74LVC2G17GV,125
74LVC2G17GV,125
    NEXPERIA(安世)
    SC74-6
    双非反相施密特触发器,具有5V容差输入 SC74-6 1.65~5.5V
74LVC2G17GV,125 数据手册
74LVC2G17 Dual non-inverting Schmitt trigger with 5 V tolerant input Rev. 10 — 21 June 2021 Product data sheet 1. General description The 74LVC2G17 is a dual buffer with Schmitt-trigger inputs. Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices as translators in mixed 3.3 V and 5 V environments. This device is fully specified for partial power down applications using IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current through the device when it is powered down. 2. Features and benefits • • • • • • • • • • • • Wide supply voltage range from 1.65 V to 5.5 V Overvoltage tolerant inputs to 5.5 V High noise immunity ±24 mA output drive (VCC = 3.0 V) CMOS low-power consumption Latch-up performance exceeds 250 mA Direct interface with TTL levels IOFF circuitry provides partial Power-down mode operation Complies with JEDEC standard: • JESD8-7 (1.65 V to 1.95 V) • JESD8-5 (2.3 V to 2.7 V) • JESD-8B/JESD36 (2.7 V to 3.6 V) ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 3. Applications • Wave and pulse shapers for highly noisy environments 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 4. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74LVC2G17GW -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 74LVC2G17GV -40 °C to +125 °C SC-74; TSOP6 plastic surface-mounted package; 6 leads SOT457 74LVC2G17GM -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 74LVC2G17GN -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 × 1.0 × 0.35 mm SOT1115 74LVC2G17GS -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 5. Marking Table 2. Marking codes Type number Marking code [1] 74LVC2G17GW VV 74LVC2G17GV VV 74LVC2G17GM VV 74LVC2G17GN VV 74LVC2G17GS VV [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 6. Functional diagram 1 1 1A 1Y 6 3 2A 2Y 4 3 Logic symbol 74LVC2G17 Product data sheet 4 1A 1Y 2A 2Y mnb067 mnb066 Fig. 1. 6 Fig. 2. IEC logic symbol mnb068 Fig. 3. Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 2 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 7. Pinning information 7.1. Pinning 74LVC2G17 74LVC2G17 1A 1 6 1Y GND 2 5 VCC 2A 3 4 2Y 1A 1 6 1Y GND 2 5 VCC 2A 3 4 Pin configuration SOT363 (SC-88) and SOT457 (SC-74; TSOP6) 1A 1 6 1Y GND 2 5 VCC 2A 3 4 2Y 2Y 001aaf079 001aaf078 Fig. 4. 74LVC2G17 001aaf080 Transparent top view Fig. 5. Pin configuration SOT886 (XSON6) Transparent top view Fig. 6. Pin configuration SOT1115 and SOT1202 (XSON6) 7.2. Pin description Table 3. Pin description Symbol Pin Description 1A 1 data input GND 2 ground (0 V) 2A 3 data input 2Y 4 data output VCC 5 supply voltage 1Y 6 data output 8. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level. Input Output nA nY L L H H 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 3 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 9. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode Min Max Unit -0.5 +6.5 V - -50 mA -0.5 +6.5 V - -50 mA [1] -0.5 VCC + 0.5 V [1] [2] -0.5 +6.5 V - ±50 mA VI < 0 V [1] Power-down mode IO output current ICC supply current - 100 mA IGND ground current - -100 mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] [3] VO = 0 V to VCC Tamb = -40 °C to +125 °C [3] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation. For SOT363 (SC-88) package: Ptot derates linearly with 3.7 mW/K above 83 °C. For SOT457 (SC-74; TSOP6) package: Ptot derates linearly with 4.1 mW/K above 89 °C. For SOT886 (XSON6) package: Ptot derates linearly with 3.3 mW/K above 74 °C. For SOT1115 (XSON6) package: Ptot derates linearly with 3.2 mW/K above 71 °C. For SOT1202 (XSON6) package: Ptot derates linearly with 3.3 mW/K above 74 °C. 10. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC supply voltage 1.65 - 5.5 V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature -40 - +125 °C 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 4 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 11. Static characteristics Table 7. