RMB2S - RMB6S
Taiwan Semiconductor
0.8A, 200V - 600V Miniature Glass Passivated Fast Recovery
Surface Mount Bridge Rectifier
FEATURES
KEY PARAMETERS
● Ideal for automated placement
● Reliable low cost construction utilizing molded plastic
technique
● High surge current capability
● Small size, simple installation
● UL Recognized File # E-326243
● Moisture sensitivity level: level 1, per J-STD-020
● Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF(AV)
0.8
A
VRRM
200 - 600
V
IFSM
30
A
TJ MAX
150
°C
Package
TO-269AA (MBS)
Configuration
Quad
APPLICATIONS
● Switching mode power supply (SMPS)
● Lighting application
MECHANICAL DATA
Case: TO-269AA (MBS)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.12g (approximately)
TO-269AA (MBS)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
RMB2S
RMB4S
RMB6S
RMB2S
RMB4S
RMB6S
UNIT
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
V
VDC
200
400
600
V
Maximum DC blocking voltage
Maximum average forward current 60Hz sine wave
resistance load on glass-epoxy P.C.B.
resistance load on aluminum substrate
Surge peak forward current, 8.3 ms single half sine-wave
superimposed on rated load per diode
Rating for fusing (t
很抱歉,暂时无法提供与“RMB6S RCG”相匹配的价格&库存,您可以联系我们找货
