SSP1117
1A Bipolar Linear Regulator
Features
Maximum output current is 1.0A
Standby current: 2mA (typ.)
Range of operation input voltage: Max 15V
Load regulation: 0.2%/A (typ.)
Line regulation: 0.03%/V (typ.)
Environment Temperature: -20℃~85℃
DVD Decode Board
ADSL Modem
Post Regulators For Switching Supplies
Applications
Power Management for Computer Mother
Board, Graphic Card
LCD Monitor and LCD TV
General Description
only two external resistors.
regulators with a dropout of 1.3V at 1A load current.
SSP1117 offers thermal shut down function, to assure the
IN
SSP1117 is a series of low dropout three-terminal
SSP1117 features a very low standby current 2mA
stability of chip and power system. And it uses trimming
compared to 5mA of competitor.
technique toguarantee output voltage accuracy within 2%.
Other output voltage accuracy can be customized on
demand, such as 1%.
PR
O
Other than a fixed version, Vout=1.2V, 1.5V, 1.8V, 2.5V,
2.85V, 3.3V and 5V, SSP1117 has an adjustable version,
which can provide an output voltage from 1.25 to 12V with
SSP1117 is available in SOT-223, TO-252 power package.
SI
Typical Application
Typical Electrical Characteristic
Ver1.4
1
Shanghai Siproin Microelectronics Co.
SSP1117
Selection Table
Marking
Output Voltage
XX=12
1.2V
XX=15
1.5V
1117
XX=18
1.8V
XX YYWW
XX=28
2.85V
SOT-223
XX=25
2.5V
TO-252
XX=33
3.3V
XX=50
5.0V
XX=ADJ
Adj
Ordering Information
Marking
1117
XX
YYWW
Description
Product code
Output Voltage(1.2~12.0V)
PR
O
1117
XXYYWW
Designator
Package
IN
Part No.
DATE CODE
Note:”XX” stands for output voltages. Other voltages can be specially customized
Parameters
Temperature&Rohs
Package type
SI
Packing type:
Voltage accuracy
Description
C:-40~85℃ ,Pb Free Rohs Std.
SOT-223
TO-252
TR:Tape&Reel (Standard)
2%(Customized)
Block Diagram
Ver1.4
2
SSP1117
PR
O
IN
Pin Configuration
Absolute Maximum Ratings
Max Input Voltage ············································································· ··············· ······· 30V
Max Operating Junction Temperature(Tj) ················································· ··············· ······· 150℃
Ambient Temperature(Ta) ··································································· ··············· ······· -40℃~ 85℃
Storage Temperature(Ts) ···································································· ··············· ······· -40℃~150℃
Lead Temperature & Time ··································································· ··············· ······· 260℃ 10S
Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect
SI
device reliability.
Recommended Work Conditions
Recommended maximum input voltage ······································································ ·······
15V
Recommended operating junction temperature(Tj)························································· ·······
-20~125℃
Thermal Information
Parameter
Package thermal
resistance
Ver1.4
Package
Rating
Unit
SOT-223
℃/W
TO-252
12.5
℃/W
3
SSP1117
Electrical Characteristics
TA=25℃,unless otherwise noted.
Symbol
Parameter
Vref
Reference
Conditions
SSP1117-Adj
voltage
Min
Typ
Max
Unit
1.225
1.25
1.275
V
1.176
1.2
1.224
V
1.47
1.5
1.53
V
1.764
1.8
1.836
V
2.45
2.5
2.55
V
10mA≤Iout≤1A , Vin=3.25V
SSP1117-1.2V
0≤Iout≤1A , Vin=3.2V
SSP1117-1.5V
0≤Iout≤1A , Vin=3.5V
SSP1117-1.8V
Vout
Output voltage
0≤Iout≤1A , Vin=3.8V
0≤Iout≤1A , Vin=4.5V
SSP1117-2.85V
0≤Iout≤1A , Vin=4.85V
2.793
2.85
2.907
V
3.234
3.3
3.366
V
4.9
5
5.1
V
0.03
0.2
%/V
0.03
0.2
%/V
0.03
0.2
%/V
0.03
0.2
%/V
0.03
0.2
%/V
0.03
0.2
%/V
0.03
0.2
%/V
0.03
0.2
%/V
PR
O
SSP1117-3.3V
IN
SSP1117-2.5V
