WPM2015
WPM2015
Http://www.sh-willsemi.com
Single P-Channel, -20V, -2.4A, Power MOSFET
VDS (V)
-20
Rds(on) (ȍ)
0.081@ VGS=4.5V
0.103@ VGS=2.5V
Descriptions
SOT-23
D
3
The WPM2015 is P-Channel enhancement MOS
Field Effect Transistor. Uses advanced trench
technology and design to provide excellent RDS (ON)
with low gate charge. This device is suitable for use
in DC-DC conversion, power switch and charging
1
2
circuit. Standard Product WPM2015 is Pb-free and
G
S
Halogen-free.
Pin configuration (Top view)
Features
z
Trench Technology
z
Supper high density cell design
z
Excellent ON resistance for higher DC current
z
Extremely Low Threshold Voltage
z
Small package SOT-23
3
WT1*
2
1
WT1= Device Code
= Month (A~Z)
Marking
Applications
z
Driver for Relay, Solenoid, Motor, LED etc.
z
DC-DC converter circuit
z
Power Switch
z
Load Switch
z
Charging
Will Semiconductor Ltd.
Order information
1
Device
Package
Shipping
WPM2015-3/TR
SOT-23
3000/Reel&Tape
Mar,2018 – Rev.1.2
WPM2015
Absolute Maximum ratings
Parameter
Symbol
10 S
Steady State
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
f8
Continuous Drain Current a
Maximum Power Dissipation a
Continuous Drain Current b
Maximum Power Dissipation b
TA=25°C
ID
TA=70°C
TA=25°C
PD
TA=70°C
TA=25°C
ID
TA=70°C
TA=25°C
PD
TA=70°C
Unit
V
-2.4
-2.2
-1.9
-1.7
0.9
0.8
0.5
0.5
-2.2
-2.0
-1.7
-1.6
0.7
0.6
0.5
0.4
A
W
A
W
Pulsed Drain Current c
IDM
-10
A
Operating Junction Temperature
TJ
150
°C
Lead Temperature
TL
260
°C
Storage Temperature Range
Tstg
-55 to 150
°C
Thermal resistance ratings
Parameter
Junction-to-Ambient Thermal Resistance a
Junction-to-Ambient Thermal Resistance b
Junction-to-Case Thermal Resistance
Symbol
t 10 s
Steady State
t 10 s
Steady State
Steady State
RșJA
RșJA
RșJC
Typical
Maximum
105
135
120
155
130
160
145
190
60
75
a
Surface mounted on FR-4 Board using 1 square inch pad size, 1oz copper
b
Surface mounted on FR-4 board using minimum pad size, 1oz copper
c
Pulse width
很抱歉,暂时无法提供与“WPM2015-3/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.21359
- 50+0.19559
- 500+0.17759
- 1000+0.15959
- 2500+0.15119
- 5000+0.14399
