…1 ST 01 01 Table 12. Management Frame Format Management Frame Fields OP PHYAD REGAD TA DATA 10 AAAAA RRRRR Z0 DDDDDDDDDDDDDDDD 01 AAAAA RRRRR 10 DDDDDDDDDDDDDDDD IDLE Z Z Table 13. Management Frame Description Description 32 Contiguous Logical 1’s Sent by the MAC on MDIO, along with 32 Corresponding Cycles on MDC. This provides synchronization for the PHY. Start of Frame. Indicated by a 01 pattern. Operation Code. Read: 10 Write: 01 PHY Address. Up to eight PHYs can be connected to one MAC. This 3-bit field selects which PHY the frame is directed to. Register Address. This is a 5-bit field that sets which of the 32 registers of the PHY this operation refers to. Integrated 10/100/1000M Ethernet Transceiver 18 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Name TA Description Turnaround. This is a 2-bit-time spacing between the register address and the data field of a frame to avoid contention during a read transaction. For a read transaction, both the STA and the PHY remain in a high-impedance state for the first bit time of the turnaround. The PHY drives a zero bit during the second bit time of the turnaround of a read transaction. Data. These are the 16 bits of data. Idle Condition. Not truly part of the management frame. This is a high impedance state. Electrically, the PHY’s pull-up resistor will pull the MDIO line to a logical ‘1’. DATA IDLE Figure 6. MDC/MDIO Read Timing MDC MDIO(MAC) z 1...1 0 1 0 Pre Start 1 0 0 0 0 Write OP (Code) 1 0 0 0 0 0 PHY Address 0x01 Reg. Address 0x00(BMCR) 1 0 0 0 0 1 0 0 Turn Around 1 1 0 Reg. Data 0x 1340 1 0 0 0 0 0 0 z Idle Figure 7. MDC/MDIO Write Timing 7.11.3. Change Page Set MDIO commands as shown below to switch to the other Page 0xXY (in Hex). 1. Write Register 31 Data=0x00XY (Page XY) 2. Read/Write the target Register Data 3. Write Register 31 Data=0x0000 (switch to Page 0) Integrated 10/100/1000M Ethernet Transceiver 19 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.11.4. Access to MDIO Manageable Device (MMD) The MDIO Manageable Device (MMD) is an extension to the management interface that provides the ability to access more device registers while still retaining logical compatibility with the MDIO interface, defined in section 8.1 Register Mapping and Definitions, page 29. Access to MMD configuration is provided via Registers 13 and 14. MMD Read/Write Operation 1. Write Function field to 00 (address mode) and DEVAD field to the device address value for the desired MMD (Register 13). 2. Write the desired address value to the MMD’s address register (Register 14). 3. Write Function field to 01 (data mode; no post increment) and DEVAD field to the same device address for the desired MMD (Register 13). 4. Read: Go to step 5. Write: Go to step 6. 5. Read the content of the selected register in MMD (Register 14). 6. Write the content of the selected register in MMD (Register 14). 7.12. Auto-Negotiation Auto-Negotiation is a mechanism to determine the fastest connection between two link partners. For copper media applications, it was introduced in IEEE 802.3u for Ethernet and Fast Ethernet, and then in IEEE 802.3ab to address extended functions for Gigabit Ethernet. It performs the following: • Auto-Negotiation Priority Resolution • Auto-Negotiation Master/Slave Resolution • Auto-Negotiation PAUSE/ASYMMETRIC PAUSE Resolution • Crossover Detection & Auto-Correction Resolution Upon de-assertion of a hardware reset, the RTL8211F(I)/RTL8211FD(I) can be configured to have auto-negotiation enabled, or be set to operate in 10Base-T, 100Base-TX, or 1000Base-T mode via the ANAR and GBCR register (register 4 and 9). The auto-negotiation process is initiated automatically upon any of the following: • Power-up • Hardware reset • Software reset (register 0.15) Integrated 10/100/1000M Ethernet Transceiver 20 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet • Restart auto-negotiation (register 0.9) • Transition from power down to power up (register 0.11) • Entering the link fail state Bit Name D15 NP D14 Ack D13 RF D[12:5] A[7:0] D[4:0] S[4:0] M15 NP M14 Ack M13 MP M12 Ack2 M11 T M[10:0] - U15 NP U14 Ack Table 14. 1000Base-T Base and Next Page Bit Assignments Bit Description Register Location Base Page Next Page. 1: Indicates that Next Pages follow 0: Indicates that no Next Pages follow Acknowledge. 1: Indicates that a device has successfully received its link partner’s Link Code Word (LCW) Remote Fault. 1: Indicates to its link partner that a device has encountered a fault condition Technology Ability Field. Register 4.[12:5] Indicates to its link partner the supported technologies specific to Table 26, page 33. the selector field value. Selector Field. Register 4.[4:0] Always 00001. Table 26, page 33. Indicates to its link partner that it is an IEEE 802.3 device. PAGE 0 (Message Next Page) Next Page. 1: Indicates that Next Pages follow 0: Indicates that no Next Pages follow Acknowledge. 1: Indicates that a device has successfully received its link partner’s Link Code Word (LCW) Message Page. 1: Indicates to its link partner that this is a message page, not an unformatted page. Acknowledge 2. 1: Indicates to its link partner that the device has the ability to comply with the message. Toggle. Used by the NWay arbitration function to ensure synchronization with its link partner during Next Page exchange. 1000Base-T Message Code (Always 8). PAGE 1 (Unformatted Next Page) Next Page. 1: Indicates that Next Pages follow 0: Indicates that no Next Pages follow Acknowledge. 1: Indicates that a device has successfully received its link partner’s Link Code Word (LCW) Integrated 10/100/1000M Ethernet Transceiver 21 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Bit U13 Name MP U12 Ack2 U11 T U[10:5] U4 - U3 - U2 - U1 - U0 - U15 NP U14 Ack U13 MP U12 Ack2 U11 T U[10:0] - Bit Description Message Page. 1: Indicates to its link partner that this is a message page, not an unformatted page. Acknowledge 2. 1: Indicates to its link partner that the device has the ability to comply with the message. Toggle. Used by the NWay arbitration function to ensure synchronization with its link partner during Next Page exchange. Reserved. Transmit as 0 1000Base-T Half Duplex. 1: Half duplex 0: No half duplex 1000Base-T Full Duplex. 1: Full duplex 0: No full duplex 1000Base-T Port Type Bit. 1: Multi-port device 0: Single-port device 1000Base-T Master-Slave Manual Configuration Value. 1: Master 0: Slave This bit is ignored if bit 9.12=0 1000Base-T Master-Slave Manual Configuration Enable. 1: Manual Configuration Enable This bit is intended to be used for manual selection in Master-Slave mode, and is to be used in conjunction with bit 9.11 PAGE 2 (Unformatted Next Page) Next Page. 1: Indicates that Next Pages follow 0: Indicates that no Next Pages follow Acknowledge. 1: Indicates that a device has successfully received its link partner’s Link Code Word (LCW) Message Page. 1: Indicates to its link partner that this is a message page, not an unformatted page Acknowledge 2. 1: Indicates to its link partner that the device has the ability to comply with the message Toggle. Used by the NWay arbitration function to ensure synchronization with its link partner during Next Page exchange. 1000Base-T Master-Slave Seed Bit[10:0] Integrated 10/100/1000M Ethernet Transceiver 22 Register Location - - - Register 9.10 (GBCR) Table 31, page 37. Register 9.11 (GBCR) Table 31, page 37. Register 9.12 (GBCR) Table 31, page 37. - - - - - Master-Slave Seed Value SB[10:0] Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.12.1. Auto-Negotiation Priority Resolution Upon the start of auto-negotiation, to advertise its capabilities each station transmits a 16-bit packet called a Link Code Word (LCW), within a burst of 17 to 33 Fast Link Pulses (FLP). A device capable of auto-negotiation transmits and receives the FLPs. The receiver must identify three identical LCWs before the information is authenticated and used in the arbitration process. The devices decode the base LCW and select capabilities with the highest common denominator supported by both devices. To advertise 1000Base-T capability, both link partners, sharing the same link medium, should engage in Next Page (1000Base-T Message Page, Unformatted Page 1, and Unformatted Page 2) exchange. Auto-negotiation ensures that the highest priority protocol will be selected as the link speed based on the following priorities advertised through the Link Code Word (LCW) exchange. Refer to IEEE 802.3 Clause 28 for detailed information. 