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ [1] Max Unit IO = 100 μA; VCC = 1.65 V to 5.5 V - IO = 4 mA; VCC = 1.65 V - - 0.1 V - 0.45 V IO = 8 mA; VCC = 2.3 V - - 0.3 V IO = 12 mA; VCC = 2.7 V - - 0.4 V IO = 24 mA; VCC = 3.0 V - - 0.55 V IO = 32 mA; VCC = 4.5 V - - 0.55 V VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 1.2 - - V IO = -8 mA; VCC = 2.3 V 1.9 - - V IO = -12 mA; VCC = 2.7 V 2.2 - - V IO = -24 mA; VCC = 3.0 V 2.3 - - V IO = -32 mA; VCC = 4.5 V 3.8 - - V Tamb = -40 °C to +85 °C VOL VOH LOW-level output voltage HIGH-level output voltage VI = VT+ or VT- VI = VT+ or VTIO = -100 μA; VCC = 1.65 V to 5.5 V II input leakage current VI = 5.5 V or GND; VCC = 5.5 V - ±0.1 ±1 μA IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - ±0.1 ±2 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - 0.1 4 μA ΔICC additional supply current VI = VCC - 0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V - 5 500 μA CI input capacitance - 3.5 - pF 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 5 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input Symbol Parameter Conditions Min Typ [1] Max Unit IO = 100 μA; VCC = 1.65 V to 5.5 V - IO = 4 mA; VCC = 1.65 V - - 0.1 V - 0.70 V IO = 8 mA; VCC = 2.3 V - - 0.45 V IO = 12 mA; VCC = 2.7 V - - 0.60 V IO = 24 mA; VCC = 3.0 V - - 0.80 V IO = 32 mA; VCC = 4.5 V - - 0.80 V VCC - 0.1 - - V IO = -4 mA; VCC = 1.65 V 0.95 - - V IO = -8 mA; VCC = 2.3 V 1.7 - - V IO = -12 mA; VCC = 2.7 V 1.9 - - V IO = -24 mA; VCC = 3.0 V 2.0 - - V IO = -32 mA; VCC = 4.5 V 3.4 - - V Tamb = -40 °C to +125 °C VOL LOW-level output voltage VOH HIGH-level output voltage VI = VT+ or VT- VI = VT+ or VTIO = -100 μA; VCC = 1.65 V to 5.5 V II input leakage current VI = 5.5 V or GND; VCC = 5.5 V - ±0.1 ±1 μA IOFF power-off leakage current VI or VO = 5.5 V; VCC = 0 V - - ±2 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4 μA ΔICC additional supply current VI = VCC - 0.6 V; IO = 0 A; VCC = 2.3 V to 5.5 V - - 500 μA [1] All typical values are measured at VCC = 3.3 V and Tamb = 25 °C. 12. Dynamic characteristics Table 8. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8. Symbol Parameter tpd propagation delay CPD [1] [2] [3] power dissipation capacitance Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 1.65 V to 1.95 V 1.5 5.6 10.5 1.5 13.1 ns VCC = 2.3 V to 2.7 V 1.0 3.7 6.5 1.0 8.5 ns VCC = 2.7 V 1.0 3.8 6.5 1.0 8.5 ns VCC = 3.0 V to 3.6 V 1.0 3.6 5.7 1.0 7.1 ns VCC = 4.5 V to 5.5 V 1.0 2.7 4.3 1.0 5.4 ns - 16.3 - - - pF nA to nY; see Fig. 7 per buffer; VCC = 3.3 V; VI = GND to VCC [2] [3] Typical values are measured at Tamb = 25 °C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively. tpd is the same as tPLH and tPHL. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 ∑(CL × VCC × fo) = sum of outputs. 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 6 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 12.1. Waveforms and test circuit VI nA input VM VM GND tPLH tPHL VOH VM nY output VM VOL mnb072 Measurement points are given in Table 9. VOL and VOH are typical output voltage drop that occur with the output load. Fig. 7. The input (nA) to output (nY) propagation delays and the output transition times Table 9. Measurement points Supply voltage Input Output VCC VM VM 1.65 V to 1.95 V 0.5 × VCC 0.5 × VCC 2.3 V to 2.7 V 0.5 × VCC 0.5 × VCC 2.7 V 1.5 V 1.5 V 3.0 V to 3.6 V 1.5 V 1.5 V 4.5 V to 5.5 V 0.5 × VCC 0.5 × VCC VEXT VCC G VI RL VO DUT RT CL RL mna616 Measurement points are given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 8. