1N4727A...1N4764A
SILICON PLANAR POWER ZENER DIODES
for use in stabilizing and clipping circuits with high
power rating.
Max. 0.7
Min. 25.4
Max. 2.8
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
XXX
Max. 4.2
ST
Min. 25.4
Glass Case DO-41
Dimensions in mm
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Symbol
Power Dissipation
Ptot
Value
1
1)
Unit
W
Junction Temperature
Tj
200
O
Storage Temperature Range
TS
- 65 to + 200
O
1)
C
C
Valid provided that leads at a distance of 8 mm from case are kept at ambient temperature.
Characteristics at Ta = 25 OC
Parameter
Symbol
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 200 mA
1)
RthA
VF
Max.
Unit
1)
K/W
170
1.2
V
SEMTECH ELECTRONICS LTD.
(Subsidiary of Sino-Tech International Holdings Limited, a company
listed on the Hong Kong Stock Exchange, Stock Code: 724)
Dated : 12/06/2007
1N4727A...1N4764A
Maximum Zener
Impedance 1)
Zener Voltage Range 3), 5)
Type
VZnom
VZ
lZT
rZJT
rZJK
at IZK
Maximum Reverse Maximum Surge Maximum
Leakage Current
Current 4)
Regulator
Current 2)
IR
at VR
at Ta = 25 OC
V
mA
Ω
Ω
mA
µA
V
IZSM (mA)
IZM (mA)
V
1N4727A
3
2.85…3.15
83
10
400
1
150
1
1375
275
1N4728A
3.3
3.13…3.47
76
10
400
1
150
1
1375
275
1N4729A
3.6
3.42…3.78
69
10
400
1
100
1
1260
252
1N4730A
3.9
3.7…4.1
64
9
400
1
100
1
1190
234
1N4731A
4.3
4.08…4.52
58
9
400
1
50
1
1070
217
1N4732A
4.7
4.46…4.94
53
8
500
1
10
1
970
193
1N4733A
5.1
4.84…5.36
49
7
550
1
10
1
890
178
1N4734A
5.6
5.32…5.88
45
5
600
1
10
2
810
162
1N4735A
6.2
5.89…6.51
41
2
700
1
10
3
730
146
1N4736A
6.8
6.46…7.14
37
3.5
700
1
10
4
660
133
1N4737A
7.5
7.12…7.88
34
4
700
0.5
10
5
605
121
1N4738A
8.2
7.79…8.61
31
4.5
700
0.5
10
6
550
110
1N4739A
9.1
8.64…9.56
28
5
700
0.5
10
7
500
100
1N4740A
10
9.5…10.5
25
7
700
0.25
10
7.6
454
91
1N4741A
11
10.45…11.55
23
8
700
0.25
5
8.4
414
83
1N4742A
12
11.4…12.6
21
9
700
0.25
5
9.1
380
76
1N4743A
13
12.35…13.65
19
10
700
0.25
5
9.9
344
69
1N4744A
15
14.25…15.75
17
14
700
0.25
5
11.4
304
61
1N4745A
16
15.2…16.8
15.5
16
700
0.25
5
12.2
285
57
1N4746A
18
17.1…18.9
14
0.25
5
13.7
250
50
1N4747A
19…21
12.5
22
750
0.25
5
15.2
225
45
1N4748A
22
20.9…23.1
11.5
23
750
0.25
5
16.7
205
41
1N4749A
24
22.8…25.2
10.5
25
750
0.25
5
18.2
190
38
1N4750A
27
25.65…28.35
9.5
35
750
0.25
5
20.6
170
34
1N4751A
30
28.5…31.5
8.5
40
1000
0.25
5
22.8
150
30
1N4752A
33
31.35…34.65
7.5
45
1000
0.25
5
25.1
135
27
1N4753A
36
34.2…37.8
7
50
1000
0.25
5
27.4
125
25
1N4754A
39
37.05…40.95
6.5
60
1000
0.25
5
29.7
115
23
1N4755A
43
40.85…45.15