1. 1000Base-T Full Duplex (highest priority) 2. 1000Base-T Half Duplex 3. 100Base-TX Full Duplex 4. 100Base-TX Half Duplex 5. 10Base-T Full Duplex 6. 10Base-T Half Duplex (lowest priority) 7.12.2. Auto-Negotiation Master/Slave Resolution To establish a valid 1000Base-T link, the Master/Slave mode of both link partners should be resolved through the auto-negotiation process: • Master Priority • ƒ Multi-port > Single-port ƒ Manual > Non-manual Determination of Master/Slave configuration from LCW ƒ ƒ ƒ ƒ Manual_MASTER=U0*U1 Manual_SLAVE=U0*!U1 Single-port device=!U0*!U2 Multi-port device=!U0*U2 Where: U0 is bit 0 of the Unformatted Page 1 U1 is bit 1 of the Unformatted Page 1 U2 is bit 2 of the Unformatted Page 1 Integrated 10/100/1000M Ethernet Transceiver 23 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet • Where there are two stations with the same configuration, the one with higher Master-Slave seed SB[10:0] in the unformatted page 2 shall become Master. • Master-Slave configuration process resolution: ƒ Successful: Bit 10.15 Master-Slave Configuration Fault is set to logical 0, and bit 10.14 is set to logical 1 for Master resolution, or set to logical 0 for Slave resolution. ƒ Unsuccessful: Auto-Negotiation restarts. ƒ Fault Detect: Bit 10.15 is set to logical 1 to indicate that a configuration fault has been detected. Auto-Negotiation restarts automatically. This happens when both stations are set to manual Master mode or manual Slave mode, or after seven attempts to configure the Master-Slave relationship through the seed method has failed. 7.12.3. Auto-Negotiation PAUSE/ASYMMETRIC PAUSE Resolution Auto-negotiation is also used to determine the flow control capability between link partners. Flow control is a mechanism that can force a busy transmitting link partner to stop transmitting in a full duplex environment by sending special MAC control frames. In IEEE 802.3u, a PAUSE control frame had already been defined. However, in IEEE 802.3ab, a new ASY-PAUSE control frame was defined; if the MAC can only generate PAUSE frames but is not able to respond to PAUSE frames generated by the link partner, then it is called ASYMMETRIC PAUSE. PAUSE/ASYMMETRIC PAUSE capability can be configured by setting the ANAR bits 10 and 11 (Table 26, page 33). Link partner PAUSE capabilities can be determined from ANLPAR bits 10 and 11 (Table 27, page 34). A PHY layer device such as the RTL8211F(I)/RTL8211FD(I) is not directly involved in PAUSE resolution, but simply advertises and reports PAUSE capabilities during the Auto-Negotiation process. The MAC is responsible for final PAUSE/ASYMMETRIC PAUSE resolution after a link is established, and is responsible for correct flow control actions thereafter. 7.13. Crossover Detection and Auto-Correction Ethernet needs a crossover mechanism between both link partners to cross the transmit signal to the receiver when the medium is twisted-pair cable. Crossover Detection & Auto-Correction Configuration eliminates the need for crossover cables between devices, such as two computers connected to each other with a CAT.5 Ethernet cable. The basic concept is to assume the initial default setting is MDI mode, and then check the link status. If no link is established after a certain time, change to MDI Crossover mode and repeat the process until a link is established. An 11-bit pseudo-random timer is applied to decide the mode change time interval. Crossover Detection & Auto-Correction is not a part of the Auto-Negotiation process, but it utilizes the process to exchange the MDI/MDI Crossover configuration. If the RTL8211F(I)/RTL8211FD(I) is configured to only operate in 100Base-TX or only in 10Base-T mode, then Auto-Negotiation is disabled only if the Crossover Detection & Auto-Correction function is also disabled. If Crossover Detection & Auto-Correction are enabled, then Auto-Negotiation is enabled and the RTL8211F(I)/RTL8211FD(I) advertises only 100Base-TX mode or 10Base-T mode. If the speed of operation is configured manually and Auto-Negotiation is still enabled because the Crossover Detection & Auto-Correction function is enabled, then the duplex advertised is as follows: Integrated 10/100/1000M Ethernet Transceiver 24 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 1. If it is set to half duplex, then only half duplex is advertised. 2. If it is set to full duplex, then both full and half duplex are advertised. If the user wishes to advertise only full duplex at a particular speed with the Crossover Detection & Auto-Correction function enabled, then Auto-Negotiation should be enabled (register 0.12) with the appropriate advertising capabilities set in registers 4 or 9. The Crossover Detection & Auto-Correction function may be enabled/disable by setting (register 24.[9:8]) manually. After initial configuration following a hardware reset, Auto-Negotiation can be enabled and disabled via register 0.12, speed via registers 0.13, 0.6, and duplex via register 0.8. The abilities that are advertised can be changed via registers 4 and 9. Changes to registers 0.12, 0.13, 0.6, and 0.8 do not take effect unless at least one of the following events occurs: • Software reset (register 0.15) • Restart of Auto-Negotiation (register 0.9) • Transition from power-down to power-up (register 0.11) Registers 4 and 9 are internally latched once each time Auto-Negotiation enters the ABILITY DETECT state in the arbitration state machine (IEEE 802.3). Hence a write into register 4 or 9 has no effect once the RTL8211F(I)/RTL8211FD(I) begins to transmit Fast Link Pulses. Register 7 is treated in a similar manner as 4 and 9 during additional Next Page exchanges. Once the RTL8211F(I)/RTL8211FD(I) completes Auto-Negotiation, it updates the various statuses in registers 1, 5, 6, and 10. The speed, duplex, page received, and Auto-Negotiation completed statuses are also available in registers 26 and 29. Integrated 10/100/1000M Ethernet Transceiver 25 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.14. LED Configuration 7.14.1. Customized LED Function The RTL8211F(I)/RTL8211FD(I) supports three LED pins, suitable for multiple types of applications that can directly drive the LEDs. The output of these pins is determined by setting the corresponding bits in Page 0xd04 Register 16. The functionality of the RTL8211F(I)/RTL8211FD(I) LEDs is shown in Table 15. Table 15. LED Default Definitions Pin LED0 LED1 LED2 Description 10M Link and Active (Transmitting or Receiving) 100M Link and Active (Transmitting or Receiving) 1000M Link and Active (Transmitting or Receiving) The LED pins can be customized from Page 0xd04 Register 16. To change the register page, see note (below) and Table 16 LED Register Table. There are 16 configuration types (see Table 17 LED Configuration Table, page 27). Note: To switch to Page 0xd04, set Register 31 Data=0x0d04 (set page). After LED setting, switch to PHY`s Page 0 (Register 31 Data=0x0000). LED0 LED1 LED2 10Mbps Reg16 Bit0 Reg16 Bit5 Reg16 Bit10 Table 16. LED Register Table LINK Speed 100Mbps 1000Mbps Reg16 Bit1 Reg16 Bit3 Reg16 Bit6 Reg16 Bit8 Reg16 Bit11 Reg16 Bit13 Integrated 10/100/1000M Ethernet Transceiver 26 Active (Tx/Rx) Reg16 Bit4 Reg16 Bit9 Reg16 Bit14 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Pin LED 10Mbps 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 Table 17. LED Configuration Table LINK Bit Active (TX/RX) Bit 100 Mbps 1000 Mbps 0 0 0 0 0 1 0 1 0 0 1 1 1 0 0 1 0 1 1 1 0 1 1 1 0 0 0 0 0 1 0 1 0 0 1 1 1 0 0 1 0 1 1 1 0 1 1 1 Description N/A N/A Link 1000 Link 1000+Active Link 100 Link 100+Active Link 100/1000 Link 100/1000+Active Link 10 Link 10+Active Link 10/1000 Link 10/1000+Active Link 10/100 Link 10/100+Active Link 10/100/1000 Link 10/100/1000+Active 7.14.2. EEE LED Function EEE Idle mode: LED continuous slow blinking. EEE Active mode: LED fast and slow blinking (on packet transmitting and receiving). Refer to Table 49, page 45 for EEE LED enable setting. Figure 8. EEE LED Behavior Integrated 10/100/1000M Ethernet Transceiver 27 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 7.15. Polarity Correction The RTL8211F(I)/RTL8211FD(I) automatically corrects polarity errors on the receive pairs in 1000Base-T and 10Base-T modes. In 100Base-TX mode polarity is irrelevant. In 1000Base-T mode, receive polarity errors are automatically corrected based on the sequence of idle symbols. Once the descrambler is locked, the polarity is also locked on all pairs. The polarity becomes unlocked only when the receiver loses lock. In 10Base-T mode, polarity errors are corrected based on the detection of validly spaced link pulses. The detection begins during the MDI crossover detection phase and locks when the 10Base-T link is up. The polarity becomes unlocked when the link is down. 7.16. Power A voltage regulator is implemented to generate operating power (switching regulator for the RTL8211F(I); LDO for the RTL8211FD(I)). The system vendor needs to supply a 3.3V, 1A steady power source. The RTL8211F(I)/RTL8211FD(I) converts the 3.3V steady power source to 1.0V via a switching regulator/LDO. Another possible implementation is to use an external regulator to generate 1.0V. Be sure that the regulator meets the required current rate (0.95V~1.05V). The RTL8211F(I)/RTL8211FD(I) implements an option for the RGMII power pins. The standard I/O voltage of the RGMII interface is 3.3V, with support for 2.5/1.8/1.5V to lower EMI. The 2.5/1.8/1.5V power source for RGMII is supplied from an internal LDO or from an external power source. 