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VEXT Load VCC VI tr, tf CL RL tPLH, tPHL 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1 kΩ open 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2.7 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 3.0 V to 3.6 V 2.7 V ≤ 2.5 ns 50 pF 500 Ω open 4.5 V to 5.5 V VCC ≤ 2.5 ns 50 pF 500 Ω open 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 7 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 13. Transfer characteristics Table 11. Transfer characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter VT+ -40 °C to +125 °C Unit Min Typ [1] Max Min Max VCC = 1.8 V 0.70 1.10 1.50 0.70 1.70 V VCC = 2.3 V 1.00 1.40 1.80 1.00 2.00 V VCC = 3.0 V 1.30 1.76 2.20 1.30 2.40 V VCC = 4.5 V 1.90 2.47 3.10 1.90 3.30 V VCC = 5.5 V 2.20 2.91 3.60 2.20 3.80 V VCC = 1.8 V 0.25 0.61 0.90 0.25 1.10 V VCC = 2.3 V 0.40 0.80 1.15 0.40 1.35 V VCC = 3.0 V 0.60 1.04 1.50 0.60 1.70 V VCC = 4.5 V 1.00 1.55 2.00 1.00 2.20 V VCC = 5.5 V 1.20 1.86 2.30 1.20 2.50 V VCC = 1.8 V 0.15 0.49 1.00 0.15 1.20 V VCC = 2.3 V 0.25 0.60 1.10 0.25 1.30 V VCC = 3.0 V 0.40 0.73 1.20 0.40 1.40 V VCC = 4.5 V 0.60 0.92 1.50 0.60 1.70 V VCC = 5.5 V 0.70 1.02 1.70 0.70 1.90 V see Fig. 9 and Fig. 10 negative-going threshold voltage VH -40 °C to +85 °C see Fig. 9 and Fig. 10 positive-going threshold voltage VT- [1] Conditions (VT+ - VT-); see Fig. 9, Fig. 10 and Fig. 11 hysteresis voltage All typical values are measured at Tamb = 25 °C. 13.1. Waveforms transfer characteristics VO VI VT+ VH VT- VO VI VH VT- Fig. 9. VT+ Transfer characteristic 74LVC2G17 Product data sheet mnb154 mnb155 VT+ and VT- limits at 70 % and 20 %. Fig. 10. Definition of VT+, VT- and VH All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 8 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input mnb156 50 ICC (mA) mnb071 14 ICC (mA) 12 (1) 40 30 10 20 8 6 (2) 10 4 0 2 0 0 0.5 1 1.5 VCC = 3.0 V. Fig. 11. Typical transfer characteristic 74LVC2G17 Product data sheet VI (V) 2 2 3 4 5 VCC (V) 6 (1) Positive-going edge (2) Negative-going edge Linear change of VI between 0.8 V to 2.0 V. All values given are typical unless otherwise specified. Fig. 12. Average ICC as a function of VCC All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 9 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 14. Package outline Plastic surface-mounted package; 6 leads SOT363 D B E y A X HE 6 5 v M A 4 Q pin 1 index A 1 2 e1 A1 3 bp c Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Fig. 13. Package outline SOT363 (SC-88) 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 10 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input Plastic, surface-mounted package (SC-74; TSOP6); 6 leads D SOT457 B E y A X HE 6 5 v M A 4 Q A pin 1 index A1 c 1 2 Lp 3 bp e detail X w M B 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A A1 1.1 0.1 0.9 bp c D E 0.40 0.26 3.1 1.7 0.013 0.25 0.10 2.7 1.3 e 0.95 HE Lp Q 3.0 0.6 0.33 2.5 0.2 0.23 v w y 0.2 0.2 0.1 sot457_po Outline version References IEC JEDEC JEITA SOT457 European projection Issue date 06-03-16 18-11-27 SC-74 Fig. 14. Package outline SOT457 (SC-74; TSOP6) 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 11 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input SOT886 XSON6: plastic extremely thin small outline package; no leads; 6 terminals; body 1 x 1.45 x 0.5 mm b 1 2 3 4x (2) L L1 e 6 5 e1 4 e1 6x A (2) A1 D E terminal 1 index area 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit mm max nom min A(1) 0.5 A1 b D E 0.04 0.25 1.50 1.05 0.20 1.45 1.00 0.17 1.40 0.95 e e1 0.6 0.5 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Notes 1. Including plating thickness. 2. Can be visible in some manufacturing processes. Outline version SOT886 sot886_po References IEC JEDEC JEITA European projection Issue date 04-07-22 12-01-05 MO-252 Fig. 15. Package outline SOT886 (XSON6) 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 12 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input XSON6: extremely thin small outline package; no leads; 6 terminals; body 0.9 x 1.0 x 0.35 mm 1 SOT1115 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e max 0.35 0.04 0.20 0.95 1.05 nom 0.15 0.90 1.00 0.55 min 0.12 0.85 0.95 e1 0.3 L L1 0.35 0.40 0.30 0.35 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1115_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-07 SOT1115 Fig. 16. Package outline SOT1115 (XSON6) 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 13 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input XSON6: extremely thin small outline package; no leads; 6 terminals; body 1.0 x 1.0 x 0.35 mm 1 SOT1202 b 3 2 (4×)(2) L L1 e 6 5 4 e1 e1 (6×)(2) A1 A D E terminal 1 index area 0 0.5 Dimensions Unit mm 1 mm scale A(1) A1 b D E e e1 L L1 max 0.35 0.04 0.20 1.05 1.05 0.35 0.40 nom 0.15 1.00 1.00 0.55 0.35 0.30 0.35 min 0.12 0.95 0.95 0.27 0.32 Note 1. Including plating thickness. 