0≤Iout≤1A , Vin=5.3V
SSP1117-5.0V
0≤Iout≤1A , Vin=7.0V
SSP1117-1.2V
Iout=10mA, 2.7V≤Vin≤10V
SSP1117-1.5V
SI
Iout=10mA, 3.0V≤Vin≤12V
SSP1117-1.8V
Iout=10mA, 3.3V≤Vin≤12V
△Vout
Line
regulation
SSP1117-2.5V
Iout=10mA, 4.0V≤Vin≤12V
SSP1117-2.85V
Iout=10mA, 4.35V≤Vin≤12V
SSP1117-3.3V
Iout=10mA, 4.8V≤Vin≤12V
SSP1117-5.0V
Iout=10mA, 6.5V≤Vin≤12V
SSP1117-ADJ
Iout=10mA, 2.75V≤Vin≤12V
Ver1.4
4
SSP1117
Symbol
Typ
Max
Unit
2
8
mV
3
10
mV
3
12
mV
4
16
mV
5
mV
6
24
mV
IN
Parameter
Conditions
Min
9
36
mV
2
8
mV
1.15
1.3
V
1.3
1.5
V
SSP1117-ADJ
2
10
mA
SSP1117-1.2V,Vin=10V
2
5
mA
SSP1117-1.5V,Vin=11V
2
5
mA
SSP1117-1.2V
Vin =2.7V, 10mA≤Iout≤1A
SSP1117-1.5V
SSP1117-1.8V
Vin =3.3V, 10mA≤Iout≤1A
△Vout
Load
SSP1117-2.5V
regulation
Vin =4.0V, 10mA≤Iout≤1A
SSP1117-2.85V
Vin =4.35V, 10mA≤Iout≤1A
SSP1117-3.3V
Vin =4.8V, 10mA≤Iout≤1A
SSP1117-5.0V
Vin =6.5V, 10mA≤Iout≤1A
PR
O
SSP1117-ADJ
Vin =2.75V, 10mA≤Iout≤1A
Vdrop
Dropout
voltage
Imin
Minimum load
Iq
IAdj
Quiescent
SSP1117-1.8V,Vin=12V
2
5
mA
Current
SSP1117-2.5V,Vin=12V
2
5
mA
SSP1117-2.85V,Vin=12V
2
5
mA
SSP1117-3.3V,Vin=12V
2
5
mA
SSP1117-5.0V,Vin=12V
2
5
mA
SSP1117-ADJ
55
120
uA
0.2
10
uA
Adjust pin
current
Ichange
Iout=1A
SI
current
Iout =100mA
Iadj change
Vin=5V,10mA≤Iout≤1A
SSP1117-ADJ
Vin=5V,10mA≤Iout≤1A
ΔV/ΔT
±100
Temperature
ppm
coefficien
θJC
Thermal
SOT-223
resistance
TO-252
10
℃/W
Note1: All test are conducted under ambient temperature 25°C and within a short period of time 20ms
Note2: Load current smaller than minimum load current of SSP1117-ADJ will lead to unstable or oscillation output.
Ver1.4
5
SSP1117
Detailed Description
SSP1117 is a series of low dropout voltage, three terminal regulators. Its application circuit is very simple: the fixed version
only needs two capacitors and the adjustable version only needs two resistors and two capacitors to work. It is composed
of some modules including start-up circuit, bias circuit, bandgap, thermal shutdown, power transistors and its driver circuit
and so on.
The thermal shut down modules can assure chip and its application system working safety when the junction temperature
is larger than 140°C.
The bandgap module provides stable reference voltage, whose temperature coefficient is compensated by careful design
considerations. The temperature coefficient is under 100 ppm/°C. And the accuracy of output voltage is guaranteed by
trimming technique.
IN
Typical Application
SSP1117 has an adjustable version and six fixed versions (1.2V, 1.5V ,1.8V, 2.5V, 2.85V , 3.3V and 5V)
SI
PR
O
Fixed Output Voltage Version
1) Recommend using 10uF tan capacitor as bypass capacitor (C1) for all application circuit.
2) Recommend using 10uF tan capacitor to assure circuit stability.
Adjustable Output Voltage Version
Application Circuit of SSP1117-ADJ
The output voltage of adjustable version follows the equation: Vout=1.25×(1+R2/R1)+IAdj×R2. We can ignore
IAdj because IAdj (about 50uA) is much less than the current of R1 (about 2~10mA).
Ver1.4
6
SSP1117
1) To meet the minimum load current (>10mA) requirement, R1 is recommended to be 125ohm or lower. As
SSP1117-ADJ can keep itself stable at load current about 2mA, R1 is not allowed to be higher than 625ohm.
2) Using a bypass capacitor (CADJ) between the ADJ pin and ground can improve ripple rejection. This bypass
capacitor prevents ripple from being amplified as the output voltage is increased. The impedance of CADJ should be less
than R1 to prevent ripple from being amplified. As R1 is normally in the range of 100Ω~500Ω, the value of CADJ should
satisfy this equation: 1/(2π×fripple×CADJ)