7.17. PHY Reset (Hardware Reset) The RTL8211F(I)/RTL8211FD(I) has a PHYRSTB pin to reset the chip. For a complete PHY reset, this pin must be asserted low for at least 10ms (Tgap in Figure 9) for the internal regulator. Wait for a further 30ms (for internal circuits settling time) before accessing the PHY register. All registers will return to default values after a hardware reset. Refer to the RTL8211xx-xx_Power_Sequence_App_Note for more detailed information. Figure 9. PHY Reset Timing Integrated 10/100/1000M Ethernet Transceiver 28 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8. Register Descriptions 8.1. Register Mapping and Definitions Table 18. Register Access Types Type LH RC RO RW SC Offset 0 1 2 3 4 5 6 7 8 9 10 11~12 13 14 15 16~17 18 19~23 24 25 26 27~28 29 30 31 Description Latch high. If the status is high, this field is set to ‘1’ and remains set. Read-cleared. The register field is cleared after read. Read only. Read and Write Self-cleared. Writing a ‘1’ to this register field causes the function to be activated immediately, and then the field will be automatically cleared to’0’ . Access RW RO RO RO RW RO RO RW RO RW RO RO WO RW RO RO RW RO RW RW RO RO RO RO RW Table 19. Register Mapping and Definitions Name Description BMCR Basic Mode Control Register. BMSR Basic Mode Status Register. PHYID1 PHY Identifier Register 1. PHYID2 PHY Identifier Register 2. ANAR Auto-Negotiation Advertising Register. ANLPAR Auto-Negotiation Link Partner Ability Register. ANER Auto-Negotiation Expansion Register. ANNPTR Auto-Negotiation Next Page Transmit Register. ANNPRR Auto-Negotiation Next Page Receive Register. GBCR 1000Base-T Control Register. GBSR 1000Base-T Status Register. RSVD Reserved. MACR MMD Access Control Register. MAADR MMD Access Address Data Register. GBESR 1000Base-T Extended Status Register. RSVD Reserved. INER Interrupt Enable Register. RSVD Reserved. PHYCR1 PHY Specific Control Register 1. PHYCR2 PHY Specific Control Register 2. PHYSR PHY Specific Status Register. RSVD Reserved. INSR Interrupt Status Register. RSVD Reserved. PAGSR Page Select Register. Integrated 10/100/1000M Ethernet Transceiver 29 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.2. MMD Register Mapping and Definitions Device 3 3 3 3 7 7 Offset 0 1 20 22 60 61 Table 20. MMD Register Mapping and Definitions Access Name Description RW PC1R PCS Control 1 Register. RW PS1R PCS Status 1 Register. RO EEECR EEE Capability Register. RC EEEWER EEE Wake Error Register. RW EEEAR EEE Advertisement Register. RO EEELPAR EEE Link Partner Ability Register. 8.3. Other Page Register Mapping and Definitions Table 21. Other Page Register Mapping and Definitions Page Offset Access Name Description d04 16 RW LCR LED Control Register. d04 17 RW EEELCR EEE LED Control Register. Note: To switch to Page 0xd04, set Register 31 Data=0x0d04 (change to Page 0xd04). After LED setting, switch to the PHY’s Page 0 (Register 31 Data=0000). 8.4. 8.4.1. Register Tables BMCR (Basic Mode Control Register, Address 0x00) Bit 0.15 Name Reset 0.14 Loopback Table 22. BMCR (Basic Mode Control Register, Address 0x00) Type Default Description RW, SC 0 Reset. 1: PHY reset 0: Normal operation Register 0 (BMCR) and register 1 (BMSR) will return to default values after a software reset (set Bit15 to 1). This action may change the internal PHY state and the state of the physical link associated with the PHY. RW 0 Loopback Mode. 1: Enable PCS loopback mode 0: Disable PCS loopback mode The loopback function enables RGMII transmit data to be routed to the RGMII receive data path. Integrated 10/100/1000M Ethernet Transceiver 30 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Bit 0.13 Name Speed[0] Type RW 0.12 ANE RW Default Description 0 Speed Select Bit 0. In forced mode, i.e., when Auto-Negotiation is disabled, bits 6 and 13 determine device speed selection. Speed[1] Speed[0] Speed Enabled 1 1 Reserved 1 0 1000Mbps 0 1 100Mbps 0 0 10Mbps 1 Auto-Negotiation Enable. 1: Enable Auto-Negotiation 0: Disable Auto-Negotiation 0.11 PWD RW 0 Power Down. 1: Power down (only Management Interface and logic are active; link is down) 0: Normal operation 0.10 Isolate RW 0 Isolate. 1: RGMII interface is isolated; the serial management interface (MDC, MDIO) is still active. When this bit is asserted, the RTL8211F(I)/RTL8211FD(I) ignores TXD[3:0], and TXCTL inputs, and presents a high impedance on TXC, RXC, RXCTL, RXD[3:0]. 0: Normal operation 0.9 Restart_AN RW, SC 0 Restart Auto-Negotiation. 1: Restart Auto-Negotiation 0: Normal operation 0.8 Duplex RW 1 Duplex Mode. 1: Full Duplex operation 0: Half Duplex operation This bit is valid only in force mode, i.e., NWay is disabled. 0.7 Collision Test RW 0 Collision Test. 1: Collision test enabled 0: Normal operation 0.6 Speed[1] RW 1 Speed Select Bit 1. Refer to bit 0.13. 0.5 Uni-directional RW 0 Uni-Directional Enable enable 1: Enable packet transmit without respect to linkok status 0: Packet transmit permitted when link is established 0.4:0 RSVD RO 00000 Reserved. Note 1: When the RTL8211F(I)/RTL8211FD(I) is switched from power down to normal operation, a software reset and restart auto-negotiation is performed, even if bits Reset (0.15) and Restart_AN (0.9) are not set by the user. Note 2: Auto-Negotiation is enabled when speed is set to 1000Base-T. Crossover Detection & Auto-Correction takes precedence over Auto-Negotiation disable (0.12=0). If ANE is disabled, speed and duplex capabilities are advertised by 0.13, 0.6, and 0.8. Otherwise, register 4.8:5 and 9.9:8 take effect. Note 3: Auto-Negotiation automatically restarts after hardware or software reset regardless of whether or not the restart bit (0.9) is set. Integrated 10/100/1000M Ethernet Transceiver 31 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.2. Bit 1.15 1.14 1.13 1.12 1.11 1.10 1.9 1.8 1.7 1.6 1.5 1.4 1.3 BMSR (Basic Mode Status Register, Address 0x01) Table 23. BMSR (Basic Mode Status Register, Address 0x01) Type Default Description RO 0 100Base-T4 Capability. The RTL8211F(I)/RTL8211FD(I) does not support 100Base-T4 mode. This bit should always be 0. 100Base-TX (full) RO 1 100Base-TX Full Duplex Capability. 1: Device is able to perform 100Base-TX in full duplex mode 0: Device is not able to perform 100Base-TX in full duplex mode 100Base-TX (half) RO 1 100Base-TX Half Duplex Capability. 1: Device is able to perform 100Base-TX in half duplex mode 0: Device is not able to perform 100Base-TX in half duplex mode 10Base-T (full) RO 1 10Base-T Full Duplex Capability. 1: Device is able to perform 10Base-T in full duplex mode. 0: Device is not able to perform 10Base-T in full duplex mode. 10Base-T (half) RO 1 10Base-T Half Duplex Capability. 1: Device is able to perform 10Base-T in half duplex mode 0: Device is not able to perform 10Base-T in half duplex mode 10Base-T2 (full) RO 0 10Base-T2 Full Duplex Capability. The RTL8211F(I)/RTL8211FD(I) does not support 10Base-T2 mode and this bit should always be 0. 10Base-T2 (half) RO 0 10Base-T2 Half Duplex Capability. The RTL8211F(I)/RTL8211FD(I) does not support 10Base-T2 mode. This bit should always be 0. 