6
70
1500
0.25
5
32.7
110
22
1N4756A
47
44.65…49.35
5.5
80
1500
0.25
5
35.8
95
19
1N4757A
51
48.45…53.55
5
95
1500
0.25
5
38.8
90
18
1N4758A
56
53.2…58.8
4.5
110
2000
0.25
5
42.6
80
16
1N4759A
62
58.9…65.1
4
125
2000
0.25
5
47.1
70
14
1N4760A
68
64.6…71.4
3.7
150
2000
0.25
5
51.7
65
13
1N4761A
75
71.25…78.75
3.3
175
2000
0.25
5
56
60
12
1N4762A
82
77.9…86.1
3
200
3000
0.25
5
62.2
55
11
1N4763A
91
86.45…95.55
2.8
250
3000
0.25
5
69.2
50
10
1N4764A
100
95…105
2.5
350
3000
0.25
5
76
45
9
1)
The Zener Impedance is derived from the 60 Hz AC voltage which results when an AC current having an RMS value equal
to 10% of the Zener Current (IZT or IZK) is superimposed on IZT or IZK. Zener Impedance is measured at two points to insure
a sharp knee on the breakdown curve and to eliminate unstable units.
2)
3)
Measured under thermal equilibrium and DC test conditions.
4)
The rating listed in the electrical characteristics table is maximum peak, non-repetitive, reverse surge current of 1/2 square
wave or equivalent sine wave pulse of 1/120 second duration superimposed on the test current IZT.
5)
Tested with pulses tp = 20 ms.
Dated : 12/06/2007
1N4727A...1N4764A
Breakdowm characteristics
Tj =constant(pulsed)
mA
100
IN...
30
IN4741
IN4736
40
IN4740
IN4735
IN4734
50
IN4739
60
IN4737
Iz
IN4738
70
IN4733
80
IN4731
IN4732
IN4727
IN4728
90
IN4730 IN47
29
Tj =25 oC
3
5
4
7
6
8
9
10
11
12
IN4764
10
IN4763
IN4762
IN4761
IN4760
IN4759
IN4758
IN4757
IN4755
30
Tj =25 oC
IN4756
Iz
IN...
IN4753
IN4754
40
IN4745
IN4742
50
IN4750
IN4751
IN4752
mA
IN4746
IN4747
IN4748
IN4749
IN4743
IN4744
Vz
40
50
60
70
80
90
100
110
120
Vz
Dated : 12/06/2007
1.0
250
0.8
200
to Ambient (°C/W)
Pd. Total Power Dissipation (W)
1N4727A...1N4764A
0.6
0.4
100
50
R
JA
0.2
150
200
10
15
30
I, Lead Length (mm)
Fig. 2 Typical Thermal Resistance vs. Lead Length
Ω
TA, Ambient Temperature
Fig. 1 Power Dissipation vs Ambient Temperature
1000
Differential Zener Impedance ( )
1000
Cj , Diode Capacitance (pF)
f=1MHz
TA=25°C
100
VR=0V
VR=2V
VR=5V
VR=20V
VR=30V
10
1
40
50
60
Vz, Zener Voltage (V)
Fig. 3 Junction Capacitance vs Zener Voltage
Iz=1mA
2mA
100
5mA
10mA
20mA
10
1
1
10
100
Fig. 4 Typical Zener Impedance vs. Zener Voltage
Dated : 12/06/2007
很抱歉,暂时无法提供与“1N4738A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.14931
- 20+0.13582
- 100+0.12232
- 500+0.10883
- 1000+0.10254
- 2000+0.09804
- 国内价格
- 20+0.32810
- 100+0.25080
- 300+0.17370
- 500+0.14400
- 2500+0.09780
- 国内价格
- 20+0.19737
- 200+0.15752
- 600+0.13538