2. Visible depending upon used manufacturing technology. Outline version sot1202_po References IEC JEDEC JEITA European projection Issue date 10-04-02 10-04-06 SOT1202 Fig. 17. Package outline SOT1202 (XSON6) 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 14 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 15. Abbreviations Table 12. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 16. Revision history Table 13. Revision history Document ID Release date Data sheet status Change notice Supersedes 74LVC2G17 v.10 20210621 Product data sheet - Modifications: • • • • • • 74LVC2G17 v.9 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74LVC2G17GF (SOT891 / XSON6) removed. Section 1 and Section 2 updated. Section 9: Derating values for Ptot total power dissipation updated. Fig. 14: Package outline drawing SOT457 (SC-74; TSOP6) updated. 74LVC2G17 v.9 20161215 Modifications: • 74LVC2G17 v.8 20130502 Modifications: • 74LVC2G17 v.6 20110921 Product data sheet - 74LVC2G17 v.5 74LVC2G17 v.5 20100806 Product data sheet - 74LVC2G17 v.4 74LVC2G17 v.4 20061009 Product data sheet - 74LVC2G17 v.3 74LVC2G17 v.3 20050926 Product data sheet - 74LVC2G17 v.2 74LVC2G17 v.2 20040908 Product specification - 74LVC2G17 v.1 74LVC2G17 v.1 20030813 Product specification - - 74LVC2G17 Product data sheet Product data sheet - 74LVC2G17 v.8 Table 7: The maximum limits for leakage current and supply current have changed. Product data sheet - 74LVC2G17 v.7 Table 3: the description of pin 6 changed from data input to data output. All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 15 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input 17. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74LVC2G17 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 16 / 17 74LVC2G17 Nexperia Dual non-inverting Schmitt trigger with 5 V tolerant input Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................2 5. Marking.......................................................................... 2 6. Functional diagram.......................................................2 7. Pinning information......................................................3 7.1. Pinning.........................................................................3 7.2. Pin description............................................................. 3 8. Functional description................................................. 3 9. Limiting values............................................................. 4 10. Recommended operating conditions........................4 11. Static characteristics..................................................5 12. Dynamic characteristics............................................ 6 12.1. Waveforms and test circuit........................................ 7 13. Transfer characteristics............................................. 8 13.1. Waveforms transfer characteristics............................8 14. Package outline........................................................ 10 15. Abbreviations............................................................ 15 16. Revision history........................................................15 17. Legal information......................................................16 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 June 2021 74LVC2G17 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 21 June 2021 © Nexperia B.V. 2021. All rights reserved 17 / 17
74LVC2G17GV,125 价格&库存
很抱歉,暂时无法提供与“74LVC2G17GV,125”相匹配的价格&库存,您可以联系我们找货
74LVC2G17GV,125
    • 1+0.68050
    • 100+0.63010