1000Base-T RO 1 1000Base-T Extended Status Register. Extended Status 1: Device supports Extended Status Register 0x0F (15) 0: Device does not support Extended Status Register 0x0F This register is read-only and is always set to 1. Uni-directional RO 1 Uni-directional ability. ability 1: PHY able to transmit from RGMII without linkok 0: PHY not able to transmit from RGMII without linkok Preamble RO 1 Preamble Suppression Capability (Permanently On). Suppression The RTL8211F(I)/RTL8211FD(I) always accepts transactions with preamble suppressed. Auto-Negotiation RO 0 Auto-Negotiation Complete. Complete 1: Auto-Negotiation process complete, and contents of registers 5, 6, 8, and 10 are valid 0: Auto-Negotiation process not complete Remote Fault RC, LH 0 Remote Fault. 1: Remote fault condition detected (cleared on read or by reset). Indication or notification of remote fault from Link Partner 0: No remote fault condition detected Auto-Negotiation RO 1 Auto Configured Link. Ability 1: Device is able to perform Auto-Negotiation 0: Device is not able to perform Auto-Negotiation Name 100Base-T4 Integrated 10/100/1000M Ethernet Transceiver 32 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Bit 1.2 Name Link Status 1.1 Jabber Detect 1.0 Extended Capability 8.4.3. Type RO RC, LH RO Default Description 0 Link Status. 1: Linked 0: Not Linked This register indicates whether the link was lost since the last read. For the current link status, either read this register twice or read register bit 17.10 Link Real Time. 0 Jabber Detect. 1: Jabber condition detected 0: No Jabber occurred 1 1: Extended register capabilities, always 1 PHYID1 (PHY Identifier Register 1, Address 0x02) Table 24. PHYID1 (PHY Identifier Register 1, Address 0x02) Bit Name Type Default Description 2.15:0 OUI_MSB RO 0000000000011100 Organizationally Unique Identifier Bit 3:18. Always 0000000000011100. Note: Realtek OUI is 0x000732. 8.4.4. Bit 3.15:10 3.9:4 3.3:0 8.4.5. Bit 4.15 4.14 4.13 4.12 4.11 PHYID2 (PHY Identifier Register 2, Address 0x03) Table 25. PHYID2 (PHY Identifier Register 2, Address 0x03) Name Type Default Description OUI_LSB RO 110010 Organizationally Unique Identifier Bit 19:24. Always 110010. Model Number RO 010001 Manufacture’s Model Number Revision Number RO 0110 Revision Number ANAR (Auto-Negotiation Advertising Register, Address 0x04) Table 26. ANAR (Auto-Negotiation Advertising Register, Address 0x04) Name Type Default Description NextPage RW 0 1: Additional next pages exchange desired 0: No additional next pages exchange desired RSVD RO 0 Reserved. Remote Fault RW 0 1: Set Remote Fault bit 0: No remote fault detected RSVD RO 0 Reserved. Asymmetric PAUSE RW 0 1: Advertise support of asymmetric pause 0: No support of asymmetric pause Integrated 10/100/1000M Ethernet Transceiver 33 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Bit 4.10 Description 1: Advertise support of pause frames 0: No support of pause frames 4.9 100Base-T4 RO 0 1: 100Base-T4 support 0: 100Base-T4 not supported 4.8 100Base-TX (Full) RW 1 1: Advertise support of 100Base-TX full-duplex mode 0: Not advertised 4.7 100Base-TX (Half) RW 1 1: Advertise support of 100Base-TX half-duplex mode 0: Not advertised 4.6 10Base-T (Full) RW 1 1: Advertise support of 10Base-TX full-duplex mode 0: Not advertised 4.5 10Base-T (Half) RW 1 1: Advertise support of 10Base-TX half-duplex mode 0: Not advertised 4.4:0 Selector Field RO 00001 Indicates the RTL8211F(I)/RTL8211FD(I) supports IEEE 802.3 Note 1: The setting of Register 4 has no effect unless NWay is restarted or the link goes down, i.e., software reset (0.15) is asserted, Restart_AN (0.9) is asserted, or PWD (0.11) transitions from power down to normal operation. Note 2: If 1000Base-T is advertised, then the required next pages are automatically transmitted. Register 4.15 should be set to 0 if no additional next pages are needed. 8.4.6. Bit 5.15 5.14 5.13 5.12 5.11:5 5.4:0 Name PAUSE Type RW Default 0 ANLPAR (Auto-Negotiation Link Partner Ability Register, Address 0x05) Table 27. ANLPAR (Auto-Negotiation Link Partner Ability Register, Address 0x05) Name Type Default Description Next Page RO 0 Next Page Indication. Received Code Word Bit 15. ACK RO 0 Acknowledge. Received Code Word Bit 14. Remote Fault RO 0 Remote Fault indicated by Link Partner. Received Code Word Bit 13. RSVD RO 0 Reserved. Technology Ability Field RO 00000000 Received Code Word Bit 12:5. Selector Field RO 00000 Received Code Word Bit 4:0. Note: Register 5 is not valid until the Auto-Negotiation complete bit 1.5 indicates completed. Integrated 10/100/1000M Ethernet Transceiver 34 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.7. ANER (Auto-Negotiation Expansion Register, Address 0x06) Table 28. ANER (Auto-Negotiation Expansion Register, Address 0x06) Name Type Default Description RSVD RO 0x000 Reserved. RX NP location ability RO 1 Received next page storage location ability. 1: Received next page storage location is specified by bit 6.5 0: Received next page storage location is not specified by bit 6.5 6.5 RX NP location RO 1 Received next page storage location. 1: Link partner next pages are stored in Register 8 0: Link partner next pages are stored in Register 5 6.4 Parallel Detection Fault RC, LH 0 1: A fault has been detected via the Parallel Detection function 0: A fault has not been detected via the Parallel Detection function 6.3 Link Partner Next Page Able RO 0 1: Link Partner supports Next Page exchange 0: Link Partner does not support Next Page exchange 6.2 Local Next Page Able RO 1 1: Local Device is able to send Next Page Always 1. 6.1 Page Received RC, LH 0 1: A New Page (new LCW) has been received 0: A New Page has not been received 6.0 Link Partner RO 0 1: Link Partner supports Auto-Negotiation Auto-Negotiation capable 0: Link Partner does not support Auto-Negotiation Note: Register 6 is not valid until the Auto-Negotiation complete bit 1.5 indicates completed. Bit 6.15:5 6.6 Integrated 10/100/1000M Ethernet Transceiver 35 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.8. Bit 7.15 7.14 7.13 7.12 7.11 7.10:0 8.4.9. ANNPTR (Auto-Negotiation Next Page Transmit Register, Address 0x07) Table 29. ANNPTR (Auto-Negotiation Next Page Transmit Register, Address 0x07) Name Type Default Description Next Page RW 0 Next Page Indication. 0: No more next pages to send 1: More next pages to send Transmit Code Word Bit 15. RSVD RO 0 Transmit Code Word Bit 14. Message Page RW 1 Message Page. 0: Unformatted Page 1: Message Page Transmit Code Word Bit 13. Acknowledge 2 RW 0 Acknowledge2. 0: Local device has no ability to comply with the message received 1: Local device has the ability to comply with the message received Transmit Code Word Bit 12. Toggle RO 0 Toggle Bit. Transmit Code Word Bit 11. Message/Unformatted Field RW 0x001 Content of Message/Unformatted Page. Transmit Code Word Bit 10:0. ANNPRR (Auto-Negotiation Next Page Receive Register, Address 0x08) Table 30. ANNPRR (Auto-Negotiation Next Page Receive Register, Address 0x08) Bit Name Type Default Description 8.15 Next Page RO 0 Received Link Code Word Bit 15. 8.14 Acknowledge RO 0 Received Link Code Word Bit 14. 8.13 Message Page RO 0 Received Link Code Word Bit 13. 8.12 Acknowledge 2 RO 0 Received Link Code Word Bit 12. 8.11 Toggle RO 0 Received Link Code Word Bit 11. 8.10:0 Message/Unformatted Field RO 0x00 Received Link Code Word Bit 10:0. Note: Register 8 is not valid until the Auto-Negotiation complete bit 1.5 indicates completed. Integrated 10/100/1000M Ethernet Transceiver 36 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.10. GBCR (1000Base-T Control Register, Address 0x09) Table 31. GBCR (1000Base-T Control Register, Address 0x09) Type Default Description RW 0 Test Mode Select. 000: Normal Mode 001: Test Mode 1 – Transmit Jitter Test 010: Test Mode 2 – Transmit Jitter Test (MASTER mode) 011: Test Mode 3 – Transmit Jitter Test (SLAVE mode) 100: Test Mode 4 – Transmit Distortion Test 101, 110, 111: Reserved 9.12 MASTER/SLAVE Manual RW 0 Enable Manual Master/Slave Configuration. Configuration Enable 1: Manual MASTER/SLAVE configuration 0: Automatic MASTER/SLAVE 9.11 MASTER/SLAVE RW 0 Advertise Master/Slave Configuration Value. Configuration Value 1: Manual configure as MASTER 0: Manual configure as SLAVE 9.10 Port Type RW 0 Advertise Device Type Preference. 1: Prefer multi-port device (MASTER) 0: Prefer single port device (SLAVE) 9.9 1000Base-T Full Duplex RW 1 Advertise 1000Base-T Full-Duplex Capability. 1: Advertise 0: Do not advertise 9.8 RSVD RW 0 Reserved. 9.7:0 RSVD RO 0 Reserved. Note 1: Values set in register 9.12:9 have no effect unless Auto-Negotiation is restarted (Reg0.9) or the link goes down. Note 2: Bits 9.11 and 9.10 are ignored when bit 9.12=0. Bit 9.15:13 Name Test Mode 8.4.11. GBSR (1000Base-T Status Register, Address 0x0A) Bit 10.15 Table 32. GBSR (1000Base-T Status Register, Address 0x0A) Name Type Default Description MASTER/SLAVE RO, RC, 0 Master/Slave Manual Configuration Fault Detected. Configuration Fault LH 1: MASTER/SLAVE configuration fault detected 10.14 MASTER/SLAVE Configuration Resolution RO 0 10.13 Local Receiver Status RO 0 10.12 Remote Receiver Status RO 0 Integrated 10/100/1000M Ethernet Transceiver 0: No MASTER/SLAVE configuration fault detected Master/Slave Configuration Result. 1: Local PHY configuration resolved to MASTER 0: Local PHY configuration resolved to SLAVE Local Receiver Status. 1: Local Receiver OK 0: Local Receiver Not OK Remote Receiver Status. 1: Remote Receiver OK 0: Remote Receiver Not OK 37 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Bit 10.11 Name Link Partner 1000Base-T Full Duplex Capability Type RO Default 0 Description Link Partner 1000Base-T Full Duplex Capability. 1: Link Partner is capable of 1000Base-T full duplex 0: Link Partner is not capable of 1000Base-T full duplex 10.10 Link Partner 1000Base-T RO 0 Link Partner 1000Base-T Half Duplex Capability. Half Duplex Capability 1: Link Partner is capable of 1000Base-T half duplex 0: Link Partner is not capable of 1000Base-T half duplex 10.9:8 RSVD RO 00 Reserved. 10.7:0 Idle Error Count RO, RC 0x00 MSB of Idle Error Counter. The counter stops automatically when it reaches 0xff. Note 1: Values set in register 10.11:10 are not valid until register 6.1 is set to 1. Note 2: Register 10 is not valid until the Auto-Negotiation complete bit 1.5 indicates completed. 8.4.12. MACR (MMD Access Control Register, Address 0x0D) Table 33. MACR (MMD Access Control Register, Address 0x0D) Bit Name Type Default Description 13.15:14 Function WO 0 00: Address 01: Data with no post increment 10: Data with post increment on reads and writes 11: Data with post increment on writes only 13.13:5 RSVD RO 000000000 Reserved. 13.4:0 DEVAD WO 0 Device Address. Note 1: This register is used in conjunction with the MAADR (Register 14) to provide access to the MMD address space. Note 2: If the MAADR accesses for address (Function=00), then it is directed to the address register within the MMD associated with the value in the DEVAD field. Note 3: If the MAADR accesses for data (Function≠00), both the DEVAD field and MMD’s address register direct the MAADR data accesses to the appropriate registers within the MMD. 8.4.13. MAADR (MMD Access Address Data Register, Address 0x0E) Table 34. MAADR (MMD Access Address Data Register, Address 0x0E) Bit Name Type Default Description 14.15:0 Address Data RW 0x0000 13.15:14 = 00 Æ MMD DEVAD’s address register 13.15:14 = 01, 10, or 11 Æ MMD DEVAD’s data register as indicated by the contents of its address register Note: This register is used in conjunction with the MACR (Register 13; Table 33) to provide access to the MMD address space. Integrated 10/100/1000M Ethernet Transceiver 38 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.14. GBESR (1000Base-T Extended Status Register, Address 0x0F) Bit 15.15 15.14 15.13 15.12 15.11:0 Table 35. GBESR (1000Base-T Extended Status Register, Address 0x0F) Name Type Default Description 1000Base-X FD RO 0 0: Not 1000Base-X full duplex capable 1000Base-X HD RO 0 0: Not 1000Base-X half duplex capable 1000Base-T FD RO 1 1: 1000Base-T full duplex capable 1000Base-T HD RO 0 1: 1000Base-T half duplex capable RSVD RO 0x000 Reserved. 8.4.15. INER (Interrupt Enable Register, Address 0x12) Table 36. INER (Interrupt Enable Register, Address 0x12) Type Default Description RW 00000 Reserved. RW 0 1: Interrupt Enable 0: Interrupt Disable Setting this bit to 0 only masks a jabber interrupt event in the INT interface. Reg29 Bit10 always reflects the jabber interrupt behavior. ALDPS State Change Interrupt RW 0 1: Interrupt Enable 0: Interrupt Disable Setting this bit to 0 only masks an ALDPS state change interrupt event in the INT interface. Reg29 Bit9 always reflects the ALDPS state change interrupt behavior. RSVD RW 0 Reserved. PME (Power Management Event RW 0 1: Interrupt Enable 0: Interrupt Disable of WOL) Setting this bit to 0 only masks a PME interrupt event in the INT interface. Reg29 Bit7 always reflects the PME interrupt behavior. RSVD RW 0 Reserved. PHY Register Access Interrupt RW 0 1: Interrupt Enable 0: Interrupt Disable Setting this bit to 0 only masks a PHY register access interrupt event in the INT interface. Reg29 Bit12 always reflects the PHY register access interrupt behavior. Link Status Change Interrupt RW 0 1: Interrupt Enable 0: Interrupt Disable Setting this bit to 0 only masks a link status change interrupt event in the INT interface. Reg29 Bit4 always reflects the link change interrupt behavior. Auto-Negotiation Completed RW 0 1: Interrupt Enable 0: Interrupt Disable Interrupt Setting this bit to 0 only masks an auto-negotiation completed interrupt event in the INT interface. Reg29 Bit3 always reflects the auto-negotiation completed interrupt behavior. Bit Name 18.15:12 RSVD 18.10 Jabber Interrupt 18.9 18.8 18.7 18.6 18.5 18.4 18.3 Integrated 10/100/1000M Ethernet Transceiver 39 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Bit 18.2 Name Page Received Interrupt Type RW Default 0 18.1 18.0 RSVD Auto-Negotiation Error Interrupt RW RW 0 0 Description 1: Interrupt Enable 0: Interrupt Disable Setting this bit to 0 only masks a page received interrupt event in the INT interface. Reg29 Bit2 always reflects the page received interrupt behavior. Reserved. 1: Interrupt Enable 0: Interrupt Disable Setting this bit to 0 only masks an auto-negotiation error interrupt event in the INT interface. Reg29 Bit0 always reflects the auto-negotiation error interrupt behavior. 8.4.16. PHYCR1 (PHY Specific Control Register 1, Address 0x18) Table 37. PHYCR1 (PHY Specific Control Register 1, Address 0x18) Bit Name Type Default Description 24.15:14 RSVD RO 00 Reserved. 24.13 PHYAD_0 Enable RW 1 1: A broadcast from MAC (A command with PHY address = 0) is valid. MDC/MDIO will respond to this command. 24.12:10 RSVD RO 000 Reserved. 24.9 MDI Mode Manual Configuration RW 0 1: Enable Manual Configuration of MDI mode Enable 24.8 MDI Mode RW 1 Set the MDI/MDIX mode. 1: MDI 0: MDIX This bit will take effect only when Reg 24.9 = 1. 24.7 TX CRS Enable RW 0 1: Assert CRS on transmit 0: Never assert CRS on transmit 24.6 PHYAD Non-zero Detect RW 0 1: The RTL8211F(I)/RTL8211FD(I) with PHYAD[2:0] = 000 will latch the first non-zero PHY address as its own PHY address 24.5 RSVD RO 0 Reserved. 24.4 Preamble Check Enable RW 1 1: Check preamble when receiving an MDC/MDIO command 24.3 Jabber Detection Enable RW 1 1: Enable Jabber Detection 24.2 ALDPS Enable RO 0 1: Enable Link Down Power Saving Mode 24.1:0 RSVD RO 00 Reserved. Note: The method to disable auto-crossover and force MDI or MDIX mode is as follows: Step 1: Set Reg24 bit[9]=1 (Manual Configuration of MDI mode) and set Reg24 bit[8]=1 (MDI) or 0 (MDIX). Step 2: Perform a PHY reset, i.e., set Reg0 bit[15]=1. Integrated 10/100/1000M Ethernet Transceiver 40 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.17. PHYCR2 (PHY Specific Control Register 2, Address 0x19) Table 38. PHYCR2 (PHY Specific Control Register 2, Address 0x19) Bit Name Type Default Description 25.15:12 RSVD RO 0000 Reserved. 25.11 CLKOUT Frequency Select RW 1 Frequency select of the CLKOUT pin clock output. 0: 25MHz 1: 125MHz 25.10:8 RSVD RO 000 Reserved. 25.7 CLKOUT SSC Enable RW 0 1: Enable Spread-Spectrum Clocking (SSC) on CLKOUT output clock. 25.6:4 RSVD RO 000 Reserved. 25.3 RXC SSC Enable RW 0 1: Enable Spread-Spectrum Clocking (SSC) on RXC clock output. 25.2 RSVD RO 0 Reserved. 25.1 RXC Enable RO 0 1: RXC clock output enabled. 25.0 CLKOUT Enable RW 1 1: CLKOUT clock output enabled. 8.4.18. PHYSR (PHY Specific Status Register, Address 0x1A) Bit 26.15 26.14 26.13 26.12 26.11 26.10:9 26.8 26.7 26.6 26.5:4 26.3 26.2 Table 39. PHYSR (PHY Specific Status Register, Address 0x1A) Name Type Default Description RSVD RO 0 Reserved. ALDPS State RO 0 Link Down Power Saving Mode. 1: Reflects local device entered Link Down Power Saving Mode, i.e., cable not plugged in (reflected after 3 sec). 0: With cable plugged in MDI Plug RO 0 MDI Status. 1: Plugged 0: Unplugged NWay Enable RO 1 Auto-Negotiation (NWay) Status. 1: Enable 0: Disable Master Mode RO 0 Device is in Master/Slave Mode. 1: Master mode 0: Slave mode RSVD RO 00 Reserved. EEE capability RO 0 1: Both local and link-partner have EEE capability of current speed Rxflow Enable RO 0 Rx Flow Control. 1: Enable 0: Disable Txflow Enable RO 0 Tx Flow Control. 1: Enable 0: Disable Speed RO 00 Link Speed. 11: Reserved 10: 1000Mbps 01: 100Mbps 00: 10Mbps Duplex RO 0 Full/Half Duplex Mode. 1: Full duplex 0: Half duplex Link (Real Time) RO 0 Real Time Link Status. 1: Link OK 0: Link not OK Integrated 10/100/1000M Ethernet Transceiver 41 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Bit 26.1 Name MDI Crossover Status Type RO Default Description 1 MDI/MDI Crossover Status. 1: MDI 0: MDI Crossover 26.0 Jabber (Real Time) RO 0 Real Time Jabber Indication. 1: Jabber Indication 0: No Jabber Indication Note 1: Bit 26.11 valid only when in Giga mode. Note 2: Bit 26.8 assert at 10M speed when local device is EEE capable. 8.4.19. INSR (Interrupt Status Register, Address 0x13) Bit 29.15:11 29.10 29.9 29.8 29.7 Table 40. INSR (Interrupt Status Register, Address 0x13) Name Type Default Description RSVD RO, RC 00000 Reserved. Jabber RO, RC 0 1: Jabber detected 0: No jabber detected ALDPS State Change RO, RC 0 1: ALDPS state changed 0: ALDPS state not changed RSVD RO, RC 0 Reserved. PME (Power Management RO, RC 0 1: WOL event occurred 0: WOL event did not occur Event of WOL) 29.6 29.5 RSVD PHY Register Access RO, RC RO, RC 0 0 29.4 29.3 Link Status Change RO, RC Auto-Negotiation Completed RO, RC 0 0 29.2 Page Received RO, RC 0 29.1 29.0 RSVD Auto-Negotiation Error RO, RC RO, RC 0 0 Integrated 10/100/1000M Ethernet Transceiver Reserved. 1: Can access PHY Register through MDC/MDIO 0: Cannot access PHY Register through MDC/MDIO 1: Link status changed 0: Link status not changed 1: Auto-Negotiation completed 0: Auto-Negotiation not completed 1: Page (a new LCW) received 0: Page not received Reserved. 1: Auto-Negotiation Error 0: No Auto-Negotiation Error 42 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.20. EPAGSR (Extension Page Select Register, Address 0x1F) Bit 31.15:12 31.11:0 Table 41. EPAGSR (Extension Page Select Register, Address 0x1F) Name Type Default Description RSVD RW 0 Reserved. ExtPageSel RW 0x000 Page Select (in HEX). 0x000: Page 0 (default page) 8.4.21. PC1R (PCS Control 1 Register, MMD Device 3, Address 0x00) Table 42. PC1R (PCS Control 1 Register, MMD Device 3, Address 0x00) Bit Name Type Default Description 3.0.15:11 RSVD RW 0 Reserved. 3.0.10 Clock Stop Enable RW 0 1: PHY stops RXC in LPI 0: RXC not stoppable 3.0.9:0 RSVD RW 0 Reserved. 8.4.22. PS1R (PCS Status1 Register, MMD Device 3, Address 0x01) Table 43. PS1R (PCS Status 1 Register, MMD Device 3, Address 0x01) Bit Name Type Default Description 3.1.15:12 RSVD RO 0 Reserved. 3.1.11 TX LPI Received RO, LH 0 1: TX PCS has received LPI 0: LPI not received 3.1.10 RX LPI Received RO, LH 0 1: RX PCS has received LPI 0: LPI not received 3.19 TX LPI Indication RO 0 1: TX PCS is currently receiving LPI 0: TX PCS is not currently receiving LPI 3.1.8 RX LPI Indication RO 0 1: RX PCS is currently receiving LPI 0: RX PCS is not currently receiving LPI 3.1.7 RSVD RO 0 Reserved. 3.1.6 Clock Stop Capable RO 1 1: MAC stops TXC in LPI 0: TXC not stoppable 3.1.5:0 RSVD RO 0 Reserved. Integrated 10/100/1000M Ethernet Transceiver 43 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.23. EEECR (EEE Capability Register, MMD Device 3, Address 0x14) Table 44. EEECR (EEE Capability Register, MMD Device 3, Address 0x14) Bit Name Type Default Description 3.20.15:3 RSVD RO 0 Reserved. 3.20.2 1000BASE-T EEE RO 1 1: EEE is supported for 1000Base-T EEE 0: EEE is not supported for 1000Base-T EEE 3.20.1 100BASE-TX EEE RO 1 1: EEE is supported for 100Base-TX EEE 0: EEE is not supported for 100Base-TX EEE 3.20.0 RSVD RO 0 Reserved. 8.4.24. EEEWER (EEE Wake Error Register, MMD Device 3, Address 0x16) Table 45. EEEWER (EEE Wake Error Register, MMD Device 3, Address 0x16) Bit Name Type Default Description 3.22.15:0 EEE Wake Error RC 0 Used by PHY types that support EEE to count wake time faults Counter where the PHY fails to complete its normal wake sequence within the time required for the specific PHY type. 8.4.25. EEEAR (EEE Advertisement Register, MMD Device 7, Address 0x3c) Table 46. EEEAR (EEE Advertisement Register, MMD Device 7, Address 0x3c) Bit Name Type Default Description 7.60.15:3 RSVD RW 0 Reserved. 7.60.2 1000BASE-T EEE RW 1 Advertise 1000Base-T EEE Capability. 1: Advertise 0: Do not advertise 7.60.1 100BASE-TX EEE RW 1 Advertise 100Base-TX EEE Capability. 1: Advertise 0: Do not advertise 7.60.0 RSVD RW 0 Reserved. Integrated 10/100/1000M Ethernet Transceiver 44 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 8.4.26. EEELPAR (EEE Link Partner Ability Register, MMD Device 7, Address 0x3d) Table 47. EEELPAR (EEE Link Partner Ability Register, MMD Device 7, Address 0x3d) Bit Name Type Default Description 7.61.15:3 RSVD RO 0 Reserved. 7.61.2 LP 1000BASE-T EEE RO 0 1: Link Partner is capable of 1000Base-T EEE 0: Link Partner is not capable of 1000Base-T EEE 7.61.1 LP 100BASE-TX EEE RO 0 1: Link Partner is capable of 100Base-TX EEE 0: Link Partner is not capable of 100Base-TX EEE 7.61.0 RSVD RO 0 Reserved. 8.4.27. LCR (LED Control Register, ExtPage 0xd04, Address 0x10) Bit 16.15 16.14 16.13 16.12 16.11 16.10 16.9 16.8 16.7 16.6 16.5 16.4 16.3 16.2 16.1 16.0 Table 48. LCR (LED Control Register, ExtPage 0xd04, Address 0x10) Name Type Default Description RSVD RO 0 Reserved. LED2_ACT RW 1 LED2 Active (Transmitting or Receiving) Indication LED2_LINK_1000 RW 1 LED2 Link Indication: 1000Mbps RSVD RO 0 Reserved. LED2_LINK_100 RW 0 LED2 Link Indication: 100Mbps LED2_LINK_10 RW 0 LED2 Link Indication: 10Mbps LED2_ACT RW 1 LED1 Active (Transmitting or Receiving) Indication LED1_LINK_1000 RW 0 LED1 Link Indication: 1000Mbps RSVD RO 0 Reserved. LED1_LINK_100 RW 1 LED1 Link Indication: 100Mbps LED1_LINK_10 RW 0 LED1 Link Indication: 10Mbps LED0_ACT RW 1 LED0 Active (Transmitting or Receiving) Indication LED0_LINK_1000 RW 0 LED0 Link Indication: 1000Mbps RSVD RO 0 Reserved. LED0_LINK_100 RW 0 LED0 Link Indication: 100Mbps LED0_LINK_10 RW 1 LED0 Link Indication: 10Mbps 8.4.28. EEELCR (EEE LED Control Register, ExtPage 0xd04, Address 0x11) Bit 17.15:4 17.3 17.2 17.1 17.0 Table 49. EEELCR (EEE LED Control Register, ExtPage 0xd04, Address 0x11) Name Type Default Description RSVD RO 0 Reserved. LED2 EEE Enable RW 1 1: Enable EEE LED indication of LED2. LED1 EEE Enable RW 1 1: Enable EEE LED indication of LED1. LED0 EEE Enable RW 1 1: Enable EEE LED indication of LED0. RSVD RO 0 Reserved. Integrated 10/100/1000M Ethernet Transceiver 45 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 9. Regulators and Power Sequence 9.1. Switching Regulator (RTL8211F(I)) The RTL8211F(I) incorporates a state-of-the-art switching regulator that requires a well-designed PCB layout in order to achieve good power efficiency and lower the output voltage ripple and input overshoot. The switching regulator 1.0V output pin (REG_OUT) should be connected only to DVDD10 and AVDD10 (do not provide this power source to other devices). 9.1.1. PCB Layout • The input 3.3V power trace connected to DVDD33 must be wider than 40mils • The bulk de-coupling capacitors (Cin1 and Cin2) must be placed within 200mils (0.5cm) of DVDD33 to prevent input voltage overshoot • The output power trace out of REG_OUT must be wider than 60mils • Lx (2.2µH/4.7µH) must be kept within 200mils (0.5cm) of REG_OUT • Cout1 and Cout2 must be kept within 200mils (0.5cm) of Lx to ensure stable output power and better power efficiency • For switching regulator stability, the capacitor Cout1 and Cout2 must be a ceramic (X5R) capacitor. Cin1 and Cin2 are recommended to be ceramic capacitors • Place Lx and Cin1 on the same layer as the RTL8211F(I). Do not use vias on DVDD33 and REG_OUT traces Note: Violation of the above rules will damage the IC. Figure 10. Switching Regulator Integrated 10/100/1000M Ethernet Transceiver 46 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 9.1.2. Inductor and Capacitor Parts List Inductor Type GLK2510P-2R2M Table 50. Inductor and Capacitor Parts List Inductance Max IDC (mA) Variation 2.2µH 1000 ≤ 20% Output Ripple (mV) (See Figure 14, page 49, and Figure 15, page 50) GLK2510P-4R7M 4.7µH 750 ≤ 20% (See Figure 16, page 50, and Figure 17, page 51) GTSD32P-2R2M 2.2µH 1500 ≤ 20% (See Figure 18, page 51) Note 1: The ESR is equivalent to RDC or DCR. Lower ESR inductor values will promote a higher-efficiency switching regulator. Note 2: The power inductor used by the switching regulator must be able to withstand 600mA of current. Note 3: Typically, if the power inductor’s ESR at 1MHz is below 0.8Ω, the switching regulator efficiency will be above 75%. However the actual switching regulator efficiency should be measured according to the method described in section 9.1.4 Efficiency Measurement, page 54. Note 4: If the inductor does not meet this requirement, it may damage the switching regulator. Capacitor Type Capacitance ESR at 1MHz (mΩ) Output Ripple (mV) 4.7µF 0805 X5R TDK 4.838 40.28 (See Figure 14, Figure 16) 10µF 0603 X5R YAGEO 11.956 58.29 (See Figure 15, Figure 17) Note: Capacitors (Cin1 & Cin2) must be ceramic due to their low ESR value. Lower ESR values will yield lower output voltage ripple. Integrated 10/100/1000M Ethernet Transceiver 47 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 9.1.3. Measurement Criteria In order for the switching regulator to operate properly, the input and output voltage measurement criteria must be met. From the input side, the voltage overshoot cannot exceed 4V; otherwise the chip may be damaged. Note that the voltage signal must be measured directly at the DVDD33 pin, not at the capacitor. In order to reduce the input voltage overshoot, the Cin1 and Cin2 must be placed close to the DVDD33 pin. The following figures show what a good input voltage and a bad one look like. Figure 11. Input Voltage Overshoot 4V (Bad) Integrated 10/100/1000M Ethernet Transceiver 48 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet From the output side measured at the REG_OUT pin, the voltage ripple must be within 100mV peak-to-peak. Choosing different types and values of input and output capacitor (Cin1, Cin2; Cout1, Cout2) and power inductor (Lx) will seriously affect the efficiency and output voltage ripple of switching regulators. The following figures show the effects of different types of capacitors on the switching regulator’s output voltage. The blue square wave signal (top row) is measured at the output of the REG_OUT pin before the power inductor (Lx). The yellow signal (second row) is measured after the power inductor (Lx), and shows there is a voltage ripple. The green signal (lower row) is the current. Data in the following figures was measured at gigabit speed. Figure 13. Ceramic 10µF 0603 (X5R) (Good) Figure 14. L=GLK2510P-2R2M, C=Ceramic 4.7µF 0805 X5R TDK (Ripple 12.4mV) Integrated 10/100/1000M Ethernet Transceiver 49 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Figure 15. L=GLK2510P-2R2M, C=Ceramic 10µF 0603 X5R YAGEO (Ripple 13.2mV) Figure 16. L=GLK2510P-4R7M, C=Ceramic 4.7µF 0805 X5R TDK (Ripple 12mV) Integrated 10/100/1000M Ethernet Transceiver 50 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Figure 17. L=GLK2510P-4R7M, C=Ceramic 10µF 0603 X5R YAGEO (Ripple 11.2mV) Figure 18. L=GTSD32P-2R2M, C=Ceramic 4.7µF 0805 X5R TDK (Ripple 9.2mV) Integrated 10/100/1000M Ethernet Transceiver 51 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Figure 19. Ceramic 10µF (Y5V) (Bad) A ceramic 10µF (X5R) will have a lower voltage ripple compared to an electrolytic 100µF. The key to choosing a proper output capacitor is to choose the lowest ESR to reduce the output voltage ripple. Choosing a ceramic 10µF (Y5V) in this case will cause malfunction of the switching regulator. Placing several Electrolytic capacitors in parallel will help lower the output voltage ripple. Figure 20. Electrolytic 100µF (Ripple Too High) Integrated 10/100/1000M Ethernet Transceiver 52 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet The following figures show how different inductors affect the REG_OUT output waveform. The typical waveform should look like Figure 21, which has a square waveform with a dip at the falling edge and the rising edge. If the inductor is not carefully chosen, the waveform may look like Figure 22, where the waveform looks like a distorted square. This will cause insufficient current supply and will undermine the stability of the system at gigabit speed. Data in the following figures was measured at gigabit speed Figure 21. GTSD32P-2R2M (Good) Figure 22. 1µH Bead (Bad) Integrated 10/100/1000M Ethernet Transceiver 53 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 9.1.4. Efficiency Measurement The efficiency of the switching regulator is designed to be above 75% in gigabit traffic mode. It is very important to choose a suitable inductor before Gerber certification, as the Inductor ESR value will affect the efficiency of the switching regulator. An inductor with a lower ESR value will result in a higher-efficiency switching regulator. The efficiency of the switching regulator is easily measured using the following method. Figure 23 shows two checkpoints, checkpoint A (CP_A) and checkpoint B (CP_B). The switching regulator input current (Icpa) should be measured at CP_A, and the switching regulator output current (Icpb) should be measured at CP_B. To determine efficiency, apply the following formula: Efficiency = Vcpb*Icpb/Vcpa*Icpa Where Vcpb is 1.05V; Vcpa is 3.3V. The measurements should be performed in gigabit traffic mode. For example: The inductor used in the evaluation board is a GOTREND GTSD32-4R7M: • The ESR value @ 1MHz is approximately 0.712ohm • The measured Icpa is 101mA at CP_A • The measured Icpb is 263mA at CP_B These values are measured in gigabit traffic mode, so the efficiency of the GOTREND GTSD32-4R7M can be calculated as follows: Efficiency = (1.05V*263mA)/(3.3V*101mA) = 0.823 = 82.3%. We strongly recommend that when choosing an inductor for the switching regulator, the efficiency should be measured, and that the inductor should yield an efficiency rating higher than 75%. If the efficiency does not meet this requirement, there may be risk to the switching regulator reliability in the long run. CP_A CP_B Figure 23. Switching Regulator Efficiency Measurement Checkpoint Integrated 10/100/1000M Ethernet Transceiver 54 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 9.2. Low-dropout Regulator (RTL8211FD(I)) The RTL8211FD(I) incorporates a state-of-the-art low-dropout regulator (LDO). The regulator 1.0V output pin (LDO_OUT) should be connected only to DVDD10 and AVDD10 pins (do not provide this power source to other devices). Integrated 10/100/1000M Ethernet Transceiver 55 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 9.3. Power Sequence Figure 24. Power Sequence Table 51. Power Sequence Parameters Symbol Description Min Typical Max Units Rt1 3.3V Rise Time 0.5* 100 ms Rt1 2.5/1.8/1.5V RGMII Rise Time 100 ms Rt2 3.3V Off Time 100 ms Rt3 Core Logic Ready Time 20 ms Rt4 LDO Ready time 1.5 ms Note 1: The RTL8211F(I)/RTL8211FD(I) does not support fast 3.3V rising. The 3.3V rise time should be controlled over 0.5ms. * A 3.3V rise time between 0.1ms to 0.5ms is conditionally permitted only if the system 3.3V power budget is sufficient to ensure that 3.3V Overcurrent Protection (OCP) will NOT be triggered during the power-on procedure. If the rise time is less than 0.1ms, it will induce a peak voltage in DVDD33 which may cause permanent damage to the regulator. Note 2: If there is any action that involves consecutive ON/OFF toggling of the switching-regulator source (3.3V), the design must make sure the OFF state of both the switching-regulator source (3.3V) and output (1.05V) reach 0V, and the time period between the consecutive ON/OFF toggling action must be longer than 100ms. Note 3: When using an external oscillator or clock source, on stopping the clock source the RTL8211F(I)/RTL8211FD(I) must also be powered off. Note 4: The RTL8211F(I)/ RTL8211FD(I) use the integrated LDO to generate the 2.5V, 1.8V/1.5V voltages for the I/O pad, the I/O pad voltage can be selected by using the CONFIG pins CFG_LDO[1:0]. Moreover, external power source for the I/O pad is also supported, please refer to the setting of CFG_EXT and CFG_LDO[1:0] pins (section 7.8 Hardware Configuration, page 15). Note 5: When using an external power source for the I/O pad , 2.5V (or 1.8/1.5V) RGMII power should rise simultaneously or slightly earlier than 3.3V power. Rising 2.5V (or 1.8/1.5V) power later than 3.3V power may lead to errors. Integrated 10/100/1000M Ethernet Transceiver 56 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 10. Characteristics 10.1. Absolute Maximum Ratings WARNING: Absolute maximum ratings are limits beyond which permanent damage may be caused to the device, or device reliability will be affected. All voltages are specified reference to GND unless otherwise specified. Table 52. Absolute Maximum Ratings Symbol Description Minimum VDD33, AVDD33 Supply Voltage 3.3V -0.3 AVDD10, DVDD10 Supply Voltage 1.0V -0.3 2.5V RGMII/GMII Supply Voltage 2.5V -0.2 1.8V RGMII Supply Voltage 1.8V -0.2 1.5V RGMII Supply Voltage 1.5V -0.2 3.3V DCinput Input Voltage -0.3 3.3V DCoutput Output Voltage 1.0V DCinput Input Voltage -0.3 1.0V DCoutput Output Voltage NA Storage Temperature -55 Note: Refer to the most updated schematic circuit for correct configuration. Maximum 3.6 1.2 2.8 2.3 2.0 Unit V V V V V 3.6 V 1.2 V +125 °C 10.2. Recommended Operating Conditions Table 53. Recommended Operating Conditions Pins Minimum Typical DVDD33, AVDD33 2.97 3.3 AVDD10, DVDD10 0.95 1.0 2.5V RGMII/GMII 2.25 2.5 1.8V RGMII 1.62 1.8 1.5V RGMII 1.5 1.55 Ambient Operating Temperature TA 0 (RTL8211F/RTL8211FD) Ambient Operating Temperature TA -40 (RTL8211FI/RTL8211FDI) Maximum Junction Temperature Description Supply Voltage VDD Integrated 10/100/1000M Ethernet Transceiver 57 Maximum 3.63 1.05 2.75 1.98 1.6 70 Unit V V V V V °C 85 °C 125 °C Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 10.3. Crystal Requirements Table 54. Crystal Requirements Symbol Description/Condition Minimum Typical Maximum Unit Fref Parallel Resonant Crystal Reference Frequency, 25 MHz Fundamental Mode, AT-Cut Type. Fref Tolerance Parallel Resonant Crystal Frequency Tolerance, -50 +50 ppm Fundamental Mode, AT-Cut Type. Ta=0°C~70°C. Fref Duty Cycle Reference Clock Input Duty Cycle. 40 60 % ESR Equivalent Series Resistance. 50 Ω DL Drive Level. 0.5 mW Jitter Broadband Peak-to-Peak Jitter1, 2 200 ps Vih_CKXTAL Crystal Output High Level 1.4 V Vil_CKXTAL Crystal Output Low Level 0.4 V Note 1: 25kHz to 25MHz RMS < 3ps. Note 2: Broadband RMS < 9ps. Note3: Fref Tolerance +/- 50ppm including effects of aging of the first year, external crystal capacitors, and PCB layout. 10.4. Oscillator/External Clock Requirements Table 55. Oscillator/External Clock Requirements Parameter Condition Minimum Typical Maximum Unit Frequency 25/50 MHz Frequency Tolerance (RTL8211F/RTL8211FD) Ta=0°C~70°C -50 50 ppm Frequency Tolerance (RTL8211FI/RTL8211FDI) Ta=-40°C~85°C -50 50 ppm Duty Cycle 40 60 % 1, 2 Broadband Peak-to-Peak Jitter 200 ps Vpeak-to-peak 3.15 3.3 3.45 V Rise Time (10%~90%) 10 ns Fall Time (10%~90%) 10 ns Operating Temperature Range -40 85 °C Note 1: 25kHz to 25MHz RMS < 3ps. Note 2: Broadband RMS < 9ps. Note3: Frequency Tolerance +/- 50ppm including effects of aging of the first year, external crystal capacitors, and PCB layout. Integrated 10/100/1000M Ethernet Transceiver 58 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 10.5. DC Characteristics Table 56. DC Characteristics Parameter Conditions Minimum 3.3V Supply Voltage 2.97 Symbol VDD33, AVDD33 1. MDIO (Table 4, page 8) 2. RGMII I/O (Table 3, page 8) 1. MDIO (Table 4, page 8) 2. RGMII I/O (Table 3, page 8) 1. MDIO (Table 4, page 8) 2. RGMII I/O (Table 3, page 8) DVDD10, AVDD10 Voh (3.3V) Voh (2.5V) Voh (1.8V) Voh (1.5V) Vol (3.3V) Vol (2.5V) Vol (1.8V) Vol (1.5V) Vih (3.3V) Vil (3.3V) Vih (2.5V) Vil (2.5V) Vih (1.8V) Vil (1.8V) Vih (1.5V) Vil (1.5V) Minimum High Level Output Voltage Minimum High Level Output Voltage Minimum High Level Output Voltage Minimum High Level Output Voltage Maximum Low Level Output Voltage Maximum Low Level Output Voltage Maximum Low Level Output Voltage Maximum Low Level Output Voltage Minimum High Level Input Voltage Maximum Low Level Input Voltage Minimum High Level Input Voltage Maximum Low Level Input Voltage Minimum High Level Input Voltage Maximum Low Level Input Voltage Minimum High Level Input Voltage Maximum Low Level Input Voltage Iin Input Current Typical 3.3 Maximum 3.63 Units V 2.5V RGMII Supply Voltage - 2.25 2.5 2.75 V 1.8V RGMII Supply Voltage - 1.62V 1.8V 1.98V V 1.5V RGMII Supply Voltage - 1.5V 1.55V 1.6V V 1.0V Supply Voltage - 0.95 1.0 1.05 V - VDD33 + 0.3 VDD25 + 0.3 VDD18 + 0.3 VDD15 + 0.3 0.4 0.4 0.1*VDD18 0.1*VDD15 0.8 0.7 0.5 0.3 V V V V V V V V V V V V V V V V - 0.5 µA 2.4 2.0 0.9*VDD18 0.9*VDD15 -0.3 -0.3 -0.3 -0.3 2.0 1.7 1.2 1.0 Vin=VDD33 0 or GND Note: Pins not mentioned above remain at 3.3V. Integrated 10/100/1000M Ethernet Transceiver 59 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 10.6. AC Characteristics 10.6.1. MDC/MDIO Timing Figure 25. MDC/MDIO Setup, Hold Time, and Valid from MDC Rising Edge Time Definitions MDC/MDIO Timing – Management Port Figure 26. MDC/MDIO Management Timing Parameters Symbol t1 t2 t3 t4 t5 t6 Table 57. MDC/MDIO Management Timing Parameters Description Minimum Maximum MDC High Pulse Width 32 MDC Low Pulse Width 32 MDC Period 80 MDIO Setup to MDC Rising Edge 10 MDIO Hold Time from MDC Rising Edge 10 MDIO Valid from MDC Rising Edge 0 300 Integrated 10/100/1000M Ethernet Transceiver 60 Unit ns ns ns ns ns ns Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 10.6.2. RGMII Timing Modes Timing for this interface will be such that the clock and data are generated simultaneously by the source of the signals and therefore skew between the clock and data is critical to proper operation. Figure 27 shows the effect of adding an internal delay to TXC when in RGMII mode. Figure 27. RGMII Timing Modes (For TXC) Integrated 10/100/1000M Ethernet Transceiver 61 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Figure 28 shows the effect of adding an internal delay to the RXC flow when in RGMII mode. Figure 28. RGMII Timing Modes (For RXC) Integrated 10/100/1000M Ethernet Transceiver 62 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet Symbol TGCC Duty_G Duty_T tR tF TsetupT TholdT TsetupR TholdR TskewT TskewR Table 58. RGMII Timing Parameters Description Min Clock Cycle Duration (1000Mbps) 7.2 Clock Cycle Duration (100Mbps) 36 Clock Cycle Duration (10Mbps) 360 Duty Cycle for 1000 45 Duty Cycle for 10/100 40 TXC/RXC Rise Time (20%~80%) TXC/RXC Fall Time (20%~80%) Data to Clock Output Setup (at transmitter 1.2 integrated delay) Data to Clock Output Hold (at transmitter 1.2 integrated delay) Data to Clock Input Setup (at receiver integrated 1.0 delay) Data to Clock Input Hold (at receiver integrated 1.0 delay) Data to Clock Output Skew (at transmitter) -0.5 Data to Clock Input Skew (at receiver) 1 This implies that PC board design will require clocks to be routed such that an additional trace delay of greater than 1.5ns and less than 2.0ns will be added to the associated clock signal. Integrated 10/100/1000M Ethernet Transceiver 63 Typical 8 40 400 50 50 2 Max 8.8 44 440 55 60 0.75 0.75 - Units ns ns ns % % ns ns ns 2 - ns 2 - ns 2 - ns 0 1.8 0.5 2.6 ns ns Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 11. Mechanical Dimensions 11.1. Mechanical Dimensions Notes Symbol Dimension in mm Nom Max A 0.85 0.90 A1 0.02 0.05 A3 0.20REF b 0.15 0.20 0.25 D/E 5.00 BSC D2/E2 3.45 3.70 3.95 e 0.40 BSC L 0.30 0.40 0.50 Note 1: CONTROLLING DIMENSION: MILLIMETER (mm). Note 2: REFERENCE DOCUMENT: JEDEC MO-220. Min 0.80 0.00 Integrated 10/100/1000M Ethernet Transceiver Min 0.031 0.000 0.006 0.136 0.012 64 Dimension in inch Nom 0.033 0.001 0.008REF 0.008 0.197 BSC 0.146 0.016 BSC 0.016 Max 0.035 0.002 0.010 0.156 0.020 Track ID: JATR-8275-15 Rev. 1.1 RTL8211F(I)/RTL8211FD(I) Datasheet 12. Ordering Information Table 59. Ordering Information Part Number RTL8211F-CG RTL8211FD-CG Package 40-Pin QFN with ‘Green’ Package (Switching Regulator model) 40-Pin QFN with ‘Green’ Package (LDO model) RTL8211FI-CG 40-Pin QFN with ‘Green’ Package (Switching Regulator model) Industrial grade. RTL8211FDI-CG 40-Pin QFN with ‘Green’ Package (LDO model). Industrial grade. Note: See page 6 for package identification. Status ES ready MP in Mar/2014 ES ready MP in Mar/2014 - Realtek Semiconductor Corp. Headquarters No. 2, Innovation Road II Hsinchu Science Park, Hsinchu 300, Taiwan Tel.: +886-3-578-0211 Fax: +886-3-577-6047 www.realtek.com Integrated 10/100/1000M Ethernet Transceiver 65 Track ID: JATR-8275-15 Rev. 1.1
rtl8211f 价格&库存
很抱歉,暂时无法提供与“rtl8211f”相匹配的价格&库存,您可以联系我